RTEMS 5.2
arm-a9mpcore-regs.h
1
9/*
10 * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Dornierstr. 4
14 * 82178 Puchheim
15 * Germany
16 * <info@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef LIBBSP_ARM_SHARED_ARM_A9MPCORE_REGS_H
24#define LIBBSP_ARM_SHARED_ARM_A9MPCORE_REGS_H
25
26#include <bsp/utility.h>
27
28typedef struct {
29 uint32_t ctrl;
30#define A9MPCORE_SCU_CTRL_SCU_EN BSP_BIT32(0)
31#define A9MPCORE_SCU_CTRL_ADDR_FLT_EN BSP_BIT32(1)
32#define A9MPCORE_SCU_CTRL_RAM_PAR_EN BSP_BIT32(2)
33#define A9MPCORE_SCU_CTRL_SCU_SPEC_LINE_FILL_EN BSP_BIT32(3)
34#define A9MPCORE_SCU_CTRL_FORCE_PORT_0_EN BSP_BIT32(4)
35#define A9MPCORE_SCU_CTRL_SCU_STANDBY_EN BSP_BIT32(5)
36#define A9MPCORE_SCU_CTRL_IC_STANDBY_EN BSP_BIT32(6)
37 uint32_t cfg;
38#define A9MPCORE_SCU_CFG_CPU_COUNT(val) BSP_FLD32(val, 0, 1)
39#define A9MPCORE_SCU_CFG_CPU_COUNT_GET(reg) BSP_FLD32GET(reg, 0, 1)
40#define A9MPCORE_SCU_CFG_CPU_COUNT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 1)
41#define A9MPCORE_SCU_CFG_SMP_MODE(val) BSP_FLD32(val, 4, 7)
42#define A9MPCORE_SCU_CFG_SMP_MODE_GET(reg) BSP_FLD32GET(reg, 4, 7)
43#define A9MPCORE_SCU_CFG_SMP_MODE_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
44#define A9MPCORE_SCU_CFG_TAG_RAM_SIZE(val) BSP_FLD32(val, 8, 15)
45#define A9MPCORE_SCU_CFG_TAG_RAM_SIZE_GET(reg) BSP_FLD32GET(reg, 8, 15)
46#define A9MPCORE_SCU_CFG_TAG_RAM_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
47 uint32_t pwrst;
48 uint32_t invss;
49#define A9MPCORE_SCU_INVSS_CPU0(ways) BSP_FLD32(val, 0, 3)
50#define A9MPCORE_SCU_INVSS_CPU0_GET(reg) /* Write only register */
51#define A9MPCORE_SCU_INVSS_CPU0_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
52#define A9MPCORE_SCU_INVSS_CPU1(ways) BSP_FLD32(val, 4, 7)
53#define A9MPCORE_SCU_INVSS_CPU1_GET(reg) /* Write only register */
54#define A9MPCORE_SCU_INVSS_CPU1_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
55#define A9MPCORE_SCU_INVSS_CPU2(ways) BSP_FLD32(val, 8, 11)
56#define A9MPCORE_SCU_INVSS_CPU2_GET(reg) /* Write only register */
57#define A9MPCORE_SCU_INVSS_CPU2_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
58#define A9MPCORE_SCU_INVSS_CPU3(ways) BSP_FLD32(val, 12, 15)
59#define A9MPCORE_SCU_INVSS_CPU3_GET(reg) /* Write only register */
60#define A9MPCORE_SCU_INVSS_CPU3_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
61 uint32_t reserved_09[8];
62 uint32_t diagn_ctrl;
63#define A9MPCORE_SCU_DIAGN_CTRL_MIGRATORY_BIT_DISABLE BSP_BIT32(0)
64 uint32_t reserved_10[3];
65 uint32_t fltstart;
66 uint32_t fltend;
67 uint32_t reserved_48[2];
68 uint32_t sac;
69 uint32_t snsac;
71
72typedef struct {
74
75typedef struct {
76 uint32_t cntrlower;
77 uint32_t cntrupper;
78#define A9MPCORE_GT_CTRL_PRESCALER(val) BSP_FLD32(val, 8, 15)
79#define A9MPCORE_GT_CTRL_PRESCALER_GET(reg) BSP_FLD32GET(reg, 8, 15)
80#define A9MPCORE_GT_CTRL_PRESCALER_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
81#define A9MPCORE_GT_CTRL_AUTOINC_EN BSP_BIT32(3)
82#define A9MPCORE_GT_CTRL_IRQ_EN BSP_BIT32(2)
83#define A9MPCORE_GT_CTRL_COMP_EN BSP_BIT32(1)
84#define A9MPCORE_GT_CTRL_TMR_EN BSP_BIT32(0)
85 uint32_t ctrl;
86#define A9MPCORE_GT_IRQST_EFLG BSP_BIT32(0)
87 uint32_t irqst;
88 uint32_t cmpvallower;
89 uint32_t cmpvalupper;
90 uint32_t autoinc;
92
93typedef struct {
94 uint32_t load;
95 uint32_t cntr;
96 uint32_t ctrl;
97#define A9MPCORE_PT_CTRL_PRESCALER(val) BSP_FLD32(val, 8, 15)
98#define A9MPCORE_PT_CTRL_PRESCALER_GET(reg) BSP_FLD32GET(reg, 8, 15)
99#define A9MPCORE_PT_CTRL_PRESCALER_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
100#define A9MPCORE_PT_CTRL_IRQ_EN BSP_BIT32(2)
101#define A9MPCORE_PT_CTRL_AUTO_RLD BSP_BIT32(1)
102#define A9MPCORE_PT_CTRL_TMR_EN BSP_BIT32(0)
103 uint32_t irqst;
104#define A9MPCORE_PT_IRQST_EFLG BSP_BIT32(0)
106
107typedef struct {
108 uint32_t load;
109 uint32_t cntr;
110 uint32_t ctrl;
111 uint32_t irqst;
112 uint32_t rstst;
113 uint32_t dis;
115
116typedef struct {
118
119typedef struct {
120 a9mpcore_scu scu;
121 uint32_t reserved_58[42];
122 a9mpcore_gic gic;
123 uint32_t reserved_100[64];
124 a9mpcore_gt gt;
125 uint32_t reserved_21c[249];
126 a9mpcore_pt pt;
127 uint32_t reserved_610[4];
128 a9mpcore_pw pw;
129 uint32_t reserved_638[626];
130 a9mpcore_idist idist;
131} a9mpcore;
132
133#endif /* LIBBSP_ARM_SHARED_ARM_A9MPCORE_REGS_H */
Utility macros.
Definition: arm-a9mpcore-regs.h:72
Definition: arm-a9mpcore-regs.h:75
Definition: arm-a9mpcore-regs.h:116
Definition: arm-a9mpcore-regs.h:93
Definition: arm-a9mpcore-regs.h:107
Definition: arm-a9mpcore-regs.h:28
Definition: arm-a9mpcore-regs.h:119
