struct drvmgr_dev * | dev |
char | devName [32] |
LEON3_SPACEWIRE_Regs_Map * | regs |
spw_config | config |
unsigned int | tx_all_in_use |
unsigned int | tx_sent |
unsigned int | tx_cur |
unsigned int | rxcur |
unsigned int | rxbufcur |
unsigned int | txdbufsize |
unsigned int | txhbufsize |
unsigned int | rxbufsize |
unsigned int | txbufcnt |
unsigned int | rxbufcnt |
unsigned int | rx_dma_area |
unsigned int | tx_data_dma_area |
unsigned int | tx_hdr_dma_area |
unsigned int | bd_dma_area |
spw_stats | stat |
unsigned int | _ptr_rxbuf0 |
char * | ptr_rxbuf0 |
char * | ptr_txdbuf0 |
char * | ptr_txhbuf0 |
char * | _ptr_bd0 |
char * | ptr_bd0 |
char * | ptr_rxbuf0_remote |
char * | ptr_txdbuf0_remote |
char * | ptr_txhbuf0_remote |
char * | ptr_bd0_remote |
unsigned int | irq |
int | minor |
int | core_ver |
int | open |
int | running |
unsigned int | core_freq_khz |
unsigned int | rtimeout |
rtems_id | txsp |
rtems_id | rxsp |
SPACEWIRE_RXBD * | rx |
SPACEWIRE_TXBD * | tx |
unsigned int | rx_remote |
unsigned int | tx_remote |
- bsps/shared/grlib/spw/grspw.c
