25 #define KBD_REPORT_UNKN             26 #define KBD_REPORT_TIMEOUTS         27 #undef KBD_IS_FOCUS_9000            28 #undef INITIALIZE_MOUSE             30 #define KBD_INIT_TIMEOUT 1000           31 #define KBC_TIMEOUT 250             32 #define KBD_TIMEOUT 1000            38 extern unsigned char pckbd_read_mask;
    39 extern unsigned char aux_device_present;
    45 #define KBD_STATUS_REG      0x64        46 #define KBD_CNTL_REG        0x64        47 #define KBD_DATA_REG        0x60        53 #define KBD_CCMD_READ_MODE  0x20        54 #define KBD_CCMD_WRITE_MODE 0x60        55 #define KBD_CCMD_GET_VERSION    0xA1        56 #define KBD_CCMD_MOUSE_DISABLE  0xA7        57 #define KBD_CCMD_MOUSE_ENABLE   0xA8        58 #define KBD_CCMD_TEST_MOUSE 0xA9        59 #define KBD_CCMD_SELF_TEST  0xAA        60 #define KBD_CCMD_KBD_TEST   0xAB        61 #define KBD_CCMD_KBD_DISABLE    0xAD        62 #define KBD_CCMD_KBD_ENABLE 0xAE        63 #define KBD_CCMD_WRITE_AUX_OBUF 0xD3        65 #define KBD_CCMD_WRITE_MOUSE    0xD4        71 #define KBD_CMD_SET_LEDS    0xED        72 #define KBD_CMD_SET_RATE    0xF3        73 #define KBD_CMD_ENABLE      0xF4        74 #define KBD_CMD_DISABLE     0xF5        75 #define KBD_CMD_RESET       0xFF        81 #define KBD_REPLY_POR       0xAA        82 #define KBD_REPLY_ACK       0xFA        83 #define KBD_REPLY_RESEND    0xFE        89 #define KBD_STAT_OBF        0x01        90 #define KBD_STAT_IBF        0x02        91 #define KBD_STAT_SELFTEST   0x04        92 #define KBD_STAT_CMD        0x08        93 #define KBD_STAT_UNLOCKED   0x10        94 #define KBD_STAT_MOUSE_OBF  0x20        95 #define KBD_STAT_GTO        0x40        96 #define KBD_STAT_PERR       0x80        98 #define AUX_STAT_OBF (KBD_STAT_OBF | KBD_STAT_MOUSE_OBF)   104 #define KBD_MODE_KBD_INT    0x01       105 #define KBD_MODE_MOUSE_INT  0x02       106 #define KBD_MODE_SYS        0x04       107 #define KBD_MODE_NO_KEYLOCK 0x08       108 #define KBD_MODE_DISABLE_KBD    0x10       109 #define KBD_MODE_DISABLE_MOUSE  0x20       110 #define KBD_MODE_KCC        0x40       111 #define KBD_MODE_RFU        0x80   117 #define AUX_SET_RES     0xE8       118 #define AUX_SET_SCALE11     0xE6       119 #define AUX_SET_SCALE21     0xE7       120 #define AUX_GET_SCALE       0xE9       121 #define AUX_SET_STREAM      0xEA       122 #define AUX_SET_SAMPLE      0xF3       123 #define AUX_ENABLE_DEV      0xF4       124 #define AUX_DISABLE_DEV     0xF5       125 #define AUX_RESET       0xFF       128 #define AUX_BUF_SIZE        512    136     struct wait_queue *proc_list;
   137     struct fasync_struct *fasync;
   138     unsigned char buf[AUX_BUF_SIZE];
   142 #define kbd_read_input() inb(KBD_DATA_REG)   143 #define kbd_read_status() inb(KBD_STATUS_REG)   144 #define kbd_write_output(val) outb(val, KBD_DATA_REG)   145 #define kbd_write_command(val) outb(val, KBD_CNTL_REG) Definition: ps2_mouse.h:133
