23 #ifndef _INCLUDE_LEON_h    24 #define _INCLUDE_LEON_h    33 #define LEON_INTERRUPT_EXTERNAL_1 5    45 #define LEON_TRAP_TYPE( _source ) SPARC_ASYNCHRONOUS_TRAP((_source) + 0x10)    47 #define LEON_TRAP_SOURCE( _trap ) ((_trap) - 0x10)    49 #define LEON_INT_TRAP( _trap ) \    50   ( (_trap) >= 0x11 && \    69 #define LEON_MEMORY_CONFIGURATION_PROM_SIZE_MASK  0x0003C000    75 #define LEON_MEMORY_CONFIGURATION_RAM_SIZE_MASK  0x00001E00    82 #define LEON_REG_TIMER_CONTROL_EN    0x00000001      84 #define LEON_REG_TIMER_CONTROL_RL    0x00000002      86 #define LEON_REG_TIMER_CONTROL_LD    0x00000004      93 #define LEON_REG_UART_CONTROL_RTD  0x000000FF     99 #define LEON_REG_UART_STATUS_DR   0x00000001    100 #define LEON_REG_UART_STATUS_TSE  0x00000002    101 #define LEON_REG_UART_STATUS_THE  0x00000004    102 #define LEON_REG_UART_STATUS_BR   0x00000008    103 #define LEON_REG_UART_STATUS_OE   0x00000010    104 #define LEON_REG_UART_STATUS_PE   0x00000020    105 #define LEON_REG_UART_STATUS_FE   0x00000040    106 #define LEON_REG_UART_STATUS_TF   0x00000200    107 #define LEON_REG_UART_STATUS_ERR  0x00000078    113 #define LEON_REG_UART_CTRL_RE     0x00000001    114 #define LEON_REG_UART_CTRL_TE     0x00000002    115 #define LEON_REG_UART_CTRL_RI     0x00000004    116 #define LEON_REG_UART_CTRL_TI     0x00000008    117 #define LEON_REG_UART_CTRL_PS     0x00000010    118 #define LEON_REG_UART_CTRL_PE     0x00000020    119 #define LEON_REG_UART_CTRL_FL     0x00000040    120 #define LEON_REG_UART_CTRL_LB     0x00000080    121 #define LEON_REG_UART_CTRL_DB     0x00000800    122 #define LEON_REG_UART_CTRL_SI     0x00004000    123 #define LEON_REG_UART_CTRL_FA     0x80000000    124 #define LEON_REG_UART_CTRL_FA_BIT 31   129 #define LEON3_REG_CACHE_CTRL_FI      0x00200000    130 #define LEON3_REG_CACHE_CTRL_DS      0x00800000    133 extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
   141 extern uint32_t LEON3_Cpu_Index;
   144 extern int LEON3_IrqCtrl_EIrq;
   146 static __inline__
int bsp_irq_fixup(
int irq)
   150   if (LEON3_IrqCtrl_EIrq != 0 && irq == LEON3_IrqCtrl_EIrq) {
   152     cpu = _LEON3_Get_current_processor();
   153     eirq = LEON3_IrqCtrl_Regs->intid[cpu] & 0x1f;
   163 #define LEON3_IRQMPSTATUS_CPUNR     28   164 #define LEON3_IRQMPSTATUS_BROADCAST 27   181 #define LEON3_IRQCTRL_ACQUIRE( _lock_context ) \   182   rtems_interrupt_lock_acquire( &LEON3_IrqCtrl_Lock, _lock_context )   184 #define LEON3_IRQCTRL_RELEASE( _lock_context ) \   185   rtems_interrupt_lock_release( &LEON3_IrqCtrl_Lock, _lock_context )   187 #define LEON_Clear_interrupt( _source ) \   189     LEON3_IrqCtrl_Regs->iclear = (1U << (_source)); \   192 #define LEON_Force_interrupt( _source ) \   194     LEON3_IrqCtrl_Regs->iforce = (1U << (_source)); \   197 #define LEON_Enable_interrupt_broadcast( _source ) \   199     rtems_interrupt_lock_context _lock_context; \   200     uint32_t _mask = 1U << ( _source ); \   201     LEON3_IRQCTRL_ACQUIRE( &_lock_context ); \   202     LEON3_IrqCtrl_Regs->bcast |= _mask; \   203     LEON3_IRQCTRL_RELEASE( &_lock_context ); \   206 #define LEON_Disable_interrupt_broadcast( _source ) \   208     rtems_interrupt_lock_context _lock_context; \   209     uint32_t _mask = 1U << ( _source ); \   210     LEON3_IRQCTRL_ACQUIRE( &_lock_context ); \   211     LEON3_IrqCtrl_Regs->bcast &= ~_mask; \   212     LEON3_IRQCTRL_RELEASE( &_lock_context ); \   215 #define LEON_Is_interrupt_pending( _source ) \   216   (LEON3_IrqCtrl_Regs->ipend & (1U << (_source)))   218 #define LEON_Cpu_Is_interrupt_masked( _source, _cpu ) \   219      (!(LEON3_IrqCtrl_Regs->mask[_cpu] & (1U << (_source))))   221 #define LEON_Cpu_Mask_interrupt( _source, _cpu ) \   223     rtems_interrupt_lock_context _lock_context; \   224     LEON3_IRQCTRL_ACQUIRE( &_lock_context ); \   225      LEON3_IrqCtrl_Regs->mask[_cpu]  &= ~(1U << (_source)); \   226     LEON3_IRQCTRL_RELEASE( &_lock_context ); \   229 #define LEON_Cpu_Unmask_interrupt( _source, _cpu ) \   231     rtems_interrupt_lock_context _lock_context; \   232     LEON3_IRQCTRL_ACQUIRE( &_lock_context ); \   233     LEON3_IrqCtrl_Regs->mask[_cpu]  |= (1U << (_source)); \   234     LEON3_IRQCTRL_RELEASE( &_lock_context ); \   237 #define LEON_Cpu_Disable_interrupt( _source, _previous, _cpu ) \   239     rtems_interrupt_lock_context _lock_context; \   240     uint32_t _mask = 1U << (_source); \   241     LEON3_IRQCTRL_ACQUIRE( &_lock_context ); \   242      (_previous) = LEON3_IrqCtrl_Regs->mask[_cpu]; \   243      LEON3_IrqCtrl_Regs->mask[_cpu] = _previous & ~_mask; \   244     LEON3_IRQCTRL_RELEASE( &_lock_context ); \   245     (_previous) &= _mask; \   248 #define LEON_Cpu_Restore_interrupt( _source, _previous, _cpu ) \   250     rtems_interrupt_lock_context _lock_context; \   251     uint32_t _mask = 1U << (_source); \   252     LEON3_IRQCTRL_ACQUIRE( &_lock_context ); \   253       LEON3_IrqCtrl_Regs->mask[_cpu] = \   254         (LEON3_IrqCtrl_Regs->mask[_cpu] & ~_mask) | (_previous); \   255     LEON3_IRQCTRL_RELEASE( &_lock_context ); \   259 #define LEON_Is_interrupt_masked( _source ) \   260   LEON_Cpu_Is_interrupt_masked(_source, _LEON3_Get_current_processor())   262 #define LEON_Mask_interrupt(_source) \   263   LEON_Cpu_Mask_interrupt(_source, _LEON3_Get_current_processor())   265 #define LEON_Unmask_interrupt(_source) \   266   LEON_Cpu_Unmask_interrupt(_source, _LEON3_Get_current_processor())   268 #define LEON_Disable_interrupt(_source, _previous) \   269   LEON_Cpu_Disable_interrupt(_source, _previous, _LEON3_Get_current_processor())   271 #define LEON_Restore_interrupt(_source, _previous) \   272   LEON_Cpu_Restore_interrupt(_source, _previous, _LEON3_Get_current_processor())   275 #define BSP_Clear_interrupt(_source) LEON_Clear_interrupt(_source)   276 #define BSP_Force_interrupt(_source) LEON_Force_interrupt(_source)   277 #define BSP_Is_interrupt_pending(_source) LEON_Is_interrupt_pending(_source)   278 #define BSP_Is_interrupt_masked(_source) LEON_Is_interrupt_masked(_source)   279 #define BSP_Unmask_interrupt(_source) LEON_Unmask_interrupt(_source)   280 #define BSP_Mask_interrupt(_source) LEON_Mask_interrupt(_source)   281 #define BSP_Disable_interrupt(_source, _previous) \   282         LEON_Disable_interrupt(_source, _prev)   283 #define BSP_Restore_interrupt(_source, _previous) \   284         LEON_Restore_interrupt(_source, _previous)   287 #define BSP_Cpu_Is_interrupt_masked(_source, _cpu) \   288         LEON_Cpu_Is_interrupt_masked(_source, _cpu)   289 #define BSP_Cpu_Unmask_interrupt(_source, _cpu) \   290         LEON_Cpu_Unmask_interrupt(_source, _cpu)   291 #define BSP_Cpu_Mask_interrupt(_source, _cpu) \   292         LEON_Cpu_Mask_interrupt(_source, _cpu)   293 #define BSP_Cpu_Disable_interrupt(_source, _previous, _cpu) \   294         LEON_Cpu_Disable_interrupt(_source, _prev, _cpu)   295 #define BSP_Cpu_Restore_interrupt(_source, _previous, _cpu) \   296         LEON_Cpu_Restore_interrupt(_source, _previous, _cpu)   315 #define LEON_REG_TIMER_COUNTER_RELOAD_AT_ZERO     0x00000002   316 #define LEON_REG_TIMER_COUNTER_STOP_AT_ZERO       0x00000000   318 #define LEON_REG_TIMER_COUNTER_LOAD_COUNTER       0x00000004   320 #define LEON_REG_TIMER_COUNTER_ENABLE_COUNTING    0x00000001   321 #define LEON_REG_TIMER_COUNTER_DISABLE_COUNTING   0x00000000   323 #define LEON_REG_TIMER_COUNTER_RELOAD_MASK        0x00000002   324 #define LEON_REG_TIMER_COUNTER_ENABLE_MASK        0x00000001   326 #define LEON_REG_TIMER_COUNTER_DEFINED_MASK       0x00000003   327 #define LEON_REG_TIMER_COUNTER_CURRENT_MODE_MASK  0x00000003   329 #if defined(RTEMS_MULTIPROCESSING)   330   #define LEON3_CLOCK_INDEX \   331    (rtems_configuration_get_user_multiprocessing_table() ? LEON3_Cpu_Index : 0)   333   #define LEON3_CLOCK_INDEX 0   336 #if defined(RTEMS_SMP)   337 #define LEON3_COUNTER_GPTIMER_INDEX (LEON3_CLOCK_INDEX + 1)   339 #define LEON3_COUNTER_GPTIMER_INDEX LEON3_CLOCK_INDEX   347 #define LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000   350 static inline unsigned int leon_r32_no_cache(uintptr_t addr)
   353   __asm__ volatile (
" lda [%1] 1, %0\n" :
"=r"(tmp) :
"r"(addr));
   364 extern int syscon_uart_index;
   373 extern int leon3_debug_uart_index;
   384 extern int leon3_timer_core_index;
   394 extern unsigned int leon3_timer_prescaler;
   397 void leon3_ext_irq_init(
void);
   401 static inline uint32_t leon3_get_cpu_count(
   405   uint32_t mpstat = irqmp->mpstat;
   407   return ((mpstat >> LEON3_IRQMPSTATUS_CPUNR) & 0xf)  + 1;
   410 static inline void leon3_set_system_register(uint32_t addr, uint32_t val)
   415     :
"r" (addr),
"r" (val)
   419 static inline uint32_t leon3_get_system_register(uint32_t addr)
   432 static inline void leon3_set_cache_control_register(uint32_t val)
   434   leon3_set_system_register(0x0, val);
   437 static inline uint32_t leon3_get_cache_control_register(
void)
   439   return leon3_get_system_register(0x0);
   442 static inline bool leon3_data_cache_snooping_enabled(
void)
   444   return leon3_get_cache_control_register() & LEON3_REG_CACHE_CTRL_DS;
   447 static inline uint32_t leon3_get_inst_cache_config_register(
void)
   449   return leon3_get_system_register(0x8);
   452 static inline uint32_t leon3_get_data_cache_config_register(
void)
   454   return leon3_get_system_register(0xc);
   457 static inline bool leon3_irqmp_has_timestamp(
   461   return (irqmp_ts->control >> 27) > 0;
   464 static inline uint32_t leon3_up_counter_low(
void)
   476 static inline uint32_t leon3_up_counter_high(
void)
   488 static inline void leon3_up_counter_enable(
void)
   495 static inline bool leon3_up_counter_is_available(
void)
   497   return leon3_up_counter_low() != leon3_up_counter_low();
   500 static inline uint32_t leon3_up_counter_frequency(
void)
   506   return ambapp_freq_get(&ambapp_plb, LEON3_IrqCtrl_Adev);
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
ISR lock control.
Definition: isrlock.h:56
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
