RTEMS
5.1
Data Fields | |
| struct arpcom | arpcom |
| i596_scp * | pScp |
| i596_scp * | base_scp |
| i596_iscp | iscp |
| i596_scb | scb |
| i596_set_add | set_add |
| i596_configure | set_conf |
| i596_tdr | tdr |
| i596_nop | nop |
| i596_tx * | pTxCmd |
| i596_tbd * | pTbd |
| i596_rfd * | pBeginRFA |
| i596_rfd * | pEndRFA |
| i596_rfd * | pLastUnkRFD |
| i596_rbd * | pLastUnkRBD |
| i596_rfd * | pEndSavedQueue |
| i596_cmd * | pCmdHead |
| i596_cmd * | pCmdTail |
| rtems_id | rxDaemonTid |
| rtems_id | txDaemonTid |
| rtems_id | resetDaemonTid |
| struct enet_statistics | stats |
| int | started |
| unsigned long | rxInterrupts |
| unsigned long | txInterrupts |
| volatile int | cmdOk |
| unsigned short * | pCurrent_command_status |
| int | resetDone |
| unsigned long | txRawWait |
| i596_rfd * | pInboundFrameQueue |
| short int | rxBdCount |
| short int | txBdCount |
| short int | countRFD |
| short int | savedCount |
| i596_rfd * | pSavedRfdQueue |
| rtems_name | semaphore_name |
| rtems_id | semaphore_id |
| char | zeroes [64] |
| unsigned long | rawsndcnt |
| int | nic_reset |
1.8.15
