RTEMS
5.1
Data Fields | |
| rtems_libi2c_bus_t | i2clib_desc |
| struct drvmgr_dev * | dev |
| struct spictrl_regs * | regs |
| int | irq |
| int | minor |
| unsigned int | core_freq_hz |
| int | fdepth |
| int | bits_per_char |
| int | lsb_first |
| int | txshift |
| int | rxshift |
| unsigned int | idle_char |
| int(* | slvSelFunc )(void *regs, uint32_t addr, int select) |
| int | periodic_started |
| struct spictrl_ioctl_config | periodic_cfg |
1.8.15
