RTEMS  5.1
keyboard.h
1 /*
2  * keyboard.h -- keyboard definitions.
3  *
4  * Copyright (C) 1999 Eric Valette. valette@crf.canon.fr
5  *
6  * The license and distribution terms for this file may be
7  * found in the file LICENSE in this distribution or at
8  * http://www.rtems.org/license/LICENSE.
9  */
10
11 #ifndef __LINUX_KEYBOARD_H
12 #define __LINUX_KEYBOARD_H
13
14 #define KG_SHIFT 0
15 #define KG_CTRL 2
16 #define KG_ALT 3
17 #define KG_ALTGR 1
18 #define KG_SHIFTL 4
19 #define KG_SHIFTR 5
20 #define KG_CTRLL 6
21 #define KG_CTRLR 7
22 #define KG_CAPSSHIFT 8
23
24 #define NR_SHIFT 9
25
26 #define NR_KEYS 128
27 #define MAX_NR_KEYMAPS 256
28 /* This means 64Kb if all keymaps are allocated. Only the superuser
29  may increase the number of keymaps beyond MAX_NR_OF_USER_KEYMAPS. */
30 #define MAX_NR_OF_USER_KEYMAPS 256 /* should be at least 7 */
31
32 #define MAX_NR_FUNC 256 /* max nr of strings assigned to keys */
33
34 #define KT_LATIN 0 /* we depend on this being zero */
35 #define KT_LETTER 11 /* symbol that can be acted upon by CapsLock */
36 #define KT_FN 1
37 #define KT_SPEC 2
38 #define KT_PAD 3
39 #define KT_DEAD 4
40 #define KT_CONS 5
41 #define KT_CUR 6
42 #define KT_SHIFT 7
43 #define KT_META 8
44 #define KT_ASCII 9
45 #define KT_LOCK 10
46 #define KT_SLOCK 12
47
48 #define K(t,v) (((t)<<8)|(v))
49 #define KTYP(x) ((x) >> 8)
50 #define KVAL(x) ((x) & 0xff)
51
52 #define K_F1 K(KT_FN,0)
53 #define K_F2 K(KT_FN,1)
54 #define K_F3 K(KT_FN,2)
55 #define K_F4 K(KT_FN,3)
56 #define K_F5 K(KT_FN,4)
57 #define K_F6 K(KT_FN,5)
58 #define K_F7 K(KT_FN,6)
59 #define K_F8 K(KT_FN,7)
60 #define K_F9 K(KT_FN,8)
61 #define K_F10 K(KT_FN,9)
62 #define K_F11 K(KT_FN,10)
63 #define K_F12 K(KT_FN,11)
64 #define K_F13 K(KT_FN,12)
65 #define K_F14 K(KT_FN,13)
66 #define K_F15 K(KT_FN,14)
67 #define K_F16 K(KT_FN,15)
68 #define K_F17 K(KT_FN,16)
69 #define K_F18 K(KT_FN,17)
70 #define K_F19 K(KT_FN,18)
71 #define K_F20 K(KT_FN,19)
72 #define K_FIND K(KT_FN,20)
73 #define K_INSERT K(KT_FN,21)
74 #define K_REMOVE K(KT_FN,22)
75 #define K_SELECT K(KT_FN,23)
76 #define K_PGUP K(KT_FN,24) /* PGUP is a synonym for PRIOR */
77 #define K_PGDN K(KT_FN,25) /* PGDN is a synonym for NEXT */
78 #define K_MACRO K(KT_FN,26)
79 #define K_HELP K(KT_FN,27)
80 #define K_DO K(KT_FN,28)
81 #define K_PAUSE K(KT_FN,29)
82 #define K_F21 K(KT_FN,30)
83 #define K_F22 K(KT_FN,31)
84 #define K_F23 K(KT_FN,32)
85 #define K_F24 K(KT_FN,33)
86 #define K_F25 K(KT_FN,34)
87 #define K_F26 K(KT_FN,35)
88 #define K_F27 K(KT_FN,36)
89 #define K_F28 K(KT_FN,37)
90 #define K_F29 K(KT_FN,38)
91 #define K_F30 K(KT_FN,39)
92 #define K_F31 K(KT_FN,40)
93 #define K_F32 K(KT_FN,41)
94 #define K_F33 K(KT_FN,42)
95 #define K_F34 K(KT_FN,43)
96 #define K_F35 K(KT_FN,44)
97 #define K_F36 K(KT_FN,45)
98 #define K_F37 K(KT_FN,46)
99 #define K_F38 K(KT_FN,47)
100 #define K_F39 K(KT_FN,48)
101 #define K_F40 K(KT_FN,49)
102 #define K_F41 K(KT_FN,50)
103 #define K_F42 K(KT_FN,51)
104 #define K_F43 K(KT_FN,52)
105 #define K_F44 K(KT_FN,53)
106 #define K_F45 K(KT_FN,54)
107 #define K_F46 K(KT_FN,55)
108 #define K_F47 K(KT_FN,56)
109 #define K_F48 K(KT_FN,57)
110 #define K_F49 K(KT_FN,58)
111 #define K_F50 K(KT_FN,59)
112 #define K_F51 K(KT_FN,60)
113 #define K_F52 K(KT_FN,61)
114 #define K_F53 K(KT_FN,62)
115 #define K_F54 K(KT_FN,63)
116 #define K_F55 K(KT_FN,64)
117 #define K_F56 K(KT_FN,65)
118 #define K_F57 K(KT_FN,66)
119 #define K_F58 K(KT_FN,67)
120 #define K_F59 K(KT_FN,68)
121 #define K_F60 K(KT_FN,69)
122 #define K_F61 K(KT_FN,70)
123 #define K_F62 K(KT_FN,71)
124 #define K_F63 K(KT_FN,72)
125 #define K_F64 K(KT_FN,73)
126 #define K_F65 K(KT_FN,74)
127 #define K_F66 K(KT_FN,75)
128 #define K_F67 K(KT_FN,76)
129 #define K_F68 K(KT_FN,77)
130 #define K_F69 K(KT_FN,78)
131 #define K_F70 K(KT_FN,79)
132 #define K_F71 K(KT_FN,80)
133 #define K_F72 K(KT_FN,81)
134 #define K_F73 K(KT_FN,82)
135 #define K_F74 K(KT_FN,83)
136 #define K_F75 K(KT_FN,84)
137 #define K_F76 K(KT_FN,85)
138 #define K_F77 K(KT_FN,86)
139 #define K_F78 K(KT_FN,87)
140 #define K_F79 K(KT_FN,88)
141 #define K_F80 K(KT_FN,89)
142 #define K_F81 K(KT_FN,90)
143 #define K_F82 K(KT_FN,91)
144 #define K_F83 K(KT_FN,92)
145 #define K_F84 K(KT_FN,93)
146 #define K_F85 K(KT_FN,94)
147 #define K_F86 K(KT_FN,95)
148 #define K_F87 K(KT_FN,96)
149 #define K_F88 K(KT_FN,97)
150 #define K_F89 K(KT_FN,98)
151 #define K_F90 K(KT_FN,99)
152 #define K_F91 K(KT_FN,100)
153 #define K_F92 K(KT_FN,101)
154 #define K_F93 K(KT_FN,102)
155 #define K_F94 K(KT_FN,103)
156 #define K_F95 K(KT_FN,104)
157 #define K_F96 K(KT_FN,105)
158 #define K_F97 K(KT_FN,106)
159 #define K_F98 K(KT_FN,107)
160 #define K_F99 K(KT_FN,108)
161 #define K_F100 K(KT_FN,109)
162 #define K_F101 K(KT_FN,110)
163 #define K_F102 K(KT_FN,111)
164 #define K_F103 K(KT_FN,112)
165 #define K_F104 K(KT_FN,113)
166 #define K_F105 K(KT_FN,114)
167 #define K_F106 K(KT_FN,115)
168 #define K_F107 K(KT_FN,116)
169 #define K_F108 K(KT_FN,117)
170 #define K_F109 K(KT_FN,118)
171 #define K_F110 K(KT_FN,119)
172 #define K_F111 K(KT_FN,120)
173 #define K_F112 K(KT_FN,121)
174 #define K_F113 K(KT_FN,122)
175 #define K_F114 K(KT_FN,123)
176 #define K_F115 K(KT_FN,124)
177 #define K_F116 K(KT_FN,125)
178 #define K_F117 K(KT_FN,126)
179 #define K_F118 K(KT_FN,127)
180 #define K_F119 K(KT_FN,128)
181 #define K_F120 K(KT_FN,129)
182 #define K_F121 K(KT_FN,130)
183 #define K_F122 K(KT_FN,131)
184 #define K_F123 K(KT_FN,132)
185 #define K_F124 K(KT_FN,133)
186 #define K_F125 K(KT_FN,134)
187 #define K_F126 K(KT_FN,135)
188 #define K_F127 K(KT_FN,136)
189 #define K_F128 K(KT_FN,137)
190 #define K_F129 K(KT_FN,138)
191 #define K_F130 K(KT_FN,139)
192 #define K_F131 K(KT_FN,140)
193 #define K_F132 K(KT_FN,141)
194 #define K_F133 K(KT_FN,142)
195 #define K_F134 K(KT_FN,143)
196 #define K_F135 K(KT_FN,144)
197 #define K_F136 K(KT_FN,145)
198 #define K_F137 K(KT_FN,146)
199 #define K_F138 K(KT_FN,147)
200 #define K_F139 K(KT_FN,148)
201 #define K_F140 K(KT_FN,149)
202 #define K_F141 K(KT_FN,150)
203 #define K_F142 K(KT_FN,151)
204 #define K_F143 K(KT_FN,152)
205 #define K_F144 K(KT_FN,153)
206 #define K_F145 K(KT_FN,154)
207 #define K_F146 K(KT_FN,155)
208 #define K_F147 K(KT_FN,156)
209 #define K_F148 K(KT_FN,157)
210 #define K_F149 K(KT_FN,158)
211 #define K_F150 K(KT_FN,159)
212 #define K_F151 K(KT_FN,160)
213 #define K_F152 K(KT_FN,161)
214 #define K_F153 K(KT_FN,162)
215 #define K_F154 K(KT_FN,163)
216 #define K_F155 K(KT_FN,164)
217 #define K_F156 K(KT_FN,165)
218 #define K_F157 K(KT_FN,166)
219 #define K_F158 K(KT_FN,167)
220 #define K_F159 K(KT_FN,168)
221 #define K_F160 K(KT_FN,169)
222 #define K_F161 K(KT_FN,170)
223 #define K_F162 K(KT_FN,171)
224 #define K_F163 K(KT_FN,172)
225 #define K_F164 K(KT_FN,173)
226 #define K_F165 K(KT_FN,174)
227 #define K_F166 K(KT_FN,175)
228 #define K_F167 K(KT_FN,176)
229 #define K_F168 K(KT_FN,177)
230 #define K_F169 K(KT_FN,178)
231 #define K_F170 K(KT_FN,179)
232 #define K_F171 K(KT_FN,180)
233 #define K_F172 K(KT_FN,181)
234 #define K_F173 K(KT_FN,182)
235 #define K_F174 K(KT_FN,183)
236 #define K_F175 K(KT_FN,184)
237 #define K_F176 K(KT_FN,185)
238 #define K_F177 K(KT_FN,186)
239 #define K_F178 K(KT_FN,187)
240 #define K_F179 K(KT_FN,188)
241 #define K_F180 K(KT_FN,189)
242 #define K_F181 K(KT_FN,190)
243 #define K_F182 K(KT_FN,191)
244 #define K_F183 K(KT_FN,192)
245 #define K_F184 K(KT_FN,193)
246 #define K_F185 K(KT_FN,194)
247 #define K_F186 K(KT_FN,195)
248 #define K_F187 K(KT_FN,196)
249 #define K_F188 K(KT_FN,197)
250 #define K_F189 K(KT_FN,198)
251 #define K_F190 K(KT_FN,199)
252 #define K_F191 K(KT_FN,200)
253 #define K_F192 K(KT_FN,201)
254 #define K_F193 K(KT_FN,202)
255 #define K_F194 K(KT_FN,203)
256 #define K_F195 K(KT_FN,204)
257 #define K_F196 K(KT_FN,205)
258 #define K_F197 K(KT_FN,206)
259 #define K_F198 K(KT_FN,207)
260 #define K_F199 K(KT_FN,208)
261 #define K_F200 K(KT_FN,209)
262 #define K_F201 K(KT_FN,210)
263 #define K_F202 K(KT_FN,211)
264 #define K_F203 K(KT_FN,212)
265 #define K_F204 K(KT_FN,213)
266 #define K_F205 K(KT_FN,214)
267 #define K_F206 K(KT_FN,215)
268 #define K_F207 K(KT_FN,216)
269 #define K_F208 K(KT_FN,217)
270 #define K_F209 K(KT_FN,218)
271 #define K_F210 K(KT_FN,219)
272 #define K_F211 K(KT_FN,220)
273 #define K_F212 K(KT_FN,221)
274 #define K_F213 K(KT_FN,222)
275 #define K_F214 K(KT_FN,223)
276 #define K_F215 K(KT_FN,224)
277 #define K_F216 K(KT_FN,225)
278 #define K_F217 K(KT_FN,226)
279 #define K_F218 K(KT_FN,227)
280 #define K_F219 K(KT_FN,228)
281 #define K_F220 K(KT_FN,229)
282 #define K_F221 K(KT_FN,230)
283 #define K_F222 K(KT_FN,231)
284 #define K_F223 K(KT_FN,232)
285 #define K_F224 K(KT_FN,233)
286 #define K_F225 K(KT_FN,234)
287 #define K_F226 K(KT_FN,235)
288 #define K_F227 K(KT_FN,236)
289 #define K_F228 K(KT_FN,237)
290 #define K_F229 K(KT_FN,238)
291 #define K_F230 K(KT_FN,239)
292 #define K_F231 K(KT_FN,240)
293 #define K_F232 K(KT_FN,241)
294 #define K_F233 K(KT_FN,242)
295 #define K_F234 K(KT_FN,243)
296 #define K_F235 K(KT_FN,244)
297 #define K_F236 K(KT_FN,245)
298 #define K_F237 K(KT_FN,246)
299 #define K_F238 K(KT_FN,247)
300 #define K_F239 K(KT_FN,248)
301 #define K_F240 K(KT_FN,249)
302 #define K_F241 K(KT_FN,250)
303 #define K_F242 K(KT_FN,251)
304 #define K_F243 K(KT_FN,252)
305 #define K_F244 K(KT_FN,253)
306 #define K_F245 K(KT_FN,254)
307 #define K_UNDO K(KT_FN,255)
308
309 #define K_HOLE K(KT_SPEC,0)
310 #define K_ENTER K(KT_SPEC,1)
311 #define K_SH_REGS K(KT_SPEC,2)
312 #define K_SH_MEM K(KT_SPEC,3)
313 #define K_SH_STAT K(KT_SPEC,4)
314 #define K_BREAK K(KT_SPEC,5)
315 #define K_CONS K(KT_SPEC,6)
316 #define K_CAPS K(KT_SPEC,7)
317 #define K_NUM K(KT_SPEC,8)
318 #define K_HOLD K(KT_SPEC,9)
319 #define K_SCROLLFORW K(KT_SPEC,10)
320 #define K_SCROLLBACK K(KT_SPEC,11)
321 #define K_BOOT K(KT_SPEC,12)
322 #define K_CAPSON K(KT_SPEC,13)
323 #define K_COMPOSE K(KT_SPEC,14)
324 #define K_SAK K(KT_SPEC,15)
325 #define K_DECRCONSOLE K(KT_SPEC,16)
326 #define K_INCRCONSOLE K(KT_SPEC,17)
327 #define K_SPAWNCONSOLE K(KT_SPEC,18)
328 #define K_BARENUMLOCK K(KT_SPEC,19)
329
330 #define K_ALLOCATED K(KT_SPEC,126) /* dynamically allocated keymap */
331 #define K_NOSUCHMAP K(KT_SPEC,127) /* returned by KDGKBENT */
332
333 #define K_P0 K(KT_PAD,0)
334 #define K_P1 K(KT_PAD,1)
335 #define K_P2 K(KT_PAD,2)
336 #define K_P3 K(KT_PAD,3)
337 #define K_P4 K(KT_PAD,4)
338 #define K_P5 K(KT_PAD,5)
339 #define K_P6 K(KT_PAD,6)
340 #define K_P7 K(KT_PAD,7)
341 #define K_P8 K(KT_PAD,8)
342 #define K_P9 K(KT_PAD,9)
343 #define K_PPLUS K(KT_PAD,10) /* key-pad plus */
344 #define K_PMINUS K(KT_PAD,11) /* key-pad minus */
345 #define K_PSTAR K(KT_PAD,12) /* key-pad asterisk (star) */
346 #define K_PSLASH K(KT_PAD,13) /* key-pad slash */
347 #define K_PENTER K(KT_PAD,14) /* key-pad enter */
348 #define K_PCOMMA K(KT_PAD,15) /* key-pad comma: kludge... */
349 #define K_PDOT K(KT_PAD,16) /* key-pad dot (period): kludge... */
350 #define K_PPLUSMINUS K(KT_PAD,17) /* key-pad plus/minus */
351 #define K_PPARENL K(KT_PAD,18) /* key-pad left parenthesis */
352 #define K_PPARENR K(KT_PAD,19) /* key-pad right parenthesis */
353
354 #define NR_PAD 20
355
356 #define K_DGRAVE K(KT_DEAD,0)
357 #define K_DACUTE K(KT_DEAD,1)
358 #define K_DCIRCM K(KT_DEAD,2)
359 #define K_DTILDE K(KT_DEAD,3)
360 #define K_DDIERE K(KT_DEAD,4)
361 #define K_DCEDIL K(KT_DEAD,5)
362
363 #define NR_DEAD 6
364
365 #define K_DOWN K(KT_CUR,0)
366 #define K_LEFT K(KT_CUR,1)
367 #define K_RIGHT K(KT_CUR,2)
368 #define K_UP K(KT_CUR,3)
369
370 #define K_SHIFT K(KT_SHIFT,KG_SHIFT)
371 #define K_CTRL K(KT_SHIFT,KG_CTRL)
372 #define K_ALT K(KT_SHIFT,KG_ALT)
373 #define K_ALTGR K(KT_SHIFT,KG_ALTGR)
374 #define K_SHIFTL K(KT_SHIFT,KG_SHIFTL)
375 #define K_SHIFTR K(KT_SHIFT,KG_SHIFTR)
376 #define K_CTRLL K(KT_SHIFT,KG_CTRLL)
377 #define K_CTRLR K(KT_SHIFT,KG_CTRLR)
378 #define K_CAPSSHIFT K(KT_SHIFT,KG_CAPSSHIFT)
379
380 #define K_ASC0 K(KT_ASCII,0)
381 #define K_ASC1 K(KT_ASCII,1)
382 #define K_ASC2 K(KT_ASCII,2)
383 #define K_ASC3 K(KT_ASCII,3)
384 #define K_ASC4 K(KT_ASCII,4)
385 #define K_ASC5 K(KT_ASCII,5)
386 #define K_ASC6 K(KT_ASCII,6)
387 #define K_ASC7 K(KT_ASCII,7)
388 #define K_ASC8 K(KT_ASCII,8)
389 #define K_ASC9 K(KT_ASCII,9)
390 #define K_HEX0 K(KT_ASCII,10)
391 #define K_HEX1 K(KT_ASCII,11)
392 #define K_HEX2 K(KT_ASCII,12)
393 #define K_HEX3 K(KT_ASCII,13)
394 #define K_HEX4 K(KT_ASCII,14)
395 #define K_HEX5 K(KT_ASCII,15)
396 #define K_HEX6 K(KT_ASCII,16)
397 #define K_HEX7 K(KT_ASCII,17)
398 #define K_HEX8 K(KT_ASCII,18)
399 #define K_HEX9 K(KT_ASCII,19)
400 #define K_HEXa K(KT_ASCII,20)
401 #define K_HEXb K(KT_ASCII,21)
402 #define K_HEXc K(KT_ASCII,22)
403 #define K_HEXd K(KT_ASCII,23)
404 #define K_HEXe K(KT_ASCII,24)
405 #define K_HEXf K(KT_ASCII,25)
406
407 #define NR_ASCII 26
408
409 #define K_SHIFTLOCK K(KT_LOCK,KG_SHIFT)
410 #define K_CTRLLOCK K(KT_LOCK,KG_CTRL)
411 #define K_ALTLOCK K(KT_LOCK,KG_ALT)
412 #define K_ALTGRLOCK K(KT_LOCK,KG_ALTGR)
413 #define K_SHIFTLLOCK K(KT_LOCK,KG_SHIFTL)
414 #define K_SHIFTRLOCK K(KT_LOCK,KG_SHIFTR)
415 #define K_CTRLLLOCK K(KT_LOCK,KG_CTRLL)
416 #define K_CTRLRLOCK K(KT_LOCK,KG_CTRLR)
417
418 #define K_SHIFT_SLOCK K(KT_SLOCK,KG_SHIFT)
419 #define K_CTRL_SLOCK K(KT_SLOCK,KG_CTRL)
420 #define K_ALT_SLOCK K(KT_SLOCK,KG_ALT)
421 #define K_ALTGR_SLOCK K(KT_SLOCK,KG_ALTGR)
422 #define K_SHIFTL_SLOCK K(KT_SLOCK,KG_SHIFTL)
423 #define K_SHIFTR_SLOCK K(KT_SLOCK,KG_SHIFTR)
424 #define K_CTRLL_SLOCK K(KT_SLOCK,KG_CTRLL)
425 #define K_CTRLR_SLOCK K(KT_SLOCK,KG_CTRLR)
426
427 #define NR_LOCK 8
428
429 #define MAX_DIACR 256
430 #endif
