RTEMS
5.1
#include <rtems-debugger-server.h>
Data Fields | |
| int | port |
| int | timeout |
| rtems_task_priority | priority |
| rtems_rx_mutex | lock |
| rtems_debugger_remote * | remote |
| rtems_id | server_task |
| rtems_rx_cond | server_cond |
| volatile bool | server_running |
| volatile bool | server_finished |
| rtems_id | events_task |
| volatile bool | events_running |
| volatile bool | events_finished |
| rtems_printer | printer |
| uint32_t | flags |
| pid_t | pid |
| bool | remote_debug |
| bool | ack_pending |
| size_t | output_level |
| uint8_t | input [RTEMS_DEBUGGER_BUFFER_SIZE] |
| uint8_t | output [RTEMS_DEBUGGER_BUFFER_SIZE] |
| rtems_debugger_threads * | threads |
| rtems_chain_control | exception_threads |
| int | signal |
| rtems_debugger_target * | target |
Debugger data.
1.8.15
