23 #ifndef LPC17XX_REGS_H    24 #define LPC17XX_REGS_H    28 #define LPC17XX_BASE 0x00    31 #define LPC17XX_WWDT_MOD_WDEN BSP_BIT32(0)    32 #define LPC17XX_WWDT_MOD_WDRESET BSP_BIT32(1)    33 #define LPC17XX_WWDT_MOD_WDTOF BSP_BIT32(2)    34 #define LPC17XX_WWDT_MOD_WDINT BSP_BIT32(3)    35 #define LPC17XX_WWDT_MOD_WDPROTECT BSP_BIT32(4)    46 #define LPC17XX_WWDT (*(volatile lpc17xx_wwdt *) (LPC17XX_BASE + 0x40000000))    49 #define LPC17XX_PLL_CON_PLLE BSP_BIT32(0)    50 #define LPC17XX_PLL_SEL_MSEL(val) BSP_FLD32(val, 0, 4)    51 #define LPC17XX_PLL_SEL_MSEL_GET(reg) BSP_FLD32GET(reg, 0, 4)    52 #define LPC17XX_PLL_SEL_MSEL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)    53 #define LPC17XX_PLL_SEL_PSEL(val) BSP_FLD32(val, 5, 6)    54 #define LPC17XX_PLL_SEL_PSEL_GET(reg) BSP_FLD32GET(reg, 5, 6)    55 #define LPC17XX_PLL_SEL_PSEL_SET(reg, val) BSP_FLD32SET(reg, val, 5, 6)    56 #define LPC17XX_PLL_STAT_PLLE BSP_BIT32(8)    57 #define LPC17XX_PLL_STAT_PLOCK BSP_BIT32(10)    66 #define LPC17XX_SCB_FLASHCFG_FLASHTIM(val) BSP_FLD32(val, 12, 15)    67 #define LPC17XX_SCB_FLASHCFG_FLASHTIM_GET(reg) BSP_FLD32GET(reg, 12, 15)    68 #define LPC17XX_SCB_FLASHCFG_FLASHTIM_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)    69     uint32_t reserved_04 [15];
    71 #define LPC17XX_SCB_MEMMAP_MAP BSP_BIT32(0)    72     uint32_t reserved_44 [15];
    74     uint32_t reserved_90 [4];
    76     uint32_t reserved_b0 [4];
    78 #define LPC17XX_SCB_PCON_PM0 BSP_BIT32(0)    79 #define LPC17XX_SCB_PCON_PM1 BSP_BIT32(1)    80 #define LPC17XX_SCB_PCON_BODRPM BSP_BIT32(2)    81 #define LPC17XX_SCB_PCON_BOGD BSP_BIT32(3)    82 #define LPC17XX_SCB_PCON_BORD BSP_BIT32(4)    83 #define LPC17XX_SCB_PCON_SMFLAG BSP_BIT32(8)    84 #define LPC17XX_SCB_PCON_DSFLAG BSP_BIT32(9)    85 #define LPC17XX_SCB_PCON_PDFLAG BSP_BIT32(10)    86 #define LPC17XX_SCB_PCON_DPDFLAG BSP_BIT32(11)    88 #define LPC17XX_SCB_PCONP_LCD BSP_BIT32(0)    89 #define LPC17XX_SCB_PCONP_TIMER_0 BSP_BIT32(1)    90 #define LPC17XX_SCB_PCONP_TIMER_1 BSP_BIT32(2)    91 #define LPC17XX_SCB_PCONP_UART_0 BSP_BIT32(3)    92 #define LPC17XX_SCB_PCONP_UART_1 BSP_BIT32(4)    93 #define LPC17XX_SCB_PCONP_PWM_0 BSP_BIT32(5)    94 #define LPC17XX_SCB_PCONP_PWM_1 BSP_BIT32(6)    95 #define LPC17XX_SCB_PCONP_I2C_0 BSP_BIT32(7)    96 #define LPC17XX_SCB_PCONP_UART_4 BSP_BIT32(8)    97 #define LPC17XX_SCB_PCONP_RTC BSP_BIT32(9)    98 #define LPC17XX_SCB_PCONP_SSP_1 BSP_BIT32(10)    99 #define LPC17XX_SCB_PCONP_EMC BSP_BIT32(11)   100 #define LPC17XX_SCB_PCONP_ADC BSP_BIT32(12)   101 #define LPC17XX_SCB_PCONP_CAN_0 BSP_BIT32(13)   102 #define LPC17XX_SCB_PCONP_CAN_1 BSP_BIT32(14)   103 #define LPC17XX_SCB_PCONP_GPIO BSP_BIT32(15)   104 #define LPC17XX_SCB_PCONP_QEI BSP_BIT32(17)   105 #define LPC17XX_SCB_PCONP_I2C_1 BSP_BIT32(18)   106 #define LPC17XX_SCB_PCONP_SSP_2 BSP_BIT32(19)   107 #define LPC17XX_SCB_PCONP_SSP_0 BSP_BIT32(20)   108 #define LPC17XX_SCB_PCONP_TIMER_2 BSP_BIT32(21)   109 #define LPC17XX_SCB_PCONP_TIMER_3 BSP_BIT32(22)   110 #define LPC17XX_SCB_PCONP_UART_2 BSP_BIT32(23)   111 #define LPC17XX_SCB_PCONP_UART_3 BSP_BIT32(24)   112 #define LPC17XX_SCB_PCONP_I2C_2 BSP_BIT32(25)   113 #define LPC17XX_SCB_PCONP_I2S BSP_BIT32(26)   114 #define LPC17XX_SCB_PCONP_SDC BSP_BIT32(27)   115 #define LPC17XX_SCB_PCONP_GPDMA BSP_BIT32(28)   116 #define LPC17XX_SCB_PCONP_ENET BSP_BIT32(29)   117 #define LPC17XX_SCB_PCONP_USB BSP_BIT32(30)   118 #define LPC17XX_SCB_PCONP_MCPWM BSP_BIT32(31)   119     uint32_t reserved_c8 [14];
   121 #define LPC17XX_SCB_EMCCLKSEL_EMCDIV BSP_BIT32(0)   123 #define LPC17XX_SCB_CCLKSEL_CCLKDIV(val) BSP_FLD32(val, 0, 4)   124 #define LPC17XX_SCB_CCLKSEL_CCLKDIV_GET(reg) BSP_FLD32GET(reg, 0, 4)   125 #define LPC17XX_SCB_CCLKSEL_CCLKDIV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)   126 #define LPC17XX_SCB_CCLKSEL_CCLKSEL BSP_BIT32(8)   128 #define LPC17XX_SCB_USBCLKSEL_USBDIV(val) BSP_FLD32(val, 0, 4)   129 #define LPC17XX_SCB_USBCLKSEL_USBDIV_GET(reg) BSP_FLD32GET(reg, 0, 4)   130 #define LPC17XX_SCB_USBCLKSEL_USBDIV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)   131 #define LPC17XX_SCB_USBCLKSEL_USBSEL(val) BSP_FLD32(val, 8, 9)   132 #define LPC17XX_SCB_USBCLKSEL_USBSEL_GET(reg) BSP_FLD32GET(reg, 8, 9)   133 #define LPC17XX_SCB_USBCLKSEL_USBSEL_SET(reg, val) BSP_FLD32SET(reg, val, 8, 9)   135 #define LPC17XX_SCB_CLKSRCSEL_CLKSRC BSP_BIT32(0)   136     uint32_t reserved_110 [12];
   138     uint32_t reserved_144;
   141     uint32_t reserved_150 [12];
   143     uint32_t reserved_184 [1];
   145     uint32_t reserved_18c [5];
   147 #define LPC17XX_SCB_SCS_EMC_SHIFT_CTL BSP_BIT32(0)   148 #define LPC17XX_SCB_SCS_EMC_RESET_DIS BSP_BIT32(1)   149 #define LPC17XX_SCB_SCS_EMC_BURST_CTL BSP_BIT32(2)   150 #define LPC17XX_SCB_SCS_MCIPWR BSP_BIT32(3)   151 #define LPC17XX_SCB_SCS_OSC_RANGE_SEL BSP_BIT32(4)   152 #define LPC17XX_SCB_SCS_OSC_ENABLE BSP_BIT32(5)   153 #define LPC17XX_SCB_SCS_OSC_STATUS BSP_BIT32(6)   154     uint32_t reserved_1a4;
   156 #define LPC17XX_SCB_PCLKSEL_PCLKDIV(val) BSP_FLD32(val, 0, 4)   157 #define LPC17XX_SCB_PCLKSEL_PCLKDIV_GET(reg) BSP_FLD32GET(reg, 0, 4)   158 #define LPC17XX_SCB_PCLKSEL_PCLKDIV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)   159     uint32_t reserved_1ac;
   161 #define LPC17XX_SCB_PBOOST_BOOST BSP_BIT32(0)   162     uint32_t reserved_1b4 [5];
   164 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTSEL(val) BSP_FLD32(val, 3, 0)   165 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTSEL_GET(reg) BSP_FLD32GET(reg, 3, 0)   166 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTSEL_SET(reg, val) BSP_FLD32SET(reg, val, 3, 0)   167 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTDIV(val) BSP_FLD32(val, 7, 4)   168 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTDIV_GET(reg) BSP_FLD32GET(reg, 7, 4)   169 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTDIV_SET(reg, val) BSP_FLD32SET(reg, val, 7, 4)   170 #define LPC17XX_SCB_CLKOUTCFG_CLKOUT_EN BSP_BIT32(8)   171 #define LPC17XX_SCB_CLKOUTCFG_CLKOUT_ACT BSP_BIT32(9)   174     uint32_t reserved_1d4 [2];
   176 #define LPC17XX_SCB_EMCDLYCTL_CMDDLY(val) BSP_FLD32(val, 0, 4)   177 #define LPC17XX_SCB_EMCDLYCTL_CMDDLY_GET(reg) BSP_FLD32GET(reg, 0, 4)   178 #define LPC17XX_SCB_EMCDLYCTL_CMDDLY_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)   179 #define LPC17XX_SCB_EMCDLYCTL_FBCLKDLY(val) BSP_FLD32(val, 8, 12)   180 #define LPC17XX_SCB_EMCDLYCTL_FBCLKDLY_GET(reg) BSP_FLD32GET(reg, 8, 12)   181 #define LPC17XX_SCB_EMCDLYCTL_FBCLKDLY_SET(reg, val) BSP_FLD32SET(reg, val, 8, 12)   182 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT0DLY(val) BSP_FLD32(val, 16, 20)   183 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT0DLY_GET(reg) BSP_FLD32GET(reg, 16, 20)   184 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT0DLY_SET(reg, val) BSP_FLD32SET(reg, val, 16, 20)   185 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT1DLY(val) BSP_FLD32(val, 24, 28)   186 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT1DLY_GET(reg) BSP_FLD32GET(reg, 24, 28)   187 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT1DLY_SET(reg, val) BSP_FLD32SET(reg, val, 24, 28)   189 #define LPC17XX_SCB_EMCCAL_CALVALUE(val) BSP_FLD32(val, 0, 7)   190 #define LPC17XX_SCB_EMCCAL_CALVALUE_GET(reg) BSP_FLD32GET(reg, 0, 7)   191 #define LPC17XX_SCB_EMCCAL_CALVALUE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)   192 #define LPC17XX_SCB_EMCCAL_START BSP_BIT32(14)   193 #define LPC17XX_SCB_EMCCAL_DONE BSP_BIT32(15)   196 #define LPC17XX_SCB (*(volatile lpc17xx_scb *) (LPC17XX_BASE + 0x400fc000))   199     uint32_t reserved_00 [268435456];
   201     uint32_t reserved_40000020 [258040];
   205 #define LPC17XX (*(volatile lpc17xx *) (LPC17XX_BASE)) Definition: lpc17xx.h:198
