RTEMS 5.2
alt_dma_common.h
1
7/******************************************************************************
8 *
9 * Copyright 2013 Altera Corporation. All Rights Reserved.
10 *
11 * Redistribution and use in source and binary forms, with or without
12 * modification, are permitted provided that the following conditions are met:
13 *
14 * 1. Redistributions of source code must retain the above copyright notice,
15 * this list of conditions and the following disclaimer.
16 *
17 * 2. Redistributions in binary form must reproduce the above copyright notice,
18 * this list of conditions and the following disclaimer in the documentation
19 * and/or other materials provided with the distribution.
20 *
21 * 3. The name of the author may not be used to endorse or promote products
22 * derived from this software without specific prior written permission.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR
25 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
26 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO
27 * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
28 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
29 * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
32 * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
33 * OF SUCH DAMAGE.
34 *
35 ******************************************************************************/
36
37#ifndef __ALT_DMA_COMMON_H__
38#define __ALT_DMA_COMMON_H__
39
40#ifdef __cplusplus
41extern "C"
42{
43#endif /* __cplusplus */
44
58{
69
83typedef enum ALT_DMA_PERIPH_e
84{
131
136{
142
146typedef enum ALT_DMA_EVENT_e
147{
159
164#ifdef __cplusplus
165}
166#endif /* __cplusplus */
167
168#endif /* __ALT_DMA_COMMON_H__ */
ALT_DMA_EVENT_e
Definition: alt_dma_common.h:147
ALT_DMA_SECURITY_e
Definition: alt_dma_common.h:136
ALT_DMA_CHANNEL_e
Definition: alt_dma_common.h:58
enum ALT_DMA_PERIPH_e ALT_DMA_PERIPH_t
enum ALT_DMA_CHANNEL_e ALT_DMA_CHANNEL_t
enum ALT_DMA_EVENT_e ALT_DMA_EVENT_t
ALT_DMA_PERIPH_e
Definition: alt_dma_common.h:84
enum ALT_DMA_SECURITY_e ALT_DMA_SECURITY_t
@ ALT_DMA_EVENT_ABORT
Definition: alt_dma_common.h:156
@ ALT_DMA_EVENT_3
Definition: alt_dma_common.h:151
@ ALT_DMA_EVENT_2
Definition: alt_dma_common.h:150
@ ALT_DMA_EVENT_4
Definition: alt_dma_common.h:152
@ ALT_DMA_EVENT_1
Definition: alt_dma_common.h:149
@ ALT_DMA_EVENT_0
Definition: alt_dma_common.h:148
@ ALT_DMA_EVENT_6
Definition: alt_dma_common.h:154
@ ALT_DMA_EVENT_7
Definition: alt_dma_common.h:155
@ ALT_DMA_EVENT_5
Definition: alt_dma_common.h:153
@ ALT_DMA_SECURITY_SECURE
Definition: alt_dma_common.h:138
@ ALT_DMA_SECURITY_NONSECURE
Definition: alt_dma_common.h:139
@ ALT_DMA_SECURITY_DEFAULT
Definition: alt_dma_common.h:137
@ ALT_DMA_CHANNEL_2
Definition: alt_dma_common.h:61
@ ALT_DMA_CHANNEL_5
Definition: alt_dma_common.h:64
@ ALT_DMA_CHANNEL_3
Definition: alt_dma_common.h:62
@ ALT_DMA_CHANNEL_0
Definition: alt_dma_common.h:59
@ ALT_DMA_CHANNEL_4
Definition: alt_dma_common.h:63
@ ALT_DMA_CHANNEL_1
Definition: alt_dma_common.h:60
@ ALT_DMA_CHANNEL_6
Definition: alt_dma_common.h:65
@ ALT_DMA_CHANNEL_7
Definition: alt_dma_common.h:66
@ ALT_DMA_PERIPH_FPGA_6
Definition: alt_dma_common.h:97
@ ALT_DMA_PERIPH_FPGA_5_OR_CAN0_IF2
Definition: alt_dma_common.h:91
@ ALT_DMA_PERIPH_CAN1_IF2
Definition: alt_dma_common.h:103
@ ALT_DMA_PERIPH_I2C3_TX
Definition: alt_dma_common.h:111
@ ALT_DMA_PERIPH_RESERVED
Definition: alt_dma_common.h:124
@ ALT_DMA_PERIPH_FPGA_1
Definition: alt_dma_common.h:86
@ ALT_DMA_PERIPH_I2C1_RX
Definition: alt_dma_common.h:108
@ ALT_DMA_PERIPH_I2C2_RX
Definition: alt_dma_common.h:110
@ ALT_DMA_PERIPH_UART1_TX
Definition: alt_dma_common.h:127
@ ALT_DMA_PERIPH_QSPI_FLASH_TX
Definition: alt_dma_common.h:121
@ ALT_DMA_PERIPH_UART1_RX
Definition: alt_dma_common.h:128
@ ALT_DMA_PERIPH_I2C3_RX
Definition: alt_dma_common.h:112
@ ALT_DMA_PERIPH_CAN0_IF1
Definition: alt_dma_common.h:100
@ ALT_DMA_PERIPH_SPI1_MASTER_RX
Definition: alt_dma_common.h:118
@ ALT_DMA_PERIPH_UART0_TX
Definition: alt_dma_common.h:125
@ ALT_DMA_PERIPH_FPGA_6_OR_CAN1_IF1
Definition: alt_dma_common.h:92
@ ALT_DMA_PERIPH_FPGA_3
Definition: alt_dma_common.h:88
@ ALT_DMA_PERIPH_SPI0_SLAVE_RX
Definition: alt_dma_common.h:116
@ ALT_DMA_PERIPH_SPI1_SLAVE_TX
Definition: alt_dma_common.h:119
@ ALT_DMA_PERIPH_I2C0_RX
Definition: alt_dma_common.h:106
@ ALT_DMA_PERIPH_SPI1_SLAVE_RX
Definition: alt_dma_common.h:120
@ ALT_DMA_PERIPH_I2C2_TX
Definition: alt_dma_common.h:109
@ ALT_DMA_PERIPH_SPI0_MASTER_RX
Definition: alt_dma_common.h:114
Definition: alt_dma_common.h:96
@ ALT_DMA_PERIPH_I2C0_TX
Definition: alt_dma_common.h:105
@ ALT_DMA_PERIPH_UART0_RX
Definition: alt_dma_common.h:126
@ ALT_DMA_PERIPH_SPI0_MASTER_TX
Definition: alt_dma_common.h:113
@ ALT_DMA_PERIPH_CAN1_IF1
Definition: alt_dma_common.h:102
@ ALT_DMA_PERIPH_I2C1_TX
Definition: alt_dma_common.h:107
@ ALT_DMA_PERIPH_FPGA_7
Definition: alt_dma_common.h:98
@ ALT_DMA_PERIPH_STM
Definition: alt_dma_common.h:123
@ ALT_DMA_PERIPH_SPI0_SLAVE_TX
Definition: alt_dma_common.h:115
@ ALT_DMA_PERIPH_FPGA_4
Definition: alt_dma_common.h:95
@ ALT_DMA_PERIPH_FPGA_0
Definition: alt_dma_common.h:85
@ ALT_DMA_PERIPH_FPGA_2
Definition: alt_dma_common.h:87
@ ALT_DMA_PERIPH_SPI1_MASTER_TX
Definition: alt_dma_common.h:117
@ ALT_DMA_PERIPH_FPGA_7_OR_CAN1_IF2
Definition: alt_dma_common.h:93
@ ALT_DMA_PERIPH_FPGA_4_OR_CAN0_IF1
Definition: alt_dma_common.h:90
@ ALT_DMA_PERIPH_CAN0_IF2
Definition: alt_dma_common.h:101
@ ALT_DMA_PERIPH_QSPI_FLASH_RX
Definition: alt_dma_common.h:122
