RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
sparc64
include
arch
mm
sun4u
mmu.h
1
2
* Copyright (c) 2005 Jakub Jermar
3
* All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
9
* - Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* - Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
* - The name of the author may not be used to endorse or promote products
15
* derived from this software without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
18
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
19
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
20
* IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
21
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
22
* NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
23
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
24
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
26
* THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27
28
35
#ifndef KERN_sparc64_sun4u_MMU_H_
36
#define KERN_sparc64_sun4u_MMU_H_
37
38
#if defined(US)
39
/* LSU Control Register ASI. */
40
#define ASI_LSU_CONTROL_REG 0x45
41
#endif
42
43
/* I-MMU ASIs. */
44
#define ASI_IMMU 0x50
45
#define ASI_IMMU_TSB_8KB_PTR_REG 0x51
46
#define ASI_IMMU_TSB_64KB_PTR_REG 0x52
47
#define ASI_ITLB_DATA_IN_REG 0x54
48
#define ASI_ITLB_DATA_ACCESS_REG 0x55
49
#define ASI_ITLB_TAG_READ_REG 0x56
50
#define ASI_IMMU_DEMAP 0x57
51
52
/* Virtual Addresses within ASI_IMMU. */
53
#define VA_IMMU_TSB_TAG_TARGET 0x0
54
#define VA_IMMU_SFSR 0x18
55
#define VA_IMMU_TSB_BASE 0x28
56
#define VA_IMMU_TAG_ACCESS 0x30
57
#if defined (US3)
58
#define VA_IMMU_PRIMARY_EXTENSION 0x48
59
#define VA_IMMU_NUCLEUS_EXTENSION 0x58
60
#endif
61
62
63
/* D-MMU ASIs. */
64
#define ASI_DMMU 0x58
65
#define ASI_DMMU_TSB_8KB_PTR_REG 0x59
66
#define ASI_DMMU_TSB_64KB_PTR_REG 0x5a
67
#define ASI_DMMU_TSB_DIRECT_PTR_REG 0x5b
68
#define ASI_DTLB_DATA_IN_REG 0x5c
69
#define ASI_DTLB_DATA_ACCESS_REG 0x5d
70
#define ASI_DTLB_TAG_READ_REG 0x5e
71
#define ASI_DMMU_DEMAP 0x5f
72
73
/* Virtual Addresses within ASI_DMMU. */
74
#define VA_DMMU_TSB_TAG_TARGET 0x0
75
#define VA_PRIMARY_CONTEXT_REG 0x8
76
#define VA_SECONDARY_CONTEXT_REG 0x10
77
#define VA_DMMU_SFSR 0x18
78
#define VA_DMMU_SFAR 0x20
79
#define VA_DMMU_TSB_BASE 0x28
80
#define VA_DMMU_TAG_ACCESS 0x30
81
#define VA_DMMU_VA_WATCHPOINT_REG 0x38
82
#define VA_DMMU_PA_WATCHPOINT_REG 0x40
83
#if defined (US3)
84
#define VA_DMMU_PRIMARY_EXTENSION 0x48
85
#define VA_DMMU_SECONDARY_EXTENSION 0x50
86
#define VA_DMMU_NUCLEUS_EXTENSION 0x58
87
#endif
88
89
#ifndef __ASM__
90
91
#include <arch/asm.h>
92
#include <arch/barrier.h>
93
#include <arch/types.h>
94
95
#if defined(US)
96
97
typedef
union
98
uint64_t value;
99
struct
100
unsigned : 23;
101
unsigned
pm : 8;
102
unsigned
vm : 8;
103
unsigned
pr
: 1;
104
unsigned
pw : 1;
105
unsigned
vr : 1;
106
unsigned
vw : 1;
107
unsigned : 1;
108
unsigned
fm : 16;
109
unsigned
dm : 1;
110
unsigned
im : 1;
111
unsigned
dc : 1;
112
unsigned
ic : 1;
114
__attribute__
((packed));
115
} lsu_cr_reg_t;
116
#endif
/* US */
117
118
#endif
/* !def __ASM__ */
119
120
#endif
121
pr
unsigned pr
Definition:
tlb.h:225
__attribute__
typedef __attribute__
Disable IRQ Interrupts.
Definition:
cmsis_gcc.h:69
