RTEMS
5.1
score
cpu
riscv
include
score
cpu_asm.h
1
11
12
* COPYRIGHT (c) 1989-1999.
13
* On-Line Applications Research Corporation (OAR).
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
28
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
29
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
30
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
31
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
32
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
33
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
34
* SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_SCORE_CPU_ASM_H
38
#define _RTEMS_SCORE_CPU_ASM_H
39
40
/* pull in the generated offsets */
41
42
43
#include <rtems/score/offsets.h>
44
45
46
47
* Hardware General Registers
48
49
50
/* put something here */
51
52
53
* Hardware Floating Point Registers
54
55
56
57
58
59
* Hardware Control Registers
60
61
62
63
64
65
* Calling Convention
66
67
68
69
70
71
* Temporary registers
72
73
74
75
76
77
* Floating Point Registers - SW Conventions
78
79
80
81
82
83
* Temporary floating point registers
84
85
86
87
88
#endif
89
90
/* end of file */
