40 #ifndef _RPCSVC_NISLIB_H    41 #define _RPCSVC_NISLIB_H    55 extern void nis_freeresult(nis_result *);
    56 extern nis_result * nis_lookup(nis_name, u_long);
    57 extern nis_result * nis_list(nis_name, u_long,
    58     int (*)(nis_name, nis_object *,
void *),
void *);
    59 extern nis_result * nis_add(nis_name, nis_object *);
    60 extern nis_result * nis_remove(nis_name, nis_object *);
    61 extern nis_result * nis_modify(nis_name, nis_object *);
    63 extern nis_result * nis_add_entry(nis_name, nis_object *, u_long);
    64 extern nis_result * nis_remove_entry(nis_name, nis_object *, u_long);
    65 extern nis_result * nis_modify_entry(nis_name, nis_object *, u_long);
    66 extern nis_result * nis_first_entry(nis_name);
    67 extern nis_result * nis_next_entry(nis_name, netobj *);
    69 extern nis_error nis_mkdir(nis_name, nis_server *);
    70 extern nis_error nis_rmdir(nis_name, nis_server *);
    71 extern name_pos nis_dir_cmp(nis_name, nis_name);
    73 extern nis_name * nis_getnames(nis_name);
    74 extern void nis_freenames(nis_name *);
    75 extern nis_name nis_domain_of(nis_name);
    76 extern nis_name nis_leaf_of(nis_name);
    77 extern nis_name nis_leaf_of_r(
const nis_name,
char *,
size_t);
    78 extern nis_name nis_name_of(nis_name);
    79 extern nis_name nis_local_group(
void);
    80 extern nis_name nis_local_directory(
void);
    81 extern nis_name nis_local_principal(
void);
    82 extern nis_name nis_local_host(
void);
    84 extern void nis_destroy_object(nis_object *);
    85 extern nis_object * nis_clone_object(nis_object *, nis_object *);
    86 extern void nis_print_object(nis_object *);
    88 extern char * nis_sperrno(nis_error);
    89 extern void nis_perror(nis_error,
char *);
    90 extern char * nis_sperror(nis_error,
char *);
    91 extern void nis_lerror(nis_error,
char *);
    93 extern void nis_print_group_entry(nis_name);
    94 extern bool_t nis_ismember(nis_name, nis_name);
    95 extern nis_error nis_creategroup(nis_name, u_long);
    96 extern nis_error nis_destroygroup(nis_name);
    97 extern nis_error nis_addmember(nis_name, nis_name);
    98 extern nis_error nis_removemember(nis_name, nis_name);
    99 extern nis_error nis_verifygroup(nis_name);
   101 extern void nis_freeservlist(nis_server **);
   102 extern nis_server ** nis_getservlist(nis_name);
   103 extern nis_error nis_stats(nis_server *, nis_tag *,
int, nis_tag **);
   104 extern nis_error nis_servstate(nis_server *, nis_tag *,
int, nis_tag **);
   105 extern void nis_freetags(nis_tag *,
int);
   107 extern nis_result * nis_checkpoint(nis_name);
   108 extern void nis_ping(nis_name, u_long, nis_object *);
   117 extern char ** __break_name(nis_name,
int *);
   118 extern int __name_distance(
char **,
char **);
   119 extern nis_result * nis_make_error(nis_error, u_long, u_long, u_long, u_long);
   120 extern nis_attr * __cvt2attr(
int *,
char **);
   121 extern void nis_free_request(ib_request *);
   122 extern nis_error nis_get_request(nis_name, nis_object *, netobj*, ib_request*);
   123 extern nis_object * nis_read_obj(
char *);
   124 extern int nis_write_obj(
char *, nis_object *);
   125 extern int nis_in_table(nis_name, NIS_HASH_TABLE *,
int *);
   126 extern int nis_insert_item(NIS_HASH_ITEM *, NIS_HASH_TABLE *);
   127 extern NIS_HASH_ITEM * nis_find_item(nis_name, NIS_HASH_TABLE *);
   128 extern NIS_HASH_ITEM * nis_remove_item(nis_name, NIS_HASH_TABLE *);
   129 extern void nis_insert_name(nis_name, NIS_HASH_TABLE *);
   130 extern void nis_remove_name(nis_name, NIS_HASH_TABLE *);
   131 extern CLIENT * nis_make_rpchandle(nis_server *,
int, u_long, u_long, u_long,
   133 extern void * nis_get_static_storage(
struct nis_sdata *, u_long, u_long);
   134 extern char * nis_data(
char *);
   135 extern void nis_print_rights(u_long);
   136 extern void nis_print_directory(directory_obj *);
   137 extern void nis_print_group(group_obj *);
   138 extern void nis_print_table(table_obj *);
   139 extern void nis_print_link(link_obj *);
   140 extern void nis_print_entry(entry_obj *);
   141 extern nis_object * nis_get_object(
char *,
char *,
char *, u_long, u_long,
   143 extern nis_server * __nis_init_callback(CLIENT *,
   144     int (*)(nis_name, nis_object *,
void *),
void *);
   145 extern int nis_getdtblsize(
void);
   146 extern int __nis_run_callback(netobj *, u_long,
struct timeval *, CLIENT *);
   148 extern log_result *nis_dumplog(nis_server *, nis_name, u_long);
   149 extern log_result *nis_dump(nis_server *, nis_name,
   150     int (*)(nis_name, nis_object *,
void *));
   152 extern bool_t __do_ismember(nis_name, nis_name,
   153     nis_result *(*)(nis_name, u_long));
   154 extern nis_name __nis_map_group(nis_name);
   155 extern nis_name __nis_map_group_r(nis_name,
char*,
size_t);
   157 extern nis_error __nis_CacheBind(
char *, directory_obj *);
   158 extern nis_error __nis_CacheSearch(
   159 extern bool_t __nis_CacheRemoveEntry(directory_obj *);
   160 extern void __nis_CacheRestart(
void);
   161 extern void __nis_CachePrint(
void);
   162 extern void __nis_CacheDumpStatistics(
void);
   163 extern bool_t writeColdStartFile(directory_obj *);
   165 extern CLIENT * __get_ti_clnt(
char *, CLIENT *,
char **, pid_t *);
   166 extern int __strcmp_case_insens(
char *,
char *);
   167 extern int __strncmp_case_insens(
char *,
char *);
   169 extern fd_result * nis_finddirectory(directory_obj *, nis_name);
   170 extern int __start_clock(
int);
   171 extern u_long __stop_clock(
int);
   180 extern struct signature *__nis_calculate_encrypted_cksum(
unsigned char *,
unsigned int,
char *,
int);
   186 extern void nis_freeresult();
   187 extern nis_result * nis_lookup();
   188 extern nis_result * nis_list();
   189 extern nis_result * nis_add();
   190 extern nis_result * nis_remove();
   191 extern nis_result * nis_modify();
   193 extern nis_result * nis_add_entry();
   194 extern nis_result * nis_remove_entry();
   195 extern nis_result * nis_modify_entry();
   196 extern nis_result * nis_first_entry();
   197 extern nis_result * nis_next_entry();
   199 extern nis_error nis_mkdir();
   200 extern nis_error nis_rmdir();
   201 extern name_pos nis_dir_cmp();
   203 extern nis_name *nis_getnames();
   204 extern void nis_freenames();
   205 extern nis_name nis_domain_of();
   206 extern nis_name nis_leaf_of();
   207 extern nis_name nis_leaf_of_r();
   208 extern nis_name nis_name_of();
   209 extern nis_name nis_local_group();
   210 extern nis_name nis_local_directory();
   211 extern nis_name nis_local_principal();
   212 extern nis_name nis_local_host();
   214 extern void nis_destroy_object();
   215 extern nis_object * nis_clone_object();
   216 extern void nis_print_object();
   218 extern char * nis_sperrno();
   219 extern void nis_perror();
   220 extern char * nis_sperror();
   221 extern void nis_lerror();
   223 extern void nis_print_group_entry();
   224 extern bool_t nis_ismember();
   225 extern nis_error nis_creategroup();
   226 extern nis_error nis_destroygroup();
   227 extern nis_error nis_addmember();
   228 extern nis_error nis_removemember();
   229 extern nis_error nis_verifygroup();
   231 extern void nis_freeservlist();
   232 extern nis_server ** nis_getservlist();
   233 extern nis_error nis_stats();
   234 extern nis_error nis_servstate();
   235 extern void nis_freetags();
   237 extern nis_result * nis_checkpoint();
   238 extern void nis_ping();
   246 extern char ** __break_name();
   247 extern int __name_distance();
   248 extern nis_result * nis_make_error();
   249 extern nis_attr * __cvt2attr();
   250 extern void nis_free_request();
   251 extern nis_error nis_get_request();
   252 extern nis_object * nis_read_obj();
   253 extern int nis_write_obj();
   254 extern int nis_in_table();
   255 extern int nis_insert_item();
   256 extern NIS_HASH_ITEM * nis_find_item();
   257 extern NIS_HASH_ITEM * nis_remove_item();
   258 extern void nis_insert_name();
   259 extern void nis_remove_name();
   260 extern CLIENT * nis_make_rpchandle();
   261 extern void * nis_get_static_storage();
   262 extern char * nis_data();
   264 extern void nis_print_rights();
   265 extern void nis_print_directory();
   266 extern void nis_print_group();
   267 extern void nis_print_table();
   268 extern void nis_print_link();
   269 extern void nis_print_entry();
   270 extern nis_object * nis_get_object();
   272 extern nis_server * __nis_init_callback();
   273 extern int nis_getdtblsize();
   274 extern int __nis_run_callback();
   276 extern log_result * nis_dump();
   277 extern log_result * nis_dumplog();
   279 extern bool_t __do_ismember();
   280 extern nis_name __nis_map_group();
   281 extern nis_name __nis_map_group_r();
   284 extern nis_error __nis_CacheBind();
   285 extern directory_obj * __nis_CacheSearch();
   286 extern bool_t __nis_CacheRemoveEntry();
   287 extern void __nis_CacheRestart();
   288 extern void __nis_CachePrint();
   289 extern void __nis_CacheDumpStatistics();
   290 extern bool_t writeColdStartFile();
   292 extern CLIENT * __get_ti_clnt();
   293 extern int __strcmp_case_insens();
   294 extern int __strncmp_case_insens();
   296 extern fd_result * nis_finddirectory();
   297 extern int __start_clock();
   298 extern u_long __stop_clock();
   307 extern struct signature *__nis_calculate_encrypted_cksum();
