66 extern int monConnect(
int (*monptr)(
int,
void *,
void *,
void *),
    67         void (*lock)(
void),
void (*unlock)(
void));
    68 extern void mon_getargv(
int *argc,
char ***argv);
    69 extern void mon_intsrestore(
unsigned long oldval);
    70 extern void mon_appexit(
int exit_value);
    71 extern void mon_free(
char *buffer);
    72 extern void mon_profiler(
void *pdata);
    73 extern void mon_bbc(
char *filename,
int linenum);
    74 extern void mon_warmstart(
unsigned long mask);
    75 extern void mon_delay(
long msec);
    76 extern void mon_printpkt(
char *buf,
int size,
int incoming);
    77 extern void mon_printmem(
char *mem,
int size,
int ascii);
    80 extern int mon_com(
int cmd,
void *arg1,
void *arg2,
void *arg3);
    81 extern int mon_timer(
int cmd,
void * arg);
    82 extern int mon_setenv(
char *varname,
char *value);
    83 extern int mon_putchar(
char c);
    84 extern int mon_getchar(
void);
    85 extern int mon_gotachar(
void);
    86 extern int mon_getbytes(
char *buf,
int count,
int block);
    87 extern int mon_restart(
int restart_value);
    88 extern int mon_tfsinit(
void);
    89 extern int mon_tfsunlink(
char *filename);
    90 extern int mon_tfslink(
char *source,
char *target);
    91 extern int mon_tfsrun(
char **arglist,
int verbosity);
    92 extern int mon_tfsfstat(
char *filename,
struct tfshdr *tfp);
    93 extern int mon_tfseof(
int file_descriptor);
    94 extern int mon_tfstruncate(
int file_descriptor,
long length);
    95 extern int mon_tfsread(
char *buffer,
int size);
    96 extern int mon_tfswrite(
char *buffer,
int size);
    97 extern int mon_tfsopen(
char *filename,
long mode,
char *buffer);
    98 extern int mon_tfsclose(
char *info);
    99 extern int mon_tfsseek(
int offset,
int whence);
   100 extern int mon_tfsgetline(
char *buffer,
int bufsize);
   101 extern int mon_tfsipmod(
char *name,
char *buffer,
int offset,
int size);
   102 extern int mon_addcommand(
struct monCommand *command_list,
char *);
   103 extern int mon_docommand(
char *cmdline,
int verbosity);
   104 extern int mon_getline(
char *buffer,
int max,
int ledit);
   105 extern int mon_decompress(
char *src,
int srcsize,
char *dest);
   106 extern int mon_heapextend(
char *base,
int size);
   107 extern int mon_pcicfgwrite(
int interface,
int bus,
int dev,
int func,
int reg,
   109 extern int mon_tfsadd(
char *filename,
char *info,
char *flags,
   110         unsigned char *src,
int size);
   111 extern int mon_i2cwrite(
int interface,
int bigaddr,
unsigned char *data,
   113 extern int mon_i2cread(
int interface,
int bigaddr,
   115 extern int mon_sendenetpkt(
char *pkt,
int len);
   116 extern int mon_recvenetpkt(
char *pkt,
int len);
   117 extern int mon_flashoverride(
void *flashinfo,
int get,
int bank);
   118 extern int mon_flasherase(
int snum);
   119 extern int mon_flashwrite(
char *dest,
char *src,
int bytecnt);
   120 extern int mon_flashinfo(
int snum,
int *
size,
char **base);
   121 extern int mon_watchdog(
void);
   122 extern int mon_timeofday(
int cmd,
void *arg);
   124 extern char *mon_getsym(
char *symname,
char *buf,
int bufsize);
   125 extern char *mon_getenv(
char *varname);
   126 extern char *mon_getenvp(
void);
   127 extern char *mon_version(
void);
   129 extern char *mon_malloc(
int size,
char *
file,
int line);
   130 extern char *mon_realloc(
char *buf,
int size,
char *
file,
int line);
   132 extern char *mon_malloc(
int size);
   133 extern char *mon_realloc(
char *buf,
int size);
   136 extern long mon_tfsctrl(
int command,
long arg1,
long arg2);
   137 extern long mon_tfstell(
   138 extern long mon_portcmd(
int cmd,
void *arg);
   140 extern unsigned short mon_xcrc16(
char *buffer,
long length);
   142 extern unsigned long mon_intsoff(
void);
   144 extern unsigned long mon_pcicfgread(
int interface,
int bus,
int dev,
   147 extern unsigned long mon_pcictrl(
int interface,
int cmd,
   148         unsigned long arg1,
unsigned long arg2);
   150 extern unsigned long mon_i2cctrl(
int interface,
int cmd,
   151         unsigned long arg1,
   153 extern unsigned long mon_assignhandler(
long hnum,
   154         unsigned long arg1,
   157 extern struct tfshdr *mon_tfsstat(
char *filename);
   164 #ifndef _INSIDE_MONLIB   165 extern void mon_memtrace(
char *fmt, ...);
   166 extern int mon_printf(
char *fmt, ...);
   167 extern int mon_cprintf(
char *fmt, ...);
   168 extern int mon_sprintf(
char *,
char *fmt, ...);
   178 #define GETMONFUNC_PUTCHAR              1   179 #define GETMONFUNC_GETCHAR              2   180 #define GETMONFUNC_GOTACHAR             3   181 #define GETMONFUNC_GETBYTES             4   182 #define GETMONFUNC_PRINTF               5   183 #define GETMONFUNC_CPRINTF              6   184 #define GETMONFUNC_SPRINTF              7   185 #define GETMONFUNC_RESTART              8   186 #define GETMONFUNC_GETENV               9   187 #define GETMONFUNC_SETENV               10   188 #define GETMONFUNC_TFSINIT              11   189 #define GETMONFUNC_TFSADD               12   190 #define GETMONFUNC_TFSUNLINK            13   191 #define GETMONFUNC_TFSRUN               14   192 #define GETMONFUNC_TFSNEXT              15   193 #define GETMONFUNC_TFSSTAT              16   194 #define GETMONFUNC_TFSREAD              17   195 #define GETMONFUNC_TFSWRITE             18   196 #define GETMONFUNC_TFSOPEN              19   197 #define GETMONFUNC_TFSCLOSE             20   198 #define GETMONFUNC_TFSSEEK              21   199 #define GETMONFUNC_TFSGETLINE           22   200 #define GETMONFUNC_TFSIPMOD             23   201 #define GETMONFUNC_TFSCTRL              24   202 #define GETMONFUNC_ADDCOMMAND           25   203 #define GETMONFUNC_DOCOMMAND            26   204 #define GETMONFUNC_GETARGV              27   205 #define GETMONFUNC_CRC16                28   206 #define GETMONFUNC_CRC32                29   207 #define GETMONFUNC_PIOGET               30     208 #define GETMONFUNC_PIOSET               31     209 #define GETMONFUNC_PIOCLR               32     210 #define GETMONFUNC_INTSOFF              33   211 #define GETMONFUNC_INTSRESTORE          34   212 #define GETMONFUNC_APPEXIT              35   213 #define GETMONFUNC_MALLOC               36   214 #define GETMONFUNC_FREE                 37   215 #define GETMONFUNC_GETLINE              38   216 #define GETMONFUNC_TFSFSTAT             39   217 #define GETMONFUNC_TFSEOF               40   218 #define GETMONFUNC_DECOMPRESS           41   219 #define GETMONFUNC_TFSTRUNCATE          42   220 #define GETMONFUNC_HEAPXTEND            43   221 #define GETMONFUNC_PROFILER             44   222 #define GETMONFUNC_TFSLINK              45   223 #define GETMONFUNC_BBC                  46   224 #define GETMONFUNC_MEMTRACE             47   225 #define GETMONFUNC_TFSTELL              48   226 #define GETMONFUNC_VERSION              49   227 #define GETMONFUNC_WARMSTART            50   228 #define GETMONFUNC_PCICFGREAD           51   229 #define GETMONFUNC_PCICFGWRITE          52   230 #define GETMONFUNC_PCICONTROL           53   231 #define GETMONFUNC_I2CREAD              54   232 #define GETMONFUNC_I2CWRITE             55   233 #define GETMONFUNC_I2CCONTROL           56   234 #define GETMONFUNC_MONDELAY             57   235 #define GETMONFUNC_GETENVP              58   236 #define GETMONFUNC_REALLOC              59   237 #define GETMONFUNC_SENDENETPKT          60   238 #define GETMONFUNC_RECVENETPKT          61   239 #define GETMONFUNC_GETSYM               62   240 #define GETMONFUNC_PRINTPKT             63   241 #define GETMONFUNC_FLASHWRITE           64   242 #define GETMONFUNC_FLASHERASE           65   243 #define GETMONFUNC_FLASHINFO            66   244 #define GETMONFUNC_ASSIGNHDLR           67   245 #define GETMONFUNC_WATCHDOG             68   246 #define GETMONFUNC_PRINTMEM             69   247 #define GETMONFUNC_PORTCMD              70   248 #define GETMONFUNC_TIMEOFDAY            71   249 #define GETMONFUNC_TIMER                72   250 #define GETMONFUNC_FLASHOVRRD           73   252 #define CACHEFTYPE_DFLUSH               200   253 #define CACHEFTYPE_IINVALIDATE          201   255 #define CHARFUNC_PUTCHAR                300   256 #define CHARFUNC_GETCHAR                301   257 #define CHARFUNC_GOTACHAR               302   258 #define CHARFUNC_RAWMODEON              303   259 #define CHARFUNC_RAWMODEOFF             304   261 #define ASSIGNFUNC_GETUSERLEVEL         400   266 #define WARMSTART_IOINIT            0x00000001   267 #define WARMSTART_BSSINIT           0x00000002   268 #define WARMSTART_RUNMONRC          0x00000004   269 #define WARMSTART_MONHEADER         0x00000008   270 #define WARMSTART_TFSAUTOBOOT       0x00000010   271 #define WARMSTART_BOARDINFO         0x00000020   272 #define WARMSTART_ALL               0xffffffff Header file for TFS transactions, used by both application and monnitor.
Header file for Command Line Interface related stuff.
unsigned size
Definition: tte.h:74
Definition: mongoose.c:442
