33 #ifndef _RTEMS_RECORDCLIENT_H    34 #define _RTEMS_RECORDCLIENT_H    36 #include "recorddata.h"    51 #define RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT 32    54   RTEMS_RECORD_CLIENT_SUCCESS,
    55   RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC,
    56   RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT,
    57   RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION,
    58   RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU,
    59   RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU_MAX,
    60   RTEMS_RECORD_CLIENT_ERROR_DOUBLE_CPU_MAX,
    61   RTEMS_RECORD_CLIENT_ERROR_DOUBLE_PER_CPU_COUNT,
    62   RTEMS_RECORD_CLIENT_ERROR_NO_CPU_MAX,
    63   RTEMS_RECORD_CLIENT_ERROR_NO_MEMORY,
    64   RTEMS_RECORD_CLIENT_ERROR_PER_CPU_ITEMS_OVERFLOW
    65 } rtems_record_client_status;
    67 typedef rtems_record_client_status ( *rtems_record_client_handler )(
    83     uint32_t time_accumulated;
   131   rtems_record_item_64 *items;
   140   uint64_t to_bt_scaler;
   147     rtems_record_item_64 format_64;
   151   rtems_record_client_status ( *consume )(
   156   rtems_record_client_handler handler;
   159   uint32_t header[ 2 ];
   160   rtems_record_client_status status;
   175   rtems_record_client_handler  handler,
   204 static inline void rtems_record_client_set_handler(
   206   rtems_record_client_handler  handler
   209   ctx->handler = handler;
   212 static inline uint64_t rtems_record_client_bintime_to_nanoseconds(
   217   uint64_t nanoseconds;
   219   ns_per_sec = 1000000000ULL;
   220   nanoseconds = ns_per_sec * ( (uint32_t) ( bt >> 32 ) );
   221   nanoseconds += ( ns_per_sec * (uint32_t) bt ) >> 32;
   226 static inline void rtems_record_client_bintime_to_seconds_and_nanoseconds(
   229   uint32_t *nanoseconds
   234   ns_per_sec = 1000000000ULL;
   235   *seconds = (uint32_t) ( bt >> 32 );
   236   *nanoseconds = (uint32_t) ( ( ns_per_sec * (uint32_t) bt ) >> 32 );
 size_t item_index
The index for the next hold back item.
Definition: recordclient.h:136
void rtems_record_client_init(rtems_record_client_context *ctx, rtems_record_client_handler handler, void *arg)
Initializes a record client.
Definition: record-client.c:688
rtems_record_client_status rtems_record_client_run(rtems_record_client_context *ctx, const void *buf, size_t n)
Runs the record client to consume new stream data.
Definition: record-client.c:703
rtems_record_event
The record events.
Definition: recorddata.h:90
size_t tail_head_index
The index of the tail and head members.
Definition: recordclient.h:106
uint32_t overflow
Count of lost items due to ring buffer overflows.
Definition: recordclient.h:111
Definition: recordclient.h:139
Definition: recordclient.h:75
The 32-bit format record item.
Definition: recorddata.h:1183
bool hold_back
If true, then hold back items for overflow or initial ramp up processing.
Definition: recordclient.h:117
void rtems_record_client_destroy(rtems_record_client_context *ctx)
Drains all internal buffers and frees the allocated resources.
Definition: record-client.c:712
