RTEMS  5.1
nvram.h
1 /*===============================================================*\
2 | Project: RTEMS generic MPC5200 BSP |
3 +-----------------------------------------------------------------+
4 | Partially based on the code references which are named below. |
5 | Adaptions, modifications, enhancements and any recent parts of |
6 | the code are: |
7 | Copyright (c) 2005 |
8 | Embedded Brains GmbH |
9 | Obere Lagerstr. 30 |
10 | D-82178 Puchheim |
11 | Germany |
12 | rtems@embedded-brains.de |
13 +-----------------------------------------------------------------+
14 | The license and distribution terms for this file may be |
15 | found in the file LICENSE in this distribution or at |
16 | |
17 | http://www.rtems.org/license/LICENSE. |
18 | |
19 +-----------------------------------------------------------------+
20 | this file contains the nvram declarations |
21 \*===============================================================*/
22 /***********************************************************************/
23 /* */
24 /* Module: nvram.h */
25 /* Date: 07/17/2003 */
26 /* Purpose: RTEMS M93C64-based header file */
27 /* */
28 /*---------------------------------------------------------------------*/
29 /* */
30 /* Description: M93C46 is a serial microwire EEPROM which contains */
31 /* 1Kbit (128 bytes/64 words) of non-volatile memory. */
32 /* The device can be configured for byte- or word- */
33 /* access. The driver provides a file-like interface */
34 /* to this memory. */
35 /* */
36 /* MPC5x00 PIN settings: */
37 /* */
38 /* PSC3_6 (output) -> MC93C46 serial data in (D) */
39 /* PSC3_7 (input) -> MC93C46 serial data out (Q) */
40 /* PSC3_8 (output) -> MC93C46 chip select input (S) */
41 /* PSC3_9 (output) -> MC93C46 serial clock (C) */
42 /* */
43 /*---------------------------------------------------------------------*/
44 /* */
45 /* Code */
46 /* References: DS1307-based Non-Volatile memory device driver */
47 /* Module: nvram.h */
48 /* Project: RTEMS 4.6.0pre1 / MCF5206Elite BSP */
49 /* Version 1.1 */
50 /* Date: 10/26/2001 */
51 /* Author: Victor V. Vengerov */
52 /* Copyright: Copyright (C) 2000 OKTET Ltd.,St.-Petersburg,Russia */
53 /* */
54 /* The license and distribution terms for this file may be */
55 /* found in the file LICENSE in this distribution or at */
56 /* http://www.rtems.org/license/LICENSE. */
57 /* */
58 /*---------------------------------------------------------------------*/
59 /* */
60 /* Partially based on the code references which are named above. */
61 /* Adaptions, modifications, enhancements and any recent parts of */
62 /* the code are under the right of */
63 /* */
64 /* IPR Engineering, Dachauer Straße 38, D-80335 München */
65 /* Copyright(C) 2003 */
66 /* */
67 /*---------------------------------------------------------------------*/
68 /* */
69 /* IPR Engineering makes no representation or warranties with */
70 /* respect to the performance of this computer program, and */
71 /* specifically disclaims any responsibility for any damages, */
72 /* special or consequential, connected with the use of this program. */
73 /* */
74 /*---------------------------------------------------------------------*/
75 /* */
76 /* Version history: 1.0 */
77 /* */
78 /***********************************************************************/
79
80 #ifndef __NVRAM_H__
81 #define __NVRAM_H__
82
83 #ifdef __cplusplus
84 extern "C" {
85 #endif
86
87 /* include <bsp.h> */
88 #include <bsp.h>
89
90 /* Macros for TBL read access */
91 #define TBL_READ(count) __asm__ volatile ("mftb %0\n" : "=r" (count) : "0" (count))
92 #define TMBASE_CLOCK (G2_CLOCK/4)
93
94 /* Simple usec delay function prototype */
95 void wait_usec(unsigned long);
96
97 /* nvram_driver_initialize --
98  * Non-volatile memory device driver initialization.
99  */
101 nvram_driver_initialize(rtems_device_major_number major,
102  rtems_device_minor_number minor,
103  void *arg);
104
105 /* nvram_driver_open --
106  * Non-volatile memory device driver open primitive.
107  */
109 nvram_driver_open(rtems_device_major_number major,
110  rtems_device_minor_number minor,
111  void *arg);
112
113 /* nvram_driver_close --
114  * Non-volatile memory device driver close primitive.
115  */
117 nvram_driver_close(rtems_device_major_number major,
118  rtems_device_minor_number minor,
119  void *arg);
120
121 /* nvram_driver_read --
122  * Non-volatile memory device driver read primitive.
123  */
125 nvram_driver_read(rtems_device_major_number major,
126  rtems_device_minor_number minor,
127  void *arg);
128
129 /* nvram_driver_write --
130  * Non-volatile memory device driver write primitive.
131  */
133 nvram_driver_write(rtems_device_major_number major,
134  rtems_device_minor_number minor,
135  void *arg);
136
137 #ifdef __cplusplus
138 }
139 #endif
140
141 #endif /* __NVRAM_H__ */
rtems_status_code
Classic API Status.
Definition: status.h:43
