struct arpcom | arpcom |
unsigned int | irno |
unsigned int | port |
int | accept_broadcasts |
rtems_id | tx_daemon_tid |
rtems_id | rx_daemon_tid |
bool | byte_transfers |
int | inuse |
int | nextavail |
int | nextsend |
int | transmitting |
int | sendlen [NE_TX_BUFS] |
int | overrun |
int | resend |
struct { |
unsigned long rx_packets |
unsigned long tx_packets |
unsigned long interrupts |
unsigned long rx_acks |
unsigned long tx_acks |
unsigned long overruns |
unsigned long rx_frame_errors |
unsigned long rx_crc_errors |
unsigned long rx_missed_errors |
| } | stats |
struct { |
| } | stats |
The documentation for this struct was generated from the following files:
- bsps/arm/gumstix/net/rtl8019.c
- bsps/i386/pc386/net/ne2000.c
