RTEMS  5.1
elf_machdep.h
1 /* $NetBSD: elf_machdep.h,v 1.6 2017/11/06 03:47:48 christos Exp $ */
2
3 /*-
4  * Copyright (c) 2019 Hesham Almatary
5  *
6  * Copyright (c) 2014 The NetBSD Foundation, Inc.
7  * All rights reserved.
8  *
9  * This code is derived from software contributed to The NetBSD Foundation
10  * by Matt Thomas of 3am Software Foundry.
11  *
12  * Redistribution and use in source and binary forms, with or without
13  * modification, are permitted provided that the following conditions
14  * are met:
15  * 1. Redistributions of source code must retain the above copyright
16  * notice, this list of conditions and the following disclaimer.
17  * 2. Redistributions in binary form must reproduce the above copyright
18  * notice, this list of conditions and the following disclaimer in the
19  * documentation and/or other materials provided with the distribution.
20  *
21  * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
22  * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
23  * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
24  * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
25  * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31  * POSSIBILITY OF SUCH DAMAGE.
32  */
33
34 #ifndef _RISCV_ELF_MACHDEP_H_
35 #define _RISCV_ELF_MACHDEP_H_
36
37 #define EM_RISCV 243
38 #define ELF32_MACHDEP_ID EM_RISCV
39 #define ELF64_MACHDEP_ID EM_RISCV
40
41 #define ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB
42 #define ELF64_MACHDEP_ENDIANNESS ELFDATA2LSB
43
44 #define ELF32_MACHDEP_ID_CASES \
45  case EM_RISCV: \
46  break;
47
48 #define ELF64_MACHDEP_ID_CASES \
49  case EM_RISCV: \
50  break;
51
52 #define KERN_ELFSIZE 32
53 #ifdef _LP64
54 #define ARCH_ELFSIZE 64 /* MD native binary size */
55 #else
56 #define ARCH_ELFSIZE 32 /* MD native binary size */
57 #endif
58
59 /* Processor specific flags for the ELF header e_flags field. */
60
61 /* Processor specific relocation types */
62
63 #define R_RISCV_NONE 0
64 #define R_RISCV_32 1 // A
65 #define R_RISCV_64 2
66 #define R_RISCV_RELATIVE 3
67 #define R_RISCV_COPY 4
68 #define R_RISCV_JMP_SLOT 5
69 #define R_RISCV_TLS_DTPMOD32 6
70 #define R_RISCV_TLS_DTPREL32 7
71 #define R_RISCV_TLS_DTPMOD64 8
72 #define R_RISCV_TLS_DTPREL64 9
73 #define R_RISCV_TLS_TPREL32 10
74 #define R_RISCV_TLS_TPREL64 11
75
76 /* The rest are not used by the dynamic linker */
77 #define R_RISCV_BRANCH 16 // (A - P) & 0xffff
78 #define R_RISCV_JAL 17 // A & 0xff
79 #define R_RISCV_CALL 18 // (A - P) & 0xff
80 #define R_RISCV_CALL_PLT 19
81 #define R_RISCV_GOT_HI20 20
82 #define R_RISCV_TLS_GOT_HI20 21
83 #define R_RISCV_TLS_GD_HI20 22
84 #define R_RISCV_PCREL_HI20 23
85 #define R_RISCV_PCREL_LO12_I 24
86 #define R_RISCV_PCREL_LO12_S 25
87 #define R_RISCV_HI20 26 // A & 0xffff
88 #define R_RISCV_LO12_I 27 // (A >> 16) & 0xffff
89 #define R_RISCV_LO12_S 28 // (S + A - P) >> 2
90 #define R_RISCV_TPREL_HI20 29
91 #define R_RISCV_TPREL_LO12_I 30
92 #define R_RISCV_TPREL_LO12_S 31
93 #define R_RISCV_TPREL_ADD 32
94 #define R_RISCV_ADD8 33
95 #define R_RISCV_ADD16 34
96 #define R_RISCV_ADD32 35
97 #define R_RISCV_ADD64 36
98 #define R_RISCV_SUB8 37
99 #define R_RISCV_SUB16 38
100 #define R_RISCV_SUB32 39
101 #define R_RISCV_SUB64 40
102 #define R_RISCV_GNU_VTINHERIT 41 // A & 0xffff
103 #define R_RISCV_GNU_VTENTRY 42
104 #define R_RISCV_ALIGN 43
105 #define R_RISCV_RVC_BRANCH 44
106 #define R_RISCV_RVC_JUMP 45
107 #define R_RISCV_RVC_LUI 46
108
109 #define R_RISCV_RELAX 51
110 #define R_RISCV_SUB6 52
111 #define R_RISCV_SET6 53
112 #define R_RISCV_SET8 54
113 #define R_RISCV_SET16 55
114 #define R_RISCV_SET32 56
115
116 #define R_RISCV_32_PCREL 57
117
118 /* These are aliases we can use R_TYPESZ */
119 #define R_RISCV_ADDR32 R_RISCV_32
120 #define R_RISCV_ADDR64 R_RISCV_64
121
122 #define R_TYPE(name) R_RISCV_ ## name
123 #if ELFSIZE == 32
124 #define R_TYPESZ(name) R_RISCV_ ## name ## 32
125 #else
126 #define R_TYPESZ(name) R_RISCV_ ## name ## 64
127 #endif
128
129 #ifdef _KERNEL
130 #ifdef ELFSIZE
131 #define ELF_MD_PROBE_FUNC ELFNAME2(cpu_netbsd,probe)
132 #endif
133
134 struct exec_package;
135
136 int cpu_netbsd_elf32_probe(struct lwp *, struct exec_package *, void *, char *,
137  vaddr_t *);
138
139 int cpu_netbsd_elf64_probe(struct lwp *, struct exec_package *, void *, char *,
140  vaddr_t *);
141
142 #endif /* _KERNEL */
143
144 #endif /* _RISCV_ELF_MACHDEP_H_ */
