RTEMS  5.1
VMEConfig.h
1 #ifndef RTEMS_BSP_VME_CONFIG_H
2 #define RTEMS_BSP_VME_CONFIG_H
3
4 /* BSP specific address space configuration parameters */
5
6 /*
7  * Authorship
8  * ----------
9  * This software was created by
10  * Till Straumann <strauman@slac.stanford.edu>, 2002,
11  * Stanford Linear Accelerator Center, Stanford University.
12  *
13  * Acknowledgement of sponsorship
14  * ------------------------------
15  * This software was produced by
16  * the Stanford Linear Accelerator Center, Stanford University,
17  * under Contract DE-AC03-76SFO0515 with the Department of Energy.
18  *
19  * Government disclaimer of liability
20  * ----------------------------------
21  * Neither the United States nor the United States Department of Energy,
22  * nor any of their employees, makes any warranty, express or implied, or
23  * assumes any legal liability or responsibility for the accuracy,
24  * completeness, or usefulness of any data, apparatus, product, or process
25  * disclosed, or represents that its use would not infringe privately owned
26  * rights.
27  *
28  * Stanford disclaimer of liability
29  * --------------------------------
30  * Stanford University makes no representations or warranties, express or
31  * implied, nor assumes any liability for the use of this software.
32  *
33  * Stanford disclaimer of copyright
34  * --------------------------------
35  * Stanford University, owner of the copyright, hereby disclaims its
36  * copyright and all other rights in this software. Hence, anyone may
37  * freely use it for any purpose without restriction.
38  *
39  * Maintenance of notices
40  * ----------------------
41  * In the interest of clarity regarding the origin and status of this
42  * SLAC software, this and all the preceding Stanford University notices
43  * are to remain affixed to any copy or derivative of this software made
44  * or distributed by the recipient and are to be affixed to any copy of
45  * software made or distributed by the recipient that contains a copy or
46  * derivative of this software.
47  *
48  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
49  */
50
51 /*
52  * The BSP maps VME address ranges into
53  * one BAT.
54  * NOTE: the BSP (startup/bspstart.c) uses
55  * hardcoded window lengths that match this
56  * layout:
57  *
58  * BSP_VME_BAT_IDX defines
59  * which BAT to use for mapping the VME bus.
60  * If this is undefined, no extra BAT will be
61  * configured and VME has to share the available
62  * PCI address space with PCI devices.
63  *
64  * If you do define BSP_VME_BAT_IDX you must
65  * make sure the corresponding BAT is really
66  * available and unused!
67  */
68
69 #if defined(mvme2100)
70 #define _VME_A32_WIN0_ON_PCI 0x90000000
71 #define _VME_A24_ON_PCI 0x9f000000
72 #define _VME_A16_ON_PCI 0x9fff0000
73 #define BSP_VME_BAT_IDX 1
74 #else
75 #define _VME_A32_WIN0_ON_PCI 0x10000000
76 #define _VME_A24_ON_PCI 0x1f000000
77 #define _VME_A16_ON_PCI 0x1fff0000
78 #define BSP_VME_BAT_IDX 0
79 #endif
80
81 /* start of the A32 window on the VME bus
82  * TODO: this should perhaps be a run-time configuration option
83  */
84 #define _VME_A32_WIN0_ON_VME 0x20000000
85
86 /* if _VME_DRAM_OFFSET is defined, the BSP
87  * will map the board RAM onto the VME bus, starting
88  * at _VME_DRAM_OFFSET
89  */
90 #define _VME_DRAM_OFFSET 0xc0000000
91
92 /* Define BSP_PCI_VME_DRIVER_DOES_EOI to let the vmeUniverse
93  * driver (Tsi148 driver doesn't implement this) implement
94  * VME IRQ priorities in software.
95  *
96  * Here's how this works:
97  *
98  * 1) VME IRQ happens
99  * 2) universe propagates IRQ to PCI/PPC/main interrupt
100  * controller ('PIC' - programmable interrupt controller).
101  * 3) PIC driver dispatches universe driver's ISR
102  * 4) universe driver ISR acknowledges IRQ on VME,
103  * determines VME vector.
104  * ++++++++++++ stuff between ++ signs is related to SW priorities +++++++++
105  * 5) universe driver *masks* all VME IRQ levels <= interrupting
106  * level.
107  * 6) universe driver calls PIC driver's 'EOI' routine.
108  * This effectively re-enables PCI and hence higher
109  * level VME interrupts.
110  * 7) universe driver dispatches user VME ISR.
111  *
112  * ++>> HIGHER PRIORITY VME IRQ COULD HAPPEN HERE and would be handled <<++
113  *
114  * 8) user ISR returns, universe driver re-enables lower
115  * level VME interrupts, returns.
116  * 9) universe driver ISR returns control to PIC driver
117  * 10) PIC driver *omits* regular EOI sequence since this
118  * was already done by universe driver (step 6).
119  * ++++++++++++ end of special handling (SW priorities) ++++++++++++++++++++
120  * 11) PIC driver ISR dispatcher returns.
121  *
122  * Note that the BSP *MUST* provide the following hooks
123  * in order for this to work:
124  * a) bsp.h must define the symbol BSP_PIC_DO_EOI to
125  * a sequence of instructions that terminates an
126  * interrupt at the interrupt controller.
127  * b) The interrupt controller driver must check the
128  * interrupt source and *must omit* running the EOI
129  * sequence if the interrupt source is the vmeUniverse
130  * (because the universe driver already ran BSP_PIC_DO_EOI)
131  * The interrupt controller must define the variable
132  *
133  * int _BSP_vme_bridge_irq = -1;
134  *
135  * which is assigned the universe's interrupt line information
136  * by vme_universe.c:BSP_VMEIrqMgrInstall(). The interrupt
137  * controller driver may use this variable to determine
138  * if an IRQ was caused by the universe.
139  *
140  * c) define BSP_PCI_VME_DRIVER_DOES_EOI
141  *
142  * NOTE: If a) and b) are not implemented by the BSP
143  * BSP_PCI_VME_DRIVER_DOES_EOI must be *undefined*.
144  */
145 #define BSP_PCI_VME_DRIVER_DOES_EOI
146
147 #ifdef BSP_PCI_VME_DRIVER_DOES_EOI
148 /* don't reference vmeUniverse0PciIrqLine directly from the irq
149  * controller driver - leave it up to BSP_VMEIrqMgrInstall() to
150  * set _BSP_vme_bridge_irq. That way, we can avoid linking
151  * the universe driver if VME is unused...
152  */
153 extern int _BSP_vme_bridge_irq;
154 #endif
155
156 /* If your BSP requires a non-standard way to configure
157  * the VME interrupt manager then define the symbol
158  *
159  * BSP_VME_UNIVERSE_INSTALL_IRQ_MGR
160  *
161  * to a proper instruction sequence that installs the
162  * universe interrupt manager. This requires knowledge
163  * of the wiring between the universe and the PIC (main
164  * interrupt controller), i.e., which IRQ 'pins' of the
165  * universe are wired to which 'lines'/inputs at the PIC.
166  * (consult vmeUniverse.h for more information).
167  *
168  * When installing the universe IRQ manager it is also
169  * possible to specify whether it should try to share
170  * PIC interrupts with other sources. This might not
171  * be supported by all BSPs (but the unverse driver
172  * recognizes that).
173  *
174  * If BSP_VME_UNIVERSE_INSTALL_IRQ_MGR is undefined then
175  * the default algorithm is used (vme_universe.c):
176  *
177  * This default setup uses only a single wire. It reads
178  * the PIC 'line' from PCI configuration space and assumes
179  * this to be wired to the first (LIRQ0) IRQ input at the
180  * universe. The default setup tries to use interrupt
181  * sharing.
182  */
183
184 #include <bsp/motorola.h>
185 #include <bsp/pci.h>
186
187 #define BSP_VME_UNIVERSE_INSTALL_IRQ_MGR(err) \
188 do { \
189 int bus, dev, i = 0, j; \
190 const struct _int_map *bspmap; \
191  /* install the VME interrupt manager; \
192  * if there's a bsp route map, use it to \
193  * configure additional lines... \
194  */ \
195  err = -1; \
196  if (0 == pci_find_device(0x10e3, 0x0000, 0, &bus, &dev, &i)){ \
197  if ( (bspmap = motorolaIntMap(currentBoard)) ) { \
198  for ( i=0; bspmap[i].bus >= 0; i++ ) { \
199  if ( bspmap[i].bus == bus && bspmap[i].slot == dev ) { \
200  int pins[5], names[4]; \
201  /* found it; use info here... */ \
202  /* copy up to 4 entries; terminated with -1 pin */ \
203  for ( j=0; \
204  j<5 && (pins[j]=bspmap[i].pin_route[j].pin-1)>=0; \
205  j++) { \
206  names[j] = bspmap[i].pin_route[j].int_name[0]; \
207  } \
208  pins[4] = -1; \
209  if ( 0 == vmeUniverseInstallIrqMgrAlt( \
210  VMEUNIVERSE_IRQ_MGR_FLAG_SHARED, /* shared IRQs */\
211  pins[0], names[0], \
212  pins[1], names[1], \
213  pins[2], names[2], \
214  pins[3], names[3], \
215  -1) ) { \
216  i = -1; \
217  break; \
218  } \
219  } \
220  } \
221  } \
222  if ( i >= 0 ) \
223  err = vmeUniverseInstallIrqMgrAlt( \
224  VMEUNIVERSE_IRQ_MGR_FLAG_SHARED, \
225  0,-1, \
226  -1); \
227  } \
228 } while (0)
229
230 extern int BSP_VMEInit(void);
231 extern int BSP_VMEIrqMgrInstall(void);
232
233 #endif
