28 #ifndef _RTEMS_SCORE_INTERRUPTS_H    29 #define _RTEMS_SCORE_INTERRUPTS_H    35 typedef void (*rtems_raw_irq_hdl)       (void);
    45 #if !defined(I386_DISABLE_INLINE_ISR_DISABLE_ENABLE)    46 #define i386_disable_interrupts( _level ) \    48     __asm__ volatile ( "pushf ; \    55 #define i386_enable_interrupts( _level )  \    57     __asm__ volatile ( "push %0 ; \    59                     : : "rm" ((_level)) : "cc" \    63 #define i386_flash_interrupts( _level ) \    65     __asm__ volatile ( "push %0 ; \    68                     : : "rm" ((_level)) : "cc" \    72 #define i386_get_interrupt_level( _level ) \    76     __asm__ volatile ( "pushf ; \    81     _level = (_eflags & EFLAGS_INTR_ENABLE) ? 0 : 1; \    84 uint32_t i386_disable_interrupts(
void );
    85 void i386_enable_interrupts(uint32_t level);
    86 void i386_flash_interrupts(uint32_t level);
    87 void i386_set_interrupt_level(uint32_t new_level);
    88 uint32_t i386_get_interrupt_level(
void );
