RTEMS  5.1
system_conf.h
1
9 #ifndef __SYSTEM_CONFIG_H_
10 #define __SYSTEM_CONFIG_H_
11
12
13 #define FPGA_DEVICE_FAMILY "ECP2M"
14 #define PLATFORM_NAME "platform1"
15 #define USE_PLL (0)
16 #define CPU_FREQUENCY (75000000)
17
18
19 /* FOUND 1 CPU UNIT(S) */
20
21 /*
22  * CPU Instance LM32 component configuration
23  */
24 #define CPU_NAME "LM32"
25 #define CPU_EBA (0x04000000)
26 #define CPU_DIVIDE_ENABLED (1)
27 #define CPU_SIGN_EXTEND_ENABLED (1)
28 #define CPU_MULTIPLIER_ENABLED (1)
29 #define CPU_SHIFT_ENABLED (1)
30 #define CPU_DEBUG_ENABLED (1)
31 #define CPU_HW_BREAKPOINTS_ENABLED (0)
32 #define CPU_NUM_HW_BREAKPOINTS (0)
33 #define CPU_NUM_WATCHPOINTS (0)
34 #define CPU_ICACHE_ENABLED (1)
35 #define CPU_ICACHE_SETS (512)
36 #define CPU_ICACHE_ASSOC (1)
37 #define CPU_ICACHE_BYTES_PER_LINE (16)
38 #define CPU_DCACHE_ENABLED (1)
39 #define CPU_DCACHE_SETS (512)
40 #define CPU_DCACHE_ASSOC (1)
41 #define CPU_DCACHE_BYTES_PER_LINE (16)
42 #define CPU_DEBA (0x0C000000)
43 #define CPU_CHARIO_IN (1)
44 #define CPU_CHARIO_OUT (1)
45 #define CPU_CHARIO_TYPE "JTAG UART"
46
47 /*
48  * gpio component configuration
49  */
50 #define GPIO_NAME "gpio"
51 #define GPIO_BASE_ADDRESS (0x80004000)
52 #define GPIO_SIZE (128)
53 #define GPIO_CHARIO_IN (0)
54 #define GPIO_CHARIO_OUT (0)
55 #define GPIO_ADDRESS_LOCK (1)
56 #define GPIO_DISABLE (0)
57 #define GPIO_OUTPUT_PORTS_ONLY (1)
58 #define GPIO_INPUT_PORTS_ONLY (0)
59 #define GPIO_TRISTATE_PORTS (0)
60 #define GPIO_BOTH_INPUT_AND_OUTPUT (0)
61 #define GPIO_DATA_WIDTH (4)
62 #define GPIO_INPUT_WIDTH (1)
63 #define GPIO_OUTPUT_WIDTH (1)
64 #define GPIO_IRQ_MODE (0)
65 #define GPIO_LEVEL (0)
66 #define GPIO_EDGE (0)
67 #define GPIO_EITHER_EDGE_IRQ (0)
68 #define GPIO_POSE_EDGE_IRQ (0)
69 #define GPIO_NEGE_EDGE_IRQ (0)
70
71 /*
72  * uart component configuration
73  */
74 #define UART_NAME "uart"
75 #define UART_BASE_ADDRESS (0x80006000)
76 #define UART_SIZE (128)
77 #define UART_IRQ (0)
78 #define UART_CHARIO_IN (1)
79 #define UART_CHARIO_OUT (1)
80 #define UART_CHARIO_TYPE "RS-232"
81 #define UART_ADDRESS_LOCK (1)
82 #define UART_DISABLE (0)
83 #define UART_MODEM (0)
84 #define UART_ADDRWIDTH (5)
85 #define UART_DATAWIDTH (8)
86 #define UART_BAUD_RATE (115200)
87 #define UART_IB_SIZE (4)
88 #define UART_OB_SIZE (4)
89 #define UART_BLOCK_WRITE (1)
90 #define UART_BLOCK_READ (1)
91 #define UART_DATA_BITS (8)
92 #define UART_STOP_BITS (1)
93 #define UART_FIFO (0)
94 #define UART_INTERRUPT_DRIVEN (1)
95
96 /*
97  * ebr component configuration
98  */
99 #define EBR_NAME "ebr"
100 #define EBR_BASE_ADDRESS (0x04000000)
101 #define EBR_SIZE (32768)
102 #define EBR_IS_READABLE (1)
103 #define EBR_IS_WRITABLE (1)
104 #define EBR_ADDRESS_LOCK (1)
105 #define EBR_DISABLE (0)
106 #define EBR_EBR_DATA_WIDTH (32)
107 #define EBR_INIT_FILE_NAME "none"
108 #define EBR_INIT_FILE_FORMAT "hex"
109
110 /*
111  * ts_mac_core component configuration
112  */
113 #define TS_MAC_CORE_NAME "ts_mac_core"
114 #define TS_MAC_CORE_BASE_ADDRESS (0x80008000)
115 #define TS_MAC_CORE_SIZE (8192)
116 #define TS_MAC_CORE_IRQ (2)
117 #define TS_MAC_CORE_CHARIO_IN (0)
118 #define TS_MAC_CORE_CHARIO_OUT (0)
119 #define TS_MAC_CORE_ADDRESS_LOCK (1)
120 #define TS_MAC_CORE_DISABLE (0)
121 #define TS_MAC_CORE_STAT_REGS (1)
122 #define TS_MAC_CORE_TXRX_FIFO_DEPTH (512)
123 #define TS_MAC_CORE_MIIM_MODULE (1)
124 #define TS_MAC_CORE_NGO "l:/mrf/lattice/crio-lm32/platform1/components/ts_mac_top_v27/ipexpress/ts_mac_core/ts_mac_core.ngo"
125 #define TS_MAC_CORE_ISPLEVER_PRJ "l:/mrf/lattice/crio-lm32/criomico.syn"
126
127 /*
128  * timer0 component configuration
129  */
130 #define TIMER0_NAME "timer0"
131 #define TIMER0_BASE_ADDRESS (0x80002000)
132 #define TIMER0_SIZE (128)
133 #define TIMER0_IRQ (1)
134 #define TIMER0_CHARIO_IN (0)
135 #define TIMER0_CHARIO_OUT (0)
136 #define TIMER0_ADDRESS_LOCK (1)
137 #define TIMER0_DISABLE (0)
138 #define TIMER0_PERIOD_NUM (20)
139 #define TIMER0_PERIOD_WIDTH (32)
140 #define TIMER0_WRITEABLE_PERIOD (1)
141 #define TIMER0_READABLE_SNAPSHOT (1)
142 #define TIMER0_START_STOP_CONTROL (1)
143 #define TIMER0_WATCHDOG (0)
144
145 /*
146  * timer1 component configuration
147  */
148 #define TIMER1_NAME "timer1"
149 #define TIMER1_BASE_ADDRESS (0x8000A000)
150 #define TIMER1_SIZE (128)
151 #define TIMER1_IRQ (3)
152 #define TIMER1_CHARIO_IN (0)
153 #define TIMER1_CHARIO_OUT (0)
154 #define TIMER1_ADDRESS_LOCK (1)
155 #define TIMER1_DISABLE (0)
156 #define TIMER1_PERIOD_NUM (20)
157 #define TIMER1_PERIOD_WIDTH (32)
158 #define TIMER1_WRITEABLE_PERIOD (1)
159 #define TIMER1_READABLE_SNAPSHOT (1)
160 #define TIMER1_START_STOP_CONTROL (1)
161 #define TIMER1_WATCHDOG (0)
162
163 /*
164  * ddr2_sdram component configuration
165  */
166 #define DDR2_SDRAM_NAME "ddr2_sdram"
167 #define DDR2_SDRAM_BASE_ADDRESS (0x08000000)
168 #define DDR2_SDRAM_SIZE (33554432)
169 #define DDR2_SDRAM_IS_READABLE (1)
170 #define DDR2_SDRAM_IS_WRITABLE (1)
171 #define DDR2_SDRAM_BST_CNT_READ (1)
172 #define DDR2_SDRAM_ADDRESS_LOCK (1)
173 #define DDR2_SDRAM_DISABLE (0)
174 #define DDR2_SDRAM_NGO "L:/mrf/lattice/cRIO-LM32/platform1/components/wb_ddr2_ctl_v65/ipexpress/ddr2_sdram/ddr2_sdram.ngo"
175 #define DDR2_SDRAM_ISPLEVER_PRJ "l:/mrf/lattice/crio-lm32/criomico.syn"
176 #define DDR2_SDRAM_PARAM_FILE "ddr_p_eval/$/src/params/ddr_sdram_mem_params.v"
177 #define DDR2_SDRAM_MEM_TOP "ddr_p_eval/$/src/rtl/top/@/ddr_sdram_mem_top.v"
178
179
180 #endif /* __SYSTEM_CONFIG_H_ */
