RTEMS  5.1
elf_machdep.h
1 #define ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB
2
3 #define ELF32_MACHDEP_ID_CASES \
4  case EM_V850: \
5  break;
6
7 #define ELF32_MACHDEP_ID EM_V850
8
9
10
11 #define EF_V850_ARCH 0xf0000000
12 #define E_V850_ARCH 0x00000000
13 #define E_V850E_ARCH 0x10000000
14 #define E_V850E1_ARCH 0x20000000
15 #define E_V850E2_ARCH 0x30000000
16 #define E_V850E2V3_ARCH 0x40000000
17
18 #define ARCH_ELFSIZE 32
19
20
21 #define R_V850_NONE 0
22 #define R_V850_9_PCREL 1
23 #define R_V850_22_PCREL 2
24 #define R_V850_HI16_S 3
25 #define R_V850_HI16 4
26 #define R_V850_LO16 5
27 #define R_V850_ABS32 6
28 #define R_V850_16 7
29 #define R_V850_8 8
30 #define R_V850_SDA_16_16_OFFSET 9
31 #define R_V850_SDA_15_16_OFFSET 10
32 #define R_V850_ZDA_16_16_OFFSET 11
33 #define R_V850_ZDA_15_16_OFFSET 12
34 #define R_V850_TDA_6_8_OFFSET 13
35 #define R_V850_TDA_7_8_OFFSET 14
36 #define R_V850_TDA_7_7_OFFSET 15
37 #define R_V850_TDA_16_16_OFFSET 16
38 #define R_V850_TDA_4_5_OFFSET 17
39 #define R_V850_TDA_4_4_OFFSET 18
40 #define R_V850_SDA_16_16_SPLIT_OFFSET 19
41 #define R_V850_ZDA_16_16_SPLIT_OFFSET 20
42 #define R_V850_CALLT_6_7_OFFSET 21
43 #define R_V850_CALLT_16_16_OFFSET 22
44 #define R_V850_GNU_VTINHERIT 23
45 #define R_V850_GNU_VTENTRY 24
46 #define R_V850_LONGCALL 25
47 #define R_V850_LONGJUMP 26
48 #define R_V850_ALIGN 27
49 #define R_V850_REL32 28
50 #define R_V850_LO16_SPLIT_OFFSET 29
51 #define R_V850_16_PCREL 30
52 #define R_V850_17_PCREL 31
53 #define R_V850_23 32
54 #define R_V850_32_PCREL 33
55 #define R_V850_32_ABS 34
56 #define R_V850_16_SPLIT_OFFSET 35
57 #define R_V850_16_S1 36
58 #define R_V850_LO16_S1 37
59 #define R_V850_CALLT_15_16_OFFSET 38
60 #define R_V850_32_GOTPCREL 39
61 #define R_V850_16_GOT 40
62 #define R_V850_32_GOT 41
63 #define R_V850_22_PLT 42
64 #define R_V850_32_PLT 43
65 #define R_V850_COPY 44
66 #define R_V850_GLOB_DAT 45
67 #define R_V850_JMP_SLOT 46
68 #define R_V850_RELATIVE 47
69 #define R_V850_16_GOTOFF 48
70 #define R_V850_32_GOTOFF 49
71 #define R_V850_CODE 50
72 #define R_V850_DATA 51
73
74 #define R_TYPE(name) __CONCAT(R_V850_,name)
