20 #ifndef LIBBSP_ARM_RASPBERRYPI_VC_H    21 #define LIBBSP_ARM_RASPBERRYPI_VC_H    38 int bcm2835_mailbox_get_display_size(
    42   bcm2835_mailbox_pixel_order_bgr = 0,
    43   bcm2835_mailbox_pixel_order_rgb = 1
    44 } bcm2835_pixel_order;
    47   bcm2835_mailbox_alpha_mode_0_opaque       = 0,
    48   bcm2835_mailbox_alpha_mode_0_transparent  = 1,
    49   bcm2835_mailbox_alpha_mode_ignored        = 2
    58   bcm2835_pixel_order pixel_order;
    59   bcm2835_alpha_mode alpha_mode;
    62   uint32_t overscan_left;
    63   uint32_t overscan_right;
    64   uint32_t overscan_top;
    65   uint32_t overscan_bottom;
    71 int bcm2835_mailbox_init_frame_buffer(
    87   bcm2835_mailbox_power_udid_sd_card = 0x00000000u,
    88   bcm2835_mailbox_power_udid_uart0 = 0x00000001u,
    89   bcm2835_mailbox_power_udid_uart1 = 0x00000002u,
    90   bcm2835_mailbox_power_udid_usb_hcd = 0x00000003u,
    91   bcm2835_mailbox_power_udid_i2c0 = 0x00000004u,
    92   bcm2835_mailbox_power_udid_i2c1 = 0x00000005u,
    93   bcm2835_mailbox_power_udid_i2c2 = 0x00000006u,
    94   bcm2835_mailbox_power_udid_spi = 0x00000007u,
    95   bcm2835_mailbox_power_udid_ccp2tx = 0x00000008u,
    96 } bcm2835_power_device_id;
    99   bcm2835_power_device_id dev_id;
   103 #define BCM2835_MAILBOX_SET_POWER_STATE_REQ_ON ( 1 << 0 )   104 #define BCM2835_MAILBOX_SET_POWER_STATE_REQ_WAIT ( 1 << 1 )   105 #define BCM2835_MAILBOX_POWER_STATE_ON ( 1 << 0 )   106 #define BCM2835_MAILBOX_POWER_STATE_NODEV ( 1 << 1 )   129 int bcm2835_mailbox_get_firmware_revision(
   138 int bcm2835_mailbox_get_board_revision(
   145 #define BCM2835_REVISION_IS_NEW_STYLE(revision) ((revision & (1 << 23)) != 0)   146 #define BCM2835_REVISION_MEMORY_SIZE(revision) ((revision >> 20) & 0x7)   147 #define BCM2835_REVISION_MANUFACTURER(revision) ((revision >> 16) & 0xf)   148 #define BCM2835_REVISION_PROCESSOR(revision) ((revision >> 12) & 0xf)   149 #define BCM2835_REVISION_TYPE(revision) ((revision >> 4) & 0xff)   150 #define BCM2835_REVISION_REVISION(revision) ((revision >> 0) & 0xf)   153   uint64_t board_serial;
   156 int bcm2835_mailbox_get_board_serial(
   164 int bcm2835_mailbox_get_clock_rate(
unsigned size
Definition: tte.h:74
