RTEMS 5.2
arm-pl011.h
1
9/*
10 * Copyright (c) 2013-2014 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Dornierstr. 4
14 * 82178 Puchheim
15 * Germany
16 * <info@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef LIBBSP_ARM_SHARED_ARM_PL011_H
24#define LIBBSP_ARM_SHARED_ARM_PL011_H
25
26#include <rtems/termiostypes.h>
27
28#include <bsp/arm-pl011-regs.h>
29
30#ifdef __cplusplus
31extern "C" {
32#endif /* __cplusplus */
33
34typedef struct {
36 volatile pl011 *regs;
38 uint32_t initial_baud;
40
41bool arm_pl011_probe(rtems_termios_device_context *base);
42
43void arm_pl011_write_polled(rtems_termios_device_context *base, char c);
44
45extern const rtems_termios_device_handler arm_pl011_fns;
46
47#ifdef __cplusplus
48}
49#endif /* __cplusplus */
50
51#endif /* LIBBSP_ARM_SHARED_ARM_PL011_H */
ARM PL011 Register definitions.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: arm-pl011.h:34
Definition: arm-pl011-regs.h:28
Termios device context.
Definition: termiostypes.h:75
Termios device handler.
Definition: termiostypes.h:141
