RTEMS 5.2
ambapp.h
1
6/*
7 * COPYRIGHT (c) 2009.
8 * Aeroflex Gaisler.
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef __AMBAPP_H__
16#define __AMBAPP_H__
17
28/* Include VENDOR and DEVICE definitions */
29#include "ambapp_ids.h"
30
31#ifdef __cplusplus
32extern "C" {
33#endif
34
35/* Max supported AHB buses */
36#define AHB_BUS_MAX 6
37
38struct ambapp_dev;
39struct ambapp_core;
40struct ambapp_apb_info;
41struct ambapp_ahb_info;
42
43struct ambapp_dev {
44 struct ambapp_dev *next; /* Next */
45 struct ambapp_dev *prev; /* Previous Device. If (this ==
46 * rev->child) prev is bus bridge */
47 struct ambapp_dev *children; /* Points to first device on sub-bus */
48 void *owner; /* Owner of this AMBA device */
49 unsigned char dev_type; /* AHB MST, AHB SLV or APB SLV*/
50 unsigned char vendor; /* Vendor ID */
51 unsigned short device; /* Device ID */
52 int devinfo[0]; /* Device info (APB/AHB dep. on type) */
53};
54
55#define AMBAPP_FLAG_FFACT_DIR 0x100 /* Frequency factor direction, 0=down, 1=up */
56#define AMBAPP_FLAG_FFACT 0x0f0 /* Frequency factor against top bus */
57#define AMBAPP_FLAG_MBUS 0x00c
58#define AMBAPP_FLAG_SBUS 0x003
59
60/* Get APB or AHB information from a AMBA device */
61#define DEV_TO_APB(adev) ((struct ambapp_apb_info *)((adev)->devinfo))
62#define DEV_TO_AHB(adev) ((struct ambapp_ahb_info *)((adev)->devinfo))
63#define DEV_TO_COMMON(adev) ((struct ambapp_common_info *)((adev)->devinfo))
64/* Convert address of ambapp_apb_info/ambapp_ahb_info into ambapp_dev */
65#define APB_TO_DEV(apb_info) ((struct ambapp_dev *)(unsigned int(apb_info) - \
66 offsetof(struct ambapp_dev, devinfo)))
67#define AHB_TO_DEV(ahb_info) ((struct ambapp_dev *)(unsigned int(ahb_info) - \
68 offsetof(struct ambapp_dev, devinfo)))
69
71 unsigned char irq;
72 unsigned char ver;
73 unsigned char ahbidx; /* AHB Bus Index */
74};
75
77 /* COMMON */
78 unsigned char irq;
79 unsigned char ver;
80 unsigned char ahbidx; /* AHB Bus Index */
81
82 /* APB SPECIFIC */
83 unsigned int start;
84 unsigned int mask;
85};
86
88 /* COMMON */
89 unsigned char irq;
90 unsigned char ver;
91 unsigned char ahbidx; /* AHB Bus Index */
92
93 /* AHB SPECIFIC */
94 unsigned int start[4];
95 unsigned int mask[4];
96 char type[4]; /* type[N] Determine type of start[N]-mask[N],
97 * 2=AHB Memory Space, 3=AHB I/O Space */
98 unsigned int custom[3];
99};
100
101/* Describes a complete AMBA Core. Each device may consist of 3 interfaces */
103 char irq; /* irq=-1 indicate no IRQ */
104 unsigned char vendor;
105 unsigned short device;
106 int index; /* Core index */
107 struct ambapp_ahb_info *ahb_mst;
108 struct ambapp_ahb_info *ahb_slv;
109 struct ambapp_apb_info *apb_slv;
110};
111
113 unsigned int ioarea; /* AHB Bus IOAREA */
114 unsigned int freq_hz; /* Frequency of AHB Bus */
115 struct ambapp_dev *bridge;/* Bridge Device on Parent AHB Bus */
116 struct ambapp_dev *dev; /* First Device on AHB Bus */
117};
118
120 unsigned int size;
121 unsigned int local_adr;
122 unsigned int remote_adr;
123};
124
125/* Complete AMBA PnP information */
127 struct ambapp_dev *root; /* AHB/APB Device Tree*/
128 struct ambapp_mmap *mmaps; /* Memory MAP Array */
129 struct ambapp_ahb_bus ahbs[AHB_BUS_MAX]; /* AHB Buses */
130};
131
132/*
133 * Return values
134 * 0 - continue
135 * 1 - stop scanning
136 */
137typedef int (*ambapp_func_t)(struct ambapp_dev *dev, int index, void *arg);
138
139#define DEV_IS_FREE(dev) (dev->owner == NULL)
140#define DEV_IS_ALLOCATED(dev) (dev->owner != NULL)
141
142/* Options to ambapp_for_each */
143#define OPTIONS_AHB_MSTS 0x00000001
144#define OPTIONS_AHB_SLVS 0x00000002
145#define OPTIONS_APB_SLVS 0x00000004
146#define OPTIONS_ALL_DEVS (OPTIONS_AHB_MSTS|OPTIONS_AHB_SLVS|OPTIONS_APB_SLVS)
147
148#define OPTIONS_FREE 0x00000010
149#define OPTIONS_ALLOCATED 0x00000020
150#define OPTIONS_ALL (OPTIONS_FREE|OPTIONS_ALLOCATED)
151
152/* Depth first search, Defualt is breath first search. */
153#define OPTIONS_DEPTH_FIRST 0x00000100
154
155#define DEV_AHB_NONE 0
156#define DEV_AHB_MST 1
157#define DEV_AHB_SLV 2
158#define DEV_APB_SLV 3
159
160/* Structures used to access Plug&Play information directly */
162 const unsigned int id; /* VENDOR, DEVICE, VER, IRQ, */
163 const unsigned int custom[3];
164 const unsigned int mbar[4]; /* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
165};
166
168 const unsigned int id; /* VENDOR, DEVICE, VER, IRQ, */
169 const unsigned int iobar; /* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
170};
171
172#define ambapp_pnp_vendor(id) (((id) >> 24) & 0xff)
173#define ambapp_pnp_device(id) (((id) >> 12) & 0xfff)
174#define ambapp_pnp_ver(id) (((id)>>5) & 0x1f)
175#define ambapp_pnp_irq(id) ((id) & 0x1f)
176
177#define ambapp_pnp_start(mbar) (((mbar) & 0xfff00000) & (((mbar) & 0xfff0) << 16))
178#define ambapp_pnp_mbar_mask(mbar) (((mbar)>>4) & 0xfff)
179#define ambapp_pnp_mbar_type(mbar) ((mbar) & 0xf)
180
181#define ambapp_pnp_apb_start(iobar, base) ((base) | ((((iobar) & 0xfff00000)>>12) & (((iobar) & 0xfff0)<<4)) )
182#define ambapp_pnp_apb_mask(iobar) ((~(ambapp_pnp_mbar_mask(iobar)<<8) & 0x000fffff) + 1)
183
184#define AMBA_TYPE_AHBIO_ADDR(addr,base_ioarea) ((unsigned int)(base_ioarea) | ((addr) >> 12))
185
186#define AMBA_TYPE_APBIO 0x1
187#define AMBA_TYPE_MEM 0x2
188#define AMBA_TYPE_AHBIO 0x3
189
190/* Copy Data from AMBA PnP I/O Area */
191typedef void *(*ambapp_memcpy_t)(
192 void *dest, /* Destination RAM copy */
193 const void *src, /* Source AMBA PnP Address to copy from */
194 int n, /* Number of bytes to be copied */
195 struct ambapp_bus *abus /* Optional AMBA Bus pointer */
196 );
197
198/* Scan a AMBA Plug & Play bus and create all device structures describing the
199 * the devices. The devices will form a tree, where every node describes one
200 * interface. The resulting tree is placed in the location pointed to by root.
201 *
202 * Since it the tree is located in RAM it is easier to work with AMBA buses
203 * that is located over PCI and SpaceWire etc.
204 *
205 * \param ioarea The IO-AREA where Plug & Play information can be found.
206 * \param parent Used internally when recursing down a bridge. Set to NULL.
207 * \param mmaps Is used to perform address translation if needed.
208 * \param root Resulting device node tree root is stored here.
209 *
210 */
211extern int ambapp_scan(
212 struct ambapp_bus *abus,
213 unsigned int ioarea,
214 ambapp_memcpy_t memfunc,
215 struct ambapp_mmap *mmaps
216 );
217
218/* Initialize the frequency [Hz] of all AHB Buses from knowing the frequency
219 * of one particular APB/AHB Device.
220 */
221extern void ambapp_freq_init(
222 struct ambapp_bus *abus,
223 struct ambapp_dev *dev,
224 unsigned int freq);
225
226/* Returns the frequency [Hz] of a AHB/APB device */
227extern unsigned int ambapp_freq_get(
228 struct ambapp_bus *abus,
229 struct ambapp_dev *dev);
230
231/* Iterates through all AMBA devices previously found, it calls func
232 * once for every device that match the search arguments.
233 *
234 * SEARCH OPTIONS
235 * All search options must be fulfilled, type of devices searched (options)
236 * and AMBA Plug&Play ID [VENDOR,DEVICE], before func() is called. The options
237 * can be use to search only for AMBA APB or AHB Slaves or AHB Masters for
238 * example. Note that when VENDOR=-1 or DEVICE=-1 it will match any vendor or
239 * device ID, this means setting both VENDOR and DEVICE to -1 will result in
240 * calling all devices matches the options argument.
241 *
242 * \param abus AMBAPP Bus to search
243 * \param options Search options, see OPTIONS_* above
244 * \param vendor AMBAPP VENDOR ID to search for
245 * \param device AMBAPP DEVICE ID to search for
246 * \param func Function called for every device matching search options
247 * \param arg Optional argument passed on to func
248 *
249 * func return value affects the search, returning a non-zero value will
250 * stop the search and ambapp_for_each will return immediately returning the
251 * same non-zero value.
252 *
253 * Return Values
254 * 0 - all devices was scanned
255 * non-zero - stopped by user function returning the non-zero value
256 */
257extern int ambapp_for_each(
258 struct ambapp_bus *abus,
259 unsigned int options,
260 int vendor,
261 int device,
262 ambapp_func_t func,
263 void *arg);
264
265/* Helper function for ambapp_for_each(), find a device by index. If pcount
266 * is NULL the first device is returned, else pcount is interpreted as index
267 * by decrementing the value until zero is reaced: *count=0 first device,
268 * *count=1 second device etc.
269 *
270 * The matching device is returned, which will stop the ambapp_for_each search.
271 * If zero is returned from ambapp_for_each no device matching the index was
272 * found
273 */
274extern int ambapp_find_by_idx(struct ambapp_dev *dev, int index, void *pcount);
275
276/* Get number of devices matching the options/vendor/device arguments, the
277 * arguments are passed onto ambapp_for_each().
278 */
279extern int ambapp_dev_count(struct ambapp_bus *abus, unsigned int options,
280 int vendor, int device);
281
282/* Print short information about devices on the AMBA bus onto the console */
283extern void ambapp_print(struct ambapp_bus *abus, int show_depth);
284
285/* Mark a device taken (allocate), Owner field is set with owner Data. Returns
286 * -1 if device has already been allocated.
287 */
288extern int ambapp_alloc_dev(struct ambapp_dev *dev, void *owner);
289
290/* Owner field is cleared, which indicates that device is not allocated */
291extern void ambapp_free_dev(struct ambapp_dev *dev);
292
293/* Find AHB/APB Bridge or AHB/AHB Bridge Parent */
294extern struct ambapp_dev *ambapp_find_parent(struct ambapp_dev *dev);
295
296/* Returns bus depth (number of sub AHB buses) of device from root bus */
297extern int ambapp_depth(struct ambapp_dev *dev);
298
299/* Get Device Name from AMBA PnP name database */
300extern char *ambapp_device_id2str(int vendor, int id);
301
302/* Get Vendor Name from AMBA PnP name database */
303extern char *ambapp_vendor_id2str(int vendor);
304
305/* Set together VENDOR_DEVICE Name from AMBA PnP name database. Return length
306 * of C-string stored in buf not including string termination '\0'.
307 */
308extern int ambapp_vendev_id2str(int vendor, int id, char *buf);
309
310/* Help functions for backwards compability */
311
312extern int ambapp_find_apbslv(
313 struct ambapp_bus *abus,
314 int vendor,
315 int device,
316 struct ambapp_apb_info *dev);
317
318extern int ambapp_find_apbslv_next(
319 struct ambapp_bus *abus,
320 int vendor,
321 int device,
322 struct ambapp_apb_info *dev,
323 int index);
324
325extern int ambapp_find_apbslvs_next(
326 struct ambapp_bus *abus,
327 int vendor,
328 int device,
329 struct ambapp_apb_info *dev,
330 int index,
331 int maxno);
332
333extern int ambapp_find_apbslvs(
334 struct ambapp_bus *abus,
335 int vendor,
336 int device,
337 struct ambapp_apb_info *dev,
338 int maxno);
339
340extern int ambapp_find_ahbslv(
341 struct ambapp_bus *abus,
342 int vendor,
343 int device,
344 struct ambapp_ahb_info *dev);
345
346extern int ambapp_find_ahbslv_next(
347 struct ambapp_bus *abus,
348 int vendor,
349 int device,
350 struct ambapp_ahb_info *dev,
351 int index);
352
353extern int ambapp_find_ahbslvs_next(
354 struct ambapp_bus *abus,
355 int vendor,
356 int device,
357 struct ambapp_ahb_info *dev,
358 int index,
359 int maxno);
360
361extern int ambapp_find_ahbslvs(
362 struct ambapp_bus *abus,
363 int vendor,
364 int device,
365 struct ambapp_ahb_info *dev,
366 int maxno);
367
368
369extern int ambapp_get_number_ahbslv_devices(
370 struct ambapp_bus *abus,
371 int vendor,
372 int device);
373
374extern int ambapp_get_number_apbslv_devices(
375 struct ambapp_bus *abus,
376 int vendor,
377 int device);
378
379#ifdef __cplusplus
380}
381#endif
382
385#endif
AMBA Plug & Play Bus Vendor and Device IDs.
Definition: ambapp.h:112
Definition: ambapp.h:87
Definition: ambapp.h:76
Definition: ambapp.h:126
Definition: ambapp.h:70
Definition: ambapp.h:102
Definition: ambapp.h:43
Definition: ambapp.h:119
Definition: ambapp.h:161
Definition: ambapp.h:167
Definition: rtemscompat1.h:15
