44 #ifndef _RTEMS_SCORE_RISCV_UTILITY_H    45 #define _RTEMS_SCORE_RISCV_UTILITY_H    47 #define MSTATUS_UIE         0x00000001    48 #define MSTATUS_SIE         0x00000002    49 #define MSTATUS_HIE         0x00000004    50 #define MSTATUS_MIE         0x00000008    51 #define MSTATUS_UPIE        0x00000010    52 #define MSTATUS_SPIE        0x00000020    53 #define MSTATUS_HPIE        0x00000040    54 #define MSTATUS_MPIE        0x00000080    55 #define MSTATUS_SPP         0x00000100    56 #define MSTATUS_HPP         0x00000600    57 #define MSTATUS_MPP         0x00001800    58 #define MSTATUS_FS          0x00006000    59 #define MSTATUS_XS          0x00018000    60 #define MSTATUS_MPRV        0x00020000    61 #define MSTATUS_SUM         0x00040000    62 #define MSTATUS_MXR         0x00080000    63 #define MSTATUS_TVM         0x00100000    64 #define MSTATUS_TW          0x00200000    65 #define MSTATUS_TSR         0x00400000    66 #define MSTATUS32_SD        0x80000000    67 #define MSTATUS64_SD        0x8000000000000000    69 #define SSTATUS_UIE         0x00000001    70 #define SSTATUS_SIE         0x00000002    71 #define SSTATUS_UPIE        0x00000010    72 #define SSTATUS_SPIE        0x00000020    73 #define SSTATUS_SPP         0x00000100    74 #define SSTATUS_FS          0x00006000    75 #define SSTATUS_XS          0x00018000    76 #define SSTATUS_SUM         0x00040000    77 #define SSTATUS_MXR         0x00080000    78 #define SSTATUS32_SD        0x80000000    79 #define SSTATUS64_SD        0x8000000000000000    81 #define DCSR_XDEBUGVER      (3U<<30)    82 #define DCSR_NDRESET        (1<<29)    83 #define DCSR_FULLRESET      (1<<28)    84 #define DCSR_EBREAKM        (1<<15)    85 #define DCSR_EBREAKH        (1<<14)    86 #define DCSR_EBREAKS        (1<<13)    87 #define DCSR_EBREAKU        (1<<12)    88 #define DCSR_STOPCYCLE      (1<<10)    89 #define DCSR_STOPTIME       (1<<9)    90 #define DCSR_CAUSE          (7<<6)    91 #define DCSR_DEBUGINT       (1<<5)    92 #define DCSR_HALT           (1<<3)    93 #define DCSR_STEP           (1<<2)    94 #define DCSR_PRV            (3<<0)    96 #define DCSR_CAUSE_NONE     0    97 #define DCSR_CAUSE_SWBP     1    98 #define DCSR_CAUSE_HWBP     2    99 #define DCSR_CAUSE_DEBUGINT 3   100 #define DCSR_CAUSE_STEP     4   101 #define DCSR_CAUSE_HALT     5   103 #define MCONTROL_TYPE(xlen)    (0xfULL<<((xlen)-4))   104 #define MCONTROL_DMODE(xlen)   (1ULL<<((xlen)-5))   105 #define MCONTROL_MASKMAX(xlen) (0x3fULL<<((xlen)-11))   107 #define MCONTROL_SELECT     (1<<19)   108 #define MCONTROL_TIMING     (1<<18)   109 #define MCONTROL_ACTION     (0x3f<<12)   110 #define MCONTROL_CHAIN      (1<<11)   111 #define MCONTROL_MATCH      (0xf<<7)   112 #define MCONTROL_M          (1<<6)   113 #define MCONTROL_H          (1<<5)   114 #define MCONTROL_S          (1<<4)   115 #define MCONTROL_U          (1<<3)   116 #define MCONTROL_EXECUTE    (1<<2)   117 #define MCONTROL_STORE      (1<<1)   118 #define MCONTROL_LOAD       (1<<0)   120 #define MCONTROL_TYPE_NONE      0   121 #define MCONTROL_TYPE_MATCH     2   123 #define MCONTROL_ACTION_DEBUG_EXCEPTION   0   124 #define MCONTROL_ACTION_DEBUG_MODE        1   125 #define MCONTROL_ACTION_TRACE_START       2   126 #define MCONTROL_ACTION_TRACE_STOP        3   127 #define MCONTROL_ACTION_TRACE_EMIT        4   129 #define MCONTROL_MATCH_EQUAL     0   130 #define MCONTROL_MATCH_NAPOT     1   131 #define MCONTROL_MATCH_GE        2   132 #define MCONTROL_MATCH_LT        3   133 #define MCONTROL_MATCH_MASK_LOW  4   134 #define MCONTROL_MATCH_MASK_HIGH 5   136 #define MIP_SSIP            (1 << IRQ_S_SOFT)   137 #define MIP_HSIP            (1 << IRQ_H_SOFT)   138 #define MIP_MSIP            (1 << IRQ_M_SOFT)   139 #define MIP_STIP            (1 << IRQ_S_TIMER)   140 #define MIP_HTIP            (1 << IRQ_H_TIMER)   141 #define MIP_MTIP            (1 << IRQ_M_TIMER)   142 #define MIP_SEIP            (1 << IRQ_S_EXT)   143 #define MIP_HEIP            (1 << IRQ_H_EXT)   144 #define MIP_MEIP            (1 << IRQ_M_EXT)   146 #define SIP_SSIP MIP_SSIP   147 #define SIP_STIP MIP_STIP   154 #define SPTBR32_MODE 0x80000000   155 #define SPTBR32_ASID 0x7FC00000   156 #define SPTBR32_PPN  0x003FFFFF   157 #define SPTBR64_MODE 0xF000000000000000   158 #define SPTBR64_ASID 0x0FFFF00000000000   159 #define SPTBR64_PPN  0x00000FFFFFFFFFFF   161 #define SPTBR_MODE_OFF  0   162 #define SPTBR_MODE_SV32 1   163 #define SPTBR_MODE_SV39 8   164 #define SPTBR_MODE_SV48 9   165 #define SPTBR_MODE_SV57 10   166 #define SPTBR_MODE_SV64 11   177 #define PMP_NAPOT 0x18   182 #define IRQ_S_TIMER  5   183 #define IRQ_H_TIMER  6   184 #define IRQ_M_TIMER  7   191 #define DEFAULT_RSTVEC     0x00001000   192 #define CLINT_BASE         0x02000000   193 #define CLINT_SIZE         0x000c0000   194 #define EXT_IO_BASE        0x40000000   195 #define DRAM_BASE          0x80000000   198 #define PTE_V     0x001 // Valid   199 #define PTE_R     0x002 // Read   200 #define PTE_W     0x004 // Write   201 #define PTE_X     0x008 // Execute   202 #define PTE_U     0x010 // User   203 #define PTE_G     0x020 // Global   204 #define PTE_A     0x040 // Accessed   205 #define PTE_D     0x080 // Dirty   206 #define PTE_SOFT  0x300 // Reserved for Software   208 #define PTE_PPN_SHIFT 10   210 #define PTE_TABLE(PTE) (((PTE) & (PTE_V | PTE_R | PTE_W | PTE_X)) == PTE_V)   214 #if __riscv_xlen == 64   215 # define MSTATUS_SD MSTATUS64_SD   216 # define SSTATUS_SD SSTATUS64_SD   217 # define RISCV_PGLEVEL_BITS 9   218 # define SPTBR_MODE SPTBR64_MODE   220 # define MSTATUS_SD MSTATUS32_SD   221 # define SSTATUS_SD SSTATUS32_SD   222 # define RISCV_PGLEVEL_BITS 10   223 # define SPTBR_MODE SPTBR32_MODE   225 #define RISCV_PGSHIFT 12   226 #define RISCV_PGSIZE (1 << RISCV_PGSHIFT)   228 #ifndef __ASSEMBLER__   236   RISCV_USER_INTERRUPT = 0,
   237   RISCV_SUPERVISOR_SW_INTERRUPT = 1,
   238   RISCV_MACHINE_SW_INTERRUPT = 3,
   239   RISCV_USER_TIMER_INTERRUPT = 4,
   240   RISCV_SUPERVISOR_TIMER_INTERRUPT = 4,
   241   RISCV_MACHINE_TIMER_INTERRUPT = 7,
   242   RISCV_USER_EXTERNAL_INTERRUPT = 8,
   243   RISCV_SUPERVISOR_EXTERNAL_INTERRUPT = 9,
   244   RISCV_MACHINE_EXTERNAL_INTERRUPT = 11
   245 } RISCV_Symbolic_interrupt_name;
   249 #define read_csr(reg) ({ unsigned long __tmp; \   250   asm volatile ("csrr %0, " #reg : "=r"(__tmp)); \   253 #define write_csr(reg, val) ({ \   254   asm volatile ("csrw " #reg ", %0" :: "rK"(val)); })   256 #define swap_csr(reg, val) ({ unsigned long __tmp; \   257   asm volatile ("csrrw %0, " #reg ", %1" : "=r"(__tmp) : "rK"(val)); \   260 #define set_csr(reg, bit) ({ unsigned long __tmp; \   261   asm volatile ("csrrs %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \   264 #define clear_csr(reg, bit) ({ unsigned long __tmp; \   265   asm volatile ("csrrc %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \   268 #define rdtime() read_csr(time)   269 #define rdcycle() read_csr(cycle)   270 #define rdinstret() read_csr(instret)   280 #ifndef RISCV_ENCODING_H   281 #define RISCV_ENCODING_H   282 #define MATCH_BEQ 0x63   283 #define MASK_BEQ  0x707f   284 #define MATCH_BNE 0x1063   285 #define MASK_BNE  0x707f   286 #define MATCH_BLT 0x4063   287 #define MASK_BLT  0x707f   288 #define MATCH_BGE 0x5063   289 #define MASK_BGE  0x707f   290 #define MATCH_BLTU 0x6063   291 #define MASK_BLTU  0x707f   292 #define MATCH_BGEU 0x7063   293 #define MASK_BGEU  0x707f   294 #define MATCH_JALR 0x67   295 #define MASK_JALR  0x707f   296 #define MATCH_JAL 0x6f   297 #define MASK_JAL  0x7f   298 #define MATCH_LUI 0x37   299 #define MASK_LUI  0x7f   300 #define MATCH_AUIPC 0x17   301 #define MASK_AUIPC  0x7f   302 #define MATCH_ADDI 0x13   303 #define MASK_ADDI  0x707f   304 #define MATCH_SLLI 0x1013   305 #define MASK_SLLI  0xfc00707f   306 #define MATCH_SLTI 0x2013   307 #define MASK_SLTI  0x707f   308 #define MATCH_SLTIU 0x3013   309 #define MASK_SLTIU  0x707f   310 #define MATCH_XORI 0x4013   311 #define MASK_XORI  0x707f   312 #define MATCH_SRLI 0x5013   313 #define MASK_SRLI  0xfc00707f   314 #define MATCH_SRAI 0x40005013   315 #define MASK_SRAI  0xfc00707f   316 #define MATCH_ORI 0x6013   317 #define MASK_ORI  0x707f   318 #define MATCH_ANDI 0x7013   319 #define MASK_ANDI  0x707f   320 #define MATCH_ADD 0x33   321 #define MASK_ADD  0xfe00707f   322 #define MATCH_SUB 0x40000033   323 #define MASK_SUB  0xfe00707f   324 #define MATCH_SLL 0x1033   325 #define MASK_SLL  0xfe00707f   326 #define MATCH_SLT 0x2033   327 #define MASK_SLT  0xfe00707f   328 #define MATCH_SLTU 0x3033   329 #define MASK_SLTU  0xfe00707f   330 #define MATCH_XOR 0x4033   331 #define MASK_XOR  0xfe00707f   332 #define MATCH_SRL 0x5033   333 #define MASK_SRL  0xfe00707f   334 #define MATCH_SRA 0x40005033   335 #define MASK_SRA  0xfe00707f   336 #define MATCH_OR 0x6033   337 #define MASK_OR  0xfe00707f   338 #define MATCH_AND 0x7033   339 #define MASK_AND  0xfe00707f   340 #define MATCH_ADDIW 0x1b   341 #define MASK_ADDIW  0x707f   342 #define MATCH_SLLIW 0x101b   343 #define MASK_SLLIW  0xfe00707f   344 #define MATCH_SRLIW 0x501b   345 #define MASK_SRLIW  0xfe00707f   346 #define MATCH_SRAIW 0x4000501b   347 #define MASK_SRAIW  0xfe00707f   348 #define MATCH_ADDW 0x3b   349 #define MASK_ADDW  0xfe00707f   350 #define MATCH_SUBW 0x4000003b   351 #define MASK_SUBW  0xfe00707f   352 #define MATCH_SLLW 0x103b   353 #define MASK_SLLW  0xfe00707f   354 #define MATCH_SRLW 0x503b   355 #define MASK_SRLW  0xfe00707f   356 #define MATCH_SRAW 0x4000503b   357 #define MASK_SRAW  0xfe00707f   359 #define MASK_LB  0x707f   360 #define MATCH_LH 0x1003   361 #define MASK_LH  0x707f   362 #define MATCH_LW 0x2003   363 #define MASK_LW  0x707f   364 #define MATCH_LD 0x3003   365 #define MASK_LD  0x707f   366 #define MATCH_LBU 0x4003   367 #define MASK_LBU  0x707f   368 #define MATCH_LHU 0x5003   369 #define MASK_LHU  0x707f   370 #define MATCH_LWU 0x6003   371 #define MASK_LWU  0x707f   372 #define MATCH_SB 0x23   373 #define MASK_SB  0x707f   374 #define MATCH_SH 0x1023   375 #define MASK_SH  0x707f   376 #define MATCH_SW 0x2023   377 #define MASK_SW  0x707f   378 #define MATCH_SD 0x3023   379 #define MASK_SD  0x707f   380 #define MATCH_FENCE 0xf   381 #define MASK_FENCE  0x707f   382 #define MATCH_FENCE_I 0x100f   383 #define MASK_FENCE_I  0x707f   384 #define MATCH_MUL 0x2000033   385 #define MASK_MUL  0xfe00707f   386 #define MATCH_MULH 0x2001033   387 #define MASK_MULH  0xfe00707f   388 #define MATCH_MULHSU 0x2002033   389 #define MASK_MULHSU  0xfe00707f   390 #define MATCH_MULHU 0x2003033   391 #define MASK_MULHU  0xfe00707f   392 #define MATCH_DIV 0x2004033   393 #define MASK_DIV  0xfe00707f   394 #define MATCH_DIVU 0x2005033   395 #define MASK_DIVU  0xfe00707f   396 #define MATCH_REM 0x2006033   397 #define MASK_REM  0xfe00707f   398 #define MATCH_REMU 0x2007033   399 #define MASK_REMU  0xfe00707f   400 #define MATCH_MULW 0x200003b   401 #define MASK_MULW  0xfe00707f   402 #define MATCH_DIVW 0x200403b   403 #define MASK_DIVW  0xfe00707f   404 #define MATCH_DIVUW 0x200503b   405 #define MASK_DIVUW  0xfe00707f   406 #define MATCH_REMW 0x200603b   407 #define MASK_REMW  0xfe00707f   408 #define MATCH_REMUW 0x200703b   409 #define MASK_REMUW  0xfe00707f   410 #define MATCH_AMOADD_W 0x202f   411 #define MASK_AMOADD_W  0xf800707f   412 #define MATCH_AMOXOR_W 0x2000202f   413 #define MASK_AMOXOR_W  0xf800707f   414 #define MATCH_AMOOR_W 0x4000202f   415 #define MASK_AMOOR_W  0xf800707f   416 #define MATCH_AMOAND_W 0x6000202f   417 #define MASK_AMOAND_W  0xf800707f   418 #define MATCH_AMOMIN_W 0x8000202f   419 #define MASK_AMOMIN_W  0xf800707f   420 #define MATCH_AMOMAX_W 0xa000202f   421 #define MASK_AMOMAX_W  0xf800707f   422 #define MATCH_AMOMINU_W 0xc000202f   423 #define MASK_AMOMINU_W  0xf800707f   424 #define MATCH_AMOMAXU_W 0xe000202f   425 #define MASK_AMOMAXU_W  0xf800707f   426 #define MATCH_AMOSWAP_W 0x800202f   427 #define MASK_AMOSWAP_W  0xf800707f   428 #define MATCH_LR_W 0x1000202f   429 #define MASK_LR_W  0xf9f0707f   430 #define MATCH_SC_W 0x1800202f   431 #define MASK_SC_W  0xf800707f   432 #define MATCH_AMOADD_D 0x302f   433 #define MASK_AMOADD_D  0xf800707f   434 #define MATCH_AMOXOR_D 0x2000302f   435 #define MASK_AMOXOR_D  0xf800707f   436 #define MATCH_AMOOR_D 0x4000302f   437 #define MASK_AMOOR_D  0xf800707f   438 #define MATCH_AMOAND_D 0x6000302f   439 #define MASK_AMOAND_D  0xf800707f   440 #define MATCH_AMOMIN_D 0x8000302f   441 #define MASK_AMOMIN_D  0xf800707f   442 #define MATCH_AMOMAX_D 0xa000302f   443 #define MASK_AMOMAX_D  0xf800707f   444 #define MATCH_AMOMINU_D 0xc000302f   445 #define MASK_AMOMINU_D  0xf800707f   446 #define MATCH_AMOMAXU_D 0xe000302f   447 #define MASK_AMOMAXU_D  0xf800707f   448 #define MATCH_AMOSWAP_D 0x800302f   449 #define MASK_AMOSWAP_D  0xf800707f   450 #define MATCH_LR_D 0x1000302f   451 #define MASK_LR_D  0xf9f0707f   452 #define MATCH_SC_D 0x1800302f   453 #define MASK_SC_D  0xf800707f   454 #define MATCH_ECALL 0x73   455 #define MASK_ECALL  0xffffffff   456 #define MATCH_EBREAK 0x100073   457 #define MASK_EBREAK  0xffffffff   458 #define MATCH_URET 0x200073   459 #define MASK_URET  0xffffffff   460 #define MATCH_SRET 0x10200073   461 #define MASK_SRET  0xffffffff   462 #define MATCH_MRET 0x30200073   463 #define MASK_MRET  0xffffffff   464 #define MATCH_DRET 0x7b200073   465 #define MASK_DRET  0xffffffff   466 #define MATCH_SFENCE_VMA 0x12000073   467 #define MASK_SFENCE_VMA  0xfe007fff   468 #define MATCH_WFI 0x10500073   469 #define MASK_WFI  0xffffffff   470 #define MATCH_CSRRW 0x1073   471 #define MASK_CSRRW  0x707f   472 #define MATCH_CSRRS 0x2073   473 #define MASK_CSRRS  0x707f   474 #define MATCH_CSRRC 0x3073   475 #define MASK_CSRRC  0x707f   476 #define MATCH_CSRRWI 0x5073   477 #define MASK_CSRRWI  0x707f   478 #define MATCH_CSRRSI 0x6073   479 #define MASK_CSRRSI  0x707f   480 #define MATCH_CSRRCI 0x7073   481 #define MASK_CSRRCI  0x707f   482 #define MATCH_FADD_S 0x53   483 #define MASK_FADD_S  0xfe00007f   484 #define MATCH_FSUB_S 0x8000053   485 #define MASK_FSUB_S  0xfe00007f   486 #define MATCH_FMUL_S 0x10000053   487 #define MASK_FMUL_S  0xfe00007f   488 #define MATCH_FDIV_S 0x18000053   489 #define MASK_FDIV_S  0xfe00007f   490 #define MATCH_FSGNJ_S 0x20000053   491 #define MASK_FSGNJ_S  0xfe00707f   492 #define MATCH_FSGNJN_S 0x20001053   493 #define MASK_FSGNJN_S  0xfe00707f   494 #define MATCH_FSGNJX_S 0x20002053   495 #define MASK_FSGNJX_S  0xfe00707f   496 #define MATCH_FMIN_S 0x28000053   497 #define MASK_FMIN_S  0xfe00707f   498 #define MATCH_FMAX_S 0x28001053   499 #define MASK_FMAX_S  0xfe00707f   500 #define MATCH_FSQRT_S 0x58000053   501 #define MASK_FSQRT_S  0xfff0007f   502 #define MATCH_FADD_D 0x2000053   503 #define MASK_FADD_D  0xfe00007f   504 #define MATCH_FSUB_D 0xa000053   505 #define MASK_FSUB_D  0xfe00007f   506 #define MATCH_FMUL_D 0x12000053   507 #define MASK_FMUL_D  0xfe00007f   508 #define MATCH_FDIV_D 0x1a000053   509 #define MASK_FDIV_D  0xfe00007f   510 #define MATCH_FSGNJ_D 0x22000053   511 #define MASK_FSGNJ_D  0xfe00707f   512 #define MATCH_FSGNJN_D 0x22001053   513 #define MASK_FSGNJN_D  0xfe00707f   514 #define MATCH_FSGNJX_D 0x22002053   515 #define MASK_FSGNJX_D  0xfe00707f   516 #define MATCH_FMIN_D 0x2a000053   517 #define MASK_FMIN_D  0xfe00707f   518 #define MATCH_FMAX_D 0x2a001053   519 #define MASK_FMAX_D  0xfe00707f   520 #define MATCH_FCVT_S_D 0x40100053   521 #define MASK_FCVT_S_D  0xfff0007f   522 #define MATCH_FCVT_D_S 0x42000053   523 #define MASK_FCVT_D_S  0xfff0007f   524 #define MATCH_FSQRT_D 0x5a000053   525 #define MASK_FSQRT_D  0xfff0007f   526 #define MATCH_FADD_Q 0x6000053   527 #define MASK_FADD_Q  0xfe00007f   528 #define MATCH_FSUB_Q 0xe000053   529 #define MASK_FSUB_Q  0xfe00007f   530 #define MATCH_FMUL_Q 0x16000053   531 #define MASK_FMUL_Q  0xfe00007f   532 #define MATCH_FDIV_Q 0x1e000053   533 #define MASK_FDIV_Q  0xfe00007f   534 #define MATCH_FSGNJ_Q 0x26000053   535 #define MASK_FSGNJ_Q  0xfe00707f   536 #define MATCH_FSGNJN_Q 0x26001053   537 #define MASK_FSGNJN_Q  0xfe00707f   538 #define MATCH_FSGNJX_Q 0x26002053   539 #define MASK_FSGNJX_Q  0xfe00707f   540 #define MATCH_FMIN_Q 0x2e000053   541 #define MASK_FMIN_Q  0xfe00707f   542 #define MATCH_FMAX_Q 0x2e001053   543 #define MASK_FMAX_Q  0xfe00707f   544 #define MATCH_FCVT_S_Q 0x40300053   545 #define MASK_FCVT_S_Q  0xfff0007f   546 #define MATCH_FCVT_Q_S 0x46000053   547 #define MASK_FCVT_Q_S  0xfff0007f   548 #define MATCH_FCVT_D_Q 0x42300053   549 #define MASK_FCVT_D_Q  0xfff0007f   550 #define MATCH_FCVT_Q_D 0x46100053   551 #define MASK_FCVT_Q_D  0xfff0007f   552 #define MATCH_FSQRT_Q 0x5e000053   553 #define MASK_FSQRT_Q  0xfff0007f   554 #define MATCH_FLE_S 0xa0000053   555 #define MASK_FLE_S  0xfe00707f   556 #define MATCH_FLT_S 0xa0001053   557 #define MASK_FLT_S  0xfe00707f   558 #define MATCH_FEQ_S 0xa0002053   559 #define MASK_FEQ_S  0xfe00707f   560 #define MATCH_FLE_D 0xa2000053   561 #define MASK_FLE_D  0xfe00707f   562 #define MATCH_FLT_D 0xa2001053   563 #define MASK_FLT_D  0xfe00707f   564 #define MATCH_FEQ_D 0xa2002053   565 #define MASK_FEQ_D  0xfe00707f   566 #define MATCH_FLE_Q 0xa6000053   567 #define MASK_FLE_Q  0xfe00707f   568 #define MATCH_FLT_Q 0xa6001053   569 #define MASK_FLT_Q  0xfe00707f   570 #define MATCH_FEQ_Q 0xa6002053   571 #define MASK_FEQ_Q  0xfe00707f   572 #define MATCH_FCVT_W_S 0xc0000053   573 #define MASK_FCVT_W_S  0xfff0007f   574 #define MATCH_FCVT_WU_S 0xc0100053   575 #define MASK_FCVT_WU_S  0xfff0007f   576 #define MATCH_FCVT_L_S 0xc0200053   577 #define MASK_FCVT_L_S  0xfff0007f   578 #define MATCH_FCVT_LU_S 0xc0300053   579 #define MASK_FCVT_LU_S  0xfff0007f   580 #define MATCH_FMV_X_W 0xe0000053   581 #define MASK_FMV_X_W  0xfff0707f   582 #define MATCH_FCLASS_S 0xe0001053   583 #define MASK_FCLASS_S  0xfff0707f   584 #define MATCH_FCVT_W_D 0xc2000053   585 #define MASK_FCVT_W_D  0xfff0007f   586 #define MATCH_FCVT_WU_D 0xc2100053   587 #define MASK_FCVT_WU_D  0xfff0007f   588 #define MATCH_FCVT_L_D 0xc2200053   589 #define MASK_FCVT_L_D  0xfff0007f   590 #define MATCH_FCVT_LU_D 0xc2300053   591 #define MASK_FCVT_LU_D  0xfff0007f   592 #define MATCH_FMV_X_D 0xe2000053   593 #define MASK_FMV_X_D  0xfff0707f   594 #define MATCH_FCLASS_D 0xe2001053   595 #define MASK_FCLASS_D  0xfff0707f   596 #define MATCH_FCVT_W_Q 0xc6000053   597 #define MASK_FCVT_W_Q  0xfff0007f   598 #define MATCH_FCVT_WU_Q 0xc6100053   599 #define MASK_FCVT_WU_Q  0xfff0007f   600 #define MATCH_FCVT_L_Q 0xc6200053   601 #define MASK_FCVT_L_Q  0xfff0007f   602 #define MATCH_FCVT_LU_Q 0xc6300053   603 #define MASK_FCVT_LU_Q  0xfff0007f   604 #define MATCH_FMV_X_Q 0xe6000053   605 #define MASK_FMV_X_Q  0xfff0707f   606 #define MATCH_FCLASS_Q 0xe6001053   607 #define MASK_FCLASS_Q  0xfff0707f   608 #define MATCH_FCVT_S_W 0xd0000053   609 #define MASK_FCVT_S_W  0xfff0007f   610 #define MATCH_FCVT_S_WU 0xd0100053   611 #define MASK_FCVT_S_WU  0xfff0007f   612 #define MATCH_FCVT_S_L 0xd0200053   613 #define MASK_FCVT_S_L  0xfff0007f   614 #define MATCH_FCVT_S_LU 0xd0300053   615 #define MASK_FCVT_S_LU  0xfff0007f   616 #define MATCH_FMV_W_X 0xf0000053   617 #define MASK_FMV_W_X  0xfff0707f   618 #define MATCH_FCVT_D_W 0xd2000053   619 #define MASK_FCVT_D_W  0xfff0007f   620 #define MATCH_FCVT_D_WU 0xd2100053   621 #define MASK_FCVT_D_WU  0xfff0007f   622 #define MATCH_FCVT_D_L 0xd2200053   623 #define MASK_FCVT_D_L  0xfff0007f   624 #define MATCH_FCVT_D_LU 0xd2300053   625 #define MASK_FCVT_D_LU  0xfff0007f   626 #define MATCH_FMV_D_X 0xf2000053   627 #define MASK_FMV_D_X  0xfff0707f   628 #define MATCH_FCVT_Q_W 0xd6000053   629 #define MASK_FCVT_Q_W  0xfff0007f   630 #define MATCH_FCVT_Q_WU 0xd6100053   631 #define MASK_FCVT_Q_WU  0xfff0007f   632 #define MATCH_FCVT_Q_L 0xd6200053   633 #define MASK_FCVT_Q_L  0xfff0007f   634 #define MATCH_FCVT_Q_LU 0xd6300053   635 #define MASK_FCVT_Q_LU  0xfff0007f   636 #define MATCH_FMV_Q_X 0xf6000053   637 #define MASK_FMV_Q_X  0xfff0707f   638 #define MATCH_FLW 0x2007   639 #define MASK_FLW  0x707f   640 #define MATCH_FLD 0x3007   641 #define MASK_FLD  0x707f   642 #define MATCH_FLQ 0x4007   643 #define MASK_FLQ  0x707f   644 #define MATCH_FSW 0x2027   645 #define MASK_FSW  0x707f   646 #define MATCH_FSD 0x3027   647 #define MASK_FSD  0x707f   648 #define MATCH_FSQ 0x4027   649 #define MASK_FSQ  0x707f   650 #define MATCH_FMADD_S 0x43   651 #define MASK_FMADD_S  0x600007f   652 #define MATCH_FMSUB_S 0x47   653 #define MASK_FMSUB_S  0x600007f   654 #define MATCH_FNMSUB_S 0x4b   655 #define MASK_FNMSUB_S  0x600007f   656 #define MATCH_FNMADD_S 0x4f   657 #define MASK_FNMADD_S  0x600007f   658 #define MATCH_FMADD_D 0x2000043   659 #define MASK_FMADD_D  0x600007f   660 #define MATCH_FMSUB_D 0x2000047   661 #define MASK_FMSUB_D  0x600007f   662 #define MATCH_FNMSUB_D 0x200004b   663 #define MASK_FNMSUB_D  0x600007f   664 #define MATCH_FNMADD_D 0x200004f   665 #define MASK_FNMADD_D  0x600007f   666 #define MATCH_FMADD_Q 0x6000043   667 #define MASK_FMADD_Q  0x600007f   668 #define MATCH_FMSUB_Q 0x6000047   669 #define MASK_FMSUB_Q  0x600007f   670 #define MATCH_FNMSUB_Q 0x600004b   671 #define MASK_FNMSUB_Q  0x600007f   672 #define MATCH_FNMADD_Q 0x600004f   673 #define MASK_FNMADD_Q  0x600007f   674 #define MATCH_C_NOP 0x1   675 #define MASK_C_NOP  0xffff   676 #define MATCH_C_ADDI16SP 0x6101   677 #define MASK_C_ADDI16SP  0xef83   678 #define MATCH_C_JR 0x8002   679 #define MASK_C_JR  0xf07f   680 #define MATCH_C_JALR 0x9002   681 #define MASK_C_JALR  0xf07f   682 #define MATCH_C_EBREAK 0x9002   683 #define MASK_C_EBREAK  0xffff   684 #define MATCH_C_LD 0x6000   685 #define MASK_C_LD  0xe003   686 #define MATCH_C_SD 0xe000   687 #define MASK_C_SD  0xe003   688 #define MATCH_C_ADDIW 0x2001   689 #define MASK_C_ADDIW  0xe003   690 #define MATCH_C_LDSP 0x6002   691 #define MASK_C_LDSP  0xe003   692 #define MATCH_C_SDSP 0xe002   693 #define MASK_C_SDSP  0xe003   694 #define MATCH_C_ADDI4SPN 0x0   695 #define MASK_C_ADDI4SPN  0xe003   696 #define MATCH_C_FLD 0x2000   697 #define MASK_C_FLD  0xe003   698 #define MATCH_C_LW 0x4000   699 #define MASK_C_LW  0xe003   700 #define MATCH_C_FLW 0x6000   701 #define MASK_C_FLW  0xe003   702 #define MATCH_C_FSD 0xa000   703 #define MASK_C_FSD  0xe003   704 #define MATCH_C_SW 0xc000   705 #define MASK_C_SW  0xe003   706 #define MATCH_C_FSW 0xe000   707 #define MASK_C_FSW  0xe003   708 #define MATCH_C_ADDI 0x1   709 #define MASK_C_ADDI  0xe003   710 #define MATCH_C_JAL 0x2001   711 #define MASK_C_JAL  0xe003   712 #define MATCH_C_LI 0x4001   713 #define MASK_C_LI  0xe003   714 #define MATCH_C_LUI 0x6001   715 #define MASK_C_LUI  0xe003   716 #define MATCH_C_SRLI 0x8001   717 #define MASK_C_SRLI  0xec03   718 #define MATCH_C_SRAI 0x8401   719 #define MASK_C_SRAI  0xec03   720 #define MATCH_C_ANDI 0x8801   721 #define MASK_C_ANDI  0xec03   722 #define MATCH_C_SUB 0x8c01   723 #define MASK_C_SUB  0xfc63   724 #define MATCH_C_XOR 0x8c21   725 #define MASK_C_XOR  0xfc63   726 #define MATCH_C_OR 0x8c41   727 #define MASK_C_OR  0xfc63   728 #define MATCH_C_AND 0x8c61   729 #define MASK_C_AND  0xfc63   730 #define MATCH_C_SUBW 0x9c01   731 #define MASK_C_SUBW  0xfc63   732 #define MATCH_C_ADDW 0x9c21   733 #define MASK_C_ADDW  0xfc63   734 #define MATCH_C_J 0xa001   735 #define MASK_C_J  0xe003   736 #define MATCH_C_BEQZ 0xc001   737 #define MASK_C_BEQZ  0xe003   738 #define MATCH_C_BNEZ 0xe001   739 #define MASK_C_BNEZ  0xe003   740 #define MATCH_C_SLLI 0x2   741 #define MASK_C_SLLI  0xe003   742 #define MATCH_C_FLDSP 0x2002   743 #define MASK_C_FLDSP  0xe003   744 #define MATCH_C_LWSP 0x4002   745 #define MASK_C_LWSP  0xe003   746 #define MATCH_C_FLWSP 0x6002   747 #define MASK_C_FLWSP  0xe003   748 #define MATCH_C_MV 0x8002   749 #define MASK_C_MV  0xf003   750 #define MATCH_C_ADD 0x9002   751 #define MASK_C_ADD  0xf003   752 #define MATCH_C_FSDSP 0xa002   753 #define MASK_C_FSDSP  0xe003   754 #define MATCH_C_SWSP 0xc002   755 #define MASK_C_SWSP  0xe003   756 #define MATCH_C_FSWSP 0xe002   757 #define MASK_C_FSWSP  0xe003   758 #define MATCH_CUSTOM0 0xb   759 #define MASK_CUSTOM0  0x707f   760 #define MATCH_CUSTOM0_RS1 0x200b   761 #define MASK_CUSTOM0_RS1  0x707f   762 #define MATCH_CUSTOM0_RS1_RS2 0x300b   763 #define MASK_CUSTOM0_RS1_RS2  0x707f   764 #define MATCH_CUSTOM0_RD 0x400b   765 #define MASK_CUSTOM0_RD  0x707f   766 #define MATCH_CUSTOM0_RD_RS1 0x600b   767 #define MASK_CUSTOM0_RD_RS1  0x707f   768 #define MATCH_CUSTOM0_RD_RS1_RS2 0x700b   769 #define MASK_CUSTOM0_RD_RS1_RS2  0x707f   770 #define MATCH_CUSTOM1 0x2b   771 #define MASK_CUSTOM1  0x707f   772 #define MATCH_CUSTOM1_RS1 0x202b   773 #define MASK_CUSTOM1_RS1  0x707f   774 #define MATCH_CUSTOM1_RS1_RS2 0x302b   775 #define MASK_CUSTOM1_RS1_RS2  0x707f   776 #define MATCH_CUSTOM1_RD 0x402b   777 #define MASK_CUSTOM1_RD  0x707f   778 #define MATCH_CUSTOM1_RD_RS1 0x602b   779 #define MASK_CUSTOM1_RD_RS1  0x707f   780 #define MATCH_CUSTOM1_RD_RS1_RS2 0x702b   781 #define MASK_CUSTOM1_RD_RS1_RS2  0x707f   782 #define MATCH_CUSTOM2 0x5b   783 #define MASK_CUSTOM2  0x707f   784 #define MATCH_CUSTOM2_RS1 0x205b   785 #define MASK_CUSTOM2_RS1  0x707f   786 #define MATCH_CUSTOM2_RS1_RS2 0x305b   787 #define MASK_CUSTOM2_RS1_RS2  0x707f   788 #define MATCH_CUSTOM2_RD 0x405b   789 #define MASK_CUSTOM2_RD  0x707f   790 #define MATCH_CUSTOM2_RD_RS1 0x605b   791 #define MASK_CUSTOM2_RD_RS1  0x707f   792 #define MATCH_CUSTOM2_RD_RS1_RS2 0x705b   793 #define MASK_CUSTOM2_RD_RS1_RS2  0x707f   794 #define MATCH_CUSTOM3 0x7b   795 #define MASK_CUSTOM3  0x707f   796 #define MATCH_CUSTOM3_RS1 0x207b   797 #define MASK_CUSTOM3_RS1  0x707f   798 #define MATCH_CUSTOM3_RS1_RS2 0x307b   799 #define MASK_CUSTOM3_RS1_RS2  0x707f   800 #define MATCH_CUSTOM3_RD 0x407b   801 #define MASK_CUSTOM3_RD  0x707f   802 #define MATCH_CUSTOM3_RD_RS1 0x607b   803 #define MASK_CUSTOM3_RD_RS1  0x707f   804 #define MATCH_CUSTOM3_RD_RS1_RS2 0x707b   805 #define MASK_CUSTOM3_RD_RS1_RS2  0x707f   806 #define CSR_FFLAGS 0x1   809 #define CSR_CYCLE 0xc00   810 #define CSR_TIME 0xc01   811 #define CSR_INSTRET 0xc02   812 #define CSR_HPMCOUNTER3 0xc03   813 #define CSR_HPMCOUNTER4 0xc04   814 #define CSR_HPMCOUNTER5 0xc05   815 #define CSR_HPMCOUNTER6 0xc06   816 #define CSR_HPMCOUNTER7 0xc07   817 #define CSR_HPMCOUNTER8 0xc08   818 #define CSR_HPMCOUNTER9 0xc09   819 #define CSR_HPMCOUNTER10 0xc0a   820 #define CSR_HPMCOUNTER11 0xc0b   821 #define CSR_HPMCOUNTER12 0xc0c   822 #define CSR_HPMCOUNTER13 0xc0d   823 #define CSR_HPMCOUNTER14 0xc0e   824 #define CSR_HPMCOUNTER15 0xc0f   825 #define CSR_HPMCOUNTER16 0xc10   826 #define CSR_HPMCOUNTER17 0xc11   827 #define CSR_HPMCOUNTER18 0xc12   828 #define CSR_HPMCOUNTER19 0xc13   829 #define CSR_HPMCOUNTER20 0xc14   830 #define CSR_HPMCOUNTER21 0xc15   831 #define CSR_HPMCOUNTER22 0xc16   832 #define CSR_HPMCOUNTER23 0xc17   833 #define CSR_HPMCOUNTER24 0xc18   834 #define CSR_HPMCOUNTER25 0xc19   835 #define CSR_HPMCOUNTER26 0xc1a   836 #define CSR_HPMCOUNTER27 0xc1b   837 #define CSR_HPMCOUNTER28 0xc1c   838 #define CSR_HPMCOUNTER29 0xc1d   839 #define CSR_HPMCOUNTER30 0xc1e   840 #define CSR_HPMCOUNTER31 0xc1f   841 #define CSR_SSTATUS 0x100   842 #define CSR_SIE 0x104   843 #define CSR_STVEC 0x105   844 #define CSR_SCOUNTEREN 0x106   845 #define CSR_SSCRATCH 0x140   846 #define CSR_SEPC 0x141   847 #define CSR_SCAUSE 0x142   848 #define CSR_SBADADDR 0x143   849 #define CSR_SIP 0x144   850 #define CSR_SPTBR 0x180   851 #define CSR_MSTATUS 0x300   852 #define CSR_MISA 0x301   853 #define CSR_MEDELEG 0x302   854 #define CSR_MIDELEG 0x303   855 #define CSR_MIE 0x304   856 #define CSR_MTVEC 0x305   857 #define CSR_MCOUNTEREN 0x306   858 #define CSR_MSCRATCH 0x340   859 #define CSR_MEPC 0x341   860 #define CSR_MCAUSE 0x342   861 #define CSR_MBADADDR 0x343   862 #define CSR_MIP 0x344   863 #define CSR_PMPCFG0 0x3a0   864 #define CSR_PMPCFG1 0x3a1   865 #define CSR_PMPCFG2 0x3a2   866 #define CSR_PMPCFG3 0x3a3   867 #define CSR_PMPADDR0 0x3b0   868 #define CSR_PMPADDR1 0x3b1   869 #define CSR_PMPADDR2 0x3b2   870 #define CSR_PMPADDR3 0x3b3   871 #define CSR_PMPADDR4 0x3b4   872 #define CSR_PMPADDR5 0x3b5   873 #define CSR_PMPADDR6 0x3b6   874 #define CSR_PMPADDR7 0x3b7   875 #define CSR_PMPADDR8 0x3b8   876 #define CSR_PMPADDR9 0x3b9   877 #define CSR_PMPADDR10 0x3ba   878 #define CSR_PMPADDR11 0x3bb   879 #define CSR_PMPADDR12 0x3bc   880 #define CSR_PMPADDR13 0x3bd   881 #define CSR_PMPADDR14 0x3be   882 #define CSR_PMPADDR15 0x3bf   883 #define CSR_TSELECT 0x7a0   884 #define CSR_TDATA1 0x7a1   885 #define CSR_TDATA2 0x7a2   886 #define CSR_TDATA3 0x7a3   887 #define CSR_DCSR 0x7b0   888 #define CSR_DPC 0x7b1   889 #define CSR_DSCRATCH 0x7b2   890 #define CSR_MCYCLE 0xb00   891 #define CSR_MINSTRET 0xb02   892 #define CSR_MHPMCOUNTER3 0xb03   893 #define CSR_MHPMCOUNTER4 0xb04   894 #define CSR_MHPMCOUNTER5 0xb05   895 #define CSR_MHPMCOUNTER6 0xb06   896 #define CSR_MHPMCOUNTER7 0xb07   897 #define CSR_MHPMCOUNTER8 0xb08   898 #define CSR_MHPMCOUNTER9 0xb09   899 #define CSR_MHPMCOUNTER10 0xb0a   900 #define CSR_MHPMCOUNTER11 0xb0b   901 #define CSR_MHPMCOUNTER12 0xb0c   902 #define CSR_MHPMCOUNTER13 0xb0d   903 #define CSR_MHPMCOUNTER14 0xb0e   904 #define CSR_MHPMCOUNTER15 0xb0f   905 #define CSR_MHPMCOUNTER16 0xb10   906 #define CSR_MHPMCOUNTER17 0xb11   907 #define CSR_MHPMCOUNTER18 0xb12   908 #define CSR_MHPMCOUNTER19 0xb13   909 #define CSR_MHPMCOUNTER20 0xb14   910 #define CSR_MHPMCOUNTER21 0xb15   911 #define CSR_MHPMCOUNTER22 0xb16   912 #define CSR_MHPMCOUNTER23 0xb17   913 #define CSR_MHPMCOUNTER24 0xb18   914 #define CSR_MHPMCOUNTER25 0xb19   915 #define CSR_MHPMCOUNTER26 0xb1a   916 #define CSR_MHPMCOUNTER27 0xb1b   917 #define CSR_MHPMCOUNTER28 0xb1c   918 #define CSR_MHPMCOUNTER29 0xb1d   919 #define CSR_MHPMCOUNTER30 0xb1e   920 #define CSR_MHPMCOUNTER31 0xb1f   921 #define CSR_MHPMEVENT3 0x323   922 #define CSR_MHPMEVENT4 0x324   923 #define CSR_MHPMEVENT5 0x325   924 #define CSR_MHPMEVENT6 0x326   925 #define CSR_MHPMEVENT7 0x327   926 #define CSR_MHPMEVENT8 0x328   927 #define CSR_MHPMEVENT9 0x329   928 #define CSR_MHPMEVENT10 0x32a   929 #define CSR_MHPMEVENT11 0x32b   930 #define CSR_MHPMEVENT12 0x32c   931 #define CSR_MHPMEVENT13 0x32d   932 #define CSR_MHPMEVENT14 0x32e   933 #define CSR_MHPMEVENT15 0x32f   934 #define CSR_MHPMEVENT16 0x330   935 #define CSR_MHPMEVENT17 0x331   936 #define CSR_MHPMEVENT18 0x332   937 #define CSR_MHPMEVENT19 0x333   938 #define CSR_MHPMEVENT20 0x334   939 #define CSR_MHPMEVENT21 0x335   940 #define CSR_MHPMEVENT22 0x336   941 #define CSR_MHPMEVENT23 0x337   942 #define CSR_MHPMEVENT24 0x338   943 #define CSR_MHPMEVENT25 0x339   944 #define CSR_MHPMEVENT26 0x33a   945 #define CSR_MHPMEVENT27 0x33b   946 #define CSR_MHPMEVENT28 0x33c   947 #define CSR_MHPMEVENT29 0x33d   948 #define CSR_MHPMEVENT30 0x33e   949 #define CSR_MHPMEVENT31 0x33f   950 #define CSR_MVENDORID 0xf11   951 #define CSR_MARCHID 0xf12   952 #define CSR_MIMPID 0xf13   953 #define CSR_MHARTID 0xf14   954 #define CSR_CYCLEH 0xc80   955 #define CSR_TIMEH 0xc81   956 #define CSR_INSTRETH 0xc82   957 #define CSR_HPMCOUNTER3H 0xc83   958 #define CSR_HPMCOUNTER4H 0xc84   959 #define CSR_HPMCOUNTER5H 0xc85   960 #define CSR_HPMCOUNTER6H 0xc86   961 #define CSR_HPMCOUNTER7H 0xc87   962 #define CSR_HPMCOUNTER8H 0xc88   963 #define CSR_HPMCOUNTER9H 0xc89   964 #define CSR_HPMCOUNTER10H 0xc8a   965 #define CSR_HPMCOUNTER11H 0xc8b   966 #define CSR_HPMCOUNTER12H 0xc8c   967 #define CSR_HPMCOUNTER13H 0xc8d   968 #define CSR_HPMCOUNTER14H 0xc8e   969 #define CSR_HPMCOUNTER15H 0xc8f   970 #define CSR_HPMCOUNTER16H 0xc90   971 #define CSR_HPMCOUNTER17H 0xc91   972 #define CSR_HPMCOUNTER18H 0xc92   973 #define CSR_HPMCOUNTER19H 0xc93   974 #define CSR_HPMCOUNTER20H 0xc94   975 #define CSR_HPMCOUNTER21H 0xc95   976 #define CSR_HPMCOUNTER22H 0xc96   977 #define CSR_HPMCOUNTER23H 0xc97   978 #define CSR_HPMCOUNTER24H 0xc98   979 #define CSR_HPMCOUNTER25H 0xc99   980 #define CSR_HPMCOUNTER26H 0xc9a   981 #define CSR_HPMCOUNTER27H 0xc9b   982 #define CSR_HPMCOUNTER28H 0xc9c   983 #define CSR_HPMCOUNTER29H 0xc9d   984 #define CSR_HPMCOUNTER30H 0xc9e   985 #define CSR_HPMCOUNTER31H 0xc9f   986 #define CSR_MCYCLEH 0xb80   987 #define CSR_MINSTRETH 0xb82   988 #define CSR_MHPMCOUNTER3H 0xb83   989 #define CSR_MHPMCOUNTER4H 0xb84   990 #define CSR_MHPMCOUNTER5H 0xb85   991 #define CSR_MHPMCOUNTER6H 0xb86   992 #define CSR_MHPMCOUNTER7H 0xb87   993 #define CSR_MHPMCOUNTER8H 0xb88   994 #define CSR_MHPMCOUNTER9H 0xb89   995 #define CSR_MHPMCOUNTER10H 0xb8a   996 #define CSR_MHPMCOUNTER11H 0xb8b   997 #define CSR_MHPMCOUNTER12H 0xb8c   998 #define CSR_MHPMCOUNTER13H 0xb8d   999 #define CSR_MHPMCOUNTER14H 0xb8e  1000 #define CSR_MHPMCOUNTER15H 0xb8f  1001 #define CSR_MHPMCOUNTER16H 0xb90  1002 #define CSR_MHPMCOUNTER17H 0xb91  1003 #define CSR_MHPMCOUNTER18H 0xb92  1004 #define CSR_MHPMCOUNTER19H 0xb93  1005 #define CSR_MHPMCOUNTER20H 0xb94  1006 #define CSR_MHPMCOUNTER21H 0xb95  1007 #define CSR_MHPMCOUNTER22H 0xb96  1008 #define CSR_MHPMCOUNTER23H 0xb97  1009 #define CSR_MHPMCOUNTER24H 0xb98  1010 #define CSR_MHPMCOUNTER25H 0xb99  1011 #define CSR_MHPMCOUNTER26H 0xb9a  1012 #define CSR_MHPMCOUNTER27H 0xb9b  1013 #define CSR_MHPMCOUNTER28H 0xb9c  1014 #define CSR_MHPMCOUNTER29H 0xb9d  1015 #define CSR_MHPMCOUNTER30H 0xb9e  1016 #define CSR_MHPMCOUNTER31H 0xb9f  1017 #define CAUSE_MISALIGNED_FETCH 0x0  1018 #define CAUSE_FETCH_ACCESS 0x1  1019 #define CAUSE_ILLEGAL_INSTRUCTION 0x2  1020 #define CAUSE_BREAKPOINT 0x3  1021 #define CAUSE_MISALIGNED_LOAD 0x4  1022 #define CAUSE_LOAD_ACCESS 0x5  1023 #define CAUSE_MISALIGNED_STORE 0x6  1024 #define CAUSE_STORE_ACCESS 0x7  1025 #define CAUSE_USER_ECALL 0x8  1026 #define CAUSE_SUPERVISOR_ECALL 0x9  1027 #define CAUSE_HYPERVISOR_ECALL 0xa  1028 #define CAUSE_MACHINE_ECALL 0xb  1029 #define CAUSE_FETCH_PAGE_FAULT 0xc  1030 #define CAUSE_LOAD_PAGE_FAULT 0xd  1031 #define CAUSE_STORE_PAGE_FAULT 0xf  1034 DECLARE_INSN(beq, MATCH_BEQ, MASK_BEQ)
  1035 DECLARE_INSN(bne, MATCH_BNE, MASK_BNE)
  1036 DECLARE_INSN(blt, MATCH_BLT, MASK_BLT)
  1037 DECLARE_INSN(bge, MATCH_BGE, MASK_BGE)
  1038 DECLARE_INSN(bltu, MATCH_BLTU, MASK_BLTU)
  1039 DECLARE_INSN(bgeu, MATCH_BGEU, MASK_BGEU)
  1040 DECLARE_INSN(jalr, MATCH_JALR, MASK_JALR)
  1041 DECLARE_INSN(jal, MATCH_JAL, MASK_JAL)
  1042 DECLARE_INSN(lui, MATCH_LUI, MASK_LUI)
  1043 DECLARE_INSN(auipc, MATCH_AUIPC, MASK_AUIPC)
  1044 DECLARE_INSN(addi, MATCH_ADDI, MASK_ADDI)
  1045 DECLARE_INSN(slli, MATCH_SLLI, MASK_SLLI)
  1046 DECLARE_INSN(slti, MATCH_SLTI, MASK_SLTI)
  1047 DECLARE_INSN(sltiu, MATCH_SLTIU, MASK_SLTIU)
  1048 DECLARE_INSN(xori, MATCH_XORI, MASK_XORI)
  1049 DECLARE_INSN(srli, MATCH_SRLI, MASK_SRLI)
  1050 DECLARE_INSN(srai, MATCH_SRAI, MASK_SRAI)
  1051 DECLARE_INSN(ori, MATCH_ORI, MASK_ORI)
  1052 DECLARE_INSN(andi, MATCH_ANDI, MASK_ANDI)
  1053 DECLARE_INSN(add, MATCH_ADD, MASK_ADD)
  1054 DECLARE_INSN(sub, MATCH_SUB, MASK_SUB)
  1055 DECLARE_INSN(sll, MATCH_SLL, MASK_SLL)
  1056 DECLARE_INSN(slt, MATCH_SLT, MASK_SLT)
  1057 DECLARE_INSN(sltu, MATCH_SLTU, MASK_SLTU)
  1058 DECLARE_INSN(xor, MATCH_XOR, MASK_XOR)
  1059 DECLARE_INSN(srl, MATCH_SRL, MASK_SRL)
  1060 DECLARE_INSN(sra, MATCH_SRA, MASK_SRA)
  1061 DECLARE_INSN( or , MATCH_OR, MASK_OR)
  1062 DECLARE_INSN( and , MATCH_AND, MASK_AND)
  1063 DECLARE_INSN(addiw, MATCH_ADDIW, MASK_ADDIW)
  1064 DECLARE_INSN(slliw, MATCH_SLLIW, MASK_SLLIW)
  1065 DECLARE_INSN(srliw, MATCH_SRLIW, MASK_SRLIW)
  1066 DECLARE_INSN(sraiw, MATCH_SRAIW, MASK_SRAIW)
  1067 DECLARE_INSN(addw, MATCH_ADDW, MASK_ADDW)
  1068 DECLARE_INSN(subw, MATCH_SUBW, MASK_SUBW)
  1069 DECLARE_INSN(sllw, MATCH_SLLW, MASK_SLLW)
  1070 DECLARE_INSN(srlw, MATCH_SRLW, MASK_SRLW)
  1071 DECLARE_INSN(sraw, MATCH_SRAW, MASK_SRAW)
  1072 DECLARE_INSN(lb, MATCH_LB, MASK_LB)
  1073 DECLARE_INSN(lh, MATCH_LH, MASK_LH)
  1074 DECLARE_INSN(lw, MATCH_LW, MASK_LW)
  1075 DECLARE_INSN(ld, MATCH_LD, MASK_LD)
  1076 DECLARE_INSN(lbu, MATCH_LBU, MASK_LBU)
  1077 DECLARE_INSN(lhu, MATCH_LHU, MASK_LHU)
  1078 DECLARE_INSN(lwu, MATCH_LWU, MASK_LWU)
  1079 DECLARE_INSN(sb, MATCH_SB, MASK_SB)
  1080 DECLARE_INSN(sh, MATCH_SH, MASK_SH)
  1081 DECLARE_INSN(sw, MATCH_SW, MASK_SW)
  1082 DECLARE_INSN(sd, MATCH_SD, MASK_SD)
  1083 DECLARE_INSN(fence, MATCH_FENCE, MASK_FENCE)
  1084 DECLARE_INSN(fence_i, MATCH_FENCE_I, MASK_FENCE_I)
  1085 DECLARE_INSN(mul, MATCH_MUL, MASK_MUL)
  1086 DECLARE_INSN(mulh, MATCH_MULH, MASK_MULH)
  1087 DECLARE_INSN(mulhsu, MATCH_MULHSU, MASK_MULHSU)
  1088 DECLARE_INSN(mulhu, MATCH_MULHU, MASK_MULHU)
  1089 DECLARE_INSN(div, MATCH_DIV, MASK_DIV)
  1090 DECLARE_INSN(divu, MATCH_DIVU, MASK_DIVU)
  1091 DECLARE_INSN(rem, MATCH_REM, MASK_REM)
  1092 DECLARE_INSN(remu, MATCH_REMU, MASK_REMU)
  1093 DECLARE_INSN(mulw, MATCH_MULW, MASK_MULW)
  1094 DECLARE_INSN(divw, MATCH_DIVW, MASK_DIVW)
  1095 DECLARE_INSN(divuw, MATCH_DIVUW, MASK_DIVUW)
  1096 DECLARE_INSN(remw, MATCH_REMW, MASK_REMW)
  1097 DECLARE_INSN(remuw, MATCH_REMUW, MASK_REMUW)
  1098 DECLARE_INSN(amoadd_w, MATCH_AMOADD_W, MASK_AMOADD_W)
  1099 DECLARE_INSN(amoxor_w, MATCH_AMOXOR_W, MASK_AMOXOR_W)
  1100 DECLARE_INSN(amoor_w, MATCH_AMOOR_W, MASK_AMOOR_W)
  1101 DECLARE_INSN(amoand_w, MATCH_AMOAND_W, MASK_AMOAND_W)
  1102 DECLARE_INSN(amomin_w, MATCH_AMOMIN_W, MASK_AMOMIN_W)
  1103 DECLARE_INSN(amomax_w, MATCH_AMOMAX_W, MASK_AMOMAX_W)
  1104 DECLARE_INSN(amominu_w, MATCH_AMOMINU_W, MASK_AMOMINU_W)
  1105 DECLARE_INSN(amomaxu_w, MATCH_AMOMAXU_W, MASK_AMOMAXU_W)
  1106 DECLARE_INSN(amoswap_w, MATCH_AMOSWAP_W, MASK_AMOSWAP_W)
  1107 DECLARE_INSN(lr_w, MATCH_LR_W, MASK_LR_W)
  1108 DECLARE_INSN(sc_w, MATCH_SC_W, MASK_SC_W)
  1109 DECLARE_INSN(amoadd_d, MATCH_AMOADD_D, MASK_AMOADD_D)
  1110 DECLARE_INSN(amoxor_d, MATCH_AMOXOR_D, MASK_AMOXOR_D)
  1111 DECLARE_INSN(amoor_d, MATCH_AMOOR_D, MASK_AMOOR_D)
  1112 DECLARE_INSN(amoand_d, MATCH_AMOAND_D, MASK_AMOAND_D)
  1113 DECLARE_INSN(amomin_d, MATCH_AMOMIN_D, MASK_AMOMIN_D)
  1114 DECLARE_INSN(amomax_d, MATCH_AMOMAX_D, MASK_AMOMAX_D)
  1115 DECLARE_INSN(amominu_d, MATCH_AMOMINU_D, MASK_AMOMINU_D)
  1116 DECLARE_INSN(amomaxu_d, MATCH_AMOMAXU_D, MASK_AMOMAXU_D)
  1117 DECLARE_INSN(amoswap_d, MATCH_AMOSWAP_D, MASK_AMOSWAP_D)
  1118 DECLARE_INSN(lr_d, MATCH_LR_D, MASK_LR_D)
  1119 DECLARE_INSN(sc_d, MATCH_SC_D, MASK_SC_D)
  1120 DECLARE_INSN(ecall, MATCH_ECALL, MASK_ECALL)
  1121 DECLARE_INSN(ebreak, MATCH_EBREAK, MASK_EBREAK)
  1122 DECLARE_INSN(uret, MATCH_URET, MASK_URET)
  1123 DECLARE_INSN(sret, MATCH_SRET, MASK_SRET)
  1124 DECLARE_INSN(mret, MATCH_MRET, MASK_MRET)
  1125 DECLARE_INSN(dret, MATCH_DRET, MASK_DRET)
  1126 DECLARE_INSN(sfence_vma, MATCH_SFENCE_VMA, MASK_SFENCE_VMA)
  1127 DECLARE_INSN(wfi, MATCH_WFI, MASK_WFI)
  1128 DECLARE_INSN(csrrw, MATCH_CSRRW, MASK_CSRRW)
  1129 DECLARE_INSN(csrrs, MATCH_CSRRS, MASK_CSRRS)
  1130 DECLARE_INSN(csrrc, MATCH_CSRRC, MASK_CSRRC)
  1131 DECLARE_INSN(csrrwi, MATCH_CSRRWI, MASK_CSRRWI)
  1132 DECLARE_INSN(csrrsi, MATCH_CSRRSI, MASK_CSRRSI)
  1133 DECLARE_INSN(csrrci, MATCH_CSRRCI, MASK_CSRRCI)
  1134 DECLARE_INSN(fadd_s, MATCH_FADD_S, MASK_FADD_S)
  1135 DECLARE_INSN(fsub_s, MATCH_FSUB_S, MASK_FSUB_S)
  1136 DECLARE_INSN(fmul_s, MATCH_FMUL_S, MASK_FMUL_S)
  1137 DECLARE_INSN(fdiv_s, MATCH_FDIV_S, MASK_FDIV_S)
  1138 DECLARE_INSN(fsgnj_s, MATCH_FSGNJ_S, MASK_FSGNJ_S)
  1139 DECLARE_INSN(fsgnjn_s, MATCH_FSGNJN_S, MASK_FSGNJN_S)
  1140 DECLARE_INSN(fsgnjx_s, MATCH_FSGNJX_S, MASK_FSGNJX_S)
  1141 DECLARE_INSN(fmin_s, MATCH_FMIN_S, MASK_FMIN_S)
  1142 DECLARE_INSN(fmax_s, MATCH_FMAX_S, MASK_FMAX_S)
  1143 DECLARE_INSN(fsqrt_s, MATCH_FSQRT_S, MASK_FSQRT_S)
  1144 DECLARE_INSN(fadd_d, MATCH_FADD_D, MASK_FADD_D)
  1145 DECLARE_INSN(fsub_d, MATCH_FSUB_D, MASK_FSUB_D)
  1146 DECLARE_INSN(fmul_d, MATCH_FMUL_D, MASK_FMUL_D)
  1147 DECLARE_INSN(fdiv_d, MATCH_FDIV_D, MASK_FDIV_D)
  1148 DECLARE_INSN(fsgnj_d, MATCH_FSGNJ_D, MASK_FSGNJ_D)
  1149 DECLARE_INSN(fsgnjn_d, MATCH_FSGNJN_D, MASK_FSGNJN_D)
  1150 DECLARE_INSN(fsgnjx_d, MATCH_FSGNJX_D, MASK_FSGNJX_D)
  1151 DECLARE_INSN(fmin_d, MATCH_FMIN_D, MASK_FMIN_D)
  1152 DECLARE_INSN(fmax_d, MATCH_FMAX_D, MASK_FMAX_D)
  1153 DECLARE_INSN(fcvt_s_d, MATCH_FCVT_S_D, MASK_FCVT_S_D)
  1154 DECLARE_INSN(fcvt_d_s, MATCH_FCVT_D_S, MASK_FCVT_D_S)
  1155 DECLARE_INSN(fsqrt_d, MATCH_FSQRT_D, MASK_FSQRT_D)
  1156 DECLARE_INSN(fadd_q, MATCH_FADD_Q, MASK_FADD_Q)
  1157 DECLARE_INSN(fsub_q, MATCH_FSUB_Q, MASK_FSUB_Q)
  1158 DECLARE_INSN(fmul_q, MATCH_FMUL_Q, MASK_FMUL_Q)
  1159 DECLARE_INSN(fdiv_q, MATCH_FDIV_Q, MASK_FDIV_Q)
  1160 DECLARE_INSN(fsgnj_q, MATCH_FSGNJ_Q, MASK_FSGNJ_Q)
  1161 DECLARE_INSN(fsgnjn_q, MATCH_FSGNJN_Q, MASK_FSGNJN_Q)
  1162 DECLARE_INSN(fsgnjx_q, MATCH_FSGNJX_Q, MASK_FSGNJX_Q)
  1163 DECLARE_INSN(fmin_q, MATCH_FMIN_Q, MASK_FMIN_Q)
  1164 DECLARE_INSN(fmax_q, MATCH_FMAX_Q, MASK_FMAX_Q)
  1165 DECLARE_INSN(fcvt_s_q, MATCH_FCVT_S_Q, MASK_FCVT_S_Q)
  1166 DECLARE_INSN(fcvt_q_s, MATCH_FCVT_Q_S, MASK_FCVT_Q_S)
  1167 DECLARE_INSN(fcvt_d_q, MATCH_FCVT_D_Q, MASK_FCVT_D_Q)
  1168 DECLARE_INSN(fcvt_q_d, MATCH_FCVT_Q_D, MASK_FCVT_Q_D)
  1169 DECLARE_INSN(fsqrt_q, MATCH_FSQRT_Q, MASK_FSQRT_Q)
  1170 DECLARE_INSN(fle_s, MATCH_FLE_S, MASK_FLE_S)
  1171 DECLARE_INSN(flt_s, MATCH_FLT_S, MASK_FLT_S)
  1172 DECLARE_INSN(feq_s, MATCH_FEQ_S, MASK_FEQ_S)
  1173 DECLARE_INSN(fle_d, MATCH_FLE_D, MASK_FLE_D)
  1174 DECLARE_INSN(flt_d, MATCH_FLT_D, MASK_FLT_D)
  1175 DECLARE_INSN(feq_d, MATCH_FEQ_D, MASK_FEQ_D)
  1176 DECLARE_INSN(fle_q, MATCH_FLE_Q, MASK_FLE_Q)
  1177 DECLARE_INSN(flt_q, MATCH_FLT_Q, MASK_FLT_Q)
  1178 DECLARE_INSN(feq_q, MATCH_FEQ_Q, MASK_FEQ_Q)
  1179 DECLARE_INSN(fcvt_w_s, MATCH_FCVT_W_S, MASK_FCVT_W_S)
  1180 DECLARE_INSN(fcvt_wu_s, MATCH_FCVT_WU_S, MASK_FCVT_WU_S)
  1181 DECLARE_INSN(fcvt_l_s, MATCH_FCVT_L_S, MASK_FCVT_L_S)
  1182 DECLARE_INSN(fcvt_lu_s, MATCH_FCVT_LU_S, MASK_FCVT_LU_S)
  1183 DECLARE_INSN(fmv_x_w, MATCH_FMV_X_W, MASK_FMV_X_W)
  1184 DECLARE_INSN(fclass_s, MATCH_FCLASS_S, MASK_FCLASS_S)
  1185 DECLARE_INSN(fcvt_w_d, MATCH_FCVT_W_D, MASK_FCVT_W_D)
  1186 DECLARE_INSN(fcvt_wu_d, MATCH_FCVT_WU_D, MASK_FCVT_WU_D)
  1187 DECLARE_INSN(fcvt_l_d, MATCH_FCVT_L_D, MASK_FCVT_L_D)
  1188 DECLARE_INSN(fcvt_lu_d, MATCH_FCVT_LU_D, MASK_FCVT_LU_D)
  1189 DECLARE_INSN(fmv_x_d, MATCH_FMV_X_D, MASK_FMV_X_D)
  1190 DECLARE_INSN(fclass_d, MATCH_FCLASS_D, MASK_FCLASS_D)
  1191 DECLARE_INSN(fcvt_w_q, MATCH_FCVT_W_Q, MASK_FCVT_W_Q)
  1192 DECLARE_INSN(fcvt_wu_q, MATCH_FCVT_WU_Q, MASK_FCVT_WU_Q)
  1193 DECLARE_INSN(fcvt_l_q, MATCH_FCVT_L_Q, MASK_FCVT_L_Q)
  1194 DECLARE_INSN(fcvt_lu_q, MATCH_FCVT_LU_Q, MASK_FCVT_LU_Q)
  1195 DECLARE_INSN(fmv_x_q, MATCH_FMV_X_Q, MASK_FMV_X_Q)
  1196 DECLARE_INSN(fclass_q, MATCH_FCLASS_Q, MASK_FCLASS_Q)
  1197 DECLARE_INSN(fcvt_s_w, MATCH_FCVT_S_W, MASK_FCVT_S_W)
  1198 DECLARE_INSN(fcvt_s_wu, MATCH_FCVT_S_WU, MASK_FCVT_S_WU)
  1199 DECLARE_INSN(fcvt_s_l, MATCH_FCVT_S_L, MASK_FCVT_S_L)
  1200 DECLARE_INSN(fcvt_s_lu, MATCH_FCVT_S_LU, MASK_FCVT_S_LU)
  1201 DECLARE_INSN(fmv_w_x, MATCH_FMV_W_X, MASK_FMV_W_X)
  1202 DECLARE_INSN(fcvt_d_w, MATCH_FCVT_D_W, MASK_FCVT_D_W)
  1203 DECLARE_INSN(fcvt_d_wu, MATCH_FCVT_D_WU, MASK_FCVT_D_WU)
  1204 DECLARE_INSN(fcvt_d_l, MATCH_FCVT_D_L, MASK_FCVT_D_L)
  1205 DECLARE_INSN(fcvt_d_lu, MATCH_FCVT_D_LU, MASK_FCVT_D_LU)
  1206 DECLARE_INSN(fmv_d_x, MATCH_FMV_D_X, MASK_FMV_D_X)
  1207 DECLARE_INSN(fcvt_q_w, MATCH_FCVT_Q_W, MASK_FCVT_Q_W)
  1208 DECLARE_INSN(fcvt_q_wu, MATCH_FCVT_Q_WU, MASK_FCVT_Q_WU)
  1209 DECLARE_INSN(fcvt_q_l, MATCH_FCVT_Q_L, MASK_FCVT_Q_L)
  1210 DECLARE_INSN(fcvt_q_lu, MATCH_FCVT_Q_LU, MASK_FCVT_Q_LU)
  1211 DECLARE_INSN(fmv_q_x, MATCH_FMV_Q_X, MASK_FMV_Q_X)
  1212 DECLARE_INSN(flw, MATCH_FLW, MASK_FLW)
  1213 DECLARE_INSN(fld, MATCH_FLD, MASK_FLD)
  1214 DECLARE_INSN(flq, MATCH_FLQ, MASK_FLQ)
  1215 DECLARE_INSN(fsw, MATCH_FSW, MASK_FSW)
  1216 DECLARE_INSN(fsd, MATCH_FSD, MASK_FSD)
  1217 DECLARE_INSN(fsq, MATCH_FSQ, MASK_FSQ)
  1218 DECLARE_INSN(fmadd_s, MATCH_FMADD_S, MASK_FMADD_S)
  1219 DECLARE_INSN(fmsub_s, MATCH_FMSUB_S, MASK_FMSUB_S)
  1220 DECLARE_INSN(fnmsub_s, MATCH_FNMSUB_S, MASK_FNMSUB_S)
  1221 DECLARE_INSN(fnmadd_s, MATCH_FNMADD_S, MASK_FNMADD_S)
  1222 DECLARE_INSN(fmadd_d, MATCH_FMADD_D, MASK_FMADD_D)
  1223 DECLARE_INSN(fmsub_d, MATCH_FMSUB_D, MASK_FMSUB_D)
  1224 DECLARE_INSN(fnmsub_d, MATCH_FNMSUB_D, MASK_FNMSUB_D)
  1225 DECLARE_INSN(fnmadd_d, MATCH_FNMADD_D, MASK_FNMADD_D)
  1226 DECLARE_INSN(fmadd_q, MATCH_FMADD_Q, MASK_FMADD_Q)
  1227 DECLARE_INSN(fmsub_q, MATCH_FMSUB_Q, MASK_FMSUB_Q)
  1228 DECLARE_INSN(fnmsub_q, MATCH_FNMSUB_Q, MASK_FNMSUB_Q)
  1229 DECLARE_INSN(fnmadd_q, MATCH_FNMADD_Q, MASK_FNMADD_Q)
  1230 DECLARE_INSN(c_nop, MATCH_C_NOP, MASK_C_NOP)
  1231 DECLARE_INSN(c_addi16sp, MATCH_C_ADDI16SP, MASK_C_ADDI16SP)
  1232 DECLARE_INSN(c_jr, MATCH_C_JR, MASK_C_JR)
  1233 DECLARE_INSN(c_jalr, MATCH_C_JALR, MASK_C_JALR)
  1234 DECLARE_INSN(c_ebreak, MATCH_C_EBREAK, MASK_C_EBREAK)
  1235 DECLARE_INSN(c_ld, MATCH_C_LD, MASK_C_LD)
  1236 DECLARE_INSN(c_sd, MATCH_C_SD, MASK_C_SD)
  1237 DECLARE_INSN(c_addiw, MATCH_C_ADDIW, MASK_C_ADDIW)
  1238 DECLARE_INSN(c_ldsp, MATCH_C_LDSP, MASK_C_LDSP)
  1239 DECLARE_INSN(c_sdsp, MATCH_C_SDSP, MASK_C_SDSP)
  1240 DECLARE_INSN(c_addi4spn, MATCH_C_ADDI4SPN, MASK_C_ADDI4SPN)
  1241 DECLARE_INSN(c_fld, MATCH_C_FLD, MASK_C_FLD)
  1242 DECLARE_INSN(c_lw, MATCH_C_LW, MASK_C_LW)
  1243 DECLARE_INSN(c_flw, MATCH_C_FLW, MASK_C_FLW)
  1244 DECLARE_INSN(c_fsd, MATCH_C_FSD, MASK_C_FSD)
  1245 DECLARE_INSN(c_sw, MATCH_C_SW, MASK_C_SW)
  1246 DECLARE_INSN(c_fsw, MATCH_C_FSW, MASK_C_FSW)
  1247 DECLARE_INSN(c_addi, MATCH_C_ADDI, MASK_C_ADDI)
  1248 DECLARE_INSN(c_jal, MATCH_C_JAL, MASK_C_JAL)
  1249 DECLARE_INSN(c_li, MATCH_C_LI, MASK_C_LI)
  1250 DECLARE_INSN(c_lui, MATCH_C_LUI, MASK_C_LUI)
  1251 DECLARE_INSN(c_srli, MATCH_C_SRLI, MASK_C_SRLI)
  1252 DECLARE_INSN(c_srai, MATCH_C_SRAI, MASK_C_SRAI)
  1253 DECLARE_INSN(c_andi, MATCH_C_ANDI, MASK_C_ANDI)
  1254 DECLARE_INSN(c_sub, MATCH_C_SUB, MASK_C_SUB)
  1255 DECLARE_INSN(c_xor, MATCH_C_XOR, MASK_C_XOR)
  1256 DECLARE_INSN(c_or, MATCH_C_OR, MASK_C_OR)
  1257 DECLARE_INSN(c_and, MATCH_C_AND, MASK_C_AND)
  1258 DECLARE_INSN(c_subw, MATCH_C_SUBW, MASK_C_SUBW)
  1259 DECLARE_INSN(c_addw, MATCH_C_ADDW, MASK_C_ADDW)
  1260 DECLARE_INSN(c_j, MATCH_C_J, MASK_C_J)
  1261 DECLARE_INSN(c_beqz, MATCH_C_BEQZ, MASK_C_BEQZ)
  1262 DECLARE_INSN(c_bnez, MATCH_C_BNEZ, MASK_C_BNEZ)
  1263 DECLARE_INSN(c_slli, MATCH_C_SLLI, MASK_C_SLLI)
  1264 DECLARE_INSN(c_fldsp, MATCH_C_FLDSP, MASK_C_FLDSP)
  1265 DECLARE_INSN(c_lwsp, MATCH_C_LWSP, MASK_C_LWSP)
  1266 DECLARE_INSN(c_flwsp, MATCH_C_FLWSP, MASK_C_FLWSP)
  1267 DECLARE_INSN(c_mv, MATCH_C_MV, MASK_C_MV)
  1268 DECLARE_INSN(c_add, MATCH_C_ADD, MASK_C_ADD)
  1269 DECLARE_INSN(c_fsdsp, MATCH_C_FSDSP, MASK_C_FSDSP)
  1270 DECLARE_INSN(c_swsp, MATCH_C_SWSP, MASK_C_SWSP)
  1271 DECLARE_INSN(c_fswsp, MATCH_C_FSWSP, MASK_C_FSWSP)
  1272 DECLARE_INSN(custom0, MATCH_CUSTOM0, MASK_CUSTOM0)
  1273 DECLARE_INSN(custom0_rs1, MATCH_CUSTOM0_RS1, MASK_CUSTOM0_RS1)
  1274 DECLARE_INSN(custom0_rs1_rs2, MATCH_CUSTOM0_RS1_RS2, MASK_CUSTOM0_RS1_RS2)
  1275 DECLARE_INSN(custom0_rd, MATCH_CUSTOM0_RD, MASK_CUSTOM0_RD)
  1276 DECLARE_INSN(custom0_rd_rs1, MATCH_CUSTOM0_RD_RS1, MASK_CUSTOM0_RD_RS1)
  1277 DECLARE_INSN(custom0_rd_rs1_rs2, MATCH_CUSTOM0_RD_RS1_RS2, MASK_CUSTOM0_RD_RS1_RS2)
  1278 DECLARE_INSN(custom1, MATCH_CUSTOM1, MASK_CUSTOM1)
  1279 DECLARE_INSN(custom1_rs1, MATCH_CUSTOM1_RS1, MASK_CUSTOM1_RS1)
  1280 DECLARE_INSN(custom1_rs1_rs2, MATCH_CUSTOM1_RS1_RS2, MASK_CUSTOM1_RS1_RS2)
  1281 DECLARE_INSN(custom1_rd, MATCH_CUSTOM1_RD, MASK_CUSTOM1_RD)
  1282 DECLARE_INSN(custom1_rd_rs1, MATCH_CUSTOM1_RD_RS1, MASK_CUSTOM1_RD_RS1)
  1283 DECLARE_INSN(custom1_rd_rs1_rs2, MATCH_CUSTOM1_RD_RS1_RS2, MASK_CUSTOM1_RD_RS1_RS2)
  1284 DECLARE_INSN(custom2, MATCH_CUSTOM2, MASK_CUSTOM2)
  1285 DECLARE_INSN(custom2_rs1, MATCH_CUSTOM2_RS1, MASK_CUSTOM2_RS1)
  1286 DECLARE_INSN(custom2_rs1_rs2, MATCH_CUSTOM2_RS1_RS2, MASK_CUSTOM2_RS1_RS2)
  1287 DECLARE_INSN(custom2_rd, MATCH_CUSTOM2_RD, MASK_CUSTOM2_RD)
  1288 DECLARE_INSN(custom2_rd_rs1, MATCH_CUSTOM2_RD_RS1, MASK_CUSTOM2_RD_RS1)
  1289 DECLARE_INSN(custom2_rd_rs1_rs2, MATCH_CUSTOM2_RD_RS1_RS2, MASK_CUSTOM2_RD_RS1_RS2)
  1290 DECLARE_INSN(custom3, MATCH_CUSTOM3, MASK_CUSTOM3)
  1291 DECLARE_INSN(custom3_rs1, MATCH_CUSTOM3_RS1, MASK_CUSTOM3_RS1)
  1292 DECLARE_INSN(custom3_rs1_rs2, MATCH_CUSTOM3_RS1_RS2, MASK_CUSTOM3_RS1_RS2)
  1293 DECLARE_INSN(custom3_rd, MATCH_CUSTOM3_RD, MASK_CUSTOM3_RD)
  1294 DECLARE_INSN(custom3_rd_rs1, MATCH_CUSTOM3_RD_RS1, MASK_CUSTOM3_RD_RS1)
  1295 DECLARE_INSN(custom3_rd_rs1_rs2, MATCH_CUSTOM3_RD_RS1_RS2, MASK_CUSTOM3_RD_RS1_RS2)
  1298 DECLARE_CSR(fflags, CSR_FFLAGS)
  1299 DECLARE_CSR(frm, CSR_FRM)
  1300 DECLARE_CSR(fcsr, CSR_FCSR)
  1301 DECLARE_CSR(cycle, CSR_CYCLE)
  1302 DECLARE_CSR(time, CSR_TIME)
  1303 DECLARE_CSR(instret, CSR_INSTRET)
  1304 DECLARE_CSR(hpmcounter3, CSR_HPMCOUNTER3)
  1305 DECLARE_CSR(hpmcounter4, CSR_HPMCOUNTER4)
  1306 DECLARE_CSR(hpmcounter5, CSR_HPMCOUNTER5)
  1307 DECLARE_CSR(hpmcounter6, CSR_HPMCOUNTER6)
  1308 DECLARE_CSR(hpmcounter7, CSR_HPMCOUNTER7)
  1309 DECLARE_CSR(hpmcounter8, CSR_HPMCOUNTER8)
  1310 DECLARE_CSR(hpmcounter9, CSR_HPMCOUNTER9)
  1311 DECLARE_CSR(hpmcounter10, CSR_HPMCOUNTER10)
  1312 DECLARE_CSR(hpmcounter11, CSR_HPMCOUNTER11)
  1313 DECLARE_CSR(hpmcounter12, CSR_HPMCOUNTER12)
  1314 DECLARE_CSR(hpmcounter13, CSR_HPMCOUNTER13)
  1315 DECLARE_CSR(hpmcounter14, CSR_HPMCOUNTER14)
  1316 DECLARE_CSR(hpmcounter15, CSR_HPMCOUNTER15)
  1317 DECLARE_CSR(hpmcounter16, CSR_HPMCOUNTER16)
  1318 DECLARE_CSR(hpmcounter17, CSR_HPMCOUNTER17)
  1319 DECLARE_CSR(hpmcounter18, CSR_HPMCOUNTER18)
  1320 DECLARE_CSR(hpmcounter19, CSR_HPMCOUNTER19)
  1321 DECLARE_CSR(hpmcounter20, CSR_HPMCOUNTER20)
  1322 DECLARE_CSR(hpmcounter21, CSR_HPMCOUNTER21)
  1323 DECLARE_CSR(hpmcounter22, CSR_HPMCOUNTER22)
  1324 DECLARE_CSR(hpmcounter23, CSR_HPMCOUNTER23)
  1325 DECLARE_CSR(hpmcounter24, CSR_HPMCOUNTER24)
  1326 DECLARE_CSR(hpmcounter25, CSR_HPMCOUNTER25)
  1327 DECLARE_CSR(hpmcounter26, CSR_HPMCOUNTER26)
  1328 DECLARE_CSR(hpmcounter27, CSR_HPMCOUNTER27)
  1329 DECLARE_CSR(hpmcounter28, CSR_HPMCOUNTER28)
  1330 DECLARE_CSR(hpmcounter29, CSR_HPMCOUNTER29)
  1331 DECLARE_CSR(hpmcounter30, CSR_HPMCOUNTER30)
  1332 DECLARE_CSR(hpmcounter31, CSR_HPMCOUNTER31)
  1333 DECLARE_CSR(sstatus, CSR_SSTATUS)
  1334 DECLARE_CSR(sie, CSR_SIE)
  1335 DECLARE_CSR(stvec, CSR_STVEC)
  1336 DECLARE_CSR(scounteren, CSR_SCOUNTEREN)
  1337 DECLARE_CSR(sscratch, CSR_SSCRATCH)
  1338 DECLARE_CSR(sepc, CSR_SEPC)
  1339 DECLARE_CSR(scause, CSR_SCAUSE)
  1340 DECLARE_CSR(sbadaddr, CSR_SBADADDR)
  1341 DECLARE_CSR(sip, CSR_SIP)
  1342 DECLARE_CSR(sptbr, CSR_SPTBR)
  1343 DECLARE_CSR(mstatus, CSR_MSTATUS)
  1344 DECLARE_CSR(misa, CSR_MISA)
  1345 DECLARE_CSR(medeleg, CSR_MEDELEG)
  1346 DECLARE_CSR(mideleg, CSR_MIDELEG)
  1347 DECLARE_CSR(mie, CSR_MIE)
  1348 DECLARE_CSR(mtvec, CSR_MTVEC)
  1349 DECLARE_CSR(mcounteren, CSR_MCOUNTEREN)
  1350 DECLARE_CSR(mscratch, CSR_MSCRATCH)
  1351 DECLARE_CSR(mepc, CSR_MEPC)
  1352 DECLARE_CSR(mcause, CSR_MCAUSE)
  1353 DECLARE_CSR(mbadaddr, CSR_MBADADDR)
  1354 DECLARE_CSR(mip, CSR_MIP)
  1355 DECLARE_CSR(pmpcfg0, CSR_PMPCFG0)
  1356 DECLARE_CSR(pmpcfg1, CSR_PMPCFG1)
  1357 DECLARE_CSR(pmpcfg2, CSR_PMPCFG2)
  1358 DECLARE_CSR(pmpcfg3, CSR_PMPCFG3)
  1359 DECLARE_CSR(pmpaddr0, CSR_PMPADDR0)
  1360 DECLARE_CSR(pmpaddr1, CSR_PMPADDR1)
  1361 DECLARE_CSR(pmpaddr2, CSR_PMPADDR2)
  1362 DECLARE_CSR(pmpaddr3, CSR_PMPADDR3)
  1363 DECLARE_CSR(pmpaddr4, CSR_PMPADDR4)
  1364 DECLARE_CSR(pmpaddr5, CSR_PMPADDR5)
  1365 DECLARE_CSR(pmpaddr6, CSR_PMPADDR6)
  1366 DECLARE_CSR(pmpaddr7, CSR_PMPADDR7)
  1367 DECLARE_CSR(pmpaddr8, CSR_PMPADDR8)
  1368 DECLARE_CSR(pmpaddr9, CSR_PMPADDR9)
  1369 DECLARE_CSR(pmpaddr10, CSR_PMPADDR10)
  1370 DECLARE_CSR(pmpaddr11, CSR_PMPADDR11)
  1371 DECLARE_CSR(pmpaddr12, CSR_PMPADDR12)
  1372 DECLARE_CSR(pmpaddr13, CSR_PMPADDR13)
  1373 DECLARE_CSR(pmpaddr14, CSR_PMPADDR14)
  1374 DECLARE_CSR(pmpaddr15, CSR_PMPADDR15)
  1375 DECLARE_CSR(tselect, CSR_TSELECT)
  1376 DECLARE_CSR(tdata1, CSR_TDATA1)
  1377 DECLARE_CSR(tdata2, CSR_TDATA2)
  1378 DECLARE_CSR(tdata3, CSR_TDATA3)
  1379 DECLARE_CSR(dcsr, CSR_DCSR)
  1380 DECLARE_CSR(dpc, CSR_DPC)
  1381 DECLARE_CSR(dscratch, CSR_DSCRATCH)
  1382 DECLARE_CSR(mcycle, CSR_MCYCLE)
  1383 DECLARE_CSR(minstret, CSR_MINSTRET)
  1384 DECLARE_CSR(mhpmcounter3, CSR_MHPMCOUNTER3)
  1385 DECLARE_CSR(mhpmcounter4, CSR_MHPMCOUNTER4)
  1386 DECLARE_CSR(mhpmcounter5, CSR_MHPMCOUNTER5)
  1387 DECLARE_CSR(mhpmcounter6, CSR_MHPMCOUNTER6)
  1388 DECLARE_CSR(mhpmcounter7, CSR_MHPMCOUNTER7)
  1389 DECLARE_CSR(mhpmcounter8, CSR_MHPMCOUNTER8)
  1390 DECLARE_CSR(mhpmcounter9, CSR_MHPMCOUNTER9)
  1391 DECLARE_CSR(mhpmcounter10, CSR_MHPMCOUNTER10)
  1392 DECLARE_CSR(mhpmcounter11, CSR_MHPMCOUNTER11)
  1393 DECLARE_CSR(mhpmcounter12, CSR_MHPMCOUNTER12)
  1394 DECLARE_CSR(mhpmcounter13, CSR_MHPMCOUNTER13)
  1395 DECLARE_CSR(mhpmcounter14, CSR_MHPMCOUNTER14)
  1396 DECLARE_CSR(mhpmcounter15, CSR_MHPMCOUNTER15)
  1397 DECLARE_CSR(mhpmcounter16, CSR_MHPMCOUNTER16)
  1398 DECLARE_CSR(mhpmcounter17, CSR_MHPMCOUNTER17)
  1399 DECLARE_CSR(mhpmcounter18, CSR_MHPMCOUNTER18)
  1400 DECLARE_CSR(mhpmcounter19, CSR_MHPMCOUNTER19)
  1401 DECLARE_CSR(mhpmcounter20, CSR_MHPMCOUNTER20)
  1402 DECLARE_CSR(mhpmcounter21, CSR_MHPMCOUNTER21)
  1403 DECLARE_CSR(mhpmcounter22, CSR_MHPMCOUNTER22)
  1404 DECLARE_CSR(mhpmcounter23, CSR_MHPMCOUNTER23)
  1405 DECLARE_CSR(mhpmcounter24, CSR_MHPMCOUNTER24)
  1406 DECLARE_CSR(mhpmcounter25, CSR_MHPMCOUNTER25)
  1407 DECLARE_CSR(mhpmcounter26, CSR_MHPMCOUNTER26)
  1408 DECLARE_CSR(mhpmcounter27, CSR_MHPMCOUNTER27)
  1409 DECLARE_CSR(mhpmcounter28, CSR_MHPMCOUNTER28)
  1410 DECLARE_CSR(mhpmcounter29, CSR_MHPMCOUNTER29)
  1411 DECLARE_CSR(mhpmcounter30, CSR_MHPMCOUNTER30)
  1412 DECLARE_CSR(mhpmcounter31, CSR_MHPMCOUNTER31)
  1413 DECLARE_CSR(mhpmevent3, CSR_MHPMEVENT3)
  1414 DECLARE_CSR(mhpmevent4, CSR_MHPMEVENT4)
  1415 DECLARE_CSR(mhpmevent5, CSR_MHPMEVENT5)
  1416 DECLARE_CSR(mhpmevent6, CSR_MHPMEVENT6)
  1417 DECLARE_CSR(mhpmevent7, CSR_MHPMEVENT7)
  1418 DECLARE_CSR(mhpmevent8, CSR_MHPMEVENT8)
  1419 DECLARE_CSR(mhpmevent9, CSR_MHPMEVENT9)
  1420 DECLARE_CSR(mhpmevent10, CSR_MHPMEVENT10)
  1421 DECLARE_CSR(mhpmevent11, CSR_MHPMEVENT11)
  1422 DECLARE_CSR(mhpmevent12, CSR_MHPMEVENT12)
  1423 DECLARE_CSR(mhpmevent13, CSR_MHPMEVENT13)
  1424 DECLARE_CSR(mhpmevent14, CSR_MHPMEVENT14)
  1425 DECLARE_CSR(mhpmevent15, CSR_MHPMEVENT15)
  1426 DECLARE_CSR(mhpmevent16, CSR_MHPMEVENT16)
  1427 DECLARE_CSR(mhpmevent17, CSR_MHPMEVENT17)
  1428 DECLARE_CSR(mhpmevent18, CSR_MHPMEVENT18)
  1429 DECLARE_CSR(mhpmevent19, CSR_MHPMEVENT19)
  1430 DECLARE_CSR(mhpmevent20, CSR_MHPMEVENT20)
  1431 DECLARE_CSR(mhpmevent21, CSR_MHPMEVENT21)
  1432 DECLARE_CSR(mhpmevent22, CSR_MHPMEVENT22)
  1433 DECLARE_CSR(mhpmevent23, CSR_MHPMEVENT23)
  1434 DECLARE_CSR(mhpmevent24, CSR_MHPMEVENT24)
  1435 DECLARE_CSR(mhpmevent25, CSR_MHPMEVENT25)
  1436 DECLARE_CSR(mhpmevent26, CSR_MHPMEVENT26)
  1437 DECLARE_CSR(mhpmevent27, CSR_MHPMEVENT27)
  1438 DECLARE_CSR(mhpmevent28, CSR_MHPMEVENT28)
  1439 DECLARE_CSR(mhpmevent29, CSR_MHPMEVENT29)
  1440 DECLARE_CSR(mhpmevent30, CSR_MHPMEVENT30)
  1441 DECLARE_CSR(mhpmevent31, CSR_MHPMEVENT31)
  1442 DECLARE_CSR(mvendorid, CSR_MVENDORID)
  1443 DECLARE_CSR(marchid, CSR_MARCHID)
  1444 DECLARE_CSR(mimpid, CSR_MIMPID)
  1445 DECLARE_CSR(mhartid, CSR_MHARTID)
  1446 DECLARE_CSR(cycleh, CSR_CYCLEH)
  1447 DECLARE_CSR(timeh, CSR_TIMEH)
  1448 DECLARE_CSR(instreth, CSR_INSTRETH)
  1449 DECLARE_CSR(hpmcounter3h, CSR_HPMCOUNTER3H)
  1450 DECLARE_CSR(hpmcounter4h, CSR_HPMCOUNTER4H)
  1451 DECLARE_CSR(hpmcounter5h, CSR_HPMCOUNTER5H)
  1452 DECLARE_CSR(hpmcounter6h, CSR_HPMCOUNTER6H)
  1453 DECLARE_CSR(hpmcounter7h, CSR_HPMCOUNTER7H)
  1454 DECLARE_CSR(hpmcounter8h, CSR_HPMCOUNTER8H)
  1455 DECLARE_CSR(hpmcounter9h, CSR_HPMCOUNTER9H)
  1456 DECLARE_CSR(hpmcounter10h, CSR_HPMCOUNTER10H)
  1457 DECLARE_CSR(hpmcounter11h, CSR_HPMCOUNTER11H)
  1458 DECLARE_CSR(hpmcounter12h, CSR_HPMCOUNTER12H)
  1459 DECLARE_CSR(hpmcounter13h, CSR_HPMCOUNTER13H)
  1460 DECLARE_CSR(hpmcounter14h, CSR_HPMCOUNTER14H)
  1461 DECLARE_CSR(hpmcounter15h, CSR_HPMCOUNTER15H)
  1462 DECLARE_CSR(hpmcounter16h, CSR_HPMCOUNTER16H)
  1463 DECLARE_CSR(hpmcounter17h, CSR_HPMCOUNTER17H)
  1464 DECLARE_CSR(hpmcounter18h, CSR_HPMCOUNTER18H)
  1465 DECLARE_CSR(hpmcounter19h, CSR_HPMCOUNTER19H)
  1466 DECLARE_CSR(hpmcounter20h, CSR_HPMCOUNTER20H)
  1467 DECLARE_CSR(hpmcounter21h, CSR_HPMCOUNTER21H)
  1468 DECLARE_CSR(hpmcounter22h, CSR_HPMCOUNTER22H)
  1469 DECLARE_CSR(hpmcounter23h, CSR_HPMCOUNTER23H)
  1470 DECLARE_CSR(hpmcounter24h, CSR_HPMCOUNTER24H)
  1471 DECLARE_CSR(hpmcounter25h, CSR_HPMCOUNTER25H)
  1472 DECLARE_CSR(hpmcounter26h, CSR_HPMCOUNTER26H)
  1473 DECLARE_CSR(hpmcounter27h, CSR_HPMCOUNTER27H)
  1474 DECLARE_CSR(hpmcounter28h, CSR_HPMCOUNTER28H)
  1475 DECLARE_CSR(hpmcounter29h, CSR_HPMCOUNTER29H)
  1476 DECLARE_CSR(hpmcounter30h, CSR_HPMCOUNTER30H)
  1477 DECLARE_CSR(hpmcounter31h, CSR_HPMCOUNTER31H)
  1478 DECLARE_CSR(mcycleh, CSR_MCYCLEH)
  1479 DECLARE_CSR(minstreth, CSR_MINSTRETH)
  1480 DECLARE_CSR(mhpmcounter3h, CSR_MHPMCOUNTER3H)
  1481 DECLARE_CSR(mhpmcounter4h, CSR_MHPMCOUNTER4H)
  1482 DECLARE_CSR(mhpmcounter5h, CSR_MHPMCOUNTER5H)
  1483 DECLARE_CSR(mhpmcounter6h, CSR_MHPMCOUNTER6H)
  1484 DECLARE_CSR(mhpmcounter7h, CSR_MHPMCOUNTER7H)
  1485 DECLARE_CSR(mhpmcounter8h, CSR_MHPMCOUNTER8H)
  1486 DECLARE_CSR(mhpmcounter9h, CSR_MHPMCOUNTER9H)
  1487 DECLARE_CSR(mhpmcounter10h, CSR_MHPMCOUNTER10H)
  1488 DECLARE_CSR(mhpmcounter11h, CSR_MHPMCOUNTER11H)
  1489 DECLARE_CSR(mhpmcounter12h, CSR_MHPMCOUNTER12H)
  1490 DECLARE_CSR(mhpmcounter13h, CSR_MHPMCOUNTER13H)
  1491 DECLARE_CSR(mhpmcounter14h, CSR_MHPMCOUNTER14H)
  1492 DECLARE_CSR(mhpmcounter15h, CSR_MHPMCOUNTER15H)
  1493 DECLARE_CSR(mhpmcounter16h, CSR_MHPMCOUNTER16H)
  1494 DECLARE_CSR(mhpmcounter17h, CSR_MHPMCOUNTER17H)
  1495 DECLARE_CSR(mhpmcounter18h, CSR_MHPMCOUNTER18H)
  1496 DECLARE_CSR(mhpmcounter19h, CSR_MHPMCOUNTER19H)
  1497 DECLARE_CSR(mhpmcounter20h, CSR_MHPMCOUNTER20H)
  1498 DECLARE_CSR(mhpmcounter21h, CSR_MHPMCOUNTER21H)
  1499 DECLARE_CSR(mhpmcounter22h, CSR_MHPMCOUNTER22H)
  1500 DECLARE_CSR(mhpmcounter23h, CSR_MHPMCOUNTER23H)
  1501 DECLARE_CSR(mhpmcounter24h, CSR_MHPMCOUNTER24H)
  1502 DECLARE_CSR(mhpmcounter25h, CSR_MHPMCOUNTER25H)
  1503 DECLARE_CSR(mhpmcounter26h, CSR_MHPMCOUNTER26H)
  1504 DECLARE_CSR(mhpmcounter27h, CSR_MHPMCOUNTER27H)
  1505 DECLARE_CSR(mhpmcounter28h, CSR_MHPMCOUNTER28H)
  1506 DECLARE_CSR(mhpmcounter29h, CSR_MHPMCOUNTER29H)
  1507 DECLARE_CSR(mhpmcounter30h, CSR_MHPMCOUNTER30H)
  1508 DECLARE_CSR(mhpmcounter31h, CSR_MHPMCOUNTER31H)
  1510 #ifdef DECLARE_CAUSE  1511 DECLARE_CAUSE(
"misaligned fetch", CAUSE_MISALIGNED_FETCH)
  1512 DECLARE_CAUSE(
"fetch access", CAUSE_FETCH_ACCESS)
  1513 DECLARE_CAUSE(
"illegal instruction", CAUSE_ILLEGAL_INSTRUCTION)
  1514 DECLARE_CAUSE(
"breakpoint", CAUSE_BREAKPOINT)
  1515 DECLARE_CAUSE(
"misaligned load", CAUSE_MISALIGNED_LOAD)
  1516 DECLARE_CAUSE(
"load access", CAUSE_LOAD_ACCESS)
  1517 DECLARE_CAUSE(
"misaligned store", CAUSE_MISALIGNED_STORE)
  1518 DECLARE_CAUSE(
"store access", CAUSE_STORE_ACCESS)
  1519 DECLARE_CAUSE(
"user_ecall", CAUSE_USER_ECALL)
  1520 DECLARE_CAUSE(
"supervisor_ecall", CAUSE_SUPERVISOR_ECALL)
  1521 DECLARE_CAUSE(
"hypervisor_ecall", CAUSE_HYPERVISOR_ECALL)
  1522 DECLARE_CAUSE(
"machine_ecall", CAUSE_MACHINE_ECALL)
  1523 DECLARE_CAUSE(
"fetch page fault", CAUSE_FETCH_PAGE_FAULT)
  1524 DECLARE_CAUSE(
"load page fault", CAUSE_LOAD_PAGE_FAULT)
  1525 DECLARE_CAUSE(
"store page fault", CAUSE_STORE_PAGE_FAULT)
