unsigned char | bf |
unsigned char | config_bytes [11] |
unsigned char | reserved1 [2] |
unsigned char | ia_bytes [6] |
unsigned short | last_tx_status |
unsigned short | tx_crc_byte01 |
unsigned short | tx_crc_byte23 |
unsigned short | rx_crc_byte01 |
unsigned short | rx_crc_byte23 |
unsigned short | rx_temp_mem01 |
unsigned short | rx_temp_mem23 |
unsigned short | rx_temp_mem45 |
unsigned short | last_rx_status |
unsigned short | hash_reg01 |
unsigned short | hash_reg23 |
unsigned short | hash_reg45 |
unsigned short | hash_reg67 |
unsigned short | slot_time_counter |
unsigned short | wait_time_counter |
unsigned short | rx_frame_length |
unsigned long | reserved2 |
unsigned long | cb_in3 |
unsigned long | cb_in2 |
unsigned long | cb_in1 |
unsigned long | la_cb_addr |
unsigned long | rdb_pointer |
unsigned long | int_memory |
unsigned long | rfd_size |
unsigned long | tbd_pointer |
unsigned long | base_addr |
unsigned long | ru_temp_reg |
unsigned long | tcb_count |
unsigned long | next_rb_size |
unsigned long | next_rb_addr |
unsigned long | curr_rb_size |
unsigned long | la_rbd_addr |
unsigned long | next_rbd_addr |
unsigned long | curr_rbd_addr |
unsigned long | curr_rb_count |
unsigned long | next_fd_addr |
unsigned long | curr_fd_add |
unsigned long | temp_cu_reg |
unsigned long | next_tb_count |
unsigned long | buffer_addr |
unsigned long | la_tbd_addr |
unsigned long | next_tbd_addr |
unsigned long | cb_command |
unsigned long | next_cb_addr |
unsigned long | curr_cb_addr |
unsigned long | scb_cmd_word |
unsigned long | scb_pointer |
unsigned long | cb_stat_word |
unsigned long | mm_lfsr |
unsigned char | micro_machine_bit_array [28] |
unsigned char | cu_port [16] |
unsigned long | mm_alu |
unsigned long | reserved3 |
unsigned long | mm_temp_a_rr |
unsigned long | mm_temp_a |
unsigned long | tx_dma_b_cnt |
unsigned long | mm_input_port_addr_reg |
unsigned long | tx_dma_addr |
unsigned long | mm_port_reg1 |
unsigned long | rx_dma_b_cnt |
unsigned long | mm_port_reg2 |
unsigned long | rx_dma_addr |
unsigned long | reserved4 |
unsigned long | bus_t_timers |
unsigned long | diu_cntrl_reg |
unsigned long | reserved5 |
unsigned long | sysbus |
unsigned long | biu_cntrl_reg |
unsigned long | mm_disp_reg |
unsigned long | mm_status_reg |
unsigned short | dump_status |
