22 #ifndef LIBBSP_ARM_LPC32XX_LPC_ETHERNET_CONFIG_H    23 #define LIBBSP_ARM_LPC32XX_LPC_ETHERNET_CONFIG_H    48 #define LPC_ETH_CONFIG_INTERRUPT LPC32XX_IRQ_ETHERNET    50 #define LPC_ETH_CONFIG_REG_BASE LPC32XX_BASE_ETHERNET    52 #define LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT 16    53 #define LPC_ETH_CONFIG_RX_UNIT_COUNT_MAX INT_MAX    55 #define LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT 32    56 #define LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX INT_MAX    58 #define LPC_ETH_CONFIG_UNIT_MULTIPLE 8U    60 #ifdef LPC32XX_ETHERNET_RMII    61   #define LPC_ETH_CONFIG_RMII    63   static void lpc_eth_config_module_enable(
void)
    65     LPC32XX_MAC_CLK_CTRL = 0x1f;
    68   static void lpc_eth_config_module_enable(
void)
    70     LPC32XX_MAC_CLK_CTRL = 0x0f;
    74 static void lpc_eth_config_module_disable(
void)
    76   LPC32XX_MAC_CLK_CTRL = 0;
    79 #define LPC_ETH_CONFIG_USE_TRANSMIT_DMA    81 static char *lpc_eth_config_alloc_table_area(
size_t size)
    86 static void lpc_eth_config_free_table_area(
char *table_area)
    89   free(table_area, (
int) 0xdeadbeef);
void * rtems_heap_allocate_aligned_with_boundary(size_t size, uintptr_t alignment, uintptr_t boundary) RTEMS_MALLOCLIKE RTEMS_ALLOC_SIZE(1) RTEMS_ALLOC_ALIGN(2) RTEMS_WARN_UNUSED_RESULT
Allocates a memory area of size size bytes from the heap.
unsigned size
Definition: tte.h:74
