40 struct rtems_bsdnet_ifconfig;
    41 int uti596_attach(
struct rtems_bsdnet_ifconfig * pConfig,
int attaching );
    42 #define RTEMS_BSP_NETWORK_DRIVER_NAME   "uti1"    43 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH uti596_attach    55 #define BOARD_BASE_ADDRESS 0xFFFF0000    66 #define GROUP_BASE_ADDRESS 0x0000CC00    73 typedef volatile struct {
    74   unsigned long     slave_adr[2];
    75   unsigned long     slave_trn[2];
    76   unsigned long     slave_ctl;
    77   unsigned long     mastr_adr[4];
    78   unsigned long     mastr_trn;
    79   unsigned long     mastr_att;
    80   unsigned long     mastr_ctl;
    81   unsigned long     dma_ctl_1;
    82   unsigned long     dma_ctl_2;
    83   unsigned long     dma_loc_cnt;
    84   unsigned long     dma_vme_cnt;
    85   unsigned long     dma_byte_cnt;
    86   unsigned long     dma_adr_cnt;
    87   unsigned long     dma_status;
    89   unsigned long     timer_cmp_1;
    90   unsigned long     timer_cnt_1;
    91   unsigned long     timer_cmp_2;
    92   unsigned long     timer_cnt_2;
    93   unsigned long     board_ctl;
    94   unsigned long     prescaler_cnt;
    95   unsigned long     intr_stat;
    96   unsigned long     intr_ena;
    97   unsigned long     intr_soft_set;
    98   unsigned long     intr_clear;
    99   unsigned long     intr_level[4];
   100   unsigned long     vector_base;
   108 #define lcsr        ((lcsr_regs * const) 0xFFF40000)   117 #define MASK_INT    0x00800000   129   unsigned char     chip_id;
   130   unsigned char     chip_revision;
   131   unsigned char     gen_control;
   132   unsigned char     vector_base;
   133   unsigned long     timer_cmp_1;
   134   unsigned long     timer_cnt_1;
   135   unsigned long     timer_cmp_2;
   136   unsigned long     timer_cnt_2;
   137   unsigned char     LSB_prescaler_count;
   138   unsigned char     prescaler_clock_adjust;
   139   unsigned char     timer_ctl_2;
   140   unsigned char     timer_ctl_1;
   141   unsigned char     gpi_int_ctl;
   142   unsigned char     gpio_ctl;
   143   unsigned char     timer_int_ctl_2;
   144   unsigned char     timer_int_ctl_1;
   145   unsigned char     SCC_error;
   146   unsigned char     SCC_modem_int_ctl;
   147   unsigned char     SCC_tx_int_ctl;
   148   unsigned char     SCC_rx_int_ctl;
   149   unsigned char     reserved1[3];
   150   unsigned char     modem_piack;
   151   unsigned char     reserved2;
   152   unsigned char     tx_piack;
   153   unsigned char     reserved3;
   154   unsigned char     rx_piack;
   155   unsigned char     LANC_error;
   156   unsigned char     reserved4;
   157   unsigned char     LANC_int_ctl;
   158   unsigned char     LANC_berr_ctl;
   159   unsigned char     SCSI_error;
   160   unsigned char     reserved5[2];
   161   unsigned char     SCSI_int_ctl;
   162   unsigned char     print_ack_int_ctl;
   163   unsigned char     print_fault_int_ctl;
   164   unsigned char     print_sel_int_ctl;
   165   unsigned char     print_pe_int_ctl;
   166   unsigned char     print_busy_int_ctl;
   167   unsigned char     reserved6;
   168   unsigned char     print_input_status;
   169   unsigned char     print_ctl;
   170   unsigned char     chip_speed;
   171   unsigned char     reserved7;
   172   unsigned char     print_data;
   173   unsigned char     reserved8[3];
   174   unsigned char     int_level;
   175   unsigned char     int_mask;
   182 #define pccchip2    ((pccchip2_regs * const) 0xFFF42000)   195 #define PCCCHIP2_VBR    0x5   203 typedef volatile struct {
   204   unsigned char       chip_revision;
   205   unsigned char       chip_id;
   207   unsigned char       board_scr;
   208   unsigned short      gpr[6];
   211 #define gcsr_vme ((gcsr_regs * const) (GROUP_BASE_ADDRESS + BOARD_BASE_ADDRESS))   212 #define gcsr     ((gcsr_regs * const) 0xFFF40100)   218   unsigned short  port_lower;
   219   unsigned short  port_upper;
   220   unsigned long   chan_attn;
   227 #define i82596    ((i82596_regs * const) 0xFFF46000)   234 typedef volatile struct nvram_config_ {
   235   unsigned char   cache_mode;
   236   unsigned char   console_mode;
   237   unsigned char   console_printk_port;
   239   unsigned long   ipaddr;
   240   unsigned long   netmask;
   241   unsigned char   enaddr[6];
   242   unsigned short  processor_id;
   243   unsigned long   rma_start;
   244   unsigned long   vma_start;
   245   unsigned long   ramsize;
   252 #define nvram      ((nvram_config * const) 0xFFFC0000)   264   #define NVRAM_CONFIGURE \   265     ( !( ( (unsigned char)(lcsr->vector_base & 0xFF) ) & 0x10 ) )   267   #define NVRAM_CONFIGURE 0 Definition: mvme16x_hw.h:203
Definition: mvme16x_hw.h:217
Definition: mvme16x_hw.h:73
Definition: mvme16x_hw.h:128
