RTEMS  5.1
vmeUniverse.h File Reference
Driver for the Tundra Universe II pci-vme bridge. More...
#include <bsp/vme_am_defs.h>
struct  VmeUniverseDMAPacketRec_
#define VME_MODE_MATCH_MASK   (3<<30)
#define VME_MODE_EXACT_MATCH   (2<<30) /* all bits must match */
#define VME_MODE_AS_MATCH   (1<<30) /* only A16/24/32 must match */
#define UNIV_REGOFF_PCI_CSR   0x4
#define UNIV_PCI_CSR_D_PE   (1<<31) /* detected parity error; write 1 to clear */
#define UNIV_PCI_CSR_S_SERR   (1<<30) /* SERR (signalled error) asserted; write 1 to clear */
#define UNIV_PCI_CSR_R_MA   (1<<29) /* received master abort; write 1 to clear */
#define UNIV_PCI_CSR_R_TA   (1<<28) /* received target abort; write 1 to clear */
#define UNIV_PCI_CSR_S_TA   (1<<27) /* signalled target abort; write 1 to clear */
#define UNIV_PCI_CSR_DEVSEL_MASK   (3<<25) /* device select timing (RO) */
#define UNIV_PCI_CSR_DP_D   (1<<24) /* data parity error detected; write 1 to clear */
#define UNIV_PCI_CSR_TFBBC   (1<<23) /* target fast back to back capable (RO) */
#define UNIV_PCI_CSR_MFBBC   (1<<9) /* master fast back to back capable (RO) */
#define UNIV_PCI_CSR_SERR_EN   (1<<8) /* enable SERR driver */
#define UNIV_PCI_CSR_WAIT   (1<<7) /* wait cycle control (RO) */
#define UNIV_PCI_CSR_PERESP   (1<<6) /* parity error response enable */
#define UNIV_PCI_CSR_VGAPS   (1<<5) /* VGA palette snoop (RO) */
#define UNIV_PCI_CSR_MWI_EN   (1<<4) /* Memory write and invalidate enable (RO) */
#define UNIV_PCI_CSR_SC   (1<<3) /* special cycles (RO) */
#define UNIV_PCI_CSR_BM   (1<<2) /* master enable (MUST SET TO ENABLE VME SLAVES) */
#define UNIV_PCI_CSR_MS   (1<<1) /* target memory enable */
#define UNIV_PCI_CSR_IOS   (1<<0) /* target IO enable */
#define UNIV_REGOFF_SCYC_CTL   0x170 /* write 0 to disable */
#define UNIV_SCYC_CTL_LAS_IO   (1<<2) /* PCI address space (1: IO, 0: mem) */
#define UNIV_SCYC_CTL_SCYC_RMW   (1<<0) /* do a RMW cycle when reading PCI address */
#define UNIV_SCYC_CTL_SCYC_ADOH   (2<<0) /* do a ADOH cycle when reading/writing PCI address */
#define UNIV_REGOFF_SCYC_ADDR   0x174 /* PCI address (must be long word aligned) */
#define UNIV_REGOFF_SCYC_EN   0x178 /* mask determining the bits involved in the compare and swap operations for VME RMW cycles */
#define UNIV_REGOFF_SCYC_CMP   0x17c /* data to compare with word returned from VME RMW read */
#define UNIV_REGOFF_SCYC_SWP   0x180 /* If enabled bits of CMP match, corresponding SWP bits are written back to VME (under control of EN) */
#define UNIV_REGOFF_LMISC   0x184
#define UNIV_LMISC_CRT_MASK   (7<<28) /* Univ. I only, not used on II */
#define UNIV_LMISC_CRT_INF   (0<<28) /* Coupled Request Timeout */
#define UNIV_LMISC_CRT_128_US   (1<<28) /* Coupled Request Timeout */
#define UNIV_LMISC_CRT_256_US   (2<<28) /* Coupled Request Timeout */
#define UNIV_LMISC_CRT_512_US   (3<<28) /* Coupled Request Timeout */
#define UNIV_LMISC_CRT_1024_US   (4<<28) /* Coupled Request Timeout */
#define UNIV_LMISC_CRT_2048_US   (5<<28) /* Coupled Request Timeout */
#define UNIV_LMISC_CRT_4096_US   (6<<28) /* Coupled Request Timeout */
#define UNIV_LMISC_CWT_MASK   (7<<24) /* coupled window timer */
#define UNIV_LMISC_CWT_DISABLE   0 /* disabled (release VME after 1 coupled xaction) */
#define UNIV_LMISC_CWT_16   (1<<24) /* 16 PCI clock cycles */
#define UNIV_LMISC_CWT_32   (2<<24) /* 32 PCI clock cycles */
#define UNIV_LMISC_CWT_64   (3<<24) /* 64 PCI clock cycles */
#define UNIV_LMISC_CWT_128   (4<<24) /* 128 PCI clock cycles */
#define UNIV_LMISC_CWT_256   (5<<24) /* 256 PCI clock cycles */
#define UNIV_LMISC_CWT_512   (6<<24) /* 512 PCI clock cycles */
#define UNIV_REGOFF_L_CMDERR   0x18c
#define UNIV_L_CMDERR_CMDERR(reg)   (((reg)>>28)&0xf) /* extract PCI cmd error log */
#define UNIV_L_CMDERR_M_ERR   (1<<27) /* multiple errors have occurred */
#define UNIV_L_CMDERR_L_STAT   (1<<23) /* PCI error log status valid (write 1 to clear and enable logging) */
#define UNIV_REGOFF_LAERR   0x190 /* PCI fault address (if L_CMDERR_L_STAT valid) */
#define UNIV_REGOFF_DCTL   0x200
#define UNIV_DCTL_L2V   (1<<31) /* PCI->VME if set */
#define UNIV_DCTL_VDW_MSK   (3<<22) /* VME max. width mask 0x00c00000 */
#define UNIV_DCTL_VDW_8   (0<<22) /* VME max. width 8 */
#define UNIV_DCTL_VDW_16   (1<<22) /* VME max. width 16 */
#define UNIV_DCTL_VDW_32   (2<<22) /* VME max. width 32 */
#define UNIV_DCTL_VDW_64   (3<<22) /* VME max. width 64 */
#define UNIV_DCTL_VAS_MSK   (7<<16) /* VME AS mask 0x00070000 */
#define UNIV_DCTL_VAS_A16   (0<<16) /* VME A16 */
#define UNIV_DCTL_VAS_A24   (1<<16) /* VME A24 */
#define UNIV_DCTL_VAS_A32   (2<<16) /* VME A32 */
#define UNIV_DCTL_PGM_MSK   (3<<14) /* VME PGM/DATA mask 0x0000c000 */
#define UNIV_DCTL_PGM   (1<<14) /* VME PGM(1)/DATA(0) */
#define UNIV_DCTL_SUPER_MSK   (3<<12) /* VME SUPER/USR mask 0x00003000 */
#define UNIV_DCTL_SUPER   (1<<12) /* VME SUPER(1)/USR(0) */
#define UNIV_DCTL_NO_VINC   (1<<9) /* VME no VME address increment [Universe IIa/b ONLY */
#define UNIV_DCTL_VCT   (1<<8) /* VME enable BLT */
#define UNIV_DCTL_LD64EN   (1<<7) /* PCI 64 enable */
#define UNIV_REGOFF_DTBC   0x204
#define UNIV_REGOFF_DLA   0x208
#define UNIV_REGOFF_DVA   0x210
#define UNIV_REGOFF_DCPP   0x218
#define UNIV_DCPP_IMG_NULL   (1<<0) /* last packet in list */
#define UNIV_DCPP_IMG_PROCESSED   (1<<1) /* packet processed */
#define UNIV_REGOFF_DGCS   0x220
#define UNIV_DGCS_GO   (1<<31) /* start xfer */
#define UNIV_DGCS_STOP_REQ   (1<<30) /* stop xfer (immediate abort) */
#define UNIV_DGCS_HALT_REQ   (1<<29) /* halt xfer (abort after current packet) */
#define UNIV_DGCS_CHAIN   (1<<27) /* enable linked list mode */
#define UNIV_DGCS_VON_MSK   (7<<20) /* VON mask */
#define UNIV_DGCS_VON_DONE   (0<<20) /* VON counter disabled (do until done) */
#define UNIV_DGCS_VON_256   (1<<20) /* VON yield bus after 256 bytes */
#define UNIV_DGCS_VON_512   (2<<20) /* VON yield bus after 512 bytes */
#define UNIV_DGCS_VON_1024   (3<<20) /* VON yield bus after 1024 bytes */
#define UNIV_DGCS_VON_2048   (4<<20) /* VON yield bus after 2048 bytes */
#define UNIV_DGCS_VON_4096   (5<<20) /* VON yield bus after 4096 bytes */
#define UNIV_DGCS_VON_8192   (6<<20) /* VON yield bus after 8192 bytes */
#define UNIV_DGCS_VON_16384   (7<<20) /* VON yield bus after 16384 bytes */
#define UNIV_DGCS_VOFF_MSK   (15<<16) /* VOFF mask */
#define UNIV_DGCS_VOFF_0_US   (0<<16) /* re-request VME master after 0 us */
#define UNIV_DGCS_VOFF_2_US   (8<<16) /* re-request VME master after 2 us */
#define UNIV_DGCS_VOFF_4_US   (9<<16) /* re-request VME master after 4 us */
#define UNIV_DGCS_VOFF_8_US   (10<<16)/* re-request VME master after 8 us */
#define UNIV_DGCS_VOFF_16_US   (1<<16) /* re-request VME master after 16 us */
#define UNIV_DGCS_VOFF_32_US   (2<<16) /* re-request VME master after 32 us */
#define UNIV_DGCS_VOFF_64_US   (3<<16) /* re-request VME master after 64 us */
#define UNIV_DGCS_VOFF_128_US   (4<<16) /* re-request VME master after 128 us */
#define UNIV_DGCS_VOFF_256_US   (5<<16) /* re-request VME master after 256 us */
#define UNIV_DGCS_VOFF_512_US   (6<<16) /* re-request VME master after 512 us */
#define UNIV_DGCS_VOFF_1024_US   (7<<16) /* re-request VME master after 1024 us */
#define UNIV_DGCS_ACT   (1<<15) /* DMA active */
#define UNIV_DGCS_STOP   (1<<14) /* DMA stopped */
#define UNIV_DGCS_HALT   (1<<13) /* DMA halted */
#define UNIV_DGCS_DONE   (1<<11) /* DMA done (OK) */
#define UNIV_DGCS_LERR   (1<<10) /* PCI bus error */
#define UNIV_DGCS_VERR   (1<<9) /* VME bus error */
#define UNIV_DGCS_P_ERR   (1<<8) /* programming protocol error (e.g. PCI master disabled) */
#define UNIV_DGCS_STATUS_CLEAR
#define UNIV_DGCS_INT_STOP   (1<<6) /* interrupt when stopped */
#define UNIV_DGCS_INT_HALT   (1<<5) /* interrupt when halted */
#define UNIV_DGCS_INT_DONE   (1<<3) /* interrupt when done */
#define UNIV_DGCS_INT_LERR   (1<<2) /* interrupt on LERR */
#define UNIV_DGCS_INT_VERR   (1<<1) /* interrupt on VERR */
#define UNIV_DGCS_INT_P_ERR   (1<<0) /* interrupt on P_ERR */
#define UNIV_DGCS_INT_MSK   (0x0000006f) /* interrupt mask */
#define UNIV_REGOFF_D_LLUE   0x224
#define UNIV_D_LLUE_UPDATE   (1<<31)
#define UNIV_REGOFF_LINT_EN   0x300
#define UNIV_LINT_EN_LM3   (1<<23) /* location monitor 3 mask */
#define UNIV_LINT_EN_LM2   (1<<22) /* location monitor 2 mask */
#define UNIV_LINT_EN_LM1   (1<<21) /* location monitor 1 mask */
#define UNIV_LINT_EN_LM0   (1<<20) /* location monitor 0 mask */
#define UNIV_LINT_EN_MBOX3   (1<<19) /* mailbox 3 mask */
#define UNIV_LINT_EN_MBOX2   (1<<18) /* mailbox 2 mask */
#define UNIV_LINT_EN_MBOX1   (1<<17) /* mailbox 1 mask */
#define UNIV_LINT_EN_MBOX0   (1<<16) /* mailbox 0 mask */
#define UNIV_LINT_EN_ACFAIL   (1<<15) /* ACFAIL irq mask */
#define UNIV_LINT_EN_SYSFAIL   (1<<14) /* SYSFAIL irq mask */
#define UNIV_LINT_EN_SW_INT   (1<<13) /* PCI (local) software irq */
#define UNIV_LINT_EN_SW_IACK   (1<<12) /* VME software IACK mask */
#define UNIV_LINT_EN_VERR   (1<<10) /* PCI VERR irq mask */
#define UNIV_LINT_EN_LERR   (1<<9) /* PCI LERR irq mask */
#define UNIV_LINT_EN_DMA   (1<<8) /* PCI DMA irq mask */
#define UNIV_LINT_EN_VIRQ7   (1<<7) /* VIRQ7 mask (universe does IACK automatically) */
#define UNIV_LINT_EN_VIRQ6   (1<<6) /* VIRQ6 mask */
#define UNIV_LINT_EN_VIRQ5   (1<<5) /* VIRQ5 mask */
#define UNIV_LINT_EN_VIRQ4   (1<<4) /* VIRQ4 mask */
#define UNIV_LINT_EN_VIRQ3   (1<<3) /* VIRQ3 mask */
#define UNIV_LINT_EN_VIRQ2   (1<<2) /* VIRQ2 mask */
#define UNIV_LINT_EN_VIRQ1   (1<<1) /* VIRQ1 mask */
#define UNIV_LINT_EN_VOWN   (1<<0) /* VOWN mask */
#define UNIV_REGOFF_LINT_STAT   0x304
#define UNIV_LINT_STAT_LM3   (1<<23) /* location monitor 3 status */
#define UNIV_LINT_STAT_LM2   (1<<22) /* location monitor 2 status */
#define UNIV_LINT_STAT_LM1   (1<<21) /* location monitor 1 status */
#define UNIV_LINT_STAT_LM0   (1<<20) /* location monitor 0 status */
#define UNIV_LINT_STAT_MBOX3   (1<<19) /* mailbox 3 status */
#define UNIV_LINT_STAT_MBOX2   (1<<18) /* mailbox 2 status */
#define UNIV_LINT_STAT_MBOX1   (1<<17) /* mailbox 1 status */
#define UNIV_LINT_STAT_MBOX0   (1<<16) /* mailbox 0 status */
#define UNIV_LINT_STAT_ACFAIL   (1<<15) /* ACFAIL irq status */
#define UNIV_LINT_STAT_SYSFAIL   (1<<14) /* SYSFAIL irq status */
#define UNIV_LINT_STAT_SW_INT   (1<<13) /* PCI (local) software irq */
#define UNIV_LINT_STAT_SW_IACK   (1<<12) /* VME software IACK status */
#define UNIV_LINT_STAT_VERR   (1<<10) /* PCI VERR irq status */
#define UNIV_LINT_STAT_LERR   (1<<9) /* PCI LERR irq status */
#define UNIV_LINT_STAT_DMA   (1<<8) /* PCI DMA irq status */
#define UNIV_LINT_STAT_VIRQ7   (1<<7) /* VIRQ7 status */
#define UNIV_LINT_STAT_VIRQ6   (1<<6) /* VIRQ6 status */
#define UNIV_LINT_STAT_VIRQ5   (1<<5) /* VIRQ5 status */
#define UNIV_LINT_STAT_VIRQ4   (1<<4) /* VIRQ4 status */
#define UNIV_LINT_STAT_VIRQ3   (1<<3) /* VIRQ3 status */
#define UNIV_LINT_STAT_VIRQ2   (1<<2) /* VIRQ2 status */
#define UNIV_LINT_STAT_VIRQ1   (1<<1) /* VIRQ1 status */
#define UNIV_LINT_STAT_VOWN   (1<<0) /* VOWN status */
#define UNIV_LINT_STAT_CLR   (0xfff7ff)/* Clear all status bits */
#define UNIV_REGOFF_LINT_MAP0   0x308 /* mapping of VME IRQ sources to PCI irqs */
#define UNIV_LINT_MAP0_VIRQ7(lint)   (((lint)&0x7)<<(7*4))
#define UNIV_LINT_MAP0_VIRQ6(lint)   (((lint)&0x7)<<(6*4))
#define UNIV_LINT_MAP0_VIRQ5(lint)   (((lint)&0x7)<<(5*4))
#define UNIV_LINT_MAP0_VIRQ4(lint)   (((lint)&0x7)<<(4*4))
#define UNIV_LINT_MAP0_VIRQ3(lint)   (((lint)&0x7)<<(3*4))
#define UNIV_LINT_MAP0_VIRQ2(lint)   (((lint)&0x7)<<(2*4))
#define UNIV_LINT_MAP0_VIRQ1(lint)   (((lint)&0x7)<<(1*4))
#define UNIV_LINT_MAP0_VOWN(lint)   (((lint)&0x7)<<(0*4))
#define UNIV_REGOFF_LINT_MAP1   0x30c /* mapping of internal / VME IRQ sources to PCI irqs */
#define UNIV_LINT_MAP1_ACFAIL(lint)   (((lint)&0x7)<<(7*4))
#define UNIV_LINT_MAP1_SYSFAIL(lint)   (((lint)&0x7)<<(6*4))
#define UNIV_LINT_MAP1_SW_INT(lint)   (((lint)&0x7)<<(5*4))
#define UNIV_LINT_MAP1_SW_IACK(lint)   (((lint)&0x7)<<(4*4))
#define UNIV_LINT_MAP1_VERR(lint)   (((lint)&0x7)<<(2*4))
#define UNIV_LINT_MAP1_LERR(lint)   (((lint)&0x7)<<(1*4))
#define UNIV_LINT_MAP1_DMA(lint)   (((lint)&0x7)<<(0*4))
#define UNIV_REGOFF_VINT_EN   0x310
#define UNIV_VINT_EN_DISABLE_ALL   0
#define UNIV_VINT_EN_SWINT   (1<<12)
#define UNIV_VINT_EN_SWINT_LVL(l)   (1<<(((l)&7)+24)) /* universe II only */
#define UNIV_REGOFF_VINT_STAT   0x314
#define UNIV_VINT_STAT_LINT(lint)   (1<<((lint)&7))
#define UNIV_VINT_STAT_LINT_MASK   (0xff)
#define UNIV_VINT_STAT_CLR   (0xfe0f17ff)
#define UNIV_VINT_STAT_SWINT(l)   (1<<(((l)&7)+24))
#define UNIV_REGOFF_VINT_MAP0   0x318 /* VME destination of PCI IRQ source, TODO */
#define UNIV_REGOFF_VINT_MAP1   0x31c /* VME destination of PCI IRQ source, TODO */
#define UNIV_VINT_MAP1_SWINT(level)   (((level)&0x7)<<16)
#define UNIV_REGOFF_VINT_STATID   0x320 /* our status/id response to IACK, TODO */
#define UNIV_VINT_STATID(id)   ((id)<<24)
#define UNIV_REGOFF_VIRQ1_STATID   0x324 /* status/id of VME IRQ level 1 */
#define UNIV_REGOFF_VIRQ2_STATID   0x328 /* status/id of VME IRQ level 2 */
#define UNIV_REGOFF_VIRQ3_STATID   0x32c /* status/id of VME IRQ level 3 */
#define UNIV_REGOFF_VIRQ4_STATID   0x330 /* status/id of VME IRQ level 4 */
#define UNIV_REGOFF_VIRQ5_STATID   0x334 /* status/id of VME IRQ level 5 */
#define UNIV_REGOFF_VIRQ6_STATID   0x338 /* status/id of VME IRQ level 6 */
#define UNIV_REGOFF_VIRQ7_STATID   0x33c /* status/id of VME IRQ level 7 */
#define UNIV_VIRQ_ERR   (1<<8) /* set if universe encountered a bus error when doing IACK */
#define UNIV_VIRQ_STATID_MASK   (0xff)
#define UNIV_REGOFF_LINT_MAP2   0x340 /* mapping of internal sources to PCI irqs */
#define UNIV_LINT_MAP2_LM3(lint)   (((lint)&0x7)<<7*4) /* location monitor 3 */
#define UNIV_LINT_MAP2_LM2(lint)   (((lint)&0x7)<<6*4) /* location monitor 2 */
#define UNIV_LINT_MAP2_LM1(lint)   (((lint)&0x7)<<5*4) /* location monitor 1 */
#define UNIV_LINT_MAP2_LM0(lint)   (((lint)&0x7)<<4*4) /* location monitor 0 */
#define UNIV_LINT_MAP2_MBOX3(lint)   (((lint)&0x7)<<3*4) /* mailbox 3 */
#define UNIV_LINT_MAP2_MBOX2(lint)   (((lint)&0x7)<<2*4) /* mailbox 2 */
#define UNIV_LINT_MAP2_MBOX1(lint)   (((lint)&0x7)<<1*4) /* mailbox 1 */
#define UNIV_LINT_MAP2_MBOX0(lint)   (((lint)&0x7)<<0*4) /* mailbox 0 */
#define UNIV_REGOFF_VINT_MAP2   0x344 /* mapping of internal sources to VME irqs */
#define UNIV_VINT_MAP2_MBOX3(vint)   (((vint)&0x7)<<3*4) /* mailbox 3 */
#define UNIV_VINT_MAP2_MBOX2(vint)   (((vint)&0x7)<<2*4) /* mailbox 2 */
#define UNIV_VINT_MAP2_MBOX1(vint)   (((vint)&0x7)<<1*4) /* mailbox 1 */
#define UNIV_VINT_MAP2_MBOX0(vint)   (((vint)&0x7)<<0*4) /* mailbox 0 */
#define UNIV_REGOFF_MBOX0   0x348 /* mailbox 0 */
#define UNIV_REGOFF_MBOX1   0x34c /* mailbox 1 */
#define UNIV_REGOFF_MBOX2   0x350 /* mailbox 2 */
#define UNIV_REGOFF_MBOX3   0x354 /* mailbox 3 */
#define UNIV_REGOFF_SEMA0   0x358 /* semaphore 0 */
#define UNIV_REGOFF_SEMA1   0x35c /* semaphore 0 */
#define UNIV_REGOFF_MAST_CTL   0x400 /* master control register */
#define UNIV_MAST_CTL_MAXRTRY(val)   (((val)&0xf)<<7*4) /* max # of pci master retries */
#define UNIV_MAST_CTL_PWON(val)   (((val)&0xf)<<6*4) /* posted write xfer count */
#define UNIV_MAST_CTL_VRL(val)   (((val)&0x3)<<22) /* VME bus request level */
#define UNIV_MAST_CTL_VRM   (1<<21) /* bus request mode (demand = 0, fair = 1) */
#define UNIV_MAST_CTL_VREL   (1<<20) /* bus release mode (when done = 0, on request = 1) */
#define UNIV_MAST_CTL_VOWN   (1<<19) /* bus ownership (release = 0, acquire/hold = 1) */
#define UNIV_MAST_CTL_VOWN_ACK   (1<<18) /* bus ownership (not owned = 0, acquired/held = 1) */
#define UNIV_MAST_CTL_PABS(val)   (((val)&0x3)<<3*4) /* PCI aligned burst size (32,64,128 byte / 0x3 is reserved) */
#define UNIV_MAST_CTL_BUS_NO(val)   (((val)&0xff)<<0*4) /* PCI bus number */
#define UNIV_REGOFF_MISC_CTL   0x404 /* misc control register */
#define UNIV_MISC_CTL_VBTO(val)   (((val)&0x7)<<7*4) /* VME bus timeout (0=disable, 16*2^(val-1) us) */
#define UNIV_MISC_CTL_VARB   (1<<26) /* VME bus arbitration mode (0=round robin, 1= priority) */
#define UNIV_MISC_CTL_VARBTO(val)   (((val)&0x3)<<6*4) /* arbitration time out: disable, 16us, 256us, reserved */
#define UNIV_MISC_CTL_SW_LRST   (1<<23) /* software PCI reset */
#define UNIV_MISC_CTL_SW_SYSRST   (1<<22) /* software VME reset */
#define UNIV_MISC_CTL_BI   (1<<20) /* BI mode */
#define UNIV_MISC_CTL_ENGBI   (1<<19) /* enable global BI mode initiator */
#define UNIV_MISC_CTL_SYSCON   (1<<17) /* (R/W) 1:universe is system controller */
#define UNIV_MISC_CTL_V64AUTO   (1<<16) /* (R/W) 1:initiate VME64 auto id slave participation */
#define UNIV_REGOFF_U2SPEC   0x4fc
#define UNIV_U2SPEC_DTKFLTR   (1<<12) /* DTAck filter: 0: slow, better filter; 1: fast, poorer filter */
#define UNIV_U2SPEC_MASt11   (1<<10) /* Master parameter t11 (DS hi time during BLT and MBLTs) */
#define UNIV_U2SPEC_READt27_DEFAULT   (0<<8) /* VME master parameter t27: (latch data after DTAck + 25ns) */
#define UNIV_U2SPEC_READt27_FAST   (1<<8) /* VME master parameter t27: (latch data faster than 25ns) */
#define UNIV_U2SPEC_READt27_NODELAY   (2<<8) /* VME master parameter t27: (latch data without any delay) */
#define UNIV_U2SPEC_POSt28_FAST   (1<<2) /* VME slave parameter t28: (faster time of DS to DTAck for posted write) */
#define UNIV_U2SPEC_PREt28_FAST   (1<<0) /* VME slave parameter t28: (faster time of DS to DTAck for prefetch read) */
#define UNIV_REGOFF_LM_CTL   0xf64
#define UNIV_LM_CTL_EN   (1<<31) /* image enable */
#define UNIV_LM_CTL_PGM   (1<<23) /* program AM */
#define UNIV_LM_CTL_DATA   (1<<22) /* data AM */
#define UNIV_LM_CTL_SUPER   (1<<21) /* supervisor AM */
#define UNIV_LM_CTL_USER   (1<<20) /* user AM */
#define UNIV_LM_CTL_VAS_A16   (0<<16) /* A16 */
#define UNIV_LM_CTL_VAS_A24   (1<<16) /* A16 */
#define UNIV_LM_CTL_VAS_A32   (2<<16) /* A16 */
#define UNIV_REGOFF_LM_BS   0xf68
#define UNIV_REGOFF_VRAI_CTL   0xf70
#define UNIV_VRAI_CTL_EN   (1<<31) /* image enable */
#define UNIV_VRAI_CTL_PGM   (1<<23) /* program AM */
#define UNIV_VRAI_CTL_DATA   (1<<22) /* data AM */
#define UNIV_VRAI_CTL_SUPER   (1<<21) /* supervisor AM */
#define UNIV_VRAI_CTL_USER   (1<<20) /* user AM */
#define UNIV_VRAI_CTL_VAS_A16   (0<<16) /* A16 */
#define UNIV_VRAI_CTL_VAS_A24   (1<<16) /* A14 */
#define UNIV_VRAI_CTL_VAS_A32   (2<<16) /* A32 */
#define UNIV_VRAI_CTL_VAS_MSK   (3<<16)
#define UNIV_REGOFF_VRAI_BS   0xf74
#define UNIV_REGOFF_VCSR_CTL   0xf80
#define UNIV_VCSR_CTL_EN   (1<<31) /* image enable */
#define UNIV_VCSR_CTL_LAS_PCI_MEM   (0<<0) /* pci mem space */
#define UNIV_VCSR_CTL_LAS_PCI_IO   (1<<0) /* pci IO space */
#define UNIV_VCSR_CTL_LAS_PCI_CFG   (2<<0) /* pci config space */
#define UNIV_REGOFF_VCSR_TO   0xf84
#define UNIV_REGOFF_V_AMERR   0xf88
#define UNIV_V_AMERR_AMERR(reg)   (((reg)>>26)&0x3f) /* extract error log code */
#define UNIV_V_AMERR_IACK   (1<<25) /* VMEbus IACK signal */
#define UNIV_V_AMERR_M_ERR   (1<<24) /* multiple errors occurred */
#define UNIV_V_AMERR_V_STAT   (1<<23) /* log status valid (write 1 to clear) */
#define UNIV_REGOFF_VAERR   0xf8c /* address of fault address (if MERR_V_STAT valid) */
#define UNIV_REGOFF_VCSR_CLR   0xff4
#define UNIV_VCSR_CLR_RESET   (1<<31) /* read/negate LRST (can only be written from VME bus */
#define UNIV_VCSR_CLR_SYSFAIL   (1<<30) /* read/negate SYSFAIL */
#define UNIV_VCSR_CLR_FAIL   (1<<29) /* read: board has failed */
#define UNIV_REGOFF_VCSR_SET   (0xff8)
#define UNIV_VCSR_SET_RESET   (1<<31) /* read/assert LRST (can only be written from VME bus */
#define UNIV_VCSR_SET_SYSFAIL   (1<<30) /* read/assert SYSFAIL */
#define UNIV_VCSR_SET_FAIL   (1<<29) /* read: board has failed */
#define UNIV_REGOFF_VCSR_BS   0xffc
#define UNIV_VCSR_BS_MASK   (0xf8000000)
#define UNIV_CSR_OFFSET   0x7f000
typedef unsigned long LERegister
typedef struct VmeUniverseDMAPacketRec_ VmeUniverseDMAPacketRec
typedef struct VmeUniverseDMAPacketRec_ * VmeUniverseDMAPacket
int vmeUniverseInit (void)
void vmeUniverseReset (void)
void vmeUniverseMasterPortsShow (FILE *f)
void vmeUniverseSlavePortsShow (FILE *f)
void vmeUniverseDisableAllMasters (void)
void vmeUniverseDisableAllSlaves (void)
int vmeUniverseMasterPortCfg (unsigned long port, unsigned long address_space, unsigned long vme_address, unsigned long local_address, unsigned long length)
int vmeUniverseXlateAddr (int master, int reverse, unsigned long as, unsigned long addr, unsigned long *paOut)
int vmeUniverseSlavePortCfg (unsigned long port, unsigned long address_space, unsigned long vme_address, unsigned long local_address, unsigned long length)
int vmeUniverseStartDMA (unsigned long local_addr, unsigned long vme_addr, unsigned long count)
int vmeUniverseStartDMAXX (volatile LERegister *ubase, unsigned long local_addr, unsigned long vme_addr, unsigned long count)
unsigned long vmeUniverseReadReg (unsigned long offset)
void vmeUniverseWriteReg (unsigned long value, unsigned long offset)
void vmeUniverseCvtToLE (unsigned long *ptr, unsigned long num)
void vmeUniverseResetBus (void)
unsigned long vmeUniverseReadRegXX (volatile LERegister *ubase, unsigned long offset)
void vmeUniverseWriteRegXX (volatile LERegister *ubase, unsigned long value, unsigned long offset)
int vmeUniverseXlateAddrXX (volatile LERegister *ubase, int master, int reverse, unsigned long as, unsigned long addr, unsigned long *paOut)
int vmeUniverseMasterPortCfgXX (volatile LERegister *ubase, unsigned long port, unsigned long address_space, unsigned long vme_address, unsigned long local_address, unsigned long length)
int vmeUniverseSlavePortCfgXX (volatile LERegister *ubase, unsigned long port, unsigned long address_space, unsigned long vme_address, unsigned long local_address, unsigned long length)
void vmeUniverseDisableAllMastersXX (volatile LERegister *ubase)
void vmeUniverseDisableAllSlavesXX (volatile LERegister *ubase)
void vmeUniverseMasterPortsShowXX (volatile LERegister *ubase, FILE *f)
void vmeUniverseSlavePortsShowXX (volatile LERegister *ubase, FILE *f)
int vmeUniverseIntRaiseXX (volatile LERegister *base, int level, unsigned vector)
int vmeUniverseIntRaise (int level, unsigned vector)
int vmeUniverseMapCRGXX (volatile LERegister *base, unsigned long vme_base, unsigned long address_space)
int vmeUniverseMapCRG (unsigned long vme_base, unsigned long address_space)
volatile LERegister * vmeUniverse0BaseAddr
int vmeUniverse0PciIrqLine
◆ UNIV_DGCS_STATUS_CLEAR
Value:
(UNIV_DGCS_ACT|UNIV_DGCS_STOP|UNIV_DGCS_HALT|\
UNIV_DGCS_DONE|UNIV_DGCS_LERR|UNIV_DGCS_VERR|UNIV_DGCS_P_ERR)
