RTEMS 5.2
8xx_immap.h
1/*===============================================================*\
2| Project: RTEMS BSP support for TQ modules |
3+-----------------------------------------------------------------+
4| Partially based on the code references which are named below. |
5| Adaptions, modifications, enhancements and any recent parts of |
6| the code are: |
7| Copyright (c) 2007 |
8| Embedded Brains GmbH |
9| Obere Lagerstr. 30 |
10| D-82178 Puchheim |
11| Germany |
12| rtems@embedded-brains.de |
13+-----------------------------------------------------------------+
14| The license and distribution terms for this file may be |
15| found in the file LICENSE in this distribution or at |
16| |
17| http://www.rtems.org/license/LICENSE. |
18| |
19+-----------------------------------------------------------------+
20| this file contains definitions to interact with TQC's |
21| processor modules |
22\*===============================================================*/
23/* derived from mbx8xx BSP */
24/*
25 * MPC8xx Internal Memory Map
26 * Copyright (c) 1997 Dan Malek (dmalek@jlc.net)
27 *
28 * The I/O on the MPC860 is comprised of blocks of special registers
29 * and the dual port ram for the Communication Processor Module.
30 * Within this space are functional units such as the SIU, memory
31 * controller, system timers, and other control functions. It is
32 * a combination that I found difficult to separate into logical
33 * functional files.....but anyone else is welcome to try. -- Dan
34 */
35#ifndef __IMMAP_8XX__
36#define __IMMAP_8XX__
37
38/* System configuration registers.
39*/
40typedef struct sys_conf {
41 unsigned int sc_siumcr;
42 unsigned int sc_sypcr;
43 unsigned int sc_swt;
44 char res1[2];
45 unsigned short sc_swsr;
46 unsigned int sc_sipend;
47 unsigned int sc_simask;
48 unsigned int sc_siel;
49 unsigned int sc_sivec;
50 unsigned int sc_tesr;
51 char res2[0xc];
52 unsigned int sc_sdcr;
53 char res3[0x4c];
55
56/* PCMCIA configuration registers.
57*/
58typedef struct pcmcia_conf {
59 unsigned int pcmc_pbr0;
60 unsigned int pcmc_por0;
61 unsigned int pcmc_pbr1;
62 unsigned int pcmc_por1;
63 unsigned int pcmc_pbr2;
64 unsigned int pcmc_por2;
65 unsigned int pcmc_pbr3;
66 unsigned int pcmc_por3;
67 unsigned int pcmc_pbr4;
68 unsigned int pcmc_por4;
69 unsigned int pcmc_pbr5;
70 unsigned int pcmc_por5;
71 unsigned int pcmc_pbr6;
72 unsigned int pcmc_por6;
73 unsigned int pcmc_pbr7;
74 unsigned int pcmc_por7;
75 char res1[0x20];
76 unsigned int pcmc_pgcra;
77 unsigned int pcmc_pgcrb;
78 unsigned int pcmc_pscr;
79 char res2[4];
80 unsigned int pcmc_pipr;
81 char res3[4];
82 unsigned int pcmc_per;
83 char res4[4];
85
86/* Memory controller registers.
87*/
88typedef struct mem_ctlr {
89 unsigned int memc_br0;
90 unsigned int memc_or0;
91 unsigned int memc_br1;
92 unsigned int memc_or1;
93 unsigned int memc_br2;
94 unsigned int memc_or2;
95 unsigned int memc_br3;
96 unsigned int memc_or3;
97 unsigned int memc_br4;
98 unsigned int memc_or4;
99 unsigned int memc_br5;
100 unsigned int memc_or5;
101 unsigned int memc_br6;
102 unsigned int memc_or6;
103 unsigned int memc_br7;
104 unsigned int memc_or7;
105 char res1[0x24];
106 unsigned int memc_mar;
107 unsigned int memc_mcr;
108 char res2[4];
109 unsigned int memc_mamr;
110 unsigned int memc_mbmr;
111 unsigned short memc_mstat;
112 unsigned short memc_mptpr;
113 unsigned int memc_mdr;
114 char res3[0x80];
116
117/* System Integration Timers.
118*/
119typedef struct sys_int_timers {
120 unsigned short sit_tbscr;
121 unsigned int sit_tbreff0;
122 unsigned int sit_tbreff1;
123 char res1[0x14];
124 unsigned short sit_rtcsc;
125 unsigned int sit_rtc;
126 unsigned int sit_rtsec;
127 unsigned int sit_rtcal;
128 char res2[0x10];
129 unsigned short sit_piscr;
130 char res3[2];
131 unsigned int sit_pitc;
132 unsigned int sit_pitr;
133 char res4[0x34];
134} sit8xx_t;
135
136#define TBSCR_TBIRQ_MASK ((unsigned short)0xff00)
137#define TBSCR_REFA ((unsigned short)0x0080)
138#define TBSCR_REFB ((unsigned short)0x0040)
139#define TBSCR_REFAE ((unsigned short)0x0008)
140#define TBSCR_REFBE ((unsigned short)0x0004)
141#define TBSCR_TBF ((unsigned short)0x0002)
142#define TBSCR_TBE ((unsigned short)0x0001)
143
144#define RTCSC_RTCIRQ_MASK ((unsigned short)0xff00)
145#define RTCSC_SEC ((unsigned short)0x0080)
146#define RTCSC_ALR ((unsigned short)0x0040)
147#define RTCSC_38K ((unsigned short)0x0010)
148#define RTCSC_SIE ((unsigned short)0x0008)
149#define RTCSC_ALE ((unsigned short)0x0004)
150#define RTCSC_RTF ((unsigned short)0x0002)
151#define RTCSC_RTE ((unsigned short)0x0001)
152
153#define PISCR_PIRQ_MASK ((unsigned short)0xff00)
154#define PISCR_PS ((unsigned short)0x0080)
155#define PISCR_PIE ((unsigned short)0x0004)
156#define PISCR_PTF ((unsigned short)0x0002)
157#define PISCR_PTE ((unsigned short)0x0001)
158
159/* Clocks and Reset.
160*/
161typedef struct clk_and_reset {
162 unsigned int car_sccr;
163 unsigned int car_plprcr;
164 unsigned int car_rsr;
165 char res[0x74]; /* Reserved area */
166} car8xx_t;
167
168/* System Integration Timers keys.
169*/
170typedef struct sitk {
171 unsigned int sitk_tbscrk;
172 unsigned int sitk_tbreff0k;
173 unsigned int sitk_tbreff1k;
174 unsigned int sitk_tbk;
175 char res1[0x10];
176 unsigned int sitk_rtcsck;
177 unsigned int sitk_rtck;
178 unsigned int sitk_rtseck;
179 unsigned int sitk_rtcalk;
180 char res2[0x10];
181 unsigned int sitk_piscrk;
182 unsigned int sitk_pitck;
183 char res3[0x38];
184} sitk8xx_t;
185
186/* Clocks and reset keys.
187*/
188typedef struct cark {
189 unsigned int cark_sccrk;
190 unsigned int cark_plprcrk;
191 unsigned int cark_rsrk;
192 char res[0x474];
193} cark8xx_t;
194
195/* The key to unlock registers maintained by keep-alive power.
196*/
197#define KAPWR_KEY ((unsigned int)0x55ccaa33)
198
199/* LCD interface. MPC821 Only.
200*/
201typedef struct lcd {
202 unsigned short lcd_lcolr[16];
203 char res[0x20];
204 unsigned int lcd_lccr;
205 unsigned int lcd_lchcr;
206 unsigned int lcd_lcvcr;
207 char res2[4];
208 unsigned int lcd_lcfaa;
209 unsigned int lcd_lcfba;
210 char lcd_lcsr;
211 char res3[0x7];
212} lcd8xx_t;
213
214/* I2C
215*/
216typedef struct i2c {
217 unsigned char i2c_i2mod;
218 char res1[3];
219 unsigned char i2c_i2add;
220 char res2[3];
221 unsigned char i2c_i2brg;
222 char res3[3];
223 unsigned char i2c_i2com;
224 char res4[3];
225 unsigned char i2c_i2cer;
226 char res5[3];
227 unsigned char i2c_i2cmr;
228 char res6[0x8b];
229} i2c8xx_t;
230
231/* DMA control/status registers.
232*/
233typedef struct sdma_csr {
234 char res1[4];
235 unsigned int sdma_sdar;
236 unsigned char sdma_sdsr;
237 char res3[3];
238 unsigned char sdma_sdmr;
239 char res4[3];
240 unsigned char sdma_idsr1;
241 char res5[3];
242 unsigned char sdma_idmr1;
243 char res6[3];
244 unsigned char sdma_idsr2;
245 char res7[3];
246 unsigned char sdma_idmr2;
247 char res8[0x13];
248} sdma8xx_t;
249
250/* Communication Processor Module Interrupt Controller.
251*/
252typedef struct cpm_ic {
253 unsigned short cpic_civr;
254 char res[0xe];
255 unsigned int cpic_cicr;
256 unsigned int cpic_cipr;
257 unsigned int cpic_cimr;
258 unsigned int cpic_cisr;
259} cpic8xx_t;
260
261/* Input/Output Port control/status registers.
262*/
263typedef struct io_port {
264 unsigned short iop_padir;
265 unsigned short iop_papar;
266 unsigned short iop_paodr;
267 unsigned short iop_padat;
268 char res1[8];
269 unsigned short iop_pcdir;
270 unsigned short iop_pcpar;
271 unsigned short iop_pcso;
272 unsigned short iop_pcdat;
273 unsigned short iop_pcint;
274 char res2[6];
275 unsigned short iop_pddir;
276 unsigned short iop_pdpar;
277 char res3[2];
278 unsigned short iop_pddat;
279 char res4[8];
280} iop8xx_t;
281
282/* Communication Processor Module Timers
283*/
284typedef struct cpm_timers {
285 unsigned short cpmt_tgcr;
286 char res1[0xe];
287 unsigned short cpmt_tmr1;
288 unsigned short cpmt_tmr2;
289 unsigned short cpmt_trr1;
290 unsigned short cpmt_trr2;
291 unsigned short cpmt_tcr1;
292 unsigned short cpmt_tcr2;
293 unsigned short cpmt_tcn1;
294 unsigned short cpmt_tcn2;
295 unsigned short cpmt_tmr3;
296 unsigned short cpmt_tmr4;
297 unsigned short cpmt_trr3;
298 unsigned short cpmt_trr4;
299 unsigned short cpmt_tcr3;
300 unsigned short cpmt_tcr4;
301 unsigned short cpmt_tcn3;
302 unsigned short cpmt_tcn4;
303 unsigned short cpmt_ter1;
304 unsigned short cpmt_ter2;
305 unsigned short cpmt_ter3;
306 unsigned short cpmt_ter4;
307 char res2[8];
309
310/* Finally, the Communication Processor stuff.....
311*/
312typedef struct scc { /* Serial communication channels */
313 unsigned int scc_gsmrl;
314 unsigned int scc_gsmrh;
315 unsigned short scc_pmsr;
316 char res1[2];
317 unsigned short scc_todr;
318 unsigned short scc_dsr;
319 unsigned short scc_scce;
320 char res2[2];
321 unsigned short scc_sccm;
322 char res3;
323 unsigned char scc_sccs;
324 char res4[8];
325} scc_t;
326
327typedef struct smc { /* Serial management channels */
328 char res1[2];
329 unsigned short smc_smcmr;
330 char res2[2];
331 unsigned char smc_smce;
332 char res3[3];
333 unsigned char smc_smcm;
334 char res4[5];
335} smc_t;
336
337/* MPC860T Fast Ethernet Controller. It isn't part of the CPM, but
338 * it fits within the address space.
339 */
340typedef struct fec {
341 unsigned int fec_addr_low; /* LS 32 bits of station address */
342 unsigned short fec_addr_high; /* MS 16 bits of address */
343 unsigned short res1;
344 unsigned int fec_hash_table_high;
345 unsigned int fec_hash_table_low;
346 unsigned int fec_r_des_start;
347 unsigned int fec_x_des_start;
348 unsigned int fec_r_buff_size;
349 unsigned int res2[9];
350 unsigned int fec_ecntrl;
351 unsigned int fec_ievent;
352 unsigned int fec_imask;
353 unsigned int fec_ivec;
354 unsigned int fec_r_des_active;
355 unsigned int fec_x_des_active;
356 unsigned int res3[10];
357 unsigned int fec_mii_data;
358 unsigned int fec_mii_speed;
359 unsigned int res4[17];
360 unsigned int fec_r_bound;
361 unsigned int fec_r_fstart;
362 unsigned int res5[6];
363 unsigned int fec_x_fstart;
364 unsigned int res6[17];
365 unsigned int fec_fun_code;
366 unsigned int res7[3];
367 unsigned int fec_r_cntrl;
368 unsigned int fec_r_hash;
369 unsigned int res8[14];
370 unsigned int fec_x_cntrl;
371 unsigned int res9[0x1e];
372} fec_t;
373
374typedef struct comm_proc {
375 /* General control and status registers.
376 */
377 unsigned short cp_cpcr;
378 char res1[2];
379 unsigned short cp_rccr;
380 char res2[6];
381 unsigned short cp_cpmcr1;
382 unsigned short cp_cpmcr2;
383 unsigned short cp_cpmcr3;
384 unsigned short cp_cpmcr4;
385 char res3[2];
386 unsigned short cp_rter;
387 char res4[2];
388 unsigned short cp_rtmr;
389 char res5[0x14];
390
391 /* Baud rate generators.
392 */
393 unsigned int cp_brgc1;
394 unsigned int cp_brgc2;
395 unsigned int cp_brgc3;
396 unsigned int cp_brgc4;
397
398 /* Serial Communication Channels.
399 */
400 scc_t cp_scc[4];
401
402 /* Serial Management Channels.
403 */
404 smc_t cp_smc[2];
405
406 /* Serial Peripheral Interface.
407 */
408 unsigned short cp_spmode;
409 char res6[4];
410 unsigned char cp_spie;
411 char res7[3];
412 unsigned char cp_spim;
413 char res8[2];
414 unsigned char cp_spcom;
415 char res9[2];
416
417 /* Parallel Interface Port.
418 */
419 char res10[2];
420 unsigned short cp_pipc;
421 char res11[2];
422 unsigned short cp_ptpr;
423 unsigned int cp_pbdir;
424 unsigned int cp_pbpar;
425 char res12[2];
426 unsigned short cp_pbodr;
427 unsigned int cp_pbdat;
428 char res13[0x18];
429
430 /* Serial Interface and Time Slot Assignment.
431 */
432 unsigned int cp_simode;
433 unsigned char cp_sigmr;
434 char res14;
435 unsigned char cp_sistr;
436 unsigned char cp_sicmr;
437 char res15[4];
438 unsigned int cp_sicr;
439 unsigned int cp_sirp;
440 char res16[0x10c];
441 unsigned char cp_siram[0x200];
442
443 /* The fast ethernet controller is not really part of the CPM,
444 * but it resides in the address space.
445 */
446 fec_t cp_fec;
447 char res18[0x1000];
448
449 /* Dual Ported RAM follows.
450 * There are many different formats for this memory area
451 * depending upon the devices used and options chosen.
452 */
453 unsigned char cp_dpmem[0x1000]; /* BD / Data / ucode */
454 unsigned char res19[0xc00];
455 unsigned char cp_dparam[0x400]; /* Parameter RAM */
456} cpm8xx_t;
457
458/* Internal memory map.
459*/
460typedef struct immap {
461 sysconf8xx_t im_siu_conf; /* SIU Configuration */
462 pcmconf8xx_t im_pcmcia; /* PCMCIA Configuration */
463 memctl8xx_t im_memctl; /* Memory Controller */
464 sit8xx_t im_sit; /* System integration timers */
465 car8xx_t im_clkrst; /* Clocks and reset */
466 sitk8xx_t im_sitk; /* Sys int timer keys */
467 cark8xx_t im_clkrstk; /* Clocks and reset keys */
468 lcd8xx_t im_lcd; /* LCD (821 only) */
469 i2c8xx_t im_i2c; /* I2C control/status */
470 sdma8xx_t im_sdma; /* SDMA control/status */
471 cpic8xx_t im_cpic; /* CPM Interrupt Controller */
472 iop8xx_t im_ioport; /* IO Port control/status */
473 cpmtimer8xx_t im_cpmtimer; /* CPM timers */
474 cpm8xx_t im_cpm; /* Communication processor */
475} immap_t;
476
477#endif /* __IMMAP_8XX__ */
Definition: 8xx_immap.h:188
Definition: 8xx_immap.h:161
Definition: 8xx_immap.h:374
Definition: 8xx_immap.h:252
Definition: 8xx_immap.h:284
Definition: 8xx_immap.h:340
Definition: 8xx_immap.h:216
Definition: 8xx_immap.h:460
Definition: 8xx_immap.h:263
Definition: 8xx_immap.h:201
Definition: 8xx_immap.h:88
Definition: 8xx_immap.h:58
Definition: 8xx_immap.h:312
Definition: 8xx_immap.h:233
Definition: 8xx_immap.h:170
Definition: 8xx_immap.h:327
Definition: 8xx_immap.h:40
Definition: 8xx_immap.h:119
