RTEMS 5.2
GT64260eth.h
1/* GT64260eth.h
2 *
3 * Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
4 * All rights reserved.
5 *
6 * RTEMS/Mvme5500 port 2004 by S. Kate Feng, <feng1@bnl.gov>,
7 * All rights reserved.
8 *
9 * Redistribution and use in source and binary forms, with or without
10 * modification, are permitted provided that the following conditions
11 * are met:
12 * 1. Redistributions of source code must retain the above copyright
13 * notice, this list of conditions and the following disclaimer.
14 * 2. Redistributions in binary form must reproduce the above copyright
15 * notice, this list of conditions and the following disclaimer in the
16 * documentation and/or other materials provided with the distribution.
17 * 3. All advertising materials mentioning features or use of this software
18 * must display the following acknowledgement:
19 * This product includes software developed for the NetBSD Project by
20 * Allegro Networks, Inc., and Wasabi Systems, Inc.
21 * 4. The name of Allegro Networks, Inc. may not be used to endorse
22 * or promote products derived from this software without specific prior
23 * written permission.
24 * 5. The name of Wasabi Systems, Inc. may not be used to endorse
25 * or promote products derived from this software without specific prior
26 * written permission.
27 *
28 * THIS SOFTWARE IS PROVIDED BY ALLEGRO NETWORKS, INC. AND
29 * WASABI SYSTEMS, INC. ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
30 * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
31 * AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
32 * IN NO EVENT SHALL EITHER ALLEGRO NETWORKS, INC. OR WASABI SYSTEMS, INC.
33 * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
34 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
35 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
36 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
37 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
38 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
39 * POSSIBILITY OF SUCH DAMAGE.
40 */
41
42/* Keep the ring sizes a power of two for efficiency.
43 Making the Tx ring too long decreases the effectiveness of channel
44 bonding and packet priority.
45 There are no ill effects from too-large receive rings. */
46#define TX_RING_SIZE 32
47#define GT_NEXTTX(x) ((x + 1) % TX_RING_SIZE )
48#define TX_QUARTER_FULL TX_RING_SIZE/2
49#define TX_HALF_FULL TX_RING_SIZE/2
50#define RX_RING_SIZE 16
51#define HASH_TABLE_SIZE 16
52#define HASH_DRAM_SIZE HASH_TABLE_SIZE*1024 /* size of DRAM for hash table */
53#define INTR_ERR_SIZE 16
54
55enum GTeth_txprio {
56 GE_TXPRIO_HI=1,
57 GE_TXPRIO_LO=0,
58 GE_TXPRIO_NONE=2
59};
60enum GTeth_rxprio {
61 GE_RXPRIO_HI=3,
62 GE_RXPRIO_MEDHI=2,
63 GE_RXPRIO_MEDLO=1,
64 GE_RXPRIO_LO=0
65};
66
68 struct GTeth_desc txq_desc[TX_RING_SIZE]; /* transmit descriptor memory */
69 struct GTeth_desc rxq_desc[RX_RING_SIZE]; /* receive descriptor memory */
70 struct mbuf* txq_mbuf[TX_RING_SIZE]; /* transmit buffer memory */
71 struct mbuf* rxq_mbuf[RX_RING_SIZE]; /* receive buffer memory */
72 struct GTeth_softc *next_module;
73 volatile unsigned int intr_errsts[INTR_ERR_SIZE]; /* capture the right intr_status */
74 unsigned int intr_err_ptr1; /* ptr used in GTeth_error() */
75 unsigned int intr_err_ptr2; /* ptr used in ISR */
76 struct ifqueue txq_pendq; /* these are ready to go to the GT */
77 unsigned int txq_pending;
78 unsigned int txq_lo; /* next to be given to GT DMA */
79 unsigned int txq_fi; /* next to be free */
80 unsigned int txq_to_cpu; /* next to be returned to CPU */
81 unsigned int txq_ei_gapcount; /* counter until next EI */
82 unsigned int txq_nactive; /* number of active descriptors */
83 unsigned int txq_nintr; /* number of txq desc. send TX_EVENT */
84 unsigned int txq_outptr; /* where to put next transmit packet */
85 unsigned int txq_inptr; /* start of 1st queued tx packet */
86 unsigned int txq_free; /* free Tx queue slots. */
87 unsigned txq_intrbits; /* bits to write to EIMR */
88 unsigned txq_esdcmrbits; /* bits to write to ESDCMR */
89 unsigned txq_epsrbits; /* bits to test with EPSR */
90
91 caddr_t txq_ectdp; /* offset to cur. tx desc ptr reg */
92 unsigned long txq_desc_busaddr; /* bus addr of tx descriptors */
93 caddr_t txq_buf_busaddr; /* bus addr of tx buffers */
94
95 struct mbuf *rxq_curpkt; /* mbuf for current packet */
96 struct GTeth_desc *rxq_head_desc; /* rxq head descriptor */
97 unsigned int rxq_fi; /* next to be returned to CPU */
98 unsigned int rxq_active; /* # of descriptors given to GT */
99 unsigned rxq_intrbits; /* bits to write to EIMR */
100 unsigned long rxq_desc_busaddr; /* bus addr of rx descriptors */
101
102 struct arpcom arpcom; /* rtems if structure, contains ifnet */
103 int sc_macno; /* which mac? 0, 1, or 2 */
104
105 unsigned int sc_tickflags;
106 #define GE_TICK_TX_IFSTART 0x0001
107 #define GE_TICK_RX_RESTART 0x0002
108 unsigned int sc_flags;
109 #define GE_ALLMULTI 0x0001
110 #define GE_PHYSTSCHG 0x0002
111 #define GE_RXACTIVE 0x0004
112 unsigned sc_pcr; /* current EPCR value */
113 unsigned sc_pcxr; /* current EPCXR value */
114 unsigned sc_intrmask; /* current EIMR value */
115 unsigned sc_idlemask; /* suspended EIMR bits */
116 unsigned sc_max_frame_length; /* maximum frame length */
117 unsigned rx_buf_sz;
118
119 /* Hash table related members */
120 unsigned long long *sc_hashtable;
121 unsigned int sc_hashmask; /* 0x1ff or 0x1fff */
122
123 rtems_id daemonTid;
124 rtems_id daemonSync; /* synchronization with the daemon */
125 /* statistics */
126 struct {
127 volatile unsigned long rxInterrupts;
128
129 volatile unsigned long txInterrupts;
130 unsigned long txMultiBuffPacket;
131 unsigned long txMultiMaxLen;
132 unsigned long txSinglMaxLen;
133 unsigned long txMultiMaxLoop;
134 unsigned long txBuffMaxLen;
135 unsigned long length_errors;
136 unsigned long frame_errors;
137 unsigned long crc_errors;
138 unsigned long or_errors; /* overrun error */
139 } stats;
140};
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: GT64260ethreg.h:61
Definition: GT64260eth.h:67
