RTEMS 5.2
_kernel_time.h
1/*-
2 * Copyright (c) 2016 embedded brains GmbH
3 * All rights reserved.
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 * 1. Redistributions of source code must retain the above copyright
9 * notice, this list of conditions and the following disclaimer.
10 * 2. Redistributions in binary form must reproduce the above copyright
11 * notice, this list of conditions and the following disclaimer in the
12 * documentation and/or other materials provided with the distribution.
13 *
14 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24 * SUCH DAMAGE.
25 */
26
27#if !defined(_SYS_TIME_H_) || !defined(_KERNEL)
28#error "must be included via <sys/time.h> in kernel space"
29#endif
30
31#include <machine/_timecounter.h>
32
33/* Operations on timespecs */
34#ifndef timespecclear
35#define timespecclear(tvp) ((tvp)->tv_sec = (tvp)->tv_nsec = 0)
36#endif
37#ifndef timespecisset
38#define timespecisset(tvp) ((tvp)->tv_sec || (tvp)->tv_nsec)
39#endif
40#ifndef timespeccmp
41#define timespeccmp(tvp, uvp, cmp) \
42 (((tvp)->tv_sec == (uvp)->tv_sec) ? \
43 ((tvp)->tv_nsec cmp (uvp)->tv_nsec) : \
44 ((tvp)->tv_sec cmp (uvp)->tv_sec))
45#endif
46
47#ifndef timespecadd
48#define timespecadd(tsp, usp, vsp) \
49 do { \
50 (vsp)->tv_sec = (tsp)->tv_sec + (usp)->tv_sec; \
51 (vsp)->tv_nsec = (tsp)->tv_nsec + (usp)->tv_nsec; \
52 if ((vsp)->tv_nsec >= 1000000000L) { \
53 (vsp)->tv_sec++; \
54 (vsp)->tv_nsec -= 1000000000L; \
55 } \
56 } while (0)
57#endif
58#ifndef timespecsub
59#define timespecsub(tsp, usp, vsp) \
60 do { \
61 (vsp)->tv_sec = (tsp)->tv_sec - (usp)->tv_sec; \
62 (vsp)->tv_nsec = (tsp)->tv_nsec - (usp)->tv_nsec; \
63 if ((vsp)->tv_nsec < 0) { \
64 (vsp)->tv_sec--; \
65 (vsp)->tv_nsec += 1000000000L; \
66 } \
67 } while (0)
68#endif
69
70/*
71 * Simple macros to convert ticks to milliseconds
72 * or microseconds and vice-versa. The answer
73 * will always be at least 1. Note the return
74 * value is a uint32_t however we step up the
75 * operations to 64 bit to avoid any overflow/underflow
76 * problems.
77 */
78#define TICKS_2_MSEC(t) max(1, (uint32_t)(hz == 1000) ? \
79 (t) : (((uint64_t)(t) * (uint64_t)1000)/(uint64_t)hz))
80#define TICKS_2_USEC(t) max(1, (uint32_t)(hz == 1000) ? \
81 ((t) * 1000) : (((uint64_t)(t) * (uint64_t)1000000)/(uint64_t)hz))
82#define MSEC_2_TICKS(m) max(1, (uint32_t)((hz == 1000) ? \
83 (m) : ((uint64_t)(m) * (uint64_t)hz)/(uint64_t)1000))
84#define USEC_2_TICKS(u) max(1, (uint32_t)((hz == 1000) ? \
85 ((u) / 1000) : ((uint64_t)(u) * (uint64_t)hz)/(uint64_t)1000000))
86
87/* Operations on timevals. */
88
89#define timevalclear(tvp) ((tvp)->tv_sec = (tvp)->tv_usec = 0)
90#define timevalisset(tvp) ((tvp)->tv_sec || (tvp)->tv_usec)
91#define timevalcmp(tvp, uvp, cmp) \
92 (((tvp)->tv_sec == (uvp)->tv_sec) ? \
93 ((tvp)->tv_usec cmp (uvp)->tv_usec) : \
94 ((tvp)->tv_sec cmp (uvp)->tv_sec))
95
96/* timevaladd and timevalsub are not inlined */
97
98/*
99 * Kernel to clock driver interface.
100 */
101void inittodr(time_t base);
102void resettodr(void);
103
104#define time_second _Timecounter_Time_second
105#define time_uptime _Timecounter_Time_uptime
106extern struct timeval boottime;
107extern struct bintime tc_tick_bt;
108extern sbintime_t tc_tick_sbt;
109extern struct bintime tick_bt;
110extern sbintime_t tick_sbt;
111extern int tc_precexp;
112extern int tc_timepercentage;
113extern struct bintime bt_timethreshold;
114extern struct bintime bt_tickthreshold;
115extern sbintime_t sbt_timethreshold;
116extern sbintime_t sbt_tickthreshold;
117
118/*
119 * Functions for looking at our clock: [get]{bin,nano,micro}[up]time()
120 *
121 * Functions without the "get" prefix returns the best timestamp
122 * we can produce in the given format.
123 *
124 * "bin" == struct bintime == seconds + 64 bit fraction of seconds.
125 * "nano" == struct timespec == seconds + nanoseconds.
126 * "micro" == struct timeval == seconds + microseconds.
127 *
128 * Functions containing "up" returns time relative to boot and
129 * should be used for calculating time intervals.
130 *
131 * Functions without "up" returns UTC time.
132 *
133 * Functions with the "get" prefix returns a less precise result
134 * much faster than the functions without "get" prefix and should
135 * be used where a precision of 1/hz seconds is acceptable or where
136 * performance is priority. (NB: "precision", _not_ "resolution" !)
137 */
138
139#define binuptime(_bt) _Timecounter_Binuptime(_bt)
140#define nanouptime(_tsp) _Timecounter_Nanouptime(_tsp)
141#define microuptime(_tvp) _Timecounter_Microuptime(_tvp)
142
143static __inline sbintime_t
144sbinuptime(void)
145{
146 struct bintime _bt;
147
148 binuptime(&_bt);
149 return (bttosbt(_bt));
150}
151
152#define bintime(_bt) _Timecounter_Bintime(_bt)
153#define nanotime(_tsp) _Timecounter_Nanotime(_tsp)
154#define microtime(_tvp) _Timecounter_Microtime(_tvp)
155
156#define getbinuptime(_bt) _Timecounter_Getbinuptime(_bt)
157#define getnanouptime(_tsp) _Timecounter_Getnanouptime(_tsp)
158#define getmicrouptime(_tvp) _Timecounter_Getmicrouptime(_tvp)
159
160static __inline sbintime_t
161getsbinuptime(void)
162{
163 struct bintime _bt;
164
165 getbinuptime(&_bt);
166 return (bttosbt(_bt));
167}
168
169#define getbintime(_bt) _Timecounter_Getbintime(_bt)
170#define getnanotime(_tsp) _Timecounter_Getnanotime(_tsp)
171#define getmicrotime(_tvp) _Timecounter_Getmicrotime(_tvp)
172
173#define getboottime(_tvp) _Timecounter_Getboottime(_tvp)
174#define getboottimebin(_bt) _Timecounter_Getboottimebin(_bt)
175
176/* Other functions */
177int itimerdecr(struct itimerval *itp, int usec);
178int itimerfix(struct timeval *tv);
179int ppsratecheck(struct timeval *, int *, int);
180int ratecheck(struct timeval *, const struct timeval *);
181void timevaladd(struct timeval *t1, const struct timeval *t2);
182void timevalsub(struct timeval *t1, const struct timeval *t2);
183int tvtohz(struct timeval *tv);
184
185#define TC_DEFAULTPERC 5
186
187#define BT2FREQ(bt) \
188 (((uint64_t)0x8000000000000000 + ((bt)->frac >> 2)) / \
189 ((bt)->frac >> 1))
190
191#define SBT2FREQ(sbt) ((SBT_1S + ((sbt) >> 1)) / (sbt))
192
193#define FREQ2BT(freq, bt) \
194{ \
195 (bt)->sec = 0; \
196 (bt)->frac = ((uint64_t)0x8000000000000000 / (freq)) << 1; \
197}
198
199#define TIMESEL(sbt, sbt2) \
200 (((sbt2) >= sbt_timethreshold) ? \
201 ((*(sbt) = getsbinuptime()), 1) : ((*(sbt) = sbinuptime()), 0))
