23 #ifndef _DEV_I2C_SENSOR_LM75A_H    24 #define _DEV_I2C_SENSOR_LM75A_H    42 int i2c_dev_register_sensor_lm75a(
    50   SENSOR_LM75A_SET_CONF,
    51   SENSOR_LM75A_CLEAR_AND_SET_CONF,
    52   SENSOR_LM75A_GET_TEMP,
    55   SENSOR_LM75A_GET_THYST,
    56   SENSOR_LM75A_SET_THYST
    57 } sensor_lm75a_command;
    59 static inline int sensor_lm75a_get_conf(
int fd, uint8_t *val)
    61   return ioctl(fd, SENSOR_LM75A_GET_CONF, val);
    64 static inline int sensor_lm75a_set_conf(
int fd, uint8_t val)
    66   return ioctl(fd, SENSOR_LM75A_SET_CONF, (
void *)(uintptr_t) val);
    69 static inline int sensor_lm75a_clear_and_set_conf(
    75   uint16_t clear_and_set = (uint16_t) (((uint16_t) set << 8) | clear);
    79     SENSOR_LM75A_CLEAR_AND_SET_CONF,
    80     (
void *)(uintptr_t) clear_and_set
    84 static inline int sensor_lm75a_get_temp(
int fd, int16_t *val)
    86   return ioctl(fd, SENSOR_LM75A_GET_TEMP, val);
    89 static inline int sensor_lm75a_get_temp_celsius(
int fd,
double *celsius)
    94   rv = ioctl(fd, SENSOR_LM75A_GET_TEMP, &val);
    95   *celsius = (((int) val) >> 5) * 0.125;
    99 static inline int sensor_lm75a_get_tos(
int fd, uint16_t *val)
   101   return ioctl(fd, SENSOR_LM75A_GET_TOS, val);
   104 static inline int sensor_lm75a_set_tos(
int fd, uint16_t val)
   106   return ioctl(fd, SENSOR_LM75A_SET_TOS, (
   109 static inline int sensor_lm75a_get_thyst(
   111   return ioctl(fd, SENSOR_LM75A_GET_THYST, val);
   114 static inline int sensor_lm75a_set_thyst(
   116   return ioctl(fd, SENSOR_LM75A_SET_THYST, (
 #define I2C_DEV_IO_CONTROL
Base number for device IO control commands.
Definition: i2c.h:287
Inter-Integrated Circuit (I2C) Driver API.
