32 #ifndef _RTEMS_SCORE_CPUIMPL_H    33 #define _RTEMS_SCORE_CPUIMPL_H    35 #include <rtems/score/cpu.h>    47 #if defined(__riscv_atomic) && __riscv_xlen == 64    48 #define CPU_PER_CPU_CONTROL_SIZE 48    49 #elif defined(__riscv_atomic) && __riscv_xlen == 32    50 #define CPU_PER_CPU_CONTROL_SIZE 32    51 #elif __riscv_xlen == 64    52 #define CPU_PER_CPU_CONTROL_SIZE 32    53 #elif __riscv_xlen == 32    54 #define CPU_PER_CPU_CONTROL_SIZE 16    58 #define RISCV_CONTEXT_IS_EXECUTING 0    61 #define RISCV_CONTEXT_ISR_DISPATCH_DISABLE 4    63 #if __riscv_xlen == 32    65 #define RISCV_CONTEXT_RA 8    66 #define RISCV_CONTEXT_SP 12    67 #define RISCV_CONTEXT_TP 16    68 #define RISCV_CONTEXT_S0 20    69 #define RISCV_CONTEXT_S1 24    70 #define RISCV_CONTEXT_S2 28    71 #define RISCV_CONTEXT_S3 32    72 #define RISCV_CONTEXT_S4 36    73 #define RISCV_CONTEXT_S5 40    74 #define RISCV_CONTEXT_S6 44    75 #define RISCV_CONTEXT_S7 48    76 #define RISCV_CONTEXT_S8 52    77 #define RISCV_CONTEXT_S9 56    78 #define RISCV_CONTEXT_S10 60    79 #define RISCV_CONTEXT_S11 64    81 #define RISCV_INTERRUPT_FRAME_MSTATUS 0    82 #define RISCV_INTERRUPT_FRAME_MEPC 4    83 #define RISCV_INTERRUPT_FRAME_A2 8    84 #define RISCV_INTERRUPT_FRAME_S0 12    85 #define RISCV_INTERRUPT_FRAME_S1 16    86 #define RISCV_INTERRUPT_FRAME_RA 20    87 #define RISCV_INTERRUPT_FRAME_A3 24    88 #define RISCV_INTERRUPT_FRAME_A4 28    89 #define RISCV_INTERRUPT_FRAME_A5 32    90 #define RISCV_INTERRUPT_FRAME_A6 36    91 #define RISCV_INTERRUPT_FRAME_A7 40    92 #define RISCV_INTERRUPT_FRAME_T0 44    93 #define RISCV_INTERRUPT_FRAME_T1 48    94 #define RISCV_INTERRUPT_FRAME_T2 52    95 #define RISCV_INTERRUPT_FRAME_T3 56    96 #define RISCV_INTERRUPT_FRAME_T4 60    97 #define RISCV_INTERRUPT_FRAME_T5 64    98 #define RISCV_INTERRUPT_FRAME_T6 68   100 #if __riscv_flen == 0   102 #define RISCV_INTERRUPT_FRAME_A0 72   103 #define RISCV_INTERRUPT_FRAME_A1 76   105 #define CPU_INTERRUPT_FRAME_SIZE 80   107 #elif __riscv_flen == 32   109 #define RISCV_CONTEXT_FCSR 68   111 #define RISCV_CONTEXT_F( x ) ( 72 + 4 * x )   113 #define RISCV_INTERRUPT_FRAME_FCSR 72   115 #define RISCV_INTERRUPT_FRAME_F( x ) ( 76 + 4 * x )   117 #define RISCV_INTERRUPT_FRAME_A0 156   118 #define RISCV_INTERRUPT_FRAME_A1 160   120 #define CPU_INTERRUPT_FRAME_SIZE 176   122 #elif __riscv_flen == 64   124 #define RISCV_CONTEXT_FCSR 68   126 #define RISCV_CONTEXT_F( x ) ( 72 + 8 * x )   128 #define RISCV_INTERRUPT_FRAME_FCSR 72   130 #define RISCV_INTERRUPT_FRAME_F( x ) ( 80 + 8 * x )   132 #define RISCV_INTERRUPT_FRAME_A0 240   133 #define RISCV_INTERRUPT_FRAME_A1 244   135 #define CPU_INTERRUPT_FRAME_SIZE 256   139 #define RISCV_EXCEPTION_FRAME_X( x ) ( CPU_INTERRUPT_FRAME_SIZE + 4 * x )   141 #elif __riscv_xlen == 64   143 #define RISCV_CONTEXT_RA 8   144 #define RISCV_CONTEXT_SP 16   145 #define RISCV_CONTEXT_TP 24   146 #define RISCV_CONTEXT_S0 32   147 #define RISCV_CONTEXT_S1 40   148 #define RISCV_CONTEXT_S2 48   149 #define RISCV_CONTEXT_S3 56   150 #define RISCV_CONTEXT_S4 64   151 #define RISCV_CONTEXT_S5 72   152 #define RISCV_CONTEXT_S6 80   153 #define RISCV_CONTEXT_S7 88   154 #define RISCV_CONTEXT_S8 96   155 #define RISCV_CONTEXT_S9 104   156 #define RISCV_CONTEXT_S10 112   157 #define RISCV_CONTEXT_S11 120   159 #define RISCV_INTERRUPT_FRAME_MSTATUS 0   160 #define RISCV_INTERRUPT_FRAME_MEPC 8   161 #define RISCV_INTERRUPT_FRAME_A2 16   162 #define RISCV_INTERRUPT_FRAME_S0 24   163 #define RISCV_INTERRUPT_FRAME_S1 32   164 #define RISCV_INTERRUPT_FRAME_RA 40   165 #define RISCV_INTERRUPT_FRAME_A3 48   166 #define RISCV_INTERRUPT_FRAME_A4 56   167 #define RISCV_INTERRUPT_FRAME_A5 64   168 #define RISCV_INTERRUPT_FRAME_A6 72   169 #define RISCV_INTERRUPT_FRAME_A7 80   170 #define RISCV_INTERRUPT_FRAME_T0 88   171 #define RISCV_INTERRUPT_FRAME_T1 96   172 #define RISCV_INTERRUPT_FRAME_T2 104   173 #define RISCV_INTERRUPT_FRAME_T3 112   174 #define RISCV_INTERRUPT_FRAME_T4 120   175 #define RISCV_INTERRUPT_FRAME_T5 128   176 #define RISCV_INTERRUPT_FRAME_T6 136   178 #if __riscv_flen == 0   180 #define RISCV_INTERRUPT_FRAME_A0 144   181 #define RISCV_INTERRUPT_FRAME_A1 152   183 #define CPU_INTERRUPT_FRAME_SIZE 160   185 #elif __riscv_flen == 32   187 #define RISCV_CONTEXT_FCSR 128   189 #define RISCV_CONTEXT_F( x ) ( 132 + 4 * x )   191 #define RISCV_INTERRUPT_FRAME_FCSR 144   193 #define RISCV_INTERRUPT_FRAME_F( x ) ( 148 + 4 * x )   195 #define RISCV_INTERRUPT_FRAME_A0 232   196 #define RISCV_INTERRUPT_FRAME_A1 240   198 #define CPU_INTERRUPT_FRAME_SIZE 256   200 #elif __riscv_flen == 64   202 #define RISCV_CONTEXT_FCSR 128   204 #define RISCV_CONTEXT_F( x ) ( 136 + 8 * x )   206 #define RISCV_INTERRUPT_FRAME_FCSR 144   208 #define RISCV_INTERRUPT_FRAME_F( x ) ( 152 + 8 * x )   210 #define RISCV_INTERRUPT_FRAME_A0 312   211 #define RISCV_INTERRUPT_FRAME_A1 320   213 #define CPU_INTERRUPT_FRAME_SIZE 336   217 #define RISCV_EXCEPTION_FRAME_X( x ) ( CPU_INTERRUPT_FRAME_SIZE + 8 * x )   221 #define RISCV_EXCEPTION_FRAME_MCAUSE RISCV_EXCEPTION_FRAME_X( 0 )   222 #define RISCV_EXCEPTION_FRAME_SP RISCV_EXCEPTION_FRAME_X( 1 )   223 #define RISCV_EXCEPTION_FRAME_GP RISCV_EXCEPTION_FRAME_X( 2 )   224 #define RISCV_EXCEPTION_FRAME_TP RISCV_EXCEPTION_FRAME_X( 3 )   225 #define RISCV_EXCEPTION_FRAME_S2 RISCV_EXCEPTION_FRAME_X( 4 )   226 #define RISCV_EXCEPTION_FRAME_S3 RISCV_EXCEPTION_FRAME_X( 5 )   227 #define RISCV_EXCEPTION_FRAME_S4 RISCV_EXCEPTION_FRAME_X( 6 )   228 #define RISCV_EXCEPTION_FRAME_S5 RISCV_EXCEPTION_FRAME_X( 7 )   229 #define RISCV_EXCEPTION_FRAME_S6 RISCV_EXCEPTION_FRAME_X( 8 )   230 #define RISCV_EXCEPTION_FRAME_S7 RISCV_EXCEPTION_FRAME_X( 9 )   231 #define RISCV_EXCEPTION_FRAME_S8 RISCV_EXCEPTION_FRAME_X( 10 )   232 #define RISCV_EXCEPTION_FRAME_S9 RISCV_EXCEPTION_FRAME_X( 11 )   233 #define RISCV_EXCEPTION_FRAME_S10 RISCV_EXCEPTION_FRAME_X( 12 )   234 #define RISCV_EXCEPTION_FRAME_S11 RISCV_EXCEPTION_FRAME_X( 13 )   238 #define RISCV_CONTEXT_FS0 RISCV_CONTEXT_F( 0 )   239 #define RISCV_CONTEXT_FS1 RISCV_CONTEXT_F( 1 )   240 #define RISCV_CONTEXT_FS2 RISCV_CONTEXT_F( 2 )   241 #define RISCV_CONTEXT_FS3 RISCV_CONTEXT_F( 3 )   242 #define RISCV_CONTEXT_FS4 RISCV_CONTEXT_F( 4 )   243 #define RISCV_CONTEXT_FS5 RISCV_CONTEXT_F( 5 )   244 #define RISCV_CONTEXT_FS6 RISCV_CONTEXT_F( 6 )   245 #define RISCV_CONTEXT_FS7 RISCV_CONTEXT_F( 7 )   246 #define RISCV_CONTEXT_FS8 RISCV_CONTEXT_F( 8 )   247 #define RISCV_CONTEXT_FS9 RISCV_CONTEXT_F( 9 )   248 #define RISCV_CONTEXT_FS10 RISCV_CONTEXT_F( 10 )   249 #define RISCV_CONTEXT_FS11 RISCV_CONTEXT_F( 11 )   251 #define RISCV_INTERRUPT_FRAME_FT0 RISCV_INTERRUPT_FRAME_F( 0 )   252 #define RISCV_INTERRUPT_FRAME_FT1 RISCV_INTERRUPT_FRAME_F( 1 )   253 #define RISCV_INTERRUPT_FRAME_FT2 RISCV_INTERRUPT_FRAME_F( 2 )   254 #define RISCV_INTERRUPT_FRAME_FT3 RISCV_INTERRUPT_FRAME_F( 3 )   255 #define RISCV_INTERRUPT_FRAME_FT4 RISCV_INTERRUPT_FRAME_F( 4 )   256 #define RISCV_INTERRUPT_FRAME_FT5 RISCV_INTERRUPT_FRAME_F( 5 )   257 #define RISCV_INTERRUPT_FRAME_FT6 RISCV_INTERRUPT_FRAME_F( 6 )   258 #define RISCV_INTERRUPT_FRAME_FT7 RISCV_INTERRUPT_FRAME_F( 7 )   259 #define RISCV_INTERRUPT_FRAME_FT8 RISCV_INTERRUPT_FRAME_F( 8 )   260 #define RISCV_INTERRUPT_FRAME_FT9 RISCV_INTERRUPT_FRAME_F( 9 )   261 #define RISCV_INTERRUPT_FRAME_FT10 RISCV_INTERRUPT_FRAME_F( 10 )   262 #define RISCV_INTERRUPT_FRAME_FT11 RISCV_INTERRUPT_FRAME_F( 11 )   263 #define RISCV_INTERRUPT_FRAME_FA0 RISCV_INTERRUPT_FRAME_F( 12 )   264 #define RISCV_INTERRUPT_FRAME_FA1 RISCV_INTERRUPT_FRAME_F( 13 )   265 #define RISCV_INTERRUPT_FRAME_FA2 RISCV_INTERRUPT_FRAME_F( 14 )   266 #define RISCV_INTERRUPT_FRAME_FA3 RISCV_INTERRUPT_FRAME_F( 15 )   267 #define RISCV_INTERRUPT_FRAME_FA4 RISCV_INTERRUPT_FRAME_F( 16 )   268 #define RISCV_INTERRUPT_FRAME_FA5 RISCV_INTERRUPT_FRAME_F( 17 )   269 #define RISCV_INTERRUPT_FRAME_FA6 RISCV_INTERRUPT_FRAME_F( 18 )   270 #define RISCV_INTERRUPT_FRAME_FA7 RISCV_INTERRUPT_FRAME_F( 19 )   272 #if __riscv_flen == 32   273 #define RISCV_EXCEPTION_FRAME_F( x ) ( RISCV_EXCEPTION_FRAME_X( 14 ) + 4 * x )   274 #elif __riscv_flen == 64   275 #define RISCV_EXCEPTION_FRAME_F( x ) ( RISCV_EXCEPTION_FRAME_X( 14 ) + 8 * x )   278 #define RISCV_EXCEPTION_FRAME_FS0 RISCV_EXCEPTION_FRAME_F( 0 )   279 #define RISCV_EXCEPTION_FRAME_FS1 RISCV_EXCEPTION_FRAME_F( 1 )   280 #define RISCV_EXCEPTION_FRAME_FS2 RISCV_EXCEPTION_FRAME_F( 2 )   281 #define RISCV_EXCEPTION_FRAME_FS3 RISCV_EXCEPTION_FRAME_F( 3 )   282 #define RISCV_EXCEPTION_FRAME_FS4 RISCV_EXCEPTION_FRAME_F( 4 )   283 #define RISCV_EXCEPTION_FRAME_FS5 RISCV_EXCEPTION_FRAME_F( 5 )   284 #define RISCV_EXCEPTION_FRAME_FS6 RISCV_EXCEPTION_FRAME_F( 6 )   285 #define RISCV_EXCEPTION_FRAME_FS7 RISCV_EXCEPTION_FRAME_F( 7 )   286 #define RISCV_EXCEPTION_FRAME_FS8 RISCV_EXCEPTION_FRAME_F( 8 )   287 #define RISCV_EXCEPTION_FRAME_FS9 RISCV_EXCEPTION_FRAME_F( 9 )   288 #define RISCV_EXCEPTION_FRAME_FS10 RISCV_EXCEPTION_FRAME_F( 10 )   289 #define RISCV_EXCEPTION_FRAME_FS11 RISCV_EXCEPTION_FRAME_F( 11 )   309   uint32_t reserved_8000[4094];
   311   uint32_t reserved_c000[4096];
   316 #define RISCV_PLIC_MAX_INTERRUPTS 1024   319   uint32_t priority_threshold;
   320   uint32_t claim_complete;
   321   uint32_t reserved_8[1022];
   325   uint32_t priority[RISCV_PLIC_MAX_INTERRUPTS];
   326   uint32_t pending[1024];
   327   uint32_t enable[16320][32];
   332 #ifdef __riscv_atomic   333   uint64_t clear_reservations;
   334   uint32_t reserved_for_alignment_of_interrupt_frame[ 2 ];
   337   volatile uint32_t *plic_m_ie;
   339   volatile uint32_t *clint_msip;
   344 void _RISCV_Interrupt_dispatch(
   349 static inline uint32_t _RISCV_Read_FCSR(
void )
   353   __asm__ volatile (
"frcsr %0" :
"=&r" ( fcsr ) );
   388 extern volatile uint32_t *_RISCV_Counter_mutable;
   394 extern volatile uint32_t _RISCV_Counter_register;
   398 static inline struct Per_CPU_Control *_RISCV_Get_current_per_CPU_control(
void )
   402   __asm__ volatile (
"csrr %0, mscratch" :
"=r" ( cpu_self ) );
   407 #define _CPU_Get_current_per_CPU_control() _RISCV_Get_current_per_CPU_control()   411 void _CPU_Context_volatile_clobber( uintptr_t pattern );
   413 void _CPU_Context_validate( uintptr_t pattern );
 Definition: cpuimpl.h:306
#define CPU_MAXIMUM_PROCESSORS
Maximum number of processors of all systems supported by this CPU port.
Definition: cpu.h:250
Definition: cpuimpl.h:324
The CPU specific per-CPU control.
Definition: cpuimpl.h:54
Per CPU Core Structure.
Definition: percpu.h:347
Definition: cpuimpl.h:301
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation(void)
Emits a no operation instruction (nop).
Definition: cpuimpl.h:132
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Definition: cpuimpl.h:318
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal(void)
Emits an illegal instruction.
Definition: cpuimpl.h:122
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
