#define  | LAN91C11X_BASE_ADDR   0x12000000 |
#define  | LAN91C11X_REG(_b_,  _r_)   ((((_b_) & 0xf) << 4) | ((_r_) & 0xf)) |
#define  | LAN91C11X_TCR   (LAN91C11X_REG(0, 0x0)) |
#define  | LAN91C11X_EPHSTAT   (LAN91C11X_REG(0, 0x2)) |
#define  | LAN91C11X_RCR   (LAN91C11X_REG(0, 0x4)) |
#define  | LAN91C11X_CNTR   (LAN91C11X_REG(0, 0x6)) |
#define  | LAN91C11X_MIR   (LAN91C11X_REG(0, 0x8)) |
#define  | LAN91C11X_RPCR   (LAN91C11X_REG(0, 0xa)) |
#define  | LAN91C11X_BANK   (LAN91C11X_REG(0, 0xe)) |
#define  | LAN91C11X_CONFIG   (LAN91C11X_REG(1, 0x0)) |
#define  | LAN91C11X_BASE   (LAN91C11X_REG(1, 0x2)) |
#define  | LAN91C11X_IA0   (LAN91C11X_REG(1, 0x4)) |
#define  | LAN91C11X_IA2   (LAN91C11X_REG(1, 0x6)) |
#define  | LAN91C11X_IA4   (LAN91C11X_REG(1, 0x8)) |
#define  | LAN91C11X_GNRL   (LAN91C11X_REG(1, 0xa)) |
#define  | LAN91C11X_CTRL   (LAN91C11X_REG(1, 0xc)) |
#define  | LAN91C11X_MMUCMD   (LAN91C11X_REG(2, 0x0)) |
#define  | LAN91C11X_PNR   (LAN91C11X_REG(2, 0x2)) |
#define  | LAN91C11X_FIFO   (LAN91C11X_REG(2, 0x4)) |
#define  | LAN91C11X_PTR   (LAN91C11X_REG(2, 0x6)) |
#define  | LAN91C11X_DATA   (LAN91C11X_REG(2, 0x8)) |
#define  | LAN91C11X_INT   (LAN91C11X_REG(2, 0xc)) |
#define  | LAN91C11X_MT0   (LAN91C11X_REG(3, 0x0)) |
#define  | LAN91C11X_MT2   (LAN91C11X_REG(3, 0x2)) |
#define  | LAN91C11X_MT4   (LAN91C11X_REG(3, 0x4)) |
#define  | LAN91C11X_MT6   (LAN91C11X_REG(3, 0x6)) |
#define  | LAN91C11X_MGMT   (LAN91C11X_REG(3, 0x8)) |
#define  | LAN91C11X_REV   (LAN91C11X_REG(3, 0xa)) |
#define  | LAN91C11X_ERCV   (LAN91C11X_REG(3, 0xc)) |
#define  | LAN91C11X_TCR_TXENA   (bit(0)) |
#define  | LAN91C11X_TCR_LOOP   (bit(1)) |
#define  | LAN91C11X_TCR_FORCOL   (bit(2)) |
#define  | LAN91C11X_TCR_PADEN   (bit(7)) |
#define  | LAN91C11X_TCR_NOCRC   (bit(8)) |
#define  | LAN91C11X_TCR_MONCSN   (bit(10)) |
#define  | LAN91C11X_TCR_FDUPLX   (bit(11)) |
#define  | LAN91C11X_TCR_STPSQET   (bit(12)) |
#define  | LAN91C11X_TCR_EPHLOOP   (bit(13)) |
#define  | LAN91C11X_TCR_SWFDUP   (bit(15)) |
#define  | LAN91C11X_EPHSTAT_TXSUC   (bit(0)) |
#define  | LAN91C11X_EPHSTAT_SNGLCOL   (bit(1)) |
#define  | LAN91C11X_EPHSTAT_MULCOL   (bit(2)) |
#define  | LAN91C11X_EPHSTAT_LTXMUL   (bit(3)) |
#define  | LAN91C11X_EPHSTAT_16COL   (bit(4)) |
#define  | LAN91C11X_EPHSTAT_SQET   (bit(5)) |
#define  | LAN91C11X_EPHSTAT_LTXBRD   (bit(6)) |
#define  | LAN91C11X_EPHSTAT_TXDFR   (bit(7)) |
#define  | LAN91C11X_EPHSTAT_LATCOL   (bit(9)) |
#define  | LAN91C11X_EPHSTAT_LOST   (bit(10)) |
#define  | LAN91C11X_EPHSTAT_EXCDEF   (bit(11)) |
#define  | LAN91C11X_EPHSTAT_CTRROL   (bit(12)) |
#define  | LAN91C11X_EPHSTAT_LINK   (bit(14)) |
#define  | LAN91C11X_EPHSTAT_TXUNRN   (bit(15)) |
#define  | LAN91C11X_RCR_RXABT   (bit(0)) |
#define  | LAN91C11X_RCR_PRMS   (bit(1)) |
#define  | LAN91C11X_RCR_ALMUL   (bit(2)) |
#define  | LAN91C11X_RCR_RXEN   (bit(8)) |
#define  | LAN91C11X_RCR_STRIP   (bit(9)) |
#define  | LAN91C11X_RCR_ABTENB   (bit(13)) |
#define  | LAN91C11X_RCR_FILT   (bit(14)) |
#define  | LAN91C11X_RCR_RST   (bit(15)) |
#define  | LAN91C11X_RPCR_LS0B   (bit(2)) |
#define  | LAN91C11X_RPCR_LS1B   (bit(3)) |
#define  | LAN91C11X_RPCR_LS2B   (bit(4)) |
#define  | LAN91C11X_RPCR_LS0A   (bit(5)) |
#define  | LAN91C11X_RPCR_LS1A   (bit(6)) |
#define  | LAN91C11X_RPCR_LS2A   (bit(7)) |
#define  | LAN91C11X_RPCR_ANEG   (bit(11)) |
#define  | LAN91C11X_RPCR_DPLX   (bit(12)) |
#define  | LAN91C11X_RPCR_SPEED   (bit(13)) |
#define  | LAN91C11X_CONFIG_EXTPHY   (bit(9)) |
#define  | LAN91C11X_CONFIG_GPCTRL   (bit(10)) |
#define  | LAN91C11X_CONFIG_NOWAIT   (bit(12)) |
#define  | LAN91C11X_CONFIG_PWR   (bit(15)) |
#define  | LAN91C11X_CTRL_STORE   (bit(0)) |
#define  | LAN91C11X_CTRL_RELOAD   (bit(1)) |
#define  | LAN91C11X_CTRL_EEPROM   (bit(2)) |
#define  | LAN91C11X_CTRL_TEEN   (bit(5)) |
#define  | LAN91C11X_CTRL_CREN   (bit(6)) |
#define  | LAN91C11X_CTRL_LEEN   (bit(7)) |
#define  | LAN91C11X_CTRL_AUTO   (bit(11)) |
#define  | LAN91C11X_CTRL_RCVBAD   (bit(14)) |
#define  | LAN91C11X_MMUCMD_BUSY   (bit(0)) |
#define  | LAN91C11X_MMUCMD_NOOP   (0 << 5) |
#define  | LAN91C11X_MMUCMD_ALLOCTX   (1 << 5) |
#define  | LAN91C11X_MMUCMD_RESETMMU   (2 << 5) |
#define  | LAN91C11X_MMUCMD_REMFRM   (3 << 5) |
#define  | LAN91C11X_MMUCMD_REMTOP   (4 << 5) |
#define  | LAN91C11X_MMUCMD_RELEASE   (5 << 5) |
#define  | LAN91C11X_MMUCMD_ENQUEUE   (6 << 5) |
#define  | LAN91C11X_MMUCMD_RESETTX   (7 << 5) |
#define  | LAN91C11X_PTR_MASK   (0x7ff) |
#define  | LAN91C11X_PTR_NE   (bit(11)) |
#define  | LAN91C11X_PTR_ETEN   (bit(12)) |
#define  | LAN91C11X_PTR_READ   (bit(13)) |
#define  | LAN91C11X_PTR_AUTOINC   (bit(14)) |
#define  | LAN91C11X_PTR_RCV   (bit(15)) |
#define  | LAN91C11X_INT_RX   (bit(0)) |
#define  | LAN91C11X_INT_TX   (bit(1)) |
#define  | LAN91C11X_INT_TXE   (bit(2)) |
#define  | LAN91C11X_INT_ALLOC   (bit(3)) |
#define  | LAN91C11X_INT_RXOV   (bit(4)) |
#define  | LAN91C11X_INT_EPH   (bit(5)) |
#define  | LAN91C11X_INT_ERX   (bit(6)) |
#define  | LAN91C11X_INT_MD   (bit(7)) |
#define  | LAN91C11X_INT_RXMASK   (bit(8)) |
#define  | LAN91C11X_INT_TXMASK   (bit(9)) |
#define  | LAN91C11X_INT_TXEMASK   (bit(10)) |
#define  | LAN91C11X_INT_ALLOCMASK   (bit(11)) |
#define  | LAN91C11X_INT_RXOVMASK   (bit(12)) |
#define  | LAN91C11X_INT_EPHMASK   (bit(13)) |
#define  | LAN91C11X_INT_ERXMASK   (bit(14)) |
#define  | LAN91C11X_INT_MDMASK   (bit(15)) |
#define  | LAN91C11X_MGMT_MDO   (bit(0)) |
#define  | LAN91C11X_MGMT_MDI   (bit(1)) |
#define  | LAN91C11X_MGMT_MCLK   (bit(2)) |
#define  | LAN91C11X_MGMT_MDOE   (bit(3)) |
#define  | LAN91C11X_MGMT_MSKCRS100   (bit(14)) |
#define  | LAN91C11X_PKT_CTRL_CRC   (bit(4)) |
#define  | LAN91C11X_PKT_CTRL_ODD   (bit(5)) |
#define  | PHY_CTRL   0x00    /* PHY Control  */ |
#define  | PHY_STAT   0x01    /* PHY Status */ |
#define  | PHY_ID1   0x02    /* PHY Identifier 1 */ |
#define  | PHY_ID2   0x03    /* PHY Identifier 2 */ |
#define  | PHY_AD   0x04    /* PHY Auto-negotiate Control */ |
#define  | PHY_RMT   0x05    /* PHY Auto-neg Remote End Cap Register */ |
#define  | PHY_CFG1   0x10    /* PHY Configuration 1 */ |
#define  | PHY_CFG2   0x11    /* PHY Configuration 2 */ |
#define  | PHY_INT   0x12    /* Status Output (Interrupt Status) */ |
#define  | PHY_MASK   0x13    /* Interrupt Mask */ |
#define  | PHY_CTRL_RST   0x8000  /* PHY Reset */ |
#define  | PHY_CTRL_LPBK   0x4000  /* PHY Loopback */ |
#define  | PHY_CTRL_SPEED   0x2000  /* 100Mbps, 0=10Mpbs */ |
#define  | PHY_CTRL_ANEGEN   0x1000  /* Enable Auto negotiation */ |
#define  | PHY_CTRL_PDN   0x0800  /* PHY Power Down mode */ |
#define  | PHY_CTRL_MIIDIS   0x0400  /* MII 4 bit interface disabled */ |
#define  | PHY_CTRL_ANEGRST   0x0200  /* Reset Auto negotiate */ |
#define  | PHY_CTRL_DPLX   0x0100  /* Full Duplex, 0=Half Duplex */ |
#define  | PHY_CTRL_COLTST   0x0080  /* MII Colision Test */ |
#define  | PHY_STAT_CAPT4   0x8000 |
#define  | PHY_STAT_CAPTXF   0x4000 |
#define  | PHY_STAT_CAPTXH   0x2000 |
#define  | PHY_STAT_CAPTF   0x1000 |
#define  | PHY_STAT_CAPTH   0x0800 |
#define  | PHY_STAT_CAPSUPR   0x0040 |
#define  | PHY_STAT_ANEGACK   0x0020 |
#define  | PHY_STAT_REMFLT   0x0010 |
#define  | PHY_STAT_CAPANEG   0x0008 |
#define  | PHY_STAT_LINK   0x0004 |
#define  | PHY_STAT_JAB   0x0002 |
#define  | PHY_STAT_EXREG   0x0001 |
#define  | PHY_ADV_NP   0x8000 |
#define  | PHY_ADV_ACK   0x4000 |
#define  | PHY_ADV_RF   0x2000 |
#define  | PHY_ADV_T4   0x0200 |
#define  | PHY_ADV_TXFDX   0x0100 |
#define  | PHY_ADV_TXHDX   0x0080 |
#define  | PHY_ADV_10FDX   0x0040 |
#define  | PHY_ADV_10HDX   0x0020 |
#define  | PHY_ADV_CSMA   0x0001 |
