RTEMS  5.1
timespec.h
1
9 /*
10  * COPYRIGHT (c) 1989-2009.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef _RTEMS_SCORE_TIMESPEC_H
19 #define _RTEMS_SCORE_TIMESPEC_H
20
34 #include <stdbool.h> /* bool */
35 #include <stdint.h> /* uint32_t */
36 #include <time.h> /* struct timespec */
37
38 #ifdef __cplusplus
39 extern "C" {
40 #endif
41
52 #define _Timespec_Set( _time, _seconds, _nanoseconds ) \
53  do { \
54  (_time)->tv_sec = (_seconds); \
55  (_time)->tv_nsec = (_nanoseconds); \
56  } while (0)
57
66 #define _Timespec_Set_to_zero( _time ) \
67  do { \
68  (_time)->tv_sec = 0; \
69  (_time)->tv_nsec = 0; \
70  } while (0)
71
81 #define _Timespec_Get_seconds( _time ) \
82  ((_time)->tv_sec)
83
93 #define _Timespec_Get_nanoseconds( _time ) \
94  ((_time)->tv_nsec)
95
106  const struct timespec *time
107 );
108
119 bool _Timespec_Is_valid(
120  const struct timespec *time
121 );
122
135  const struct timespec *lhs,
136  const struct timespec *rhs
137 );
138
150 #define _Timespec_Greater_than( _lhs, _rhs ) \
151  _Timespec_Less_than( _rhs, _lhs )
152
164 #define _Timespec_Equal_to( lhs, rhs ) \
165  ( ((lhs)->tv_sec == (rhs)->tv_sec) && \
166  ((lhs)->tv_nsec == (rhs)->tv_nsec) \
167  )
168
180 uint32_t _Timespec_Add_to(
181  struct timespec *time,
182  const struct timespec *add
183 );
184
195 uint32_t _Timespec_To_ticks(
196  const struct timespec *time
197 );
198
209  uint32_t ticks,
210  struct timespec *time
211 );
212
223 void _Timespec_Subtract(
224  const struct timespec *start,
225  const struct timespec *end,
226  struct timespec *result
227 );
228
241  const struct timespec *time,
242  uint32_t iterations,
243  struct timespec *result
244 );
245
257 void _Timespec_Divide(
258  const struct timespec *lhs,
259  const struct timespec *rhs,
260  uint32_t *ival_percentage,
261  uint32_t *fval_percentage
262 );
263
264 #ifdef __cplusplus
265 }
266 #endif
267
270 #endif
271 /* end of include file */
uint32_t _Timespec_To_ticks(const struct timespec *time)
Converts timespec to number of ticks.
Definition: timespectoticks.c:27
bool _Timespec_Is_valid(const struct timespec *time)
Checks if timespec is valid.
Definition: timespecisvalid.c:24
void _Timespec_Divide_by_integer(const struct timespec *time, uint32_t iterations, struct timespec *result)
Divides timespec by an integer.
Definition: timespecdividebyinteger.c:25
void _Timespec_Subtract(const struct timespec *start, const struct timespec *end, struct timespec *result)
Subtracts two timespec.
Definition: timespecsubtract.c:24
void _Timespec_Divide(const struct timespec *lhs, const struct timespec *rhs, uint32_t *ival_percentage, uint32_t *fval_percentage)
Divides a timespec by another timespec.
Definition: timespecdivide.c:25
bool _Timespec_Less_than(const struct timespec *lhs, const struct timespec *rhs)
Checks if the left hand side timespec is less than the right one.
Definition: timespeclessthan.c:25
void _Timespec_From_ticks(uint32_t ticks, struct timespec *time)
Converts ticks to timespec.
Definition: timespecfromticks.c:25
uint64_t _Timespec_Get_as_nanoseconds(const struct timespec *time)
Gets the timestamp as nanoseconds.
Definition: timespecgetasnanoseconds.c:23
uint32_t _Timespec_Add_to(struct timespec *time, const struct timespec *add)
Adds two timespecs.
Definition: timespecaddto.c:25
