RTEMS  5.1
elf_machdep.h
1 /* $NetBSD: elf_machdep.h,v 1.7 2009/05/30 05:56:53 skrll Exp $ */
2
3 #define ELF32_MACHDEP_ENDIANNESS ELFDATA2MSB
4 #define ELF32_MACHDEP_ID_CASES \
5  case EM_SPARC: \
6  case EM_SPARC32PLUS: \
7  break;
8
9 #define ELF64_MACHDEP_ENDIANNESS ELFDATA2MSB
10 #define ELF64_MACHDEP_ID_CASES \
11  case EM_SPARC32PLUS: \
12  case EM_SPARCV9: \
13  /* no 64-bit ELF machine types supported */
14
15 #define ELF32_MACHDEP_ID EM_SPARC /* XXX right? */
16
17 #define ARCH_ELFSIZE 32 /* MD native binary size */
18
19 #define R_SPARC_NONE 0
20 #define R_SPARC_8 1
21 #define R_SPARC_16 2
22 #define R_SPARC_32 3
23 #define R_SPARC_DISP8 4
24 #define R_SPARC_DISP16 5
25 #define R_SPARC_DISP32 6
26 #define R_SPARC_WDISP30 7
27 #define R_SPARC_WDISP22 8
28 #define R_SPARC_HI22 9
29 #define R_SPARC_22 10
30 #define R_SPARC_13 11
31 #define R_SPARC_LO10 12
32 #define R_SPARC_GOT10 13
33 #define R_SPARC_GOT13 14
34 #define R_SPARC_GOT22 15
35 #define R_SPARC_PC10 16
36 #define R_SPARC_PC22 17
37 #define R_SPARC_WPLT30 18
38 #define R_SPARC_COPY 19
39 #define R_SPARC_GLOB_DAT 20
40 #define R_SPARC_JMP_SLOT 21
41 #define R_SPARC_RELATIVE 22
42 #define R_SPARC_UA32 23
43 #define R_SPARC_PLT32 24
44 #define R_SPARC_HIPLT22 25
45 #define R_SPARC_LOPLT10 26
46 #define R_SPARC_PCPLT32 27
47 #define R_SPARC_PCPLT22 28
48 #define R_SPARC_PCPLT10 29
49 #define R_SPARC_10 30
50 #define R_SPARC_11 31
51 #define R_SPARC_64 32
52 #define R_SPARC_OLO10 33
53 #define R_SPARC_HH22 34
54 #define R_SPARC_HM10 35
55 #define R_SPARC_LM22 36
56 #define R_SPARC_PC_HH22 37
57 #define R_SPARC_PC_HM10 38
58 #define R_SPARC_PC_LM22 39
59 #define R_SPARC_WDISP16 40
60 #define R_SPARC_WDISP19 41
61 #define R_SPARC_GLOB_JMP 42
62 #define R_SPARC_7 43
63 #define R_SPARC_5 44
64 #define R_SPARC_6 45
65
66 /* TLS relocations */
67 #define R_SPARC_TLS_GD_HI22 56
68 #define R_SPARC_TLS_GD_LO10 57
69 #define R_SPARC_TLS_GD_ADD 58
70 #define R_SPARC_TLS_GD_CALL 59
71 #define R_SPARC_TLS_LDM_HI22 60
72 #define R_SPARC_TLS_LDM_LO10 61
73 #define R_SPARC_TLS_LDM_ADD 62
74 #define R_SPARC_TLS_LDM_CALL 63
75 #define R_SPARC_TLS_LDO_HIX22 64
76 #define R_SPARC_TLS_LDO_LOX10 65
77 #define R_SPARC_TLS_LDO_ADD 66
78 #define R_SPARC_TLS_IE_HI22 67
79 #define R_SPARC_TLS_IE_LO10 68
80 #define R_SPARC_TLS_IE_LD 69
81 #define R_SPARC_TLS_IE_LDX 70
82 #define R_SPARC_TLS_IE_ADD 71
83 #define R_SPARC_TLS_LE_HIX22 72
84 #define R_SPARC_TLS_LE_LOX10 73
85 #define R_SPARC_TLS_DTPMOD32 74
86 #define R_SPARC_TLS_DTPMOD64 75
87 #define R_SPARC_TLS_DTPOFF32 76
88 #define R_SPARC_TLS_DTPOFF64 77
89 #define R_SPARC_TLS_TPOFF32 78
90 #define R_SPARC_TLS_TPOFF64 79
91
92 #define R_TYPE(name) __CONCAT(R_SPARC_,name)
