RTEMS 5.2
arm-pl050-regs.h
1
9/*
10 * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Dornierstr. 4
14 * 82178 Puchheim
15 * Germany
16 * <info@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef LIBBSP_ARM_SHARED_ARM_PL050_REGS_H
24#define LIBBSP_ARM_SHARED_ARM_PL050_REGS_H
25
26#include <bsp/utility.h>
27
28typedef struct {
29 uint32_t kmicr;
30#define PL050_KMICR_KMITYPE BSP_BIT32(5)
31#define PL050_KMICR_KMIRXINTREN BSP_BIT32(4)
32#define PL050_KMICR_KMITXINTREN BSP_BIT32(3)
33#define PL050_KMICR_KMIEN BSP_BIT32(2)
34#define PL050_KMICR_FKMID BSP_BIT32(1)
35#define PL050_KMICR_FKMIC BSP_BIT32(0)
36 uint32_t kmistat;
37#define PL050_KMISTAT_TXEMPTY BSP_BIT32(6)
38#define PL050_KMISTAT_TXBUSY BSP_BIT32(5)
39#define PL050_KMISTAT_RXFULL BSP_BIT32(4)
40#define PL050_KMISTAT_RXBUSY BSP_BIT32(3)
41#define PL050_KMISTAT_RXPARITY BSP_BIT32(2)
42#define PL050_KMISTAT_KMIC BSP_BIT32(1)
43#define PL050_KMISTAT_KMID BSP_BIT32(0)
44 uint32_t kmidata;
45#define PL050_KMIDATA_KMIDATA(val) BSP_FLD32(val, 0, 7)
46#define PL050_KMIDATA_KMIDATA_GET(reg) BSP_FLD32GET(reg, 0, 7)
47#define PL050_KMIDATA_KMIDATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
48 uint32_t kmiclkdiv;
49#define PL050_KMICLKDIV_KMICLKDIV(val) BSP_FLD32(val, 0, 3)
50#define PL050_KMICLKDIV_KMICLKDIV_GET(reg) BSP_FLD32GET(reg, 0, 3)
51#define PL050_KMICLKDIV_KMICLKDIV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
52 uint32_t kmiir;
53#define PL050_KMIIR_KMITXINTR BSP_BIT32(1)
54#define PL050_KMIIR_KMIRXINTR BSP_BIT32(0)
55} pl050;
56
57#endif /* LIBBSP_ARM_SHARED_ARM_PL050_REGS_H */
Utility macros.
Definition: arm-pl050-regs.h:28
