    RTEMS
    5.1
Go to the documentation of this file.   11 #ifndef _RTEMS_TMTEST27    12 #error "This is an RTEMS internal file you must not include directly."    24 #define MUST_WAIT_FOR_INTERRUPT 1    26 #define Install_tm27_vector( handler ) \    27    rtems_interrupt_handler_install( \    28       TX3904_IRQ_TMR0, "benchmark", 0, \    29       (rtems_interrupt_handler)handler, NULL );    31 #define Cause_tm27_intr() \    33     uint32_t   _clicks = 20; \    34     TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_CCDR, 0x3 ); \    35     TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_CPRA, _clicks ); \    36     TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_TISR, 0x00 ); \    37     TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_ITMR, 0x8001 ); \    38     TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_TCR,   0xC0 ); \    39     *((volatile uint32_t*) 0xFFFFC01C) = 0x00000700; \    42 #define Clear_tm27_intr() \    44     TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_ITMR, 0x0001 ); \    45     TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_CCDR, 0x3 ); \    46     TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_TISR,   0x00 ); \    49 #define Lower_tm27_intr() \    50   mips_enable_in_interrupt_mask( 0xff01 );
