#define  | SED1356_REG_REV_and_MISC   SED_REG16(0x00) |
#define  | SED1356_REG_GPIO_CFG   SED_REG16(0x04) |
#define  | SED1356_REG_GPIO_CTL   SED_REG16(0x08) |
#define  | SED1356_REG_MD_CFG_RD_LO_and_HI   SED_REG16(0x0c) |
#define  | SED1356_REG_MCLK_CFG   SED_REG16(0x10) |
#define  | SED1356_REG_LCD_PCLK_CFG   SED_REG16(0x14) |
#define  | SED1356_REG_CRT_PCLK_CFG   SED_REG16(0x18) |
#define  | SED1356_REG_MEDIA_PCLK_CFG   SED_REG16(0x1c) |
#define  | SED1356_REG_WAIT_STATE   SED_REG16(0x1e) |
#define  | SED1356_REG_MEM_CFG_and_REF_RATE   SED_REG16(0x20) |
#define  | SED1356_REG_MEM_TMG0_and_1   SED_REG16(0x2a) |
#define  | SED1356_REG_PANEL_TYPE_and_MOD_RATE   SED_REG16(0x30) |
#define  | SED1356_REG_LCD_HOR_DISP   SED_REG16(0x32) |
#define  | SED1356_REG_LCD_HOR_NONDISP_and_START   SED_REG16(0x34) |
#define  | SED1356_REG_LCD_HOR_PULSE   SED_REG16(0x36) |
#define  | SED1356_REG_LCD_VER_DISP_HT_LO_and_HI   SED_REG16(0x38) |
#define  | SED1356_REG_LCD_VER_NONDISP_and_START   SED_REG16(0x3a) |
#define  | SED1356_REG_LCD_VER_PULSE   SED_REG16(0x3c) |
#define  | SED1356_REG_LCD_DISP_MODE_and_MISC   SED_REG16(0x40) |
#define  | SED1356_REG_LCD_DISP_START_LO_and_MID   SED_REG16(0x42) |
#define  | SED1356_REG_LCD_DISP_START_HI   SED_REG16(0x44) |
#define  | SED1356_REG_LCD_ADD_OFFSET_LO_and_HI   SED_REG16(0x46) |
#define  | SED1356_REG_LCD_PIXEL_PAN   SED_REG16(0x48) |
#define  | SED1356_REG_LCD_FIFO_THRESH_LO_and_HI   SED_REG16(0x4a) |
#define  | SED1356_REG_CRT_HOR_DISP   SED_REG16(0x50) |
#define  | SED1356_REG_CRT_HOR_NONDISP_and_START   SED_REG16(0x52) |
#define  | SED1356_REG_CRT_HOR_PULSE   SED_REG16(0x54) |
#define  | SED1356_REG_CRT_VER_DISP_HT_LO_and_HI   SED_REG16(0x56) |
#define  | SED1356_REG_CRT_VER_NONDISP_and_START   SED_REG16(0x58) |
#define  | SED1356_REG_CRT_VER_PULSE_and_OUT_CTL   SED_REG16(0x5a) |
#define  | SED1356_REG_CRT_DISP_MODE   SED_REG16(0x60) |
#define  | SED1356_REG_CRT_DISP_START_LO_and_MID   SED_REG16(0x62) |
#define  | SED1356_REG_CRT_DISP_START_HI   SED_REG16(0x64) |
#define  | SED1356_REG_CRT_ADD_OFFSET_LO_and_HI   SED_REG16(0x66) |
#define  | SED1356_REG_CRT_PIXEL_PAN   SED_REG16(0x68) |
#define  | SED1356_REG_CRT_FIFO_THRESH_LO_and_HI   SED_REG16(0x6a) |
#define  | SED1356_REG_LCD_CURSOR_CTL_and_START_ADD   SED_REG16(0x70) |
#define  | SED1356_REG_LCD_CURSOR_X_POS_LO_and_HI   SED_REG16(0x72) |
#define  | SED1356_REG_LCD_CURSOR_Y_POS_LO_and_HI   SED_REG16(0x74) |
#define  | SED1356_REG_LCD_CURSOR_BLUE_and_GREEN_CLR_0   SED_REG16(0x76) |
#define  | SED1356_REG_LCD_CURSOR_RED_CLR_0   SED_REG16(0x78) |
#define  | SED1356_REG_LCD_CURSOR_BLUE_and_GREEN_CLR_1   SED_REG16(0x7a) |
#define  | SED1356_REG_LCD_CURSOR_RED_CLR_1   SED_REG16(0x7c) |
#define  | SED1356_REG_LCD_CURSOR_FIFO_THRESH   SED_REG16(0x7e) |
#define  | SED1356_REG_CRT_CURSOR_CTL_and_START_ADD   SED_REG16(0x80) |
#define  | SED1356_REG_CRT_CURSOR_X_POS_LO_and_HI   SED_REG16(0x82) |
#define  | SED1356_REG_CRT_CURSOR_Y_POS_LO_and_HI   SED_REG16(0x84) |
#define  | SED1356_REG_CRT_CURSOR_BLUE_and_GREEN_CLR_0   SED_REG16(0x86) |
#define  | SED1356_REG_CRT_CURSOR_RED_CLR_0   SED_REG16(0x88) |
#define  | SED1356_REG_CRT_CURSOR_BLUE_and_GREEN_CLR_1   SED_REG16(0x8a) |
#define  | SED1356_REG_CRT_CURSOR_RED_CLR_1   SED_REG16(0x8c) |
#define  | SED1356_REG_CRT_CURSOR_FIFO_THRESH   SED_REG16(0x8e) |
#define  | SED1356_REG_BLT_CTL_0_and_1   SED_REG16(0x100) |
#define  | SED1356_REG_BLT_ROP_CODE_and_BLT_OP   SED_REG16(0x102) |
#define  | SED1356_REG_BLT_SRC_START_LO_and_MID   SED_REG16(0x104) |
#define  | SED1356_REG_BLT_SRC_START_HI   SED_REG16(0x106) |
#define  | SED1356_REG_BLT_DEST_START_LO_and_MID   SED_REG16(0x108) |
#define  | SED1356_REG_BLT_DEST_START_HI   SED_REG16(0x10a) |
#define  | SED1356_REG_BLT_ADD_OFFSET_LO_and_HI   SED_REG16(0x10c) |
#define  | SED1356_REG_BLT_WID_LO_and_HI   SED_REG16(0x110) |
#define  | SED1356_REG_BLT_HGT_LO_and_HI   SED_REG16(0x112) |
#define  | SED1356_REG_BLT_BG_CLR_LO_and_HI   SED_REG16(0x114) |
#define  | SED1356_REG_BLT_FG_CLR_LO_and_HI   SED_REG16(0x118) |
#define  | SED1356_REG_LUT_MODE   SED_REG16(0x1e0) |
#define  | SED1356_REG_LUT_ADD   SED_REG16(0x1e2) |
#define  | SED1356_REG_LUT_DATA   SED_REG16(0x1e4) |
#define  | SED1356_REG_PWR_CFG_and_STAT   SED_REG16(0x1f0) |
#define  | SED1356_REG_WATCHDOG_CTL   SED_REG16(0x1f4) |
#define  | SED1356_REG_DISP_MODE   SED_REG16(0x1fc) |
#define  | SED1356_REV_ID_MASK   0xfc /* ID bits - masks off the rev bits */ |
#define  | SED1356_REV_ID_1356   BIT4 |
#define  | SED1356_REV_ID_1355   BIT3 |
#define  | SED1356_MISC_HOST_DIS   BIT7 << 8  /* 0 = enable host access, 1 = disable */ |
#define  | SED1356_GPIO_GPIO3   BIT3    /* 0 = input, 1 = output, if configured as GPIO */ |
#define  | SED1356_GPIO_GPIO2   BIT2 |
#define  | SED1356_GPIO_GPIO1   BIT1 |
#define  | SED1356_MCLK_DIV2   BIT4 |
#define  | SED1356_MCLK_SRC_BCLK   BIT0 |
#define  | SED1356_MCLK_SRC_CLKI   0x00 |
#define  | SED1356_PCLK_X2   BIT7    /* SED1356_REG_CRT_PCLK_CFG only */ |
#define  | SED1356_PCLK_DIV1   0x00 << 4 |
#define  | SED1356_PCLK_DIV2   0x01 << 4 |
#define  | SED1356_PCLK_DIV3   0x02 << 4 |
#define  | SED1356_PCLK_DIV4   0x03 << 4 |
#define  | SED1356_PCLK_SRC_CLKI   0x00 |
#define  | SED1356_PCLK_SRC_BCLK   0x01 |
#define  | SED1356_PCLK_SRC_CLKI2   0x02 |
#define  | SED1356_PCLK_SRC_MCLK   0x03 |
#define  | SED1356_MEM_CFG_2CAS_EDO   0x00 |
#define  | SED1356_MEM_CFG_2CAS_FPM   0x01 |
#define  | SED1356_MEM_CFG_2WE_EDO   0x02 |
#define  | SED1356_MEM_CFG_2WE_FPM   0x03 |
#define  | SED1356_MEM_CFG_MASK   0x03 |
#define  | SED1356_REF_TYPE_CBR   0x00 << 6 << 8 |
#define  | SED1356_REF_TYPE_SELF   0x01 << 6 << 8 |
#define  | SED1356_REF_TYPE_NONE   0x02 << 6 << 8 |
#define  | SED1356_REF_TYPE_MASK   0x03 << 6 << 8 |
#define  | SED1356_REF_RATE_64   0x00 << 0 << 8  /* MCLK / 64 */ |
#define  | SED1356_REF_RATE_128   0x01 << 0 << 8  /* MCLK / 128 */ |
#define  | SED1356_REF_RATE_256   0x02 << 0 << 8  /* MCLK / 256 */ |
#define  | SED1356_REF_RATE_512   0x03 << 0 << 8  /* MCLK / 512 */ |
#define  | SED1356_REF_RATE_1024   0x04 << 0 << 8  /* MCLK / 1024 */ |
#define  | SED1356_REF_RATE_2048   0x05 << 0 << 8  /* MCLK / 2048 */ |
#define  | SED1356_REF_RATE_4096   0x06 << 0 << 8  /* MCLK / 4096 */ |
#define  | SED1356_REF_RATE_8192   0x07 << 0 << 8  /* MCLK / 8192 */ |
#define  | SED1356_REF_RATE_MASK   0x07 << 0 << 8  /* MCLK / 8192 */ |
#define  | SED1356_MEM_TMG0_EDO50_MCLK40   0x01 |
#define  | SED1356_MEM_TMG0_EDO50_MCLK33   0x01 |
#define  | SED1356_MEM_TMG0_EDO60_MCLK33   0x01 |
#define  | SED1356_MEM_TMG0_EDO50_MCLK30   0x12 |
#define  | SED1356_MEM_TMG0_EDO60_MCLK30   0x01 |
#define  | SED1356_MEM_TMG0_EDO70_MCLK30   0x00 |
#define  | SED1356_MEM_TMG0_EDO50_MCLK25   0x12 |
#define  | SED1356_MEM_TMG0_EDO60_MCLK25   0x12 |
#define  | SED1356_MEM_TMG0_EDO70_MCLK25   0x01 |
#define  | SED1356_MEM_TMG0_EDO80_MCLK25   0x00 |
#define  | SED1356_MEM_TMG0_EDO50_MCLK20   0x12 |
#define  | SED1356_MEM_TMG0_EDO60_MCLK20   0x12 |
#define  | SED1356_MEM_TMG0_EDO70_MCLK20   0x12 |
#define  | SED1356_MEM_TMG0_EDO80_MCLK20   0x01 |
#define  | SED1356_MEM_TMG0_FPM50_MCLK25   0x12 |
#define  | SED1356_MEM_TMG0_FPM60_MCLK25   0x01 |
#define  | SED1356_MEM_TMG0_FPM50_MCLK20   0x12 |
#define  | SED1356_MEM_TMG0_FPM60_MCLK20   0x12 |
#define  | SED1356_MEM_TMG0_FPM70_MCLK20   0x11 |
#define  | SED1356_MEM_TMG0_FPM80_MCLK20   0x01 |
#define  | SED1356_MEM_TMG1_EDO50_MCLK40   0x01 << 8 |
#define  | SED1356_MEM_TMG1_EDO50_MCLK33   0x01 << 8 |
#define  | SED1356_MEM_TMG1_EDO60_MCLK33   0x01 << 8 |
#define  | SED1356_MEM_TMG1_EDO50_MCLK30   0x02 << 8 |
#define  | SED1356_MEM_TMG1_EDO60_MCLK30   0x01 << 8 |
#define  | SED1356_MEM_TMG1_EDO70_MCLK30   0x00 << 8 |
#define  | SED1356_MEM_TMG1_EDO50_MCLK25   0x02 << 8 |
#define  | SED1356_MEM_TMG1_EDO60_MCLK25   0x02 << 8 |
#define  | SED1356_MEM_TMG1_EDO70_MCLK25   0x01 << 8 |
#define  | SED1356_MEM_TMG1_EDO80_MCLK25   0x01 << 8 |
#define  | SED1356_MEM_TMG1_EDO50_MCLK20   0x02 << 8 |
#define  | SED1356_MEM_TMG1_EDO60_MCLK20   0x02 << 8 |
#define  | SED1356_MEM_TMG1_EDO70_MCLK20   0x02 << 8 |
#define  | SED1356_MEM_TMG1_EDO80_MCLK20   0x01 << 8 |
#define  | SED1356_MEM_TMG1_FPM50_MCLK25   0x02 << 8 |
#define  | SED1356_MEM_TMG1_FPM60_MCLK25   0x01 << 8 |
#define  | SED1356_MEM_TMG1_FPM50_MCLK20   0x02 << 8 |
#define  | SED1356_MEM_TMG1_FPM60_MCLK20   0x02 << 8 |
#define  | SED1356_MEM_TMG1_FPM70_MCLK20   0x02 << 8 |
#define  | SED1356_MEM_TMG1_FPM80_MCLK20   0x01 << 8 |
#define  | SED1356_PANEL_TYPE_EL   BIT7 |
#define  | SED1356_PANEL_TYPE_4_9   (0x00 << 4)    /* Passive 4-Bit, TFT 9-Bit */ |
#define  | SED1356_PANEL_TYPE_8_12   (0x01 << 4)    /* Passive 8-Bit, TFT 12-Bit */ |
#define  | SED1356_PANEL_TYPE_16   (0x02 << 4)    /* Passive 16-Bit, or TFT 18-Bit */ |
#define  | SED1356_PANEL_TYPE_MASK   (0x03 << 4) |
#define  | SED1356_PANEL_TYPE_FMT   BIT3      /* 0 = Passive Format 1, 1 = Passive Format 2 */ |
#define  | SED1356_PANEL_TYPE_CLR   BIT2      /* 0 = Passive Mono, 1 = Passive Color */ |
#define  | SED1356_PANEL_TYPE_DUAL   BIT1      /* 0 = Passive Single, 1 = Passive Dual */ |
#define  | SED1356_PANEL_TYPE_TFT   BIT0      /* 0 = Passive, 1 = TFT (DUAL, FMT & CLR are don't cares) */ |
#define  | SED1356_PULSE_POL_HIGH   BIT7      /* 0 = CRT/TFT Pulse is Low, Passive is High, 1 = CRT/TFT Pulse is High, Passive is Low */ |
#define  | SED1356_PULSE_POL_LOW   0x00      /* 0 = CRT/TFT Pulse is Low, Passive is High, 1 = CRT/TFT Pulse is High, Passive is Low */ |
#define  | SED1356_PULSE_WID(_x_)   (_x_ & 0x0f)  /* Pulse Width in Pixels */ |
#define  | SED1356_LCD_DISP_BLANK   BIT7      /* 1 = Blank LCD Display */ |
#define  | SED1356_LCD_DISP_SWIV_NORM   (0x00 << 4)    /* Used with SED1356_REG_DISP_MODE Bit 6 */ |
#define  | SED1356_LCD_DISP_SWIV_90   (0x00 << 4) |
#define  | SED1356_LCD_DISP_SWIV_180   (0x01 << 4) |
#define  | SED1356_LCD_DISP_SWIV_270   (0x01 << 4) |
#define  | SED1356_LCD_DISP_SWIV_MASK   (0x01 << 4) |
#define  | SED1356_LCD_DISP_16BPP   0x05      /* Bit Per Pixel Selection */ |
#define  | SED1356_LCD_DISP_15BPP   0x04 |
#define  | SED1356_LCD_DISP_8BPP   0x03 |
#define  | SED1356_LCD_DISP_4BPP   0x02 |
#define  | SED1356_LCD_DISP_BPP_MASK   0x07 |
#define  | SED1356_LCD_MISC_DITH   BIT1 << 8    /* 1 = Dither Disable, Passive Panel Only */ |
#define  | SED1356_LCD_MISC_DUAL   BIT0 << 8    /* 1 = Dual Panel Disable, Passive Panel Only */ |
#define  | SED1356_CRT_OUT_CHROM   BIT5 << 8    /* 1 = TV Chrominance Filter Enable */ |
#define  | SED1356_CRT_OUT_LUM   BIT4 << 8    /* 1 = TV Luminance Filter Enable */ |
#define  | SED1356_CRT_OUT_DAC_LVL   BIT3 << 8    /* 1 = 4.6ma IREF, 0 = 9.2 IREF */ |
#define  | SED1356_CRT_OUT_SVIDEO   BIT1 << 8    /* 1 = S-Video Output, 0 = Composite Video Output */ |
#define  | SED1356_CRT_OUT_PAL   BIT0 << 8    /* 1 = PAL Format Output, 0 = NTSC Format Output */ |
#define  | SED1356_CRT_DISP_BLANK   BIT7      /* 1 = Blank CRT Display */ |
#define  | SED1356_CRT_DISP_16BPP   0x05      /* Bit Per Pixel Selection */ |
#define  | SED1356_CRT_DISP_15BPP   0x04 |
#define  | SED1356_CRT_DISP_8BPP   0x03 |
#define  | SED1356_CRT_DISP_4BPP   0x02 |
#define  | SED1356_CRT_DISP_BPP_MASK   0x07 |
#define  | SED1356_DISP_SWIV_NORM   (0x00 << 6)    /* Used with SED1356_LCD_DISP_MODE Bit 4 */ |
#define  | SED1356_DISP_SWIV_90   (0x01 << 6) |
#define  | SED1356_DISP_SWIV_180   (0x00 << 6) |
#define  | SED1356_DISP_SWIV_270   (0x01 << 6) |
#define  | SED1356_DISP_MODE_OFF   0x00      /* All Displays Off */ |
#define  | SED1356_DISP_MODE_LCD   0x01      /* LCD Only */ |
#define  | SED1356_DISP_MODE_CRT   0x02      /* CRT Only */ |
#define  | SED1356_DISP_MODE_LCD_CRT   0x03      /* Simultaneous LCD and CRT */ |
#define  | SED1356_DISP_MODE_TV   0x04      /* TV Only, Flicker Filter Off */ |
#define  | SED1356_DISP_MODE_TV_LCD   0x05      /* Simultaneous LCD and TV, Flicker Filter Off */ |
#define  | SED1356_DISP_MODE_TV_FLICK   0x06      /* TV Only, Flicker Filter On */ |
#define  | SED1356_DISP_MODE_TV_LCD_FLICK   0x07      /* Simultaneous LCD and TV, Flicker Filter On */ |
#define  | SED1356_PWR_PCLK   BIT1      /* SED1356_REG_PWR_STAT only */ |
#define  | SED1356_PWR_MCLK   BIT0 |
#define  | SED1356_VER_NONDISP   BIT7      /* vertical retrace status 1 = in retrace */ |
#define  | BYTES_PER_PIXEL   2 |
#define  | RED_SUBPIXEL(n)   ((n & 0x1f) << 11) |
#define  | GREEN_SUBPIXEL(n)   ((n & 0x1f) << 5) |
#define  | BLUE_SUBPIXEL(n)   ((n & 0x1f) << 0) |
#define  | BLUE   (0x14 << 0) |
#define  | GREEN   (0x14 << 6) |
#define  | RED   (0x14 << 11) |
#define  | HALF_BLUE   (0x0a << 0) |
#define  | HALF_GREEN   (0x0a << 6) |
#define  | HALF_RED   (0x0a << 11) |
#define  | BRT_BLUE   (0x1e << 0) |
#define  | BRT_GREEN   (0x1e << 6) |
#define  | BRT_RED   (0x1e << 11) |
#define  | LU_BLACK   0 |
#define  | LU_BLUE   (BLUE) |
#define  | LU_GREEN   (GREEN) |
#define  | LU_CYAN   (GREEN | BLUE) |
#define  | LU_RED   (RED) |
#define  | LU_VIOLET   (RED | BLUE) |
#define  | LU_YELLOW   (RED | GREEN) |
#define  | LU_WHITE   (RED | GREEN | BLUE) |
#define  | LU_GREY   (HALF_RED | HALF_GREEN | HALF_BLUE) |
#define  | LU_BRT_BLUE   (HALF_RED | HALF_GREEN | BRT_BLUE) |
#define  | LU_BRT_GREEN   (HALF_RED | BRT_GREEN | HALF_BLUE) |
#define  | LU_BRT_CYAN   (HALF_RED | BRT_GREEN | BRT_BLUE) |
#define  | LU_BRT_RED   (BRT_RED | HALF_GREEN | HALF_BLUE) |
#define  | LU_BRT_VIOLET   (BRT_RED | HALF_GREEN | BRT_BLUE) |
#define  | LU_BRT_YELLOW   (BRT_RED | BRT_GREEN | HALF_BLUE) |
#define  | LU_BRT_WHITE   (BRT_RED | BRT_GREEN | BRT_BLUE) |
#define  | SED_BG_DEF   1 |
#define  | SED_FG_DEF   14 |
#define  | TOP   0 |
#define  | BOTTOM   (PIXELS_PER_COL-1) |
#define  | LEFT   0 |
#define  | RIGHT   (PIXELS_PER_ROW-1) |
#define  | CENTER_X   (PIXELS_PER_ROW/2) |
#define  | CENTER_Y   (PIXELS_PER_COL/2) |
#define  | SED_HOR_PULSE_WIDTH_CRT   0x07 /* Horizontal Pulse Width Register           = (Thp/8) - 1 */ |
#define  | SED_HOR_PULSE_START_CRT   0x02 /* Horizontal Pulse Start Position Register    = ((Thfp + 2)/8) - 1 */ |
#define  | SED_HOR_NONDISP_CRT   0x17 /* Horizontal Non-Display Period Register     = ((Thp + Thfp + Thbp)/8) - 1 */ |
#define  | SED_VER_PULSE_WIDTH_CRT   0x02 |
#define  | SED_VER_PULSE_START_CRT   0x08 |
#define  | SED_VER_NONDISP_CRT   0x27 |
