    RTEMS
    5.1
Go to the documentation of this file.   61 #define MCAN_PROG_CLK_PRESCALER       1       67 #define MCAN_PROG_CLK_SELECT          PMC_PCK_CSS_MCK    68 #define MCAN_PROG_CLK_FREQ_HZ \    69     ((float) 150000000 / (float) MCAN_PROG_CLK_PRESCALER)    71 #define MCAN0_BIT_RATE_BPS            500000    72 #define MCAN0_PROP_SEG                2    73 #define MCAN0_PHASE_SEG1              11    74 #define MCAN0_PHASE_SEG2              11    75 #define MCAN0_SYNC_JUMP               4    77 #define MCAN0_FAST_BIT_RATE_BPS       2000000    78 #define MCAN0_FAST_PROP_SEG           2    79 #define MCAN0_FAST_PHASE_SEG1         4    80 #define MCAN0_FAST_PHASE_SEG2         4    81 #define MCAN0_FAST_SYNC_JUMP          2    83 #define MCAN0_NMBR_STD_FLTS           8      84 #define MCAN0_NMBR_EXT_FLTS           8      85 #define MCAN0_NMBR_RX_FIFO0_ELMTS     0      86 #define MCAN0_NMBR_RX_FIFO1_ELMTS     0      87 #define MCAN0_NMBR_RX_DED_BUF_ELMTS   16     88 #define MCAN0_NMBR_TX_EVT_FIFO_ELMTS  0      89 #define MCAN0_NMBR_TX_DED_BUF_ELMTS   4      90 #define MCAN0_NMBR_TX_FIFO_Q_ELMTS    0      91 #define MCAN0_RX_FIFO0_ELMT_SZ        8      92 #define MCAN0_RX_FIFO1_ELMT_SZ        8      93 #define MCAN0_RX_BUF_ELMT_SZ          8      94 #define MCAN0_TX_BUF_ELMT_SZ          8      96 #define MCAN1_BIT_RATE_BPS            500000    97 #define MCAN1_PROP_SEG                2    98 #define MCAN1_PHASE_SEG1              11    99 #define MCAN1_PHASE_SEG2              11   100 #define MCAN1_SYNC_JUMP               4   102 #define MCAN1_FAST_BIT_RATE_BPS       2000000   103 #define MCAN1_FAST_PROP_SEG           2   104 #define MCAN1_FAST_PHASE_SEG1         4   105 #define MCAN1_FAST_PHASE_SEG2         4   106 #define MCAN1_FAST_SYNC_JUMP          2   108 #define MCAN1_NMBR_STD_FLTS           8      109 #define MCAN1_NMBR_EXT_FLTS           8      110 #define MCAN1_NMBR_RX_FIFO0_ELMTS     12     111 #define MCAN1_NMBR_RX_FIFO1_ELMTS     0      112 #define MCAN1_NMBR_RX_DED_BUF_ELMTS   4      113 #define MCAN1_NMBR_TX_EVT_FIFO_ELMTS  0      114 #define MCAN1_NMBR_TX_DED_BUF_ELMTS   4      115 #define MCAN1_NMBR_TX_FIFO_Q_ELMTS    4      116 #define MCAN1_RX_FIFO0_ELMT_SZ        8      117 #define MCAN1_RX_FIFO1_ELMT_SZ        8      118 #define MCAN1_RX_BUF_ELMT_SZ          64     119 #define MCAN1_TX_BUF_ELMT_SZ          32
