23 #ifndef _UAPI_LINUX_SPI_H    24 #define _UAPI_LINUX_SPI_H    26 #include <sys/ioccom.h>    70 #define SPI_MODE_1 SPI_CPHA    76 #define SPI_MODE_2 SPI_CPOL    82 #define SPI_MODE_3 (SPI_CPOL | SPI_CPHA)    88 #define SPI_CS_HIGH 0x04    94 #define SPI_LSB_FIRST 0x08   100 #define SPI_3WIRE 0x10   105 #define SPI_LOOP 0x20   111 #define SPI_NO_CS 0x40   116 #define SPI_READY 0x80   121 #define SPI_TX_DUAL 0x100   126 #define SPI_TX_QUAD 0x200   131 #define SPI_RX_DUAL 0x400   136 #define SPI_RX_QUAD 0x800   140 #define SPI_IOC_MAGIC 's'   208 #define SPI_MSGSIZE(n) \   209   (((n) * sizeof(struct spi_ioc_transfer) < IOCPARM_MAX) ? \   210     (n) * sizeof(struct spi_ioc_transfer) : 0)   215 #define SPI_IOC_MESSAGE(n) _IOW(SPI_IOC_MAGIC, 0, char[SPI_MSGSIZE(n)])   220 #define SPI_IOC_RD_MODE _IOR(SPI_IOC_MAGIC, 1, uint8_t)   226 #define SPI_IOC_WR_MODE _IOW(SPI_IOC_MAGIC, 1, uint8_t)   231 #define SPI_IOC_RD_LSB_FIRST _IOR(SPI_IOC_MAGIC, 2, uint8_t)   236 #define SPI_IOC_WR_LSB_FIRST _IOW(SPI_IOC_MAGIC, 2, uint8_t)   241 #define SPI_IOC_RD_BITS_PER_WORD _IOR(SPI_IOC_MAGIC, 3, uint8_t)   246 #define SPI_IOC_WR_BITS_PER_WORD _IOW(SPI_IOC_MAGIC, 3, uint8_t)   251 #define SPI_IOC_RD_MAX_SPEED_HZ _IOR(SPI_IOC_MAGIC, 4, uint32_t)   256 #define SPI_IOC_WR_MAX_SPEED_HZ _IOW(SPI_IOC_MAGIC, 4, uint32_t)   261 #define SPI_IOC_RD_MODE32 _IOR(SPI_IOC_MAGIC, 5, uint32_t)   266 #define SPI_IOC_WR_MODE32 _IOW(SPI_IOC_MAGIC, 5, uint32_t) uint16_t delay_usecs
Sets the delay after a transfer before the chip select status is changed and the next transfer is tri...
Definition: spidev.h:170
uint8_t cs
Indicates which device is currently used.
Definition: spidev.h:202
SPI transfer message.
Definition: spidev.h:145
void * rx_buf
Buffer for receive data.
Definition: spidev.h:149
const void * tx_buf
Buffer for transmit data.
Definition: spidev.h:154
uint32_t speed_hz
Sets the bit-rate of the device.
Definition: spidev.h:164
uint8_t tx_nbits
Amount of bits that are used for writing.
Definition: spidev.h:191
uint32_t mode
Sets one of the possible modes that can be used for SPI transfers (dependent on clock phase and polar...
Definition: spidev.h:197
uint8_t rx_nbits
Amount of bits that are used for reading.
Definition: spidev.h:186
size_t len
Length of receive and transmit buffers in bytes.
Definition: spidev.h:159
uint8_t cs_change
If true, device is deselected after transfer ended and before a new transfer is started.
Definition: spidev.h:181
uint8_t bits_per_word
Sets the device wordsize.
Definition: spidev.h:175
