    RTEMS
    5.1
Go to the documentation of this file.   25 #if !defined (_RTEMS_RFS_DATA_H_)    26 #define _RTEMS_RFS_DATA_H_    33 #define rtems_rfs_data_ptr(_d) ((uint8_t*)(_d))    38 #define rtems_rfs_data_get(_d, _t, _o, _s) \    39   (((_t)(rtems_rfs_data_ptr (_d)[_o])) << (_s))    44 #define rtems_rfs_read_u8(_d) \    45   (*rtems_rfs_data_ptr (_d))    50 #define rtems_rfs_read_u16(_d) \    51   (rtems_rfs_data_get (_d, uint16_t, 0, 8) | \    52    rtems_rfs_data_get (_d, uint16_t, 1, 0))    57 #define rtems_rfs_read_u32(_d) \    58   (rtems_rfs_data_get (_d, uint32_t, 0, 24) | \    59    rtems_rfs_data_get (_d, uint32_t, 1, 16) | \    60    rtems_rfs_data_get (_d, uint32_t, 2, 8) | \    61    rtems_rfs_data_get (_d, uint32_t, 3, 0))    66 #define rtems_rfs_write_u8(_d, _v) \    67   (*rtems_rfs_data_ptr (_d) = (uint8_t)(_v))    72 #define rtems_rfs_write_u16(_d, _v) \    74     rtems_rfs_data_ptr (_d)[0] = (uint8_t)(((uint16_t)(_v)) >> 8); \    75     rtems_rfs_data_ptr (_d)[1] = (uint8_t)((_v)); \    81 #define rtems_rfs_write_u32(_d, _v) \    83     rtems_rfs_data_ptr (_d)[0] = (uint8_t)(((uint32_t)(_v)) >> 24); \    84     rtems_rfs_data_ptr (_d)[1] = (uint8_t)(((uint32_t)(_v)) >> 16); \    85     rtems_rfs_data_ptr (_d)[2] = (uint8_t)(((uint32_t)(_v)) >> 8);  \    86     rtems_rfs_data_ptr (_d)[3] = (uint8_t)((uint32_t)(_v)); \
