RTEMS  5.1
io_types.h
1 /************************************************************************
2  *
3  * Data types and constants for Hitachi SH704X on-chip peripherals
4  *
5  * Author: John M.Mills (jmills@tga.com)
6  *
7  * COPYRIGHT (c) 1999, TGA Technologies, Norcross, GA, USA
8  *
9  * This program is distributed in the hope that it will be useful,
10  * but WITHOUT ANY WARRANTY; without even the implied warranty of
11  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
12  *
13  * This file may be distributed as part of the RTEMS software item.
14  *
15  * The license and distribution terms for this file may be
16  * found in the file LICENSE in this distribution or at
17  * http://www.rtems.org/license/LICENSE.
18  *
19  * John M. Mills (jmills@tga.com)
20  * TGA Technologies, Inc.
21  * 100 Pinnacle Way, Suite 140
22  * Norcross, GA 30071 U.S.A.
23  *
24  * This modified file may be copied and distributed in accordance
25  * the above-referenced license. It is provided for critique and
26  * developmental purposes without any warranty nor representation
27  * by the authors or by TGA Technologies.
28  *
29  *
30  ************************************************************************/
31
32 #ifndef _sh_io_types_h
33 #define _sh_io_types_h
34
35 #include <rtems/score/iosh7045.h>
36 #include <termios.h>
37
38 typedef enum {SCI0, SCI1} portNo;
39 typedef enum {eight, seven} dataBits;
40 typedef enum {one, two} stopBits;
41 typedef enum {even, odd} parity;
42
43 typedef struct {
44  portNo line;
45  int speed_ix;
46  dataBits dBits;
47  int parEn;
48  parity par;
49  int mulPro;
50  stopBits sBits;
51 } sci_setup_t;
52
53 typedef union{
54  unsigned char Reg; /* By Register */
55  struct { /* By Field */
56  unsigned char Sync :1; /* Async/Sync */
57  unsigned char DBts :1; /* Char.Length */
58  unsigned char ParEn :1; /* Parity En.*/
59  unsigned char Odd :1; /* Even/Odd */
60  unsigned char SBts :1; /* No.Stop Bits */
61  unsigned char MulP :1; /* Multi-Proc. */
62  unsigned char Dvsr :2; /* Clock Sel. */
63  } Fld;
64 } sci_smr_t;
65
66 typedef union {
67  unsigned char Reg; /* By Register */
68  struct { /* By Field */
69  unsigned char TIE :1; /* Tx.Int.En. */
70  unsigned char RIE :1; /* Rx.Int.En. */
71  unsigned char TE :1; /* Tx.En. */
72  unsigned char RE :1; /* Rx.En. */
73  unsigned char MPIE:1; /* Mult.Pro.Int.En. */
74  unsigned char TEIE:1; /* Tx.End Int.En. */
75  unsigned char CkSrc :2; /* Clock Src. */
76  } Fld;
77 } sci_scr_t;
78
79 typedef struct {
80  unsigned char n ;
81  unsigned char N ;
83
84 #endif /* _sh_io_types_h */
Definition: io_types.h:43
Definition: io_types.h:53
Definition: io_types.h:66
Definition: io_types.h:79
