29 #define MSCAN_A_DEV_NAME         "/dev/mscana"    30 #define MSCAN_B_DEV_NAME         "/dev/mscanb"    31 #define MSCAN_0_DEV_NAME         "/dev/mscan0"    32 #define MSCAN_1_DEV_NAME         "/dev/mscan1"    36 #define MSCAN_MAX_DATA_BYTES     8    38 #define MSCAN_MESS_ID_RTR        (1 << 15)    39 #define MSCAN_MESS_ID_RTR_MASK   (1 << 15)    40 #define MSCAN_MESS_ID_ID_MASK    ((1 << 11)-1)    41 #define MSCAN_MESS_ID_HAS_RTR(id) (((id)&MSCAN_MESS_ID_RTR_MASK)==MSCAN_MESS_ID_RTR)    43 #define MSCAN_SET_RX_ID          1    44 #define MSCAN_GET_RX_ID          2    45 #define MSCAN_SET_RX_ID_MASK     3    46 #define MSCAN_GET_RX_ID_MASK     4    47 #define MSCAN_SET_TX_ID          5    48 #define MSCAN_GET_TX_ID          6    49 #define TOUCAN_MSCAN_INIT        7    50 #define MSCAN_SET_BAUDRATE       8    51 #define SET_TX_BUF_NO            9    57   uint16_t mess_time_stamp;
    58   uint8_t  mess_data[MSCAN_MAX_DATA_BYTES];
    61   uint32_t toucan_tx_idx;
    80     uint32_t ctrl_id_mask;
    82     uint8_t  ctrl_tx_buf_no;
    83     uint32_t ctrl_can_bitrate;
    84     void (*toucan_cb_fnc)(int16_t);
    89                                       rtems_device_minor_number,
    94                                 rtems_device_minor_number,
    99                                  rtems_device_minor_number,
   104                                 rtems_device_minor_number,
   109                                  rtems_device_minor_number,
   114                                    rtems_device_minor_number,
   119 #define MSCAN_DRIVER_TABLE_ENTRY \   120   { mscan_initialize, mscan_open, mscan_close, \   121     mscan_read, mscan_write, mscan_control }
rtems_status_code
Classic API Status.
Definition: status.h:43
A CAN message represented of both forms.
Definition: can.h:66
