    RTEMS
    5.1
DP8390 Ethernet controller definitions. More...
| #define | DATAPORT 0x10 /* Port Window. */ |
| #define | RESET 0x1f /* Issue a read for reset */ |
| #define | W83CREG 0x00 /* I/O port definition */ |
| #define | ADDROM 0x08 |
| #define | CMDR 0x00+RO |
| #define | CLDA0 0x01+RO /* current local dma addr 0 for read */ |
| #define | CLDA1 0x02+RO /* current local dma addr 1 for read */ |
| #define | BNRY 0x03+RO /* boundary reg for rd and wr */ |
| #define | TSR 0x04+RO /* tx status reg for rd */ |
| #define | NCR 0x05+RO /* number of collision reg for rd */ |
| #define | FIFO 0x06+RO /* FIFO for rd */ |
| #define | ISR 0x07+RO /* interrupt status reg for rd and wr */ |
| #define | CRDA0 0x08+RO /* current remote dma address 0 for rd */ |
| #define | CRDA1 0x09+RO /* current remote dma address 1 for rd */ |
| #define | RSR 0x0C+RO /* rx status reg for rd */ |
| #define | CNTR0 0x0D+RO /* tally cnt 0 for frm alg err for rd */ |
| #define | CNTR1 RO+0x0E /* tally cnt 1 for crc err for rd */ |
| #define | CNTR2 0x0F+RO /* tally cnt 2 for missed pkt for rd */ |
| #define | PSTART 0x01+RO /* page start register */ |
| #define | PSTOP 0x02+RO /* page stop register */ |
| #define | TPSR 0x04+RO /* tx start page start reg */ |
| #define | TBCR0 0x05+RO /* tx byte count 0 reg */ |
| #define | TBCR1 0x06+RO /* tx byte count 1 reg */ |
| #define | RSAR0 0x08+RO /* remote start address reg 0 */ |
| #define | RSAR1 0x09+RO /* remote start address reg 1 */ |
| #define | RBCR0 0x0A+RO /* remote byte count reg 0 */ |
| #define | RBCR1 0x0B+RO /* remote byte count reg 1 */ |
| #define | RCR 0x0C+RO /* rx configuration reg */ |
| #define | TCR 0x0D+RO /* tx configuration reg */ |
| #define | DCR RO+0x0E /* data configuration reg */ |
| #define | IMR 0x0F+RO /* interrupt mask reg */ |
| #define | PAR 0x01+RO /* physical addr reg base for rd and wr */ |
| #define | CURR 0x07+RO /* current page reg for rd and wr */ |
| #define | MAR 0x08+RO /* multicast addr reg base fro rd and WR */ |
| #define | MARsize 8 /* size of multicast addr space */ |
| #define | MSK_RESET 0x80 /* W83CREG masks */ |
| #define | MSK_ENASH 0x40 |
| #define | MSK_DECOD 0x3F /* memory decode bits, corresponding */ |
| #define | MSK_STP 0x01 /* stop the chip */ |
| #define | MSK_STA 0x02 /* start the chip */ |
| #define | MSK_TXP 0x04 /* initial txing of a frm */ |
| #define | MSK_RRE 0x08 /* remote read */ |
| #define | MSK_RWR 0x10 /* remote write */ |
| #define | MSK_RD2 0x20 /* no DMA used */ |
| #define | MSK_PG0 0x00 /* select register page 0 */ |
| #define | MSK_PG1 0x40 /* select register page 1 */ |
| #define | MSK_PG2 0x80 /* select register page 2 */ |
| #define | MSK_PRX 0x01 /* rx with no error */ |
| #define | MSK_PTX 0x02 /* tx with no error */ |
| #define | MSK_RXE 0x04 /* rx with error */ |
| #define | MSK_TXE 0x08 /* tx with error */ |
| #define | MSK_OVW 0x10 /* overwrite warning */ |
| #define | MSK_CNT 0x20 /* MSB of one of the tally counters is set */ |
| #define | MSK_RDC 0x40 /* remote dma completed */ |
| #define | MSK_RST 0x80 /* reset state indicator */ |
| #define | MSK_WTS 0x01 /* word transfer mode selection */ |
| #define | MSK_BOS 0x02 /* byte order selection */ |
| #define | MSK_LAS 0x04 /* long addr selection */ |
| #define | MSK_BMS 0x08 /* burst mode selection */ |
| #define | MSK_ARM 0x10 /* autoinitialize remote */ |
| #define | MSK_FT00 0x00 /* burst lrngth selection */ |
| #define | MSK_FT01 0x20 /* burst lrngth selection */ |
| #define | MSK_FT10 0x40 /* burst lrngth selection */ |
| #define | MSK_FT11 0x60 /* burst lrngth selection */ |
| #define | MSK_SEP 0x01 /* save error pkts */ |
| #define | MSK_AR 0x02 /* accept runt pkt */ |
| #define | MSK_AB 0x04 /* 8390 RCR */ |
| #define | MSK_AM 0x08 /* accept multicast */ |
| #define | MSK_PRO 0x10 /* accept all pkt with physical adr */ |
| #define | MSK_MON 0x20 /* monitor mode */ |
| #define | MSK_CRC 0x01 /* inhibit CRC, do not append crc */ |
| #define | MSK_LOOP 0x02 /* set loopback mode */ |
| #define | MSK_BCST 0x04 /* Accept broadcasts */ |
| #define | MSK_LB01 0x06 /* encoded loopback control */ |
| #define | MSK_ATD 0x08 /* auto tx disable */ |
| #define | MSK_OFST 0x10 /* collision offset enable */ |
| #define | SMK_PRX 0x01 /* rx without error */ |
| #define | SMK_CRC 0x02 /* CRC error */ |
| #define | SMK_FAE 0x04 /* frame alignment error */ |
| #define | SMK_FO 0x08 /* FIFO overrun */ |
| #define | SMK_MPA 0x10 /* missed pkt */ |
| #define | SMK_PHY 0x20 /* physical/multicase address */ |
| #define | SMK_DIS 0x40 /* receiver disable. set in monitor mode */ |
| #define | SMK_DEF 0x80 /* deferring */ |
| #define | SMK_PTX 0x01 /* tx without error */ |
| #define | SMK_DFR 0x02 /* non deferred tx */ |
| #define | SMK_COL 0x04 /* tx collided */ |
| #define | SMK_ABT 0x08 /* tx abort because of excessive collisions */ |
| #define | SMK_CRS 0x10 /* carrier sense lost */ |
| #define | SMK_FU 0x20 /* FIFO underrun */ |
| #define | SMK_CDH 0x40 /* collision detect heartbeat */ |
| #define | SMK_OWC 0x80 /* out of window collision */ |
 1.8.15
