25 #ifndef LIBBSP_ARM_LPC32XX_NAND_MLC_H    26 #define LIBBSP_ARM_LPC32XX_NAND_MLC_H    74 #define MLC_SMALL_PAGE_SIZE 528    75 #define MLC_SMALL_DATA_SIZE 512    76 #define MLC_SMALL_SPARE_SIZE 16    77 #define MLC_SMALL_USER_SPARE_SIZE 6    78 #define MLC_SMALL_ECC_SPARE_SIZE 10    79 #define MLC_SMALL_DATA_WORD_COUNT (MLC_SMALL_DATA_SIZE / 4)    80 #define MLC_SMALL_SPARE_WORD_COUNT (MLC_SMALL_SPARE_SIZE / 4)    81 #define MLC_SMALL_PAGES_PER_LARGE_PAGE 4    82 #define MLC_LARGE_PAGE_SIZE \    83   (MLC_SMALL_PAGES_PER_LARGE_PAGE * MLC_SMALL_PAGE_SIZE)    84 #define MLC_LARGE_DATA_SIZE \    85   (MLC_SMALL_PAGES_PER_LARGE_PAGE * MLC_SMALL_DATA_SIZE)    86 #define MLC_LARGE_SPARE_SIZE \    87   (MLC_SMALL_PAGES_PER_LARGE_PAGE * MLC_SMALL_SPARE_SIZE)    88 #define MLC_LARGE_DATA_WORD_COUNT (MLC_LARGE_DATA_SIZE / 4)    89 #define MLC_LARGE_SPARE_WORD_COUNT (MLC_LARGE_SPARE_SIZE / 4)    99 #define FLASHCLK_IRQ_MLC BSP_BIT32(5)   100 #define FLASHCLK_MLC_DMA_RNB BSP_BIT32(4)   101 #define FLASHCLK_MLC_DMA_INT BSP_BIT32(3)   102 #define FLASHCLK_SELECT_SLC BSP_BIT32(2)   103 #define FLASHCLK_MLC_CLK_ENABLE BSP_BIT32(1)   104 #define FLASHCLK_SLC_CLK_ENABLE BSP_BIT32(0)   114 #define MLC_TIME_WR_LOW(val) BSP_FLD32(val, 0, 3)   115 #define MLC_TIME_WR_HIGH(val) BSP_FLD32(val, 4, 7)   116 #define MLC_TIME_RD_LOW(val) BSP_FLD32(val, 8, 11)   117 #define MLC_TIME_RD_HIGH(val) BSP_FLD32(val, 12, 15)   118 #define MLC_TIME_NAND_TA(val) BSP_FLD32(val, 16, 18)   119 #define MLC_TIME_BUSY_DELAY(val) BSP_FLD32(val, 19, 23)   120 #define MLC_TIME_TCEA_DELAY(val) BSP_FLD32(val, 24, 25)   130 #define MLC_UNLOCK_PROT 0xa25e   140 #define MLC_ISR_DECODER_FAILURE BSP_BIT32(6)   141 #define MLC_ISR_SYMBOL_ERRORS(reg) BSP_FLD32GET(reg, 4, 5)   142 #define MLC_ISR_ERRORS_DETECTED BSP_BIT32(3)   143 #define MLC_ISR_ECC_READY BSP_BIT32(2)   144 #define MLC_ISR_CONTROLLER_READY BSP_BIT32(1)   145 #define MLC_ISR_NAND_READY BSP_BIT32(0)   155 #define MLC_ICR_SOFT_WRITE_PROT BSP_BIT32(3)   156 #define MLC_ICR_LARGE_PAGES BSP_BIT32(2)   157 #define MLC_ICR_ADDR_WORD_COUNT_4_5 BSP_BIT32(1)   158 #define MLC_ICR_IO_BUS_16 BSP_BIT32(0)   168 #define MLC_ECC_AUTO_ENC_PROGRAM BSP_BIT32(8)   178 #define NAND_STATUS_ERROR (1U << 0)   179 #define NAND_STATUS_READY (1U << 6)   180 #define NAND_STATUS_NOT_PROTECTED (1U << 7)   190   uint32_t block_count;
   202 #define MLC_SMALL_PAGES 0x1U   208 #define MLC_MANY_ADDRESS_CYCLES 0x2U   215 #define MLC_NORMAL_BLOCKS 0x4U   220 #define MLC_IO_WIDTH_16_BIT 0x8U   227 uint32_t lpc32xx_mlc_page_size(
void);
   229 uint32_t lpc32xx_mlc_pages_per_block(
void);
   231 uint32_t lpc32xx_mlc_block_count(
void);
   233 uint32_t lpc32xx_mlc_io_width(
void);
   235 void lpc32xx_mlc_write_protection(
   236   uint32_t page_index_low,
   237   uint32_t page_index_high
   240 void lpc32xx_mlc_read_id(uint8_t *
id,
size_t n);
   259   uint32_t *symbol_error_count
   313   uint32_t block_index,
   353   uint32_t block_begin,
   357   uint32_t page_buffer [MLC_LARGE_DATA_WORD_COUNT]
   372   uint32_t page_data [MLC_LARGE_DATA_WORD_COUNT],
   373   uint32_t page_spare [MLC_LARGE_SPARE_WORD_COUNT]
   387   uint32_t block_begin,
   391   uint32_t page_buffer_0 [MLC_LARGE_DATA_WORD_COUNT],
   392   uint32_t page_buffer_1 [MLC_LARGE_DATA_WORD_COUNT]
   407 static inline bool lpc32xx_mlc_is_bad_page(
const uint32_t *spare)
   409   uint32_t first_byte_mask = 0x000000ff;
   410   uint32_t sixth_byte_mask = 0x0000ff00;
   412   return (spare [0] & first_byte_mask) != first_byte_mask
   413     || (spare [1] & sixth_byte_mask) != sixth_byte_mask;
 rtems_status_code lpc32xx_mlc_read_page(uint32_t page_index, void *data, void *spare, uint32_t *symbol_error_count)
Reads the page with index page_index.
Definition: nand-mlc.c:211
rtems_status_code lpc32xx_mlc_read_blocks(uint32_t block_begin, uint32_t block_end, lpc32xx_mlc_read_process process, void *process_arg, uint32_t page_buffer_0 [MLC_LARGE_DATA_WORD_COUNT], uint32_t page_buffer_1 [MLC_LARGE_DATA_WORD_COUNT])
Reads the pages of block block_begin up to and excluding block_end.
Definition: nand-mlc-read-blocks.c:51
rtems_status_code lpc32xx_mlc_erase_block_safe(uint32_t block_index)
Erases the block with index block_index.
Definition: nand-mlc-erase-block-safe.c:111
rtems_status_code lpc32xx_mlc_write_page_with_ecc(uint32_t page_index, const void *data, const void *spare)
Writes the page with index page_index.
Definition: nand-mlc.c:339
bool(* lpc32xx_mlc_read_process)(void *process_arg, uint32_t page_index, uint32_t page_size, uint32_t page_data [MLC_LARGE_DATA_WORD_COUNT], uint32_t page_spare [MLC_LARGE_SPARE_WORD_COUNT])
Read blocks process function type.
Definition: nand-mlc.h:368
rtems_status_code lpc32xx_mlc_erase_block_safe_3(uint32_t block_index, uint32_t page_begin, uint32_t page_end)
Definition: nand-mlc-erase-block-safe.c:92
rtems_status_code
Classic API Status.
Definition: status.h:43
void lpc32xx_mlc_init(const lpc32xx_mlc_config *cfg)
Initializes the MLC NAND controller according to cfg.
Definition: nand-mlc.c:165
uint32_t time
Value for the MLC NAND Timing Register (MLC_TIME_REG).
Definition: nand-mlc.h:195
MLC NAND controller configuration.
Definition: nand-mlc.h:187
rtems_status_code lpc32xx_mlc_write_blocks(uint32_t block_begin, uint32_t block_end, const void *src, size_t src_size, uint32_t page_buffer [MLC_LARGE_DATA_WORD_COUNT])
Writes src_size Bytes from src to the flash area specified by block_begin and block_end.
rtems_status_code lpc32xx_mlc_erase_block(uint32_t block_index)
Definition: nand-mlc.c:319
void lpc32xx_mlc_zero_pages(uint32_t page_begin, uint32_t page_end)
Writes zero values to the pages specified by page_begin and page_end.
Definition: nand-mlc-erase-block-safe.c:30
rtems_status_code lpc32xx_mlc_is_valid_block(uint32_t block_index)
Checks if the block with index block_index is valid.
Definition: nand-mlc-erase-block-safe.c:84
