    RTEMS
    5.1
Go to the documentation of this file.   23 #ifndef _RTEMS_SCORE_MIPS_H    24 #define _RTEMS_SCORE_MIPS_H    48 #if (__mips == 3) || (__mips == 32)    50 #define SR_INTERRUPT_ENABLE_BITS 0x01    52 #define SR_INTERRUPT_ENABLE_BITS SR_IE    56 #define SR_INTERRUPT_ENABLE_BITS SR_IEC    59 #error "mips interrupt enable bits: unknown architecture level!"    71 #if defined(__mips_soft_float)    72 #define MIPS_HAS_FPU 0    74 #define MIPS_HAS_FPU 1    79 #define CPU_MODEL_NAME  "ISA Level 1 or 2"    80 #elif (__mips == 3) || (__mips == 32)    82 #define CPU_MODEL_NAME  "ISA Level 4"    84 #define CPU_MODEL_NAME  "ISA Level 3"    87 #error "Unknown MIPS ISA level"    94 #define CPU_NAME "MIPS"   101 #define MIPS_EXCEPTION_BASE 0   103 #define MIPS_EXCEPTION_INT              MIPS_EXCEPTION_BASE+0   104 #define MIPS_EXCEPTION_MOD              MIPS_EXCEPTION_BASE+1   105 #define MIPS_EXCEPTION_TLBL             MIPS_EXCEPTION_BASE+2   106 #define MIPS_EXCEPTION_TLBS             MIPS_EXCEPTION_BASE+3   107 #define MIPS_EXCEPTION_ADEL             MIPS_EXCEPTION_BASE+4   108 #define MIPS_EXCEPTION_ADES             MIPS_EXCEPTION_BASE+5   109 #define MIPS_EXCEPTION_IBE              MIPS_EXCEPTION_BASE+6   110 #define MIPS_EXCEPTION_DBE              MIPS_EXCEPTION_BASE+7   111 #define MIPS_EXCEPTION_SYSCALL          MIPS_EXCEPTION_BASE+8   112 #define MIPS_EXCEPTION_BREAK            MIPS_EXCEPTION_BASE+9   113 #define MIPS_EXCEPTION_RI               MIPS_EXCEPTION_BASE+10   114 #define MIPS_EXCEPTION_CPU              MIPS_EXCEPTION_BASE+11   115 #define MIPS_EXCEPTION_OVERFLOW         MIPS_EXCEPTION_BASE+12   116 #define MIPS_EXCEPTION_TRAP             MIPS_EXCEPTION_BASE+13   117 #define MIPS_EXCEPTION_VCEI             MIPS_EXCEPTION_BASE+14   119 #define MIPS_EXCEPTION_FPE              MIPS_EXCEPTION_BASE+15   120 #define MIPS_EXCEPTION_C2E              MIPS_EXCEPTION_BASE+16   122 #define MIPS_EXCEPTION_WATCH            MIPS_EXCEPTION_BASE+23   124 #define MIPS_EXCEPTION_VCED             MIPS_EXCEPTION_BASE+31   126 #define MIPS_INTERRUPT_BASE             MIPS_EXCEPTION_BASE+32   132 #define mips_get_sr( _x ) \   134     __asm__ volatile( "mfc0 %0, $12; nop" : "=r" (_x) : ); \   137 #define mips_set_sr( _x ) \   139     unsigned int __x = (_x); \   140     __asm__ volatile( "mtc0 %0, $12; nop" : : "r" (__x) ); \   148 #define mips_get_cause( _x ) \   150     __asm__ volatile( "mfc0 %0, $13; nop" : "=r" (_x) : ); \   154 #define mips_set_cause( _x ) \   156     unsigned int __x = (_x); \   157     __asm__ volatile( "mtc0 %0, $13; nop" : : "r" (__x) ); \   167 #define mips_get_dcic( _x ) \   169     __asm__ volatile( "mfc0 %0, $7; nop" : "=r" (_x) : ); \   173 #define mips_set_dcic( _x ) \   175     unsigned int __x = (_x); \   176     __asm__ volatile( "mtc0 %0, $7; nop" : : "r" (__x) ); \   187 #define mips_get_bpcrm( _x, _y ) \   189     __asm__ volatile( "mfc0 %0, $3; nop" : "=r" (_x) : ); \   190     __asm__ volatile( "mfc0 %0, $11; nop" : "=r" (_y) : ); \   194 #define mips_set_bpcrm( _x, _y ) \   196     unsigned int __x = (_x); \   197     unsigned int __y = (_y); \   198     __asm__ volatile( "mtc0 %0, $11; nop" : : "r" (__y) ); \   199     __asm__ volatile( "mtc0 %0, $3; nop" : : "r" (__x) ); \   212 #define mips_get_bdarm( _x, _y ) \   214     __asm__ volatile( "mfc0 %0, $5; nop" : "=r" (_x) : ); \   215     __asm__ volatile( "mfc0 %0, $9; nop" : "=r" (_y) : ); \   219 #define mips_set_bdarm( _x, _y ) \   221     unsigned int __x = (_x); \   222     unsigned int __y = (_y); \   223     __asm__ volatile( "mtc0 %0, $9; nop" : : "r" (__y) ); \   224     __asm__ volatile( "mtc0 %0, $5; nop" : : "r" (__x) ); \   237 #if ( MIPS_HAS_FPU == 1 )   239 #define mips_get_fcr31( _x ) \   241     __asm__ volatile( "cfc1 %0, $31; nop" : "=r" (_x) : ); \   245 #define mips_set_fcr31( _x ) \   247     unsigned int __x = (_x); \   248     __asm__ volatile( "ctc1 %0, $31; nop" : : "r" (__x) ); \   253 #define mips_get_fcr31( _x )   254 #define mips_set_fcr31( _x )   277 #define mips_enable_in_interrupt_mask( _mask ) \   280     mips_get_sr( _sr ); \   282     mips_set_sr( _sr ); \   285 #define mips_disable_in_interrupt_mask( _mask ) \   288     mips_get_sr( _sr ); \   290     mips_set_sr( _sr ); \
