RTEMS  5.1
alt_qspi.h
1
7 /*******************************************************************************
8 * *
9 * Copyright 2013 Altera Corporation. All Rights Reserved. *
10 * *
11 * Redistribution and use in source and binary forms, with or without *
12 * modification, are permitted provided that the following conditions are met: *
13 * *
14 * 1. Redistributions of source code must retain the above copyright notice, *
15 * this list of conditions and the following disclaimer. *
16 * *
17 * 2. Redistributions in binary form must reproduce the above copyright notice, *
18 * this list of conditions and the following disclaimer in the documentation *
19 * and/or other materials provided with the distribution. *
20 * *
21 * 3. The name of the author may not be used to endorse or promote products *
22 * derived from this software without specific prior written permission. *
23 * *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27 * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33 * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34 * *
35 *******************************************************************************/
36
37 /* Altera - ALT_QSPI */
38
39 #ifndef __ALTERA_ALT_QSPI_H__
40 #define __ALTERA_ALT_QSPI_H__
41
42 #ifdef __cplusplus
43 extern "C"
44 {
45 #endif /* __cplusplus */
46
47 /*
48  * Component : QSPI Flash Controller Module Registers - ALT_QSPI
49  * QSPI Flash Controller Module Registers
50  *
51  * Registers in the QSPI Flash Controller module accessible via its APB slave
52  *
53  */
54 /*
55  * Register : QSPI Configuration Register - cfg
56  *
57  * Register Layout
58  *
59  * Bits | Access | Reset | Description
60  * :--------|:-------|:------|:-------------------------------------------
61  * [0] | RW | 0x0 | QSPI Enable
62  * [1] | RW | 0x0 | Clock Polarity
63  * [2] | RW | 0x0 | Select Clock Phase
64  * [6:3] | ??? | 0x0 | *UNDEFINED*
65  * [7] | RW | 0x0 | Enable Direct Access Controller
66  * [8] | RW | 0x0 | Legacy IP Mode Enable
67  * [9] | RW | 0x0 | Peripheral select decode
68  * [13:10] | RW | 0x0 | Peripheral Chip Select Lines
69  * [14] | RW | 0x0 | Write Protect Flash Pin
70  * [15] | RW | 0x0 | Enable DMA Peripheral Interface
71  * [16] | RW | 0x0 | Enable AHB Address Re-mapping
72  * [17] | RW | 0x0 | Enter XIP Mode on next READ
73  * [18] | RW | 0x0 | Enter XIP Mode Immediately
74  * [22:19] | RW | 0xf | Master Mode Baud Rate Divisor
75  * [30:23] | ??? | 0x0 | *UNDEFINED*
76  * [31] | R | 0x0 | Serial interface and QSPI pipeline is IDLE
77  *
78  */
79 /*
80  * Field : QSPI Enable - en
81  *
82  * If this bit is disabled, the QSPI will finish the current transfer of the data
83  * word (FF_W) and stop sending. When Enabled, and qspi_n_mo_en = 0, all output
84  * enables are inactive and all pins are set to input mode.
85  *
86  * Field Enumeration Values:
87  *
88  * Enum | Value | Description
89  * :----------------------|:------|:-----------------
90  * ALT_QSPI_CFG_EN_E_DIS | 0x0 | Disable the QSPI
91  * ALT_QSPI_CFG_EN_E_EN | 0x1 | Enable the QSPI
92  *
93  * Field Access Macros:
94  *
95  */
96 /*
97  * Enumerated value for register field ALT_QSPI_CFG_EN
98  *
99  * Disable the QSPI
100  */
101 #define ALT_QSPI_CFG_EN_E_DIS 0x0
102 /*
103  * Enumerated value for register field ALT_QSPI_CFG_EN
104  *
105  * Enable the QSPI
106  */
107 #define ALT_QSPI_CFG_EN_E_EN 0x1
108
109 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_EN register field. */
110 #define ALT_QSPI_CFG_EN_LSB 0
111 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_EN register field. */
112 #define ALT_QSPI_CFG_EN_MSB 0
113 /* The width in bits of the ALT_QSPI_CFG_EN register field. */
114 #define ALT_QSPI_CFG_EN_WIDTH 1
115 /* The mask used to set the ALT_QSPI_CFG_EN register field value. */
116 #define ALT_QSPI_CFG_EN_SET_MSK 0x00000001
117 /* The mask used to clear the ALT_QSPI_CFG_EN register field value. */
118 #define ALT_QSPI_CFG_EN_CLR_MSK 0xfffffffe
119 /* The reset value of the ALT_QSPI_CFG_EN register field. */
120 #define ALT_QSPI_CFG_EN_RESET 0x0
121 /* Extracts the ALT_QSPI_CFG_EN field value from a register. */
122 #define ALT_QSPI_CFG_EN_GET(value) (((value) & 0x00000001) >> 0)
123 /* Produces a ALT_QSPI_CFG_EN register field value suitable for setting the register. */
124 #define ALT_QSPI_CFG_EN_SET(value) (((value) << 0) & 0x00000001)
125
126 /*
127  * Field : Clock Polarity - selclkpol
128  *
129  * Controls spiclk modes of operation.
130  *
131  * Field Enumeration Values:
132  *
133  * Enum | Value | Description
134  * :------------------------------|:------|:----------------------------
135  * ALT_QSPI_CFG_SELCLKPOL_E_LOW | 0x1 | SPI clock is quiescent low
136  * ALT_QSPI_CFG_SELCLKPOL_E_HIGH | 0x0 | SPI clock is quiescent high
137  *
138  * Field Access Macros:
139  *
140  */
141 /*
142  * Enumerated value for register field ALT_QSPI_CFG_SELCLKPOL
143  *
144  * SPI clock is quiescent low
145  */
146 #define ALT_QSPI_CFG_SELCLKPOL_E_LOW 0x1
147 /*
148  * Enumerated value for register field ALT_QSPI_CFG_SELCLKPOL
149  *
150  * SPI clock is quiescent high
151  */
152 #define ALT_QSPI_CFG_SELCLKPOL_E_HIGH 0x0
153
154 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_SELCLKPOL register field. */
155 #define ALT_QSPI_CFG_SELCLKPOL_LSB 1
156 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_SELCLKPOL register field. */
157 #define ALT_QSPI_CFG_SELCLKPOL_MSB 1
158 /* The width in bits of the ALT_QSPI_CFG_SELCLKPOL register field. */
159 #define ALT_QSPI_CFG_SELCLKPOL_WIDTH 1
160 /* The mask used to set the ALT_QSPI_CFG_SELCLKPOL register field value. */
161 #define ALT_QSPI_CFG_SELCLKPOL_SET_MSK 0x00000002
162 /* The mask used to clear the ALT_QSPI_CFG_SELCLKPOL register field value. */
163 #define ALT_QSPI_CFG_SELCLKPOL_CLR_MSK 0xfffffffd
164 /* The reset value of the ALT_QSPI_CFG_SELCLKPOL register field. */
165 #define ALT_QSPI_CFG_SELCLKPOL_RESET 0x0
166 /* Extracts the ALT_QSPI_CFG_SELCLKPOL field value from a register. */
167 #define ALT_QSPI_CFG_SELCLKPOL_GET(value) (((value) & 0x00000002) >> 1)
168 /* Produces a ALT_QSPI_CFG_SELCLKPOL register field value suitable for setting the register. */
169 #define ALT_QSPI_CFG_SELCLKPOL_SET(value) (((value) << 1) & 0x00000002)
170
171 /*
172  * Field : Select Clock Phase - selclkphase
173  *
174  * Selects whether the clock is in an active or inactive phase outside the SPI
175  * word.
176  *
177  * Field Enumeration Values:
178  *
179  * Enum | Value | Description
180  * :---------------------------------|:------|:---------------------------
181  * ALT_QSPI_CFG_SELCLKPHASE_E_ACT | 0x0 | SPI clock is quiescent low
182  * ALT_QSPI_CFG_SELCLKPHASE_E_INACT | 0x1 | Clock Inactive
183  *
184  * Field Access Macros:
185  *
186  */
187 /*
188  * Enumerated value for register field ALT_QSPI_CFG_SELCLKPHASE
189  *
190  * SPI clock is quiescent low
191  */
192 #define ALT_QSPI_CFG_SELCLKPHASE_E_ACT 0x0
193 /*
194  * Enumerated value for register field ALT_QSPI_CFG_SELCLKPHASE
195  *
196  * Clock Inactive
197  */
198 #define ALT_QSPI_CFG_SELCLKPHASE_E_INACT 0x1
199
200 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_SELCLKPHASE register field. */
201 #define ALT_QSPI_CFG_SELCLKPHASE_LSB 2
202 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_SELCLKPHASE register field. */
203 #define ALT_QSPI_CFG_SELCLKPHASE_MSB 2
204 /* The width in bits of the ALT_QSPI_CFG_SELCLKPHASE register field. */
205 #define ALT_QSPI_CFG_SELCLKPHASE_WIDTH 1
206 /* The mask used to set the ALT_QSPI_CFG_SELCLKPHASE register field value. */
207 #define ALT_QSPI_CFG_SELCLKPHASE_SET_MSK 0x00000004
208 /* The mask used to clear the ALT_QSPI_CFG_SELCLKPHASE register field value. */
209 #define ALT_QSPI_CFG_SELCLKPHASE_CLR_MSK 0xfffffffb
210 /* The reset value of the ALT_QSPI_CFG_SELCLKPHASE register field. */
211 #define ALT_QSPI_CFG_SELCLKPHASE_RESET 0x0
212 /* Extracts the ALT_QSPI_CFG_SELCLKPHASE field value from a register. */
213 #define ALT_QSPI_CFG_SELCLKPHASE_GET(value) (((value) & 0x00000004) >> 2)
214 /* Produces a ALT_QSPI_CFG_SELCLKPHASE register field value suitable for setting the register. */
215 #define ALT_QSPI_CFG_SELCLKPHASE_SET(value) (((value) << 2) & 0x00000004)
216
217 /*
218  * Field : Enable Direct Access Controller - endiracc
219  *
220  * If disabled, the Direct Access Controller becomes inactive once the current
221  * transfer of the data word (FF_W) is complete. When the Direct Access Controller
222  * and Indirect Access Controller are both disabled, all AHB requests are completed
223  * with an error response.
224  *
225  * Field Enumeration Values:
226  *
227  * Enum | Value | Description
228  * :----------------------------|:------|:---------------------------
229  * ALT_QSPI_CFG_ENDIRACC_E_DIS | 0x0 | Disable Direct Access Ctrl
230  * ALT_QSPI_CFG_ENDIRACC_E_EN | 0x1 | Enable Direct Access Ctrl
231  *
232  * Field Access Macros:
233  *
234  */
235 /*
236  * Enumerated value for register field ALT_QSPI_CFG_ENDIRACC
237  *
238  * Disable Direct Access Ctrl
239  */
240 #define ALT_QSPI_CFG_ENDIRACC_E_DIS 0x0
241 /*
242  * Enumerated value for register field ALT_QSPI_CFG_ENDIRACC
243  *
244  * Enable Direct Access Ctrl
245  */
246 #define ALT_QSPI_CFG_ENDIRACC_E_EN 0x1
247
248 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_ENDIRACC register field. */
249 #define ALT_QSPI_CFG_ENDIRACC_LSB 7
250 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_ENDIRACC register field. */
251 #define ALT_QSPI_CFG_ENDIRACC_MSB 7
252 /* The width in bits of the ALT_QSPI_CFG_ENDIRACC register field. */
253 #define ALT_QSPI_CFG_ENDIRACC_WIDTH 1
254 /* The mask used to set the ALT_QSPI_CFG_ENDIRACC register field value. */
255 #define ALT_QSPI_CFG_ENDIRACC_SET_MSK 0x00000080
256 /* The mask used to clear the ALT_QSPI_CFG_ENDIRACC register field value. */
257 #define ALT_QSPI_CFG_ENDIRACC_CLR_MSK 0xffffff7f
258 /* The reset value of the ALT_QSPI_CFG_ENDIRACC register field. */
259 #define ALT_QSPI_CFG_ENDIRACC_RESET 0x0
260 /* Extracts the ALT_QSPI_CFG_ENDIRACC field value from a register. */
261 #define ALT_QSPI_CFG_ENDIRACC_GET(value) (((value) & 0x00000080) >> 7)
262 /* Produces a ALT_QSPI_CFG_ENDIRACC register field value suitable for setting the register. */
263 #define ALT_QSPI_CFG_ENDIRACC_SET(value) (((value) << 7) & 0x00000080)
264
265 /*
266  * Field : Legacy IP Mode Enable - enlegacyip
267  *
268  * This bit can select the Direct Access Controller/Indirect Access Controller or
269  * legacy mode.If legacy mode is selected, any write to the controller via the AHB
270  * interface is serialized and sent to the FLASH device. Any valid AHB read will
271  * pop the internal RX-FIFO, retrieving data that was forwarded by the external
272  * FLASH device on the SPI lines, byte transfers of 4, 2 or 1 are permitted and
273  * controlled via the HSIZE input.
274  *
275  * Field Enumeration Values:
276  *
277  * Enum | Value | Description
278  * :---------------------------------|:------|:--------------------------------------
279  * ALT_QSPI_CFG_ENLEGACYIP_E_LEGMOD | 0x1 | Legacy Mode
280  * ALT_QSPI_CFG_ENLEGACYIP_E_DIMOD | 0x0 | Use Direct/Indirect Access Controller
281  *
282  * Field Access Macros:
283  *
284  */
285 /*
286  * Enumerated value for register field ALT_QSPI_CFG_ENLEGACYIP
287  *
288  * Legacy Mode
289  */
290 #define ALT_QSPI_CFG_ENLEGACYIP_E_LEGMOD 0x1
291 /*
292  * Enumerated value for register field ALT_QSPI_CFG_ENLEGACYIP
293  *
294  * Use Direct/Indirect Access Controller
295  */
296 #define ALT_QSPI_CFG_ENLEGACYIP_E_DIMOD 0x0
297
298 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_ENLEGACYIP register field. */
299 #define ALT_QSPI_CFG_ENLEGACYIP_LSB 8
300 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_ENLEGACYIP register field. */
301 #define ALT_QSPI_CFG_ENLEGACYIP_MSB 8
302 /* The width in bits of the ALT_QSPI_CFG_ENLEGACYIP register field. */
303 #define ALT_QSPI_CFG_ENLEGACYIP_WIDTH 1
304 /* The mask used to set the ALT_QSPI_CFG_ENLEGACYIP register field value. */
305 #define ALT_QSPI_CFG_ENLEGACYIP_SET_MSK 0x00000100
306 /* The mask used to clear the ALT_QSPI_CFG_ENLEGACYIP register field value. */
307 #define ALT_QSPI_CFG_ENLEGACYIP_CLR_MSK 0xfffffeff
308 /* The reset value of the ALT_QSPI_CFG_ENLEGACYIP register field. */
309 #define ALT_QSPI_CFG_ENLEGACYIP_RESET 0x0
310 /* Extracts the ALT_QSPI_CFG_ENLEGACYIP field value from a register. */
311 #define ALT_QSPI_CFG_ENLEGACYIP_GET(value) (((value) & 0x00000100) >> 8)
312 /* Produces a ALT_QSPI_CFG_ENLEGACYIP register field value suitable for setting the register. */
313 #define ALT_QSPI_CFG_ENLEGACYIP_SET(value) (((value) << 8) & 0x00000100)
314
315 /*
316  * Field : Peripheral select decode - perseldec
317  *
318  * Select between '1 of 4 selects' or 'external 4-to-16 decode'. The
319  * qspi_n_ss_out[3:0] output signals are controlled.
320  *
321  * Field Enumeration Values:
322  *
323  * Enum | Value | Description
324  * :----------------------------------|:------|:----------------------------------
325  * ALT_QSPI_CFG_PERSELDEC_E_SEL4TO16 | 0x1 | Select external 4-to-16 decode
326  * ALT_QSPI_CFG_PERSELDEC_E_SEL1OF4 | 0x0 | Selects 1 of 4 qspi_n_ss_out[3:0]
327  *
328  * Field Access Macros:
329  *
330  */
331 /*
332  * Enumerated value for register field ALT_QSPI_CFG_PERSELDEC
333  *
334  * Select external 4-to-16 decode
335  */
336 #define ALT_QSPI_CFG_PERSELDEC_E_SEL4TO16 0x1
337 /*
338  * Enumerated value for register field ALT_QSPI_CFG_PERSELDEC
339  *
340  * Selects 1 of 4 qspi_n_ss_out[3:0]
341  */
342 #define ALT_QSPI_CFG_PERSELDEC_E_SEL1OF4 0x0
343
344 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_PERSELDEC register field. */
345 #define ALT_QSPI_CFG_PERSELDEC_LSB 9
346 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_PERSELDEC register field. */
347 #define ALT_QSPI_CFG_PERSELDEC_MSB 9
348 /* The width in bits of the ALT_QSPI_CFG_PERSELDEC register field. */
349 #define ALT_QSPI_CFG_PERSELDEC_WIDTH 1
350 /* The mask used to set the ALT_QSPI_CFG_PERSELDEC register field value. */
351 #define ALT_QSPI_CFG_PERSELDEC_SET_MSK 0x00000200
352 /* The mask used to clear the ALT_QSPI_CFG_PERSELDEC register field value. */
353 #define ALT_QSPI_CFG_PERSELDEC_CLR_MSK 0xfffffdff
354 /* The reset value of the ALT_QSPI_CFG_PERSELDEC register field. */
355 #define ALT_QSPI_CFG_PERSELDEC_RESET 0x0
356 /* Extracts the ALT_QSPI_CFG_PERSELDEC field value from a register. */
357 #define ALT_QSPI_CFG_PERSELDEC_GET(value) (((value) & 0x00000200) >> 9)
358 /* Produces a ALT_QSPI_CFG_PERSELDEC register field value suitable for setting the register. */
359 #define ALT_QSPI_CFG_PERSELDEC_SET(value) (((value) << 9) & 0x00000200)
360
361 /*
362  * Field : Peripheral Chip Select Lines - percslines
363  *
364  * Peripheral chip select line output decode type. As per perseldec, if perseldec =
365  * 0, the decode is select 1 of 4 decoding on signals, qspi_n_ss_out[3:0], The
366  * asserted decode line goes to 0. If perseldec = 1, the signals qspi_n_ss_out[3:0]
367  * require an external 4 to 16 decoder.
368  *
369  * Field Access Macros:
370  *
371  */
372 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_PERCSLINES register field. */
373 #define ALT_QSPI_CFG_PERCSLINES_LSB 10
374 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_PERCSLINES register field. */
375 #define ALT_QSPI_CFG_PERCSLINES_MSB 13
376 /* The width in bits of the ALT_QSPI_CFG_PERCSLINES register field. */
377 #define ALT_QSPI_CFG_PERCSLINES_WIDTH 4
378 /* The mask used to set the ALT_QSPI_CFG_PERCSLINES register field value. */
379 #define ALT_QSPI_CFG_PERCSLINES_SET_MSK 0x00003c00
380 /* The mask used to clear the ALT_QSPI_CFG_PERCSLINES register field value. */
381 #define ALT_QSPI_CFG_PERCSLINES_CLR_MSK 0xffffc3ff
382 /* The reset value of the ALT_QSPI_CFG_PERCSLINES register field. */
383 #define ALT_QSPI_CFG_PERCSLINES_RESET 0x0
384 /* Extracts the ALT_QSPI_CFG_PERCSLINES field value from a register. */
385 #define ALT_QSPI_CFG_PERCSLINES_GET(value) (((value) & 0x00003c00) >> 10)
386 /* Produces a ALT_QSPI_CFG_PERCSLINES register field value suitable for setting the register. */
387 #define ALT_QSPI_CFG_PERCSLINES_SET(value) (((value) << 10) & 0x00003c00)
388
389 /*
390  * Field : Write Protect Flash Pin - wp
391  *
392  * This bit controls the write protect pin of the flash devices. The signal
393  * qspi_mo2_wpn needs to be resynchronized to the generated memory clock as
394  * necessary.
395  *
396  * Field Enumeration Values:
397  *
398  * Enum | Value | Description
399  * :-----------------------------|:------|:----------------------
400  * ALT_QSPI_CFG_WP_E_WRPROTON | 0x1 | Enable Write Protect
401  * ALT_QSPI_CFG_WP_E_WRTPROTOFF | 0x0 | Disable Write Protect
402  *
403  * Field Access Macros:
404  *
405  */
406 /*
407  * Enumerated value for register field ALT_QSPI_CFG_WP
408  *
409  * Enable Write Protect
410  */
411 #define ALT_QSPI_CFG_WP_E_WRPROTON 0x1
412 /*
413  * Enumerated value for register field ALT_QSPI_CFG_WP
414  *
415  * Disable Write Protect
416  */
417 #define ALT_QSPI_CFG_WP_E_WRTPROTOFF 0x0
418
419 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_WP register field. */
420 #define ALT_QSPI_CFG_WP_LSB 14
421 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_WP register field. */
422 #define ALT_QSPI_CFG_WP_MSB 14
423 /* The width in bits of the ALT_QSPI_CFG_WP register field. */
424 #define ALT_QSPI_CFG_WP_WIDTH 1
425 /* The mask used to set the ALT_QSPI_CFG_WP register field value. */
426 #define ALT_QSPI_CFG_WP_SET_MSK 0x00004000
427 /* The mask used to clear the ALT_QSPI_CFG_WP register field value. */
428 #define ALT_QSPI_CFG_WP_CLR_MSK 0xffffbfff
429 /* The reset value of the ALT_QSPI_CFG_WP register field. */
430 #define ALT_QSPI_CFG_WP_RESET 0x0
431 /* Extracts the ALT_QSPI_CFG_WP field value from a register. */
432 #define ALT_QSPI_CFG_WP_GET(value) (((value) & 0x00004000) >> 14)
433 /* Produces a ALT_QSPI_CFG_WP register field value suitable for setting the register. */
434 #define ALT_QSPI_CFG_WP_SET(value) (((value) << 14) & 0x00004000)
435
436 /*
437  * Field : Enable DMA Peripheral Interface - endma
438  *
439  * Allows DMA handshaking mode. When enabled the QSPI will trigger DMA transfer
440  * requests via the DMA peripheral interface.
441  *
442  * Field Enumeration Values:
443  *
444  * Enum | Value | Description
445  * :-------------------------|:------|:-----------------
446  * ALT_QSPI_CFG_ENDMA_E_EN | 0x1 | Enable DMA Mode
447  * ALT_QSPI_CFG_ENDMA_E_DIS | 0x0 | Disable DMA Mode
448  *
449  * Field Access Macros:
450  *
451  */
452 /*
453  * Enumerated value for register field ALT_QSPI_CFG_ENDMA
454  *
455  * Enable DMA Mode
456  */
457 #define ALT_QSPI_CFG_ENDMA_E_EN 0x1
458 /*
459  * Enumerated value for register field ALT_QSPI_CFG_ENDMA
460  *
461  * Disable DMA Mode
462  */
463 #define ALT_QSPI_CFG_ENDMA_E_DIS 0x0
464
465 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_ENDMA register field. */
466 #define ALT_QSPI_CFG_ENDMA_LSB 15
467 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_ENDMA register field. */
468 #define ALT_QSPI_CFG_ENDMA_MSB 15
469 /* The width in bits of the ALT_QSPI_CFG_ENDMA register field. */
470 #define ALT_QSPI_CFG_ENDMA_WIDTH 1
471 /* The mask used to set the ALT_QSPI_CFG_ENDMA register field value. */
472 #define ALT_QSPI_CFG_ENDMA_SET_MSK 0x00008000
473 /* The mask used to clear the ALT_QSPI_CFG_ENDMA register field value. */
474 #define ALT_QSPI_CFG_ENDMA_CLR_MSK 0xffff7fff
475 /* The reset value of the ALT_QSPI_CFG_ENDMA register field. */
476 #define ALT_QSPI_CFG_ENDMA_RESET 0x0
477 /* Extracts the ALT_QSPI_CFG_ENDMA field value from a register. */
478 #define ALT_QSPI_CFG_ENDMA_GET(value) (((value) & 0x00008000) >> 15)
479 /* Produces a ALT_QSPI_CFG_ENDMA register field value suitable for setting the register. */
480 #define ALT_QSPI_CFG_ENDMA_SET(value) (((value) << 15) & 0x00008000)
481
482 /*
483  * Field : Enable AHB Address Re-mapping - enahbremap
484  *
485  * (Direct Access Mode Only) When enabled, the incoming AHB address will be adapted
486  * and sent to the FLASH device as (address + N), where N is the value stored in
487  * the remap address register.
488  *
489  * Field Enumeration Values:
490  *
491  * Enum | Value | Description
492  * :------------------------------|:------|:-----------------------
493  * ALT_QSPI_CFG_ENAHBREMAP_E_EN | 0x1 | Enable AHB Re-mapping
494  * ALT_QSPI_CFG_ENAHBREMAP_E_DIS | 0x0 | Disable AHB Re-mapping
495  *
496  * Field Access Macros:
497  *
498  */
499 /*
500  * Enumerated value for register field ALT_QSPI_CFG_ENAHBREMAP
501  *
502  * Enable AHB Re-mapping
503  */
504 #define ALT_QSPI_CFG_ENAHBREMAP_E_EN 0x1
505 /*
506  * Enumerated value for register field ALT_QSPI_CFG_ENAHBREMAP
507  *
508  * Disable AHB Re-mapping
509  */
510 #define ALT_QSPI_CFG_ENAHBREMAP_E_DIS 0x0
511
512 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_ENAHBREMAP register field. */
513 #define ALT_QSPI_CFG_ENAHBREMAP_LSB 16
514 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_ENAHBREMAP register field. */
515 #define ALT_QSPI_CFG_ENAHBREMAP_MSB 16
516 /* The width in bits of the ALT_QSPI_CFG_ENAHBREMAP register field. */
517 #define ALT_QSPI_CFG_ENAHBREMAP_WIDTH 1
518 /* The mask used to set the ALT_QSPI_CFG_ENAHBREMAP register field value. */
519 #define ALT_QSPI_CFG_ENAHBREMAP_SET_MSK 0x00010000
520 /* The mask used to clear the ALT_QSPI_CFG_ENAHBREMAP register field value. */
521 #define ALT_QSPI_CFG_ENAHBREMAP_CLR_MSK 0xfffeffff
522 /* The reset value of the ALT_QSPI_CFG_ENAHBREMAP register field. */
523 #define ALT_QSPI_CFG_ENAHBREMAP_RESET 0x0
524 /* Extracts the ALT_QSPI_CFG_ENAHBREMAP field value from a register. */
525 #define ALT_QSPI_CFG_ENAHBREMAP_GET(value) (((value) & 0x00010000) >> 16)
526 /* Produces a ALT_QSPI_CFG_ENAHBREMAP register field value suitable for setting the register. */
527 #define ALT_QSPI_CFG_ENAHBREMAP_SET(value) (((value) << 16) & 0x00010000)
528
529 /*
530  * Field : Enter XIP Mode on next READ - enterxipnextrd
531  *
532  * If XIP is enabled, then setting to disabled will cause the controller to exit
533  * XIP mode on the next READ instruction. If XIP is disabled, then setting to
534  * enabled will inform the controller that the device is ready to enter XIP on the
535  * next READ instruction. The controller will therefore send the appropriate
536  * command sequence, including mode bits to cause the device to enter XIP mode. Use
537  * this register after the controller has ensured the FLASH device has been
538  * configured to be ready to enter XIP mode. Note : To exit XIP mode, this bit
539  * should be set to 0. This will take effect in the attached device only AFTER the
540  * next READ instruction is executed. Software should therefore ensure that at
541  * least one READ instruction is requested after resetting this bit before it can
542  * be sure XIP mode in the device is exited.
543  *
544  * Field Enumeration Values:
545  *
546  * Enum | Value | Description
547  * :----------------------------------|:------|:----------------------------------------
548  * ALT_QSPI_CFG_ENTERXIPNEXTRD_E_EN | 0x1 | Enter XIP Mode on next READ instruction
549  * ALT_QSPI_CFG_ENTERXIPNEXTRD_E_DIS | 0x0 | Exit XIP Mode on next READ instruction
550  *
551  * Field Access Macros:
552  *
553  */
554 /*
555  * Enumerated value for register field ALT_QSPI_CFG_ENTERXIPNEXTRD
556  *
557  * Enter XIP Mode on next READ instruction
558  */
559 #define ALT_QSPI_CFG_ENTERXIPNEXTRD_E_EN 0x1
560 /*
561  * Enumerated value for register field ALT_QSPI_CFG_ENTERXIPNEXTRD
562  *
563  * Exit XIP Mode on next READ instruction
564  */
565 #define ALT_QSPI_CFG_ENTERXIPNEXTRD_E_DIS 0x0
566
567 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_ENTERXIPNEXTRD register field. */
568 #define ALT_QSPI_CFG_ENTERXIPNEXTRD_LSB 17
569 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_ENTERXIPNEXTRD register field. */
570 #define ALT_QSPI_CFG_ENTERXIPNEXTRD_MSB 17
571 /* The width in bits of the ALT_QSPI_CFG_ENTERXIPNEXTRD register field. */
572 #define ALT_QSPI_CFG_ENTERXIPNEXTRD_WIDTH 1
573 /* The mask used to set the ALT_QSPI_CFG_ENTERXIPNEXTRD register field value. */
574 #define ALT_QSPI_CFG_ENTERXIPNEXTRD_SET_MSK 0x00020000
575 /* The mask used to clear the ALT_QSPI_CFG_ENTERXIPNEXTRD register field value. */
576 #define ALT_QSPI_CFG_ENTERXIPNEXTRD_CLR_MSK 0xfffdffff
577 /* The reset value of the ALT_QSPI_CFG_ENTERXIPNEXTRD register field. */
578 #define ALT_QSPI_CFG_ENTERXIPNEXTRD_RESET 0x0
579 /* Extracts the ALT_QSPI_CFG_ENTERXIPNEXTRD field value from a register. */
580 #define ALT_QSPI_CFG_ENTERXIPNEXTRD_GET(value) (((value) & 0x00020000) >> 17)
581 /* Produces a ALT_QSPI_CFG_ENTERXIPNEXTRD register field value suitable for setting the register. */
582 #define ALT_QSPI_CFG_ENTERXIPNEXTRD_SET(value) (((value) << 17) & 0x00020000)
583
584 /*
585  * Field : Enter XIP Mode Immediately - enterxipimm
586  *
587  * If XIP is enabled, then setting to disabled will cause the controller to exit
588  * XIP mode on the next READ instruction. If XIP is disabled, then setting enable
589  * will operate the device in XIP mode immediately. Use this register when the
590  * external device wakes up in XIP mode (as per the contents of its non- volatile
591  * configuration register). The controller will assume the next READ instruction
592  * will be passed to the device as an XIP instruction, and therefore will not
593  * require the READ opcode to be transferred. Note: To exit XIP mode, this bit
594  * should be set to 0. This will take effect in the attached device only after the
595  * next READ instruction is executed. Software therefore should ensure that at
596  * least one READ instruction is requested after resetting this bit in order to be
597  * sure that XIP mode is exited.
598  *
599  * Field Enumeration Values:
600  *
601  * Enum | Value | Description
602  * :-------------------------------|:------|:---------------------------------------
603  * ALT_QSPI_CFG_ENTERXIPIMM_E_EN | 0x1 | Enter XIP Mode immediately
604  * ALT_QSPI_CFG_ENTERXIPIMM_E_DIS | 0x0 | Exit XIP Mode on next READ instruction
605  *
606  * Field Access Macros:
607  *
608  */
609 /*
610  * Enumerated value for register field ALT_QSPI_CFG_ENTERXIPIMM
611  *
612  * Enter XIP Mode immediately
613  */
614 #define ALT_QSPI_CFG_ENTERXIPIMM_E_EN 0x1
615 /*
616  * Enumerated value for register field ALT_QSPI_CFG_ENTERXIPIMM
617  *
618  * Exit XIP Mode on next READ instruction
619  */
620 #define ALT_QSPI_CFG_ENTERXIPIMM_E_DIS 0x0
621
622 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_ENTERXIPIMM register field. */
623 #define ALT_QSPI_CFG_ENTERXIPIMM_LSB 18
624 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_ENTERXIPIMM register field. */
625 #define ALT_QSPI_CFG_ENTERXIPIMM_MSB 18
626 /* The width in bits of the ALT_QSPI_CFG_ENTERXIPIMM register field. */
627 #define ALT_QSPI_CFG_ENTERXIPIMM_WIDTH 1
628 /* The mask used to set the ALT_QSPI_CFG_ENTERXIPIMM register field value. */
629 #define ALT_QSPI_CFG_ENTERXIPIMM_SET_MSK 0x00040000
630 /* The mask used to clear the ALT_QSPI_CFG_ENTERXIPIMM register field value. */
631 #define ALT_QSPI_CFG_ENTERXIPIMM_CLR_MSK 0xfffbffff
632 /* The reset value of the ALT_QSPI_CFG_ENTERXIPIMM register field. */
633 #define ALT_QSPI_CFG_ENTERXIPIMM_RESET 0x0
634 /* Extracts the ALT_QSPI_CFG_ENTERXIPIMM field value from a register. */
635 #define ALT_QSPI_CFG_ENTERXIPIMM_GET(value) (((value) & 0x00040000) >> 18)
636 /* Produces a ALT_QSPI_CFG_ENTERXIPIMM register field value suitable for setting the register. */
637 #define ALT_QSPI_CFG_ENTERXIPIMM_SET(value) (((value) << 18) & 0x00040000)
638
639 /*
640  * Field : Master Mode Baud Rate Divisor - bauddiv
641  *
642  * SPI baud rate = ref_clk / (2 * baud_rate_divisor)
643  *
644  * Field Enumeration Values:
645  *
646  * Enum | Value | Description
647  * :------------------------------|:------|:-----------------
648  * ALT_QSPI_CFG_BAUDDIV_E_BAUD2 | 0x0 | Baud Rate Div/2
649  * ALT_QSPI_CFG_BAUDDIV_E_BAUD4 | 0x1 | Baud Rate Div/4
650  * ALT_QSPI_CFG_BAUDDIV_E_BAUD6 | 0x2 | Baud Rate Div/6
651  * ALT_QSPI_CFG_BAUDDIV_E_BAUD8 | 0x3 | Baud Rate Div/8
652  * ALT_QSPI_CFG_BAUDDIV_E_BAUD10 | 0x4 | Baud Rate Div/10
653  * ALT_QSPI_CFG_BAUDDIV_E_BAUD12 | 0x5 | Baud Rate Div/12
654  * ALT_QSPI_CFG_BAUDDIV_E_BAUD14 | 0x6 | Baud Rate Div/14
655  * ALT_QSPI_CFG_BAUDDIV_E_BAUD16 | 0x7 | Baud Rate Div/16
656  * ALT_QSPI_CFG_BAUDDIV_E_BAUD18 | 0x8 | Baud Rate Div/18
657  * ALT_QSPI_CFG_BAUDDIV_E_BAUD20 | 0x9 | Baud Rate Div/20
658  * ALT_QSPI_CFG_BAUDDIV_E_BAUD22 | 0xa | Baud Rate Div/22
659  * ALT_QSPI_CFG_BAUDDIV_E_BAUD24 | 0xb | Baud Rate Div/24
660  * ALT_QSPI_CFG_BAUDDIV_E_BAUD26 | 0xc | Baud Rate Div/26
661  * ALT_QSPI_CFG_BAUDDIV_E_BAUD28 | 0xd | Baud Rate Div/28
662  * ALT_QSPI_CFG_BAUDDIV_E_BAUD30 | 0xe | Baud Rate Div/30
663  * ALT_QSPI_CFG_BAUDDIV_E_BAUD32 | 0xf | Baud Rate Div/32
664  *
665  * Field Access Macros:
666  *
667  */
668 /*
669  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
670  *
671  * Baud Rate Div/2
672  */
673 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD2 0x0
674 /*
675  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
676  *
677  * Baud Rate Div/4
678  */
679 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD4 0x1
680 /*
681  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
682  *
683  * Baud Rate Div/6
684  */
685 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD6 0x2
686 /*
687  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
688  *
689  * Baud Rate Div/8
690  */
691 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD8 0x3
692 /*
693  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
694  *
695  * Baud Rate Div/10
696  */
697 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD10 0x4
698 /*
699  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
700  *
701  * Baud Rate Div/12
702  */
703 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD12 0x5
704 /*
705  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
706  *
707  * Baud Rate Div/14
708  */
709 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD14 0x6
710 /*
711  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
712  *
713  * Baud Rate Div/16
714  */
715 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD16 0x7
716 /*
717  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
718  *
719  * Baud Rate Div/18
720  */
721 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD18 0x8
722 /*
723  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
724  *
725  * Baud Rate Div/20
726  */
727 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD20 0x9
728 /*
729  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
730  *
731  * Baud Rate Div/22
732  */
733 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD22 0xa
734 /*
735  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
736  *
737  * Baud Rate Div/24
738  */
739 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD24 0xb
740 /*
741  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
742  *
743  * Baud Rate Div/26
744  */
745 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD26 0xc
746 /*
747  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
748  *
749  * Baud Rate Div/28
750  */
751 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD28 0xd
752 /*
753  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
754  *
755  * Baud Rate Div/30
756  */
757 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD30 0xe
758 /*
759  * Enumerated value for register field ALT_QSPI_CFG_BAUDDIV
760  *
761  * Baud Rate Div/32
762  */
763 #define ALT_QSPI_CFG_BAUDDIV_E_BAUD32 0xf
764
765 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_BAUDDIV register field. */
766 #define ALT_QSPI_CFG_BAUDDIV_LSB 19
767 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_BAUDDIV register field. */
768 #define ALT_QSPI_CFG_BAUDDIV_MSB 22
769 /* The width in bits of the ALT_QSPI_CFG_BAUDDIV register field. */
770 #define ALT_QSPI_CFG_BAUDDIV_WIDTH 4
771 /* The mask used to set the ALT_QSPI_CFG_BAUDDIV register field value. */
772 #define ALT_QSPI_CFG_BAUDDIV_SET_MSK 0x00780000
773 /* The mask used to clear the ALT_QSPI_CFG_BAUDDIV register field value. */
774 #define ALT_QSPI_CFG_BAUDDIV_CLR_MSK 0xff87ffff
775 /* The reset value of the ALT_QSPI_CFG_BAUDDIV register field. */
776 #define ALT_QSPI_CFG_BAUDDIV_RESET 0xf
777 /* Extracts the ALT_QSPI_CFG_BAUDDIV field value from a register. */
778 #define ALT_QSPI_CFG_BAUDDIV_GET(value) (((value) & 0x00780000) >> 19)
779 /* Produces a ALT_QSPI_CFG_BAUDDIV register field value suitable for setting the register. */
780 #define ALT_QSPI_CFG_BAUDDIV_SET(value) (((value) << 19) & 0x00780000)
781
782 /*
783  * Field : Serial interface and QSPI pipeline is IDLE - idle
784  *
785  * This is a STATUS read-only bit. Note this is a retimed signal, so there will be
786  * some inherent delay on the generation of this status signal.
787  *
788  * Field Enumeration Values:
789  *
790  * Enum | Value | Description
791  * :---------------------------|:------|:--------------
792  * ALT_QSPI_CFG_IDLE_E_SET | 0x1 | Idle Mode
793  * ALT_QSPI_CFG_IDLE_E_NOTSET | 0x0 | Non-Idle Mode
794  *
795  * Field Access Macros:
796  *
797  */
798 /*
799  * Enumerated value for register field ALT_QSPI_CFG_IDLE
800  *
801  * Idle Mode
802  */
803 #define ALT_QSPI_CFG_IDLE_E_SET 0x1
804 /*
805  * Enumerated value for register field ALT_QSPI_CFG_IDLE
806  *
807  * Non-Idle Mode
808  */
809 #define ALT_QSPI_CFG_IDLE_E_NOTSET 0x0
810
811 /* The Least Significant Bit (LSB) position of the ALT_QSPI_CFG_IDLE register field. */
812 #define ALT_QSPI_CFG_IDLE_LSB 31
813 /* The Most Significant Bit (MSB) position of the ALT_QSPI_CFG_IDLE register field. */
814 #define ALT_QSPI_CFG_IDLE_MSB 31
815 /* The width in bits of the ALT_QSPI_CFG_IDLE register field. */
816 #define ALT_QSPI_CFG_IDLE_WIDTH 1
817 /* The mask used to set the ALT_QSPI_CFG_IDLE register field value. */
818 #define ALT_QSPI_CFG_IDLE_SET_MSK 0x80000000
819 /* The mask used to clear the ALT_QSPI_CFG_IDLE register field value. */
820 #define ALT_QSPI_CFG_IDLE_CLR_MSK 0x7fffffff
821 /* The reset value of the ALT_QSPI_CFG_IDLE register field. */
822 #define ALT_QSPI_CFG_IDLE_RESET 0x0
823 /* Extracts the ALT_QSPI_CFG_IDLE field value from a register. */
824 #define ALT_QSPI_CFG_IDLE_GET(value) (((value) & 0x80000000) >> 31)
825 /* Produces a ALT_QSPI_CFG_IDLE register field value suitable for setting the register. */
826 #define ALT_QSPI_CFG_IDLE_SET(value) (((value) << 31) & 0x80000000)
827
828 #ifndef __ASSEMBLY__
829 /*
830  * WARNING: The C register and register group struct declarations are provided for
831  * convenience and illustrative purposes. They should, however, be used with
832  * caution as the C language standard provides no guarantees about the alignment or
833  * atomicity of device memory accesses. The recommended practice for writing
834  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
835  * alt_write_word() functions.
836  *
837  * The struct declaration for register ALT_QSPI_CFG.
838  */
840 {
841  uint32_t en : 1; /* QSPI Enable */
842  uint32_t selclkpol : 1; /* Clock Polarity */
843  uint32_t selclkphase : 1; /* Select Clock Phase */
844  uint32_t : 4; /* *UNDEFINED* */
845  uint32_t endiracc : 1; /* Enable Direct Access Controller */
846  uint32_t enlegacyip : 1; /* Legacy IP Mode Enable */
847  uint32_t perseldec : 1; /* Peripheral select decode */
848  uint32_t percslines : 4; /* Peripheral Chip Select Lines */
849  uint32_t wp : 1; /* Write Protect Flash Pin */
850  uint32_t endma : 1; /* Enable DMA Peripheral Interface */
851  uint32_t enahbremap : 1; /* Enable AHB Address Re-mapping */
852  uint32_t enterxipnextrd : 1; /* Enter XIP Mode on next READ */
853  uint32_t enterxipimm : 1; /* Enter XIP Mode Immediately */
854  uint32_t bauddiv : 4; /* Master Mode Baud Rate Divisor */
855  uint32_t : 8; /* *UNDEFINED* */
856  const uint32_t idle : 1; /* Serial interface and QSPI pipeline is IDLE */
857 };
858
859 /* The typedef declaration for register ALT_QSPI_CFG. */
860 typedef volatile struct ALT_QSPI_CFG_s ALT_QSPI_CFG_t;
861 #endif /* __ASSEMBLY__ */
862
863 /* The byte offset of the ALT_QSPI_CFG register from the beginning of the component. */
864 #define ALT_QSPI_CFG_OFST 0x0
865
866 /*
867  * Register : Device Read Instruction Register - devrd
868  *
869  * Register Layout
870  *
871  * Bits | Access | Reset | Description
872  * :--------|:-------|:------|:----------------------------
873  * [7:0] | RW | 0x3 | Read Opcode in non-XIP mode
874  * [9:8] | RW | 0x0 | Instruction Transfer Width
875  * [11:10] | ??? | 0x0 | *UNDEFINED*
876  * [13:12] | RW | 0x0 | Address Transfer Width
877  * [15:14] | ??? | 0x0 | *UNDEFINED*
878  * [17:16] | RW | 0x0 | Data Transfer Width
879  * [19:18] | ??? | 0x0 | *UNDEFINED*
880  * [20] | RW | 0x0 | Mode Bit Enable
881  * [23:21] | ??? | 0x0 | *UNDEFINED*
882  * [28:24] | RW | 0x0 | Dummy Read Clock Cycles
883  * [31:29] | ??? | 0x0 | *UNDEFINED*
884  *
885  */
886 /*
887  * Field : Read Opcode in non-XIP mode - rdopcode
888  *
889  * Read Opcode to use when not in XIP mode
890  *
891  * Field Enumeration Values:
892  *
893  * Enum | Value | Description
894  * :---------------------------------|:------|:----------------------------
895  * ALT_QSPI_DEVRD_RDOPCODE_E_RD | 0x3 | Read Opcode in Non-XIP mode
896  * ALT_QSPI_DEVRD_RDOPCODE_E_FASTRD | 0xb | Fast Read in Non-XIP mode
897  *
898  * Field Access Macros:
899  *
900  */
901 /*
902  * Enumerated value for register field ALT_QSPI_DEVRD_RDOPCODE
903  *
904  * Read Opcode in Non-XIP mode
905  */
906 #define ALT_QSPI_DEVRD_RDOPCODE_E_RD 0x3
907 /*
908  * Enumerated value for register field ALT_QSPI_DEVRD_RDOPCODE
909  *
910  * Fast Read in Non-XIP mode
911  */
912 #define ALT_QSPI_DEVRD_RDOPCODE_E_FASTRD 0xb
913
914 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVRD_RDOPCODE register field. */
915 #define ALT_QSPI_DEVRD_RDOPCODE_LSB 0
916 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVRD_RDOPCODE register field. */
917 #define ALT_QSPI_DEVRD_RDOPCODE_MSB 7
918 /* The width in bits of the ALT_QSPI_DEVRD_RDOPCODE register field. */
919 #define ALT_QSPI_DEVRD_RDOPCODE_WIDTH 8
920 /* The mask used to set the ALT_QSPI_DEVRD_RDOPCODE register field value. */
921 #define ALT_QSPI_DEVRD_RDOPCODE_SET_MSK 0x000000ff
922 /* The mask used to clear the ALT_QSPI_DEVRD_RDOPCODE register field value. */
923 #define ALT_QSPI_DEVRD_RDOPCODE_CLR_MSK 0xffffff00
924 /* The reset value of the ALT_QSPI_DEVRD_RDOPCODE register field. */
925 #define ALT_QSPI_DEVRD_RDOPCODE_RESET 0x3
926 /* Extracts the ALT_QSPI_DEVRD_RDOPCODE field value from a register. */
927 #define ALT_QSPI_DEVRD_RDOPCODE_GET(value) (((value) & 0x000000ff) >> 0)
928 /* Produces a ALT_QSPI_DEVRD_RDOPCODE register field value suitable for setting the register. */
929 #define ALT_QSPI_DEVRD_RDOPCODE_SET(value) (((value) << 0) & 0x000000ff)
930
931 /*
932  * Field : Instruction Transfer Width - instwidth
933  *
934  * Sets instruction transfer width (1, 2, or 4 bits). Applies to all instructions
935  * sent to SPI flash device (not just read instructions).
936  *
937  * Field Enumeration Values:
938  *
939  * Enum | Value | Description
940  * :----------------------------------|:------|:-------------------------------------------------
941  * ALT_QSPI_DEVRD_INSTWIDTH_E_SINGLE | 0x0 | Instruction transferred on DQ0. Supported by all
942  * : | | SPI flash devices.
943  * ALT_QSPI_DEVRD_INSTWIDTH_E_DUAL | 0x1 | Instruction transferred on DQ0 and DQ1.
944  * : | | Supported by all SPI flash devices that support
945  * : | | the Dual SP (DIO-SPI) Protocol.
946  * ALT_QSPI_DEVRD_INSTWIDTH_E_QUAD | 0x2 | Instruction transferred on DQ0, DQ1, DQ2, and
947  * : | | DQ3. Supported by all SPI flash devices that
948  * : | | support the Quad SP (QIO-SPI) Protocol.
949  *
950  * Field Access Macros:
951  *
952  */
953 /*
954  * Enumerated value for register field ALT_QSPI_DEVRD_INSTWIDTH
955  *
956  * Instruction transferred on DQ0. Supported by all SPI flash devices.
957  */
958 #define ALT_QSPI_DEVRD_INSTWIDTH_E_SINGLE 0x0
959 /*
960  * Enumerated value for register field ALT_QSPI_DEVRD_INSTWIDTH
961  *
962  * Instruction transferred on DQ0 and DQ1. Supported by all SPI flash devices that
963  * support the Dual SP (DIO-SPI) Protocol.
964  */
965 #define ALT_QSPI_DEVRD_INSTWIDTH_E_DUAL 0x1
966 /*
967  * Enumerated value for register field ALT_QSPI_DEVRD_INSTWIDTH
968  *
969  * Instruction transferred on DQ0, DQ1, DQ2, and DQ3. Supported by all SPI flash
970  * devices that support the Quad SP (QIO-SPI) Protocol.
971  */
972 #define ALT_QSPI_DEVRD_INSTWIDTH_E_QUAD 0x2
973
974 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVRD_INSTWIDTH register field. */
975 #define ALT_QSPI_DEVRD_INSTWIDTH_LSB 8
976 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVRD_INSTWIDTH register field. */
977 #define ALT_QSPI_DEVRD_INSTWIDTH_MSB 9
978 /* The width in bits of the ALT_QSPI_DEVRD_INSTWIDTH register field. */
979 #define ALT_QSPI_DEVRD_INSTWIDTH_WIDTH 2
980 /* The mask used to set the ALT_QSPI_DEVRD_INSTWIDTH register field value. */
981 #define ALT_QSPI_DEVRD_INSTWIDTH_SET_MSK 0x00000300
982 /* The mask used to clear the ALT_QSPI_DEVRD_INSTWIDTH register field value. */
983 #define ALT_QSPI_DEVRD_INSTWIDTH_CLR_MSK 0xfffffcff
984 /* The reset value of the ALT_QSPI_DEVRD_INSTWIDTH register field. */
985 #define ALT_QSPI_DEVRD_INSTWIDTH_RESET 0x0
986 /* Extracts the ALT_QSPI_DEVRD_INSTWIDTH field value from a register. */
987 #define ALT_QSPI_DEVRD_INSTWIDTH_GET(value) (((value) & 0x00000300) >> 8)
988 /* Produces a ALT_QSPI_DEVRD_INSTWIDTH register field value suitable for setting the register. */
989 #define ALT_QSPI_DEVRD_INSTWIDTH_SET(value) (((value) << 8) & 0x00000300)
990
991 /*
992  * Field : Address Transfer Width - addrwidth
993  *
994  * Sets read address transfer width (1, 2, or 4 bits).
995  *
996  * Field Enumeration Values:
997  *
998  * Enum | Value | Description
999  * :----------------------------------|:------|:-------------------------------------------------
1000  * ALT_QSPI_DEVRD_ADDRWIDTH_E_SINGLE | 0x0 | Read address transferred on DQ0. Supported by
1001  * : | | all SPI flash devices
1002  * ALT_QSPI_DEVRD_ADDRWIDTH_E_DUAL | 0x1 | Read address transferred on DQ0 and DQ1.
1003  * : | | Supported by some SPI flash devices that support
1004  * : | | the Extended SPI Protocol and by all SPI flash
1005  * : | | devices that support the Dual SP (DIO-SPI)
1006  * : | | Protocol.
1007  * ALT_QSPI_DEVRD_ADDRWIDTH_E_QUAD | 0x2 | Read address transferred on DQ0, DQ1, DQ2, and
1008  * : | | DQ3. Supported by some SPI flash devices that
1009  * : | | support the Extended SPI Protocol and by all SPI
1010  * : | | flash devices that support the Quad SP (QIO-SPI)
1011  * : | | Protocol.
1012  *
1013  * Field Access Macros:
1014  *
1015  */
1016 /*
1017  * Enumerated value for register field ALT_QSPI_DEVRD_ADDRWIDTH
1018  *
1019  * Read address transferred on DQ0. Supported by all SPI flash devices
1020  */
1021 #define ALT_QSPI_DEVRD_ADDRWIDTH_E_SINGLE 0x0
1022 /*
1023  * Enumerated value for register field ALT_QSPI_DEVRD_ADDRWIDTH
1024  *
1025  * Read address transferred on DQ0 and DQ1. Supported by some SPI flash devices
1026  * that support the Extended SPI Protocol and by all SPI flash devices that support
1027  * the Dual SP (DIO-SPI) Protocol.
1028  */
1029 #define ALT_QSPI_DEVRD_ADDRWIDTH_E_DUAL 0x1
1030 /*
1031  * Enumerated value for register field ALT_QSPI_DEVRD_ADDRWIDTH
1032  *
1033  * Read address transferred on DQ0, DQ1, DQ2, and DQ3. Supported by some SPI flash
1034  * devices that support the Extended SPI Protocol and by all SPI flash devices that
1035  * support the Quad SP (QIO-SPI) Protocol.
1036  */
1037 #define ALT_QSPI_DEVRD_ADDRWIDTH_E_QUAD 0x2
1038
1039 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVRD_ADDRWIDTH register field. */
1040 #define ALT_QSPI_DEVRD_ADDRWIDTH_LSB 12
1041 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVRD_ADDRWIDTH register field. */
1042 #define ALT_QSPI_DEVRD_ADDRWIDTH_MSB 13
1043 /* The width in bits of the ALT_QSPI_DEVRD_ADDRWIDTH register field. */
1044 #define ALT_QSPI_DEVRD_ADDRWIDTH_WIDTH 2
1045 /* The mask used to set the ALT_QSPI_DEVRD_ADDRWIDTH register field value. */
1046 #define ALT_QSPI_DEVRD_ADDRWIDTH_SET_MSK 0x00003000
1047 /* The mask used to clear the ALT_QSPI_DEVRD_ADDRWIDTH register field value. */
1048 #define ALT_QSPI_DEVRD_ADDRWIDTH_CLR_MSK 0xffffcfff
1049 /* The reset value of the ALT_QSPI_DEVRD_ADDRWIDTH register field. */
1050 #define ALT_QSPI_DEVRD_ADDRWIDTH_RESET 0x0
1051 /* Extracts the ALT_QSPI_DEVRD_ADDRWIDTH field value from a register. */
1052 #define ALT_QSPI_DEVRD_ADDRWIDTH_GET(value) (((value) & 0x00003000) >> 12)
1053 /* Produces a ALT_QSPI_DEVRD_ADDRWIDTH register field value suitable for setting the register. */
1054 #define ALT_QSPI_DEVRD_ADDRWIDTH_SET(value) (((value) << 12) & 0x00003000)
1055
1056 /*
1057  * Field : Data Transfer Width - datawidth
1058  *
1059  * Sets read data transfer width (1, 2, or 4 bits).
1060  *
1061  * Field Enumeration Values:
1062  *
1063  * Enum | Value | Description
1064  * :----------------------------------|:------|:-------------------------------------------------
1065  * ALT_QSPI_DEVRD_DATAWIDTH_E_SINGLE | 0x0 | Read data transferred on DQ0. Supported by all
1066  * : | | SPI flash devices
1067  * ALT_QSPI_DEVRD_DATAWIDTH_E_DUAL | 0x1 | Read data transferred on DQ0 and DQ1. Supported
1068  * : | | by some SPI flash devices that support the
1069  * : | | Extended SPI Protocol and by all SPI flash
1070  * : | | devices that support the Dual SP (DIO-SPI)
1071  * : | | Protocol.
1072  * ALT_QSPI_DEVRD_DATAWIDTH_E_QUAD | 0x2 | Read data transferred on DQ0, DQ1, DQ2, and DQ3.
1073  * : | | Supported by some SPI flash devices that support
1074  * : | | the Extended SPI Protocol and by all SPI flash
1075  * : | | devices that support the Quad SP (QIO-SPI)
1076  * : | | Protocol.
1077  *
1078  * Field Access Macros:
1079  *
1080  */
1081 /*
1082  * Enumerated value for register field ALT_QSPI_DEVRD_DATAWIDTH
1083  *
1084  * Read data transferred on DQ0. Supported by all SPI flash devices
1085  */
1086 #define ALT_QSPI_DEVRD_DATAWIDTH_E_SINGLE 0x0
1087 /*
1088  * Enumerated value for register field ALT_QSPI_DEVRD_DATAWIDTH
1089  *
1090  * Read data transferred on DQ0 and DQ1. Supported by some SPI flash devices that
1091  * support the Extended SPI Protocol and by all SPI flash devices that support the
1092  * Dual SP (DIO-SPI) Protocol.
1093  */
1094 #define ALT_QSPI_DEVRD_DATAWIDTH_E_DUAL 0x1
1095 /*
1096  * Enumerated value for register field ALT_QSPI_DEVRD_DATAWIDTH
1097  *
1098  * Read data transferred on DQ0, DQ1, DQ2, and DQ3. Supported by some SPI flash
1099  * devices that support the Extended SPI Protocol and by all SPI flash devices that
1100  * support the Quad SP (QIO-SPI) Protocol.
1101  */
1102 #define ALT_QSPI_DEVRD_DATAWIDTH_E_QUAD 0x2
1103
1104 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVRD_DATAWIDTH register field. */
1105 #define ALT_QSPI_DEVRD_DATAWIDTH_LSB 16
1106 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVRD_DATAWIDTH register field. */
1107 #define ALT_QSPI_DEVRD_DATAWIDTH_MSB 17
1108 /* The width in bits of the ALT_QSPI_DEVRD_DATAWIDTH register field. */
1109 #define ALT_QSPI_DEVRD_DATAWIDTH_WIDTH 2
1110 /* The mask used to set the ALT_QSPI_DEVRD_DATAWIDTH register field value. */
1111 #define ALT_QSPI_DEVRD_DATAWIDTH_SET_MSK 0x00030000
1112 /* The mask used to clear the ALT_QSPI_DEVRD_DATAWIDTH register field value. */
1113 #define ALT_QSPI_DEVRD_DATAWIDTH_CLR_MSK 0xfffcffff
1114 /* The reset value of the ALT_QSPI_DEVRD_DATAWIDTH register field. */
1115 #define ALT_QSPI_DEVRD_DATAWIDTH_RESET 0x0
1116 /* Extracts the ALT_QSPI_DEVRD_DATAWIDTH field value from a register. */
1117 #define ALT_QSPI_DEVRD_DATAWIDTH_GET(value) (((value) & 0x00030000) >> 16)
1118 /* Produces a ALT_QSPI_DEVRD_DATAWIDTH register field value suitable for setting the register. */
1119 #define ALT_QSPI_DEVRD_DATAWIDTH_SET(value) (((value) << 16) & 0x00030000)
1120
1121 /*
1122  * Field : Mode Bit Enable - enmodebits
1123  *
1124  * If this bit is set, the mode bits as defined in the Mode Bit Configuration
1125  * register are sent following the address bytes.
1126  *
1127  * Field Enumeration Values:
1128  *
1129  * Enum | Value | Description
1130  * :-----------------------------------|:------|:-------------------------------
1131  * ALT_QSPI_DEVRD_ENMODBITS_E_NOORDER | 0x0 | No Order
1132  * ALT_QSPI_DEVRD_ENMODBITS_E_ORDER | 0x1 | Mode Bits follow address bytes
1133  *
1134  * Field Access Macros:
1135  *
1136  */
1137 /*
1138  * Enumerated value for register field ALT_QSPI_DEVRD_ENMODBITS
1139  *
1140  * No Order
1141  */
1142 #define ALT_QSPI_DEVRD_ENMODBITS_E_NOORDER 0x0
1143 /*
1144  * Enumerated value for register field ALT_QSPI_DEVRD_ENMODBITS
1145  *
1146  * Mode Bits follow address bytes
1147  */
1148 #define ALT_QSPI_DEVRD_ENMODBITS_E_ORDER 0x1
1149
1150 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVRD_ENMODBITS register field. */
1151 #define ALT_QSPI_DEVRD_ENMODBITS_LSB 20
1152 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVRD_ENMODBITS register field. */
1153 #define ALT_QSPI_DEVRD_ENMODBITS_MSB 20
1154 /* The width in bits of the ALT_QSPI_DEVRD_ENMODBITS register field. */
1155 #define ALT_QSPI_DEVRD_ENMODBITS_WIDTH 1
1156 /* The mask used to set the ALT_QSPI_DEVRD_ENMODBITS register field value. */
1157 #define ALT_QSPI_DEVRD_ENMODBITS_SET_MSK 0x00100000
1158 /* The mask used to clear the ALT_QSPI_DEVRD_ENMODBITS register field value. */
1159 #define ALT_QSPI_DEVRD_ENMODBITS_CLR_MSK 0xffefffff
1160 /* The reset value of the ALT_QSPI_DEVRD_ENMODBITS register field. */
1161 #define ALT_QSPI_DEVRD_ENMODBITS_RESET 0x0
1162 /* Extracts the ALT_QSPI_DEVRD_ENMODBITS field value from a register. */
1163 #define ALT_QSPI_DEVRD_ENMODBITS_GET(value) (((value) & 0x00100000) >> 20)
1164 /* Produces a ALT_QSPI_DEVRD_ENMODBITS register field value suitable for setting the register. */
1165 #define ALT_QSPI_DEVRD_ENMODBITS_SET(value) (((value) << 20) & 0x00100000)
1166
1167 /*
1168  * Field : Dummy Read Clock Cycles - dummyrdclks
1169  *
1170  * Number of dummy clock cycles required by device for read instruction.
1171  *
1172  * Field Access Macros:
1173  *
1174  */
1175 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVRD_DUMMYRDCLKS register field. */
1176 #define ALT_QSPI_DEVRD_DUMMYRDCLKS_LSB 24
1177 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVRD_DUMMYRDCLKS register field. */
1178 #define ALT_QSPI_DEVRD_DUMMYRDCLKS_MSB 28
1179 /* The width in bits of the ALT_QSPI_DEVRD_DUMMYRDCLKS register field. */
1180 #define ALT_QSPI_DEVRD_DUMMYRDCLKS_WIDTH 5
1181 /* The mask used to set the ALT_QSPI_DEVRD_DUMMYRDCLKS register field value. */
1182 #define ALT_QSPI_DEVRD_DUMMYRDCLKS_SET_MSK 0x1f000000
1183 /* The mask used to clear the ALT_QSPI_DEVRD_DUMMYRDCLKS register field value. */
1184 #define ALT_QSPI_DEVRD_DUMMYRDCLKS_CLR_MSK 0xe0ffffff
1185 /* The reset value of the ALT_QSPI_DEVRD_DUMMYRDCLKS register field. */
1186 #define ALT_QSPI_DEVRD_DUMMYRDCLKS_RESET 0x0
1187 /* Extracts the ALT_QSPI_DEVRD_DUMMYRDCLKS field value from a register. */
1188 #define ALT_QSPI_DEVRD_DUMMYRDCLKS_GET(value) (((value) & 0x1f000000) >> 24)
1189 /* Produces a ALT_QSPI_DEVRD_DUMMYRDCLKS register field value suitable for setting the register. */
1190 #define ALT_QSPI_DEVRD_DUMMYRDCLKS_SET(value) (((value) << 24) & 0x1f000000)
1191
1192 #ifndef __ASSEMBLY__
1193 /*
1194  * WARNING: The C register and register group struct declarations are provided for
1195  * convenience and illustrative purposes. They should, however, be used with
1196  * caution as the C language standard provides no guarantees about the alignment or
1197  * atomicity of device memory accesses. The recommended practice for writing
1198  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1199  * alt_write_word() functions.
1200  *
1201  * The struct declaration for register ALT_QSPI_DEVRD.
1202  */
1204 {
1205  uint32_t rdopcode : 8; /* Read Opcode in non-XIP mode */
1206  uint32_t instwidth : 2; /* Instruction Transfer Width */
1207  uint32_t : 2; /* *UNDEFINED* */
1208  uint32_t addrwidth : 2; /* Address Transfer Width */
1209  uint32_t : 2; /* *UNDEFINED* */
1210  uint32_t datawidth : 2; /* Data Transfer Width */
1211  uint32_t : 2; /* *UNDEFINED* */
1212  uint32_t enmodebits : 1; /* Mode Bit Enable */
1213  uint32_t : 3; /* *UNDEFINED* */
1214  uint32_t dummyrdclks : 5; /* Dummy Read Clock Cycles */
1215  uint32_t : 3; /* *UNDEFINED* */
1216 };
1217
1218 /* The typedef declaration for register ALT_QSPI_DEVRD. */
1219 typedef volatile struct ALT_QSPI_DEVRD_s ALT_QSPI_DEVRD_t;
1220 #endif /* __ASSEMBLY__ */
1221
1222 /* The byte offset of the ALT_QSPI_DEVRD register from the beginning of the component. */
1223 #define ALT_QSPI_DEVRD_OFST 0x4
1224
1225 /*
1226  * Register : Device Write Instruction Register - devwr
1227  *
1228  * Register Layout
1229  *
1230  * Bits | Access | Reset | Description
1231  * :--------|:-------|:------|:-------------------------
1232  * [7:0] | RW | 0x2 | Write Opcode
1233  * [11:8] | ??? | 0x0 | *UNDEFINED*
1234  * [13:12] | RW | 0x0 | Address Transfer Width
1235  * [15:14] | ??? | 0x0 | *UNDEFINED*
1236  * [17:16] | RW | 0x0 | Data Transfer Width
1237  * [23:18] | ??? | 0x0 | *UNDEFINED*
1238  * [28:24] | RW | 0x0 | Dummy Write Clock Cycles
1239  * [31:29] | ??? | 0x0 | *UNDEFINED*
1240  *
1241  */
1242 /*
1243  * Field : Write Opcode - wropcode
1244  *
1245  * Write Opcode
1246  *
1247  * Field Access Macros:
1248  *
1249  */
1250 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVWR_WROPCODE register field. */
1251 #define ALT_QSPI_DEVWR_WROPCODE_LSB 0
1252 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVWR_WROPCODE register field. */
1253 #define ALT_QSPI_DEVWR_WROPCODE_MSB 7
1254 /* The width in bits of the ALT_QSPI_DEVWR_WROPCODE register field. */
1255 #define ALT_QSPI_DEVWR_WROPCODE_WIDTH 8
1256 /* The mask used to set the ALT_QSPI_DEVWR_WROPCODE register field value. */
1257 #define ALT_QSPI_DEVWR_WROPCODE_SET_MSK 0x000000ff
1258 /* The mask used to clear the ALT_QSPI_DEVWR_WROPCODE register field value. */
1259 #define ALT_QSPI_DEVWR_WROPCODE_CLR_MSK 0xffffff00
1260 /* The reset value of the ALT_QSPI_DEVWR_WROPCODE register field. */
1261 #define ALT_QSPI_DEVWR_WROPCODE_RESET 0x2
1262 /* Extracts the ALT_QSPI_DEVWR_WROPCODE field value from a register. */
1263 #define ALT_QSPI_DEVWR_WROPCODE_GET(value) (((value) & 0x000000ff) >> 0)
1264 /* Produces a ALT_QSPI_DEVWR_WROPCODE register field value suitable for setting the register. */
1265 #define ALT_QSPI_DEVWR_WROPCODE_SET(value) (((value) << 0) & 0x000000ff)
1266
1267 /*
1268  * Field : Address Transfer Width - addrwidth
1269  *
1270  * Sets write address transfer width (1, 2, or 4 bits).
1271  *
1272  * Field Enumeration Values:
1273  *
1274  * Enum | Value | Description
1275  * :----------------------------------|:------|:-------------------------------------------------
1276  * ALT_QSPI_DEVWR_ADDRWIDTH_E_SINGLE | 0x0 | Write address transferred on DQ0. Supported by
1277  * : | | all SPI flash devices
1278  * ALT_QSPI_DEVWR_ADDRWIDTH_E_DUAL | 0x1 | Read address transferred on DQ0 and DQ1.
1279  * : | | Supported by some SPI flash devices that support
1280  * : | | the Extended SPI Protocol and by all SPI flash
1281  * : | | devices that support the Dual SP (DIO-SPI)
1282  * : | | Protocol.
1283  * ALT_QSPI_DEVWR_ADDRWIDTH_E_QUAD | 0x2 | Read address transferred on DQ0, DQ1, DQ2, and
1284  * : | | DQ3. Supported by some SPI flash devices that
1285  * : | | support the Extended SPI Protocol and by all SPI
1286  * : | | flash devices that support the Quad SP (QIO-SPI)
1287  * : | | Protocol.
1288  *
1289  * Field Access Macros:
1290  *
1291  */
1292 /*
1293  * Enumerated value for register field ALT_QSPI_DEVWR_ADDRWIDTH
1294  *
1295  * Write address transferred on DQ0. Supported by all SPI flash devices
1296  */
1297 #define ALT_QSPI_DEVWR_ADDRWIDTH_E_SINGLE 0x0
1298 /*
1299  * Enumerated value for register field ALT_QSPI_DEVWR_ADDRWIDTH
1300  *
1301  * Read address transferred on DQ0 and DQ1. Supported by some SPI flash devices
1302  * that support the Extended SPI Protocol and by all SPI flash devices that support
1303  * the Dual SP (DIO-SPI) Protocol.
1304  */
1305 #define ALT_QSPI_DEVWR_ADDRWIDTH_E_DUAL 0x1
1306 /*
1307  * Enumerated value for register field ALT_QSPI_DEVWR_ADDRWIDTH
1308  *
1309  * Read address transferred on DQ0, DQ1, DQ2, and DQ3. Supported by some SPI flash
1310  * devices that support the Extended SPI Protocol and by all SPI flash devices that
1311  * support the Quad SP (QIO-SPI) Protocol.
1312  */
1313 #define ALT_QSPI_DEVWR_ADDRWIDTH_E_QUAD 0x2
1314
1315 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVWR_ADDRWIDTH register field. */
1316 #define ALT_QSPI_DEVWR_ADDRWIDTH_LSB 12
1317 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVWR_ADDRWIDTH register field. */
1318 #define ALT_QSPI_DEVWR_ADDRWIDTH_MSB 13
1319 /* The width in bits of the ALT_QSPI_DEVWR_ADDRWIDTH register field. */
1320 #define ALT_QSPI_DEVWR_ADDRWIDTH_WIDTH 2
1321 /* The mask used to set the ALT_QSPI_DEVWR_ADDRWIDTH register field value. */
1322 #define ALT_QSPI_DEVWR_ADDRWIDTH_SET_MSK 0x00003000
1323 /* The mask used to clear the ALT_QSPI_DEVWR_ADDRWIDTH register field value. */
1324 #define ALT_QSPI_DEVWR_ADDRWIDTH_CLR_MSK 0xffffcfff
1325 /* The reset value of the ALT_QSPI_DEVWR_ADDRWIDTH register field. */
1326 #define ALT_QSPI_DEVWR_ADDRWIDTH_RESET 0x0
1327 /* Extracts the ALT_QSPI_DEVWR_ADDRWIDTH field value from a register. */
1328 #define ALT_QSPI_DEVWR_ADDRWIDTH_GET(value) (((value) & 0x00003000) >> 12)
1329 /* Produces a ALT_QSPI_DEVWR_ADDRWIDTH register field value suitable for setting the register. */
1330 #define ALT_QSPI_DEVWR_ADDRWIDTH_SET(value) (((value) << 12) & 0x00003000)
1331
1332 /*
1333  * Field : Data Transfer Width - datawidth
1334  *
1335  * Sets write data transfer width (1, 2, or 4 bits).
1336  *
1337  * Field Enumeration Values:
1338  *
1339  * Enum | Value | Description
1340  * :----------------------------------|:------|:-------------------------------------------------
1341  * ALT_QSPI_DEVWR_DATAWIDTH_E_SINGLE | 0x0 | Write data transferred on DQ0. Supported by all
1342  * : | | SPI flash devices
1343  * ALT_QSPI_DEVWR_DATAWIDTH_E_DUAL | 0x1 | Read data transferred on DQ0 and DQ1. Supported
1344  * : | | by some SPI flash devices that support the
1345  * : | | Extended SPI Protocol and by all SPI flash
1346  * : | | devices that support the Dual SP (DIO-SPI)
1347  * : | | Protocol.
1348  * ALT_QSPI_DEVWR_DATAWIDTH_E_QUAD | 0x2 | Read data transferred on DQ0, DQ1, DQ2, and DQ3.
1349  * : | | Supported by some SPI flash devices that support
1350  * : | | the Extended SPI Protocol and by all SPI flash
1351  * : | | devices that support the Quad SP (QIO-SPI)
1352  * : | | Protocol.
1353  *
1354  * Field Access Macros:
1355  *
1356  */
1357 /*
1358  * Enumerated value for register field ALT_QSPI_DEVWR_DATAWIDTH
1359  *
1360  * Write data transferred on DQ0. Supported by all SPI flash devices
1361  */
1362 #define ALT_QSPI_DEVWR_DATAWIDTH_E_SINGLE 0x0
1363 /*
1364  * Enumerated value for register field ALT_QSPI_DEVWR_DATAWIDTH
1365  *
1366  * Read data transferred on DQ0 and DQ1. Supported by some SPI flash devices that
1367  * support the Extended SPI Protocol and by all SPI flash devices that support the
1368  * Dual SP (DIO-SPI) Protocol.
1369  */
1370 #define ALT_QSPI_DEVWR_DATAWIDTH_E_DUAL 0x1
1371 /*
1372  * Enumerated value for register field ALT_QSPI_DEVWR_DATAWIDTH
1373  *
1374  * Read data transferred on DQ0, DQ1, DQ2, and DQ3. Supported by some SPI flash
1375  * devices that support the Extended SPI Protocol and by all SPI flash devices that
1376  * support the Quad SP (QIO-SPI) Protocol.
1377  */
1378 #define ALT_QSPI_DEVWR_DATAWIDTH_E_QUAD 0x2
1379
1380 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVWR_DATAWIDTH register field. */
1381 #define ALT_QSPI_DEVWR_DATAWIDTH_LSB 16
1382 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVWR_DATAWIDTH register field. */
1383 #define ALT_QSPI_DEVWR_DATAWIDTH_MSB 17
1384 /* The width in bits of the ALT_QSPI_DEVWR_DATAWIDTH register field. */
1385 #define ALT_QSPI_DEVWR_DATAWIDTH_WIDTH 2
1386 /* The mask used to set the ALT_QSPI_DEVWR_DATAWIDTH register field value. */
1387 #define ALT_QSPI_DEVWR_DATAWIDTH_SET_MSK 0x00030000
1388 /* The mask used to clear the ALT_QSPI_DEVWR_DATAWIDTH register field value. */
1389 #define ALT_QSPI_DEVWR_DATAWIDTH_CLR_MSK 0xfffcffff
1390 /* The reset value of the ALT_QSPI_DEVWR_DATAWIDTH register field. */
1391 #define ALT_QSPI_DEVWR_DATAWIDTH_RESET 0x0
1392 /* Extracts the ALT_QSPI_DEVWR_DATAWIDTH field value from a register. */
1393 #define ALT_QSPI_DEVWR_DATAWIDTH_GET(value) (((value) & 0x00030000) >> 16)
1394 /* Produces a ALT_QSPI_DEVWR_DATAWIDTH register field value suitable for setting the register. */
1395 #define ALT_QSPI_DEVWR_DATAWIDTH_SET(value) (((value) << 16) & 0x00030000)
1396
1397 /*
1398  * Field : Dummy Write Clock Cycles - dummywrclks
1399  *
1400  * Number of dummy clock cycles required by device for write instruction.
1401  *
1402  * Field Access Macros:
1403  *
1404  */
1405 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVWR_DUMMYWRCLKS register field. */
1406 #define ALT_QSPI_DEVWR_DUMMYWRCLKS_LSB 24
1407 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVWR_DUMMYWRCLKS register field. */
1408 #define ALT_QSPI_DEVWR_DUMMYWRCLKS_MSB 28
1409 /* The width in bits of the ALT_QSPI_DEVWR_DUMMYWRCLKS register field. */
1410 #define ALT_QSPI_DEVWR_DUMMYWRCLKS_WIDTH 5
1411 /* The mask used to set the ALT_QSPI_DEVWR_DUMMYWRCLKS register field value. */
1412 #define ALT_QSPI_DEVWR_DUMMYWRCLKS_SET_MSK 0x1f000000
1413 /* The mask used to clear the ALT_QSPI_DEVWR_DUMMYWRCLKS register field value. */
1414 #define ALT_QSPI_DEVWR_DUMMYWRCLKS_CLR_MSK 0xe0ffffff
1415 /* The reset value of the ALT_QSPI_DEVWR_DUMMYWRCLKS register field. */
1416 #define ALT_QSPI_DEVWR_DUMMYWRCLKS_RESET 0x0
1417 /* Extracts the ALT_QSPI_DEVWR_DUMMYWRCLKS field value from a register. */
1418 #define ALT_QSPI_DEVWR_DUMMYWRCLKS_GET(value) (((value) & 0x1f000000) >> 24)
1419 /* Produces a ALT_QSPI_DEVWR_DUMMYWRCLKS register field value suitable for setting the register. */
1420 #define ALT_QSPI_DEVWR_DUMMYWRCLKS_SET(value) (((value) << 24) & 0x1f000000)
1421
1422 #ifndef __ASSEMBLY__
1423 /*
1424  * WARNING: The C register and register group struct declarations are provided for
1425  * convenience and illustrative purposes. They should, however, be used with
1426  * caution as the C language standard provides no guarantees about the alignment or
1427  * atomicity of device memory accesses. The recommended practice for writing
1428  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1429  * alt_write_word() functions.
1430  *
1431  * The struct declaration for register ALT_QSPI_DEVWR.
1432  */
1434 {
1435  uint32_t wropcode : 8; /* Write Opcode */
1436  uint32_t : 4; /* *UNDEFINED* */
1437  uint32_t addrwidth : 2; /* Address Transfer Width */
1438  uint32_t : 2; /* *UNDEFINED* */
1439  uint32_t datawidth : 2; /* Data Transfer Width */
1440  uint32_t : 6; /* *UNDEFINED* */
1441  uint32_t dummywrclks : 5; /* Dummy Write Clock Cycles */
1442  uint32_t : 3; /* *UNDEFINED* */
1443 };
1444
1445 /* The typedef declaration for register ALT_QSPI_DEVWR. */
1446 typedef volatile struct ALT_QSPI_DEVWR_s ALT_QSPI_DEVWR_t;
1447 #endif /* __ASSEMBLY__ */
1448
1449 /* The byte offset of the ALT_QSPI_DEVWR register from the beginning of the component. */
1450 #define ALT_QSPI_DEVWR_OFST 0x8
1451
1452 /*
1453  * Register : QSPI Device Delay Register - delay
1454  *
1455  * This register is used to introduce relative delays into the generation of the
1456  * master output signals. All timings are defined in cycles of the qspi_clk.
1457  *
1458  * Register Layout
1459  *
1460  * Bits | Access | Reset | Description
1461  * :--------|:-------|:------|:-----------------------------------------
1462  * [7:0] | RW | 0x0 | Clock Delay with qspi_n_ss_out
1463  * [15:8] | RW | 0x0 | Clock Delay for Last Transaction Bit
1464  * [23:16] | RW | 0x0 | Clock Delay for Chip Select Deactivation
1465  * [31:24] | RW | 0x0 | Clock Delay for Chip Select Deassert
1466  *
1467  */
1468 /*
1469  * Field : Clock Delay with qspi_n_ss_out - init
1470  *
1471  * Delay in master reference clocks between setting qspi_n_ss_out low and first bit
1472  * transfer.
1473  *
1474  * Field Access Macros:
1475  *
1476  */
1477 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DELAY_INIT register field. */
1478 #define ALT_QSPI_DELAY_INIT_LSB 0
1479 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DELAY_INIT register field. */
1480 #define ALT_QSPI_DELAY_INIT_MSB 7
1481 /* The width in bits of the ALT_QSPI_DELAY_INIT register field. */
1482 #define ALT_QSPI_DELAY_INIT_WIDTH 8
1483 /* The mask used to set the ALT_QSPI_DELAY_INIT register field value. */
1484 #define ALT_QSPI_DELAY_INIT_SET_MSK 0x000000ff
1485 /* The mask used to clear the ALT_QSPI_DELAY_INIT register field value. */
1486 #define ALT_QSPI_DELAY_INIT_CLR_MSK 0xffffff00
1487 /* The reset value of the ALT_QSPI_DELAY_INIT register field. */
1488 #define ALT_QSPI_DELAY_INIT_RESET 0x0
1489 /* Extracts the ALT_QSPI_DELAY_INIT field value from a register. */
1490 #define ALT_QSPI_DELAY_INIT_GET(value) (((value) & 0x000000ff) >> 0)
1491 /* Produces a ALT_QSPI_DELAY_INIT register field value suitable for setting the register. */
1492 #define ALT_QSPI_DELAY_INIT_SET(value) (((value) << 0) & 0x000000ff)
1493
1494 /*
1495  * Field : Clock Delay for Last Transaction Bit - after
1496  *
1497  * Delay in master reference clocks between last bit of current transaction and
1498  * deasserting the device chip select (qspi_n_ss_out). By default, the chip select
1499  * will be deasserted on the cycle following the completion of the current
1500  * transaction.
1501  *
1502  * Field Access Macros:
1503  *
1504  */
1505 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DELAY_AFTER register field. */
1506 #define ALT_QSPI_DELAY_AFTER_LSB 8
1507 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DELAY_AFTER register field. */
1508 #define ALT_QSPI_DELAY_AFTER_MSB 15
1509 /* The width in bits of the ALT_QSPI_DELAY_AFTER register field. */
1510 #define ALT_QSPI_DELAY_AFTER_WIDTH 8
1511 /* The mask used to set the ALT_QSPI_DELAY_AFTER register field value. */
1512 #define ALT_QSPI_DELAY_AFTER_SET_MSK 0x0000ff00
1513 /* The mask used to clear the ALT_QSPI_DELAY_AFTER register field value. */
1514 #define ALT_QSPI_DELAY_AFTER_CLR_MSK 0xffff00ff
1515 /* The reset value of the ALT_QSPI_DELAY_AFTER register field. */
1516 #define ALT_QSPI_DELAY_AFTER_RESET 0x0
1517 /* Extracts the ALT_QSPI_DELAY_AFTER field value from a register. */
1518 #define ALT_QSPI_DELAY_AFTER_GET(value) (((value) & 0x0000ff00) >> 8)
1519 /* Produces a ALT_QSPI_DELAY_AFTER register field value suitable for setting the register. */
1520 #define ALT_QSPI_DELAY_AFTER_SET(value) (((value) << 8) & 0x0000ff00)
1521
1522 /*
1523  * Field : Clock Delay for Chip Select Deactivation - btwn
1524  *
1525  * Delay in master reference clocks between one chip select being de-activated and
1526  * the activation of another. This is used to ensure a quiet period between the
1527  * selection of two different slaves and requires the transmit FIFO to be empty.
1528  *
1529  * Field Access Macros:
1530  *
1531  */
1532 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DELAY_BTWN register field. */
1533 #define ALT_QSPI_DELAY_BTWN_LSB 16
1534 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DELAY_BTWN register field. */
1535 #define ALT_QSPI_DELAY_BTWN_MSB 23
1536 /* The width in bits of the ALT_QSPI_DELAY_BTWN register field. */
1537 #define ALT_QSPI_DELAY_BTWN_WIDTH 8
1538 /* The mask used to set the ALT_QSPI_DELAY_BTWN register field value. */
1539 #define ALT_QSPI_DELAY_BTWN_SET_MSK 0x00ff0000
1540 /* The mask used to clear the ALT_QSPI_DELAY_BTWN register field value. */
1541 #define ALT_QSPI_DELAY_BTWN_CLR_MSK 0xff00ffff
1542 /* The reset value of the ALT_QSPI_DELAY_BTWN register field. */
1543 #define ALT_QSPI_DELAY_BTWN_RESET 0x0
1544 /* Extracts the ALT_QSPI_DELAY_BTWN field value from a register. */
1545 #define ALT_QSPI_DELAY_BTWN_GET(value) (((value) & 0x00ff0000) >> 16)
1546 /* Produces a ALT_QSPI_DELAY_BTWN register field value suitable for setting the register. */
1547 #define ALT_QSPI_DELAY_BTWN_SET(value) (((value) << 16) & 0x00ff0000)
1548
1549 /*
1550  * Field : Clock Delay for Chip Select Deassert - nss
1551  *
1552  * Delay in master reference clocks for the length that the master mode chip select
1553  * outputs are de-asserted between transactions. The minimum delay is always
1554  * qspi_sck_out period to ensure the chip select is never re-asserted within an
1555  * qspi_sck_out period.
1556  *
1557  * Field Access Macros:
1558  *
1559  */
1560 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DELAY_NSS register field. */
1561 #define ALT_QSPI_DELAY_NSS_LSB 24
1562 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DELAY_NSS register field. */
1563 #define ALT_QSPI_DELAY_NSS_MSB 31
1564 /* The width in bits of the ALT_QSPI_DELAY_NSS register field. */
1565 #define ALT_QSPI_DELAY_NSS_WIDTH 8
1566 /* The mask used to set the ALT_QSPI_DELAY_NSS register field value. */
1567 #define ALT_QSPI_DELAY_NSS_SET_MSK 0xff000000
1568 /* The mask used to clear the ALT_QSPI_DELAY_NSS register field value. */
1569 #define ALT_QSPI_DELAY_NSS_CLR_MSK 0x00ffffff
1570 /* The reset value of the ALT_QSPI_DELAY_NSS register field. */
1571 #define ALT_QSPI_DELAY_NSS_RESET 0x0
1572 /* Extracts the ALT_QSPI_DELAY_NSS field value from a register. */
1573 #define ALT_QSPI_DELAY_NSS_GET(value) (((value) & 0xff000000) >> 24)
1574 /* Produces a ALT_QSPI_DELAY_NSS register field value suitable for setting the register. */
1575 #define ALT_QSPI_DELAY_NSS_SET(value) (((value) << 24) & 0xff000000)
1576
1577 #ifndef __ASSEMBLY__
1578 /*
1579  * WARNING: The C register and register group struct declarations are provided for
1580  * convenience and illustrative purposes. They should, however, be used with
1581  * caution as the C language standard provides no guarantees about the alignment or
1582  * atomicity of device memory accesses. The recommended practice for writing
1583  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1584  * alt_write_word() functions.
1585  *
1586  * The struct declaration for register ALT_QSPI_DELAY.
1587  */
1589 {
1590  uint32_t init : 8; /* Clock Delay with qspi_n_ss_out */
1591  uint32_t after : 8; /* Clock Delay for Last Transaction Bit */
1592  uint32_t btwn : 8; /* Clock Delay for Chip Select Deactivation */
1593  uint32_t nss : 8; /* Clock Delay for Chip Select Deassert */
1594 };
1595
1596 /* The typedef declaration for register ALT_QSPI_DELAY. */
1597 typedef volatile struct ALT_QSPI_DELAY_s ALT_QSPI_DELAY_t;
1598 #endif /* __ASSEMBLY__ */
1599
1600 /* The byte offset of the ALT_QSPI_DELAY register from the beginning of the component. */
1601 #define ALT_QSPI_DELAY_OFST 0xc
1602
1603 /*
1604  * Register : Read Data Capture Register - rddatacap
1605  *
1606  * Register Layout
1607  *
1608  * Bits | Access | Reset | Description
1609  * :-------|:-------|:------|:------------
1610  * [0] | RW | 0x1 | Bypass
1611  * [4:1] | RW | 0x0 | Read Delay
1612  * [31:5] | ??? | 0x0 | *UNDEFINED*
1613  *
1614  */
1615 /*
1616  * Field : Bypass - byp
1617  *
1618  * Controls bypass of the adapted loopback clock circuit
1619  *
1620  * Field Enumeration Values:
1621  *
1622  * Enum | Value | Description
1623  * :----------------------------------|:------|:------------------------------
1624  * ALT_QSPI_RDDATACAP_BYP_E_NOBYPASS | 0x0 | No Bypass
1625  * ALT_QSPI_RDDATACAP_BYP_E_BYPASS | 0x1 | Bypass loopback clock circuit
1626  *
1627  * Field Access Macros:
1628  *
1629  */
1630 /*
1631  * Enumerated value for register field ALT_QSPI_RDDATACAP_BYP
1632  *
1633  * No Bypass
1634  */
1635 #define ALT_QSPI_RDDATACAP_BYP_E_NOBYPASS 0x0
1636 /*
1637  * Enumerated value for register field ALT_QSPI_RDDATACAP_BYP
1638  *
1639  * Bypass loopback clock circuit
1640  */
1641 #define ALT_QSPI_RDDATACAP_BYP_E_BYPASS 0x1
1642
1643 /* The Least Significant Bit (LSB) position of the ALT_QSPI_RDDATACAP_BYP register field. */
1644 #define ALT_QSPI_RDDATACAP_BYP_LSB 0
1645 /* The Most Significant Bit (MSB) position of the ALT_QSPI_RDDATACAP_BYP register field. */
1646 #define ALT_QSPI_RDDATACAP_BYP_MSB 0
1647 /* The width in bits of the ALT_QSPI_RDDATACAP_BYP register field. */
1648 #define ALT_QSPI_RDDATACAP_BYP_WIDTH 1
1649 /* The mask used to set the ALT_QSPI_RDDATACAP_BYP register field value. */
1650 #define ALT_QSPI_RDDATACAP_BYP_SET_MSK 0x00000001
1651 /* The mask used to clear the ALT_QSPI_RDDATACAP_BYP register field value. */
1652 #define ALT_QSPI_RDDATACAP_BYP_CLR_MSK 0xfffffffe
1653 /* The reset value of the ALT_QSPI_RDDATACAP_BYP register field. */
1654 #define ALT_QSPI_RDDATACAP_BYP_RESET 0x1
1655 /* Extracts the ALT_QSPI_RDDATACAP_BYP field value from a register. */
1656 #define ALT_QSPI_RDDATACAP_BYP_GET(value) (((value) & 0x00000001) >> 0)
1657 /* Produces a ALT_QSPI_RDDATACAP_BYP register field value suitable for setting the register. */
1658 #define ALT_QSPI_RDDATACAP_BYP_SET(value) (((value) << 0) & 0x00000001)
1659
1660 /*
1661  * Field : Read Delay - delay
1662  *
1663  * Delay the read data capturing logic by the programmed number of qspi_clk cycles
1664  *
1665  * Field Access Macros:
1666  *
1667  */
1668 /* The Least Significant Bit (LSB) position of the ALT_QSPI_RDDATACAP_DELAY register field. */
1669 #define ALT_QSPI_RDDATACAP_DELAY_LSB 1
1670 /* The Most Significant Bit (MSB) position of the ALT_QSPI_RDDATACAP_DELAY register field. */
1671 #define ALT_QSPI_RDDATACAP_DELAY_MSB 4
1672 /* The width in bits of the ALT_QSPI_RDDATACAP_DELAY register field. */
1673 #define ALT_QSPI_RDDATACAP_DELAY_WIDTH 4
1674 /* The mask used to set the ALT_QSPI_RDDATACAP_DELAY register field value. */
1675 #define ALT_QSPI_RDDATACAP_DELAY_SET_MSK 0x0000001e
1676 /* The mask used to clear the ALT_QSPI_RDDATACAP_DELAY register field value. */
1677 #define ALT_QSPI_RDDATACAP_DELAY_CLR_MSK 0xffffffe1
1678 /* The reset value of the ALT_QSPI_RDDATACAP_DELAY register field. */
1679 #define ALT_QSPI_RDDATACAP_DELAY_RESET 0x0
1680 /* Extracts the ALT_QSPI_RDDATACAP_DELAY field value from a register. */
1681 #define ALT_QSPI_RDDATACAP_DELAY_GET(value) (((value) & 0x0000001e) >> 1)
1682 /* Produces a ALT_QSPI_RDDATACAP_DELAY register field value suitable for setting the register. */
1683 #define ALT_QSPI_RDDATACAP_DELAY_SET(value) (((value) << 1) & 0x0000001e)
1684
1685 #ifndef __ASSEMBLY__
1686 /*
1687  * WARNING: The C register and register group struct declarations are provided for
1688  * convenience and illustrative purposes. They should, however, be used with
1689  * caution as the C language standard provides no guarantees about the alignment or
1690  * atomicity of device memory accesses. The recommended practice for writing
1691  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1692  * alt_write_word() functions.
1693  *
1694  * The struct declaration for register ALT_QSPI_RDDATACAP.
1695  */
1697 {
1698  uint32_t byp : 1; /* Bypass */
1699  uint32_t delay : 4; /* Read Delay */
1700  uint32_t : 27; /* *UNDEFINED* */
1701 };
1702
1703 /* The typedef declaration for register ALT_QSPI_RDDATACAP. */
1704 typedef volatile struct ALT_QSPI_RDDATACAP_s ALT_QSPI_RDDATACAP_t;
1705 #endif /* __ASSEMBLY__ */
1706
1707 /* The byte offset of the ALT_QSPI_RDDATACAP register from the beginning of the component. */
1708 #define ALT_QSPI_RDDATACAP_OFST 0x10
1709
1710 /*
1711  * Register : Device Size Register - devsz
1712  *
1713  * Register Layout
1714  *
1715  * Bits | Access | Reset | Description
1716  * :--------|:-------|:------|:--------------------------------
1717  * [3:0] | RW | 0x2 | Number of address Bytes
1718  * [15:4] | RW | 0x100 | Number of Bytes per Device Page
1719  * [20:16] | RW | 0x10 | Number of Bytes per Block
1720  * [31:21] | ??? | 0x0 | *UNDEFINED*
1721  *
1722  */
1723 /*
1724  * Field : Number of address Bytes - numaddrbytes
1725  *
1726  * Number of address bytes. A value of 0 indicates 1 byte.
1727  *
1728  * Field Access Macros:
1729  *
1730  */
1731 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVSZ_NUMADDRBYTES register field. */
1732 #define ALT_QSPI_DEVSZ_NUMADDRBYTES_LSB 0
1733 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVSZ_NUMADDRBYTES register field. */
1734 #define ALT_QSPI_DEVSZ_NUMADDRBYTES_MSB 3
1735 /* The width in bits of the ALT_QSPI_DEVSZ_NUMADDRBYTES register field. */
1736 #define ALT_QSPI_DEVSZ_NUMADDRBYTES_WIDTH 4
1737 /* The mask used to set the ALT_QSPI_DEVSZ_NUMADDRBYTES register field value. */
1738 #define ALT_QSPI_DEVSZ_NUMADDRBYTES_SET_MSK 0x0000000f
1739 /* The mask used to clear the ALT_QSPI_DEVSZ_NUMADDRBYTES register field value. */
1740 #define ALT_QSPI_DEVSZ_NUMADDRBYTES_CLR_MSK 0xfffffff0
1741 /* The reset value of the ALT_QSPI_DEVSZ_NUMADDRBYTES register field. */
1742 #define ALT_QSPI_DEVSZ_NUMADDRBYTES_RESET 0x2
1743 /* Extracts the ALT_QSPI_DEVSZ_NUMADDRBYTES field value from a register. */
1744 #define ALT_QSPI_DEVSZ_NUMADDRBYTES_GET(value) (((value) & 0x0000000f) >> 0)
1745 /* Produces a ALT_QSPI_DEVSZ_NUMADDRBYTES register field value suitable for setting the register. */
1746 #define ALT_QSPI_DEVSZ_NUMADDRBYTES_SET(value) (((value) << 0) & 0x0000000f)
1747
1748 /*
1749  * Field : Number of Bytes per Device Page - bytesperdevicepage
1750  *
1751  * Number of bytes per device page. This is required by the controller for
1752  * performing FLASH writes up to and across page boundaries.
1753  *
1754  * Field Access Macros:
1755  *
1756  */
1757 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE register field. */
1758 #define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_LSB 4
1759 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE register field. */
1760 #define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_MSB 15
1761 /* The width in bits of the ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE register field. */
1762 #define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_WIDTH 12
1763 /* The mask used to set the ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE register field value. */
1764 #define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_SET_MSK 0x0000fff0
1765 /* The mask used to clear the ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE register field value. */
1766 #define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_CLR_MSK 0xffff000f
1767 /* The reset value of the ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE register field. */
1768 #define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_RESET 0x100
1769 /* Extracts the ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE field value from a register. */
1770 #define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_GET(value) (((value) & 0x0000fff0) >> 4)
1771 /* Produces a ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE register field value suitable for setting the register. */
1772 #define ALT_QSPI_DEVSZ_BYTESPERDEVICEPAGE_SET(value) (((value) << 4) & 0x0000fff0)
1773
1774 /*
1775  * Field : Number of Bytes per Block - bytespersubsector
1776  *
1777  * Number of bytes per Block. This is required by the controller for performing the
1778  * write protection logic. The number of bytes per block must be a power of 2
1779  * number.
1780  *
1781  * Field Access Macros:
1782  *
1783  */
1784 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR register field. */
1785 #define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_LSB 16
1786 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR register field. */
1787 #define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_MSB 20
1788 /* The width in bits of the ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR register field. */
1789 #define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_WIDTH 5
1790 /* The mask used to set the ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR register field value. */
1791 #define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_SET_MSK 0x001f0000
1792 /* The mask used to clear the ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR register field value. */
1793 #define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_CLR_MSK 0xffe0ffff
1794 /* The reset value of the ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR register field. */
1795 #define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_RESET 0x10
1796 /* Extracts the ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR field value from a register. */
1797 #define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_GET(value) (((value) & 0x001f0000) >> 16)
1798 /* Produces a ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR register field value suitable for setting the register. */
1799 #define ALT_QSPI_DEVSZ_BYTESPERSUBSECTOR_SET(value) (((value) << 16) & 0x001f0000)
1800
1801 #ifndef __ASSEMBLY__
1802 /*
1803  * WARNING: The C register and register group struct declarations are provided for
1804  * convenience and illustrative purposes. They should, however, be used with
1805  * caution as the C language standard provides no guarantees about the alignment or
1806  * atomicity of device memory accesses. The recommended practice for writing
1807  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1808  * alt_write_word() functions.
1809  *
1810  * The struct declaration for register ALT_QSPI_DEVSZ.
1811  */
1813 {
1814  uint32_t numaddrbytes : 4; /* Number of address Bytes */
1815  uint32_t bytesperdevicepage : 12; /* Number of Bytes per Device Page */
1816  uint32_t bytespersubsector : 5; /* Number of Bytes per Block */
1817  uint32_t : 11; /* *UNDEFINED* */
1818 };
1819
1820 /* The typedef declaration for register ALT_QSPI_DEVSZ. */
1821 typedef volatile struct ALT_QSPI_DEVSZ_s ALT_QSPI_DEVSZ_t;
1822 #endif /* __ASSEMBLY__ */
1823
1824 /* The byte offset of the ALT_QSPI_DEVSZ register from the beginning of the component. */
1825 #define ALT_QSPI_DEVSZ_OFST 0x14
1826
1827 /*
1828  * Register : SRAM Partition Register - srampart
1829  *
1830  * Register Layout
1831  *
1832  * Bits | Access | Reset | Description
1833  * :-------|:-------|:------|:-----------------------------
1834  * [6:0] | RW | 0x40 | Indirect Read Partition Size
1835  * [31:7] | ??? | 0x0 | *UNDEFINED*
1836  *
1837  */
1838 /*
1839  * Field : Indirect Read Partition Size - addr
1840  *
1841  * Defines the size of the indirect read partition in the SRAM, in units of SRAM
1842  * locations. By default, half of the SRAM is reserved for indirect read operations
1843  * and half for indirect write operations.
1844  *
1845  * Field Access Macros:
1846  *
1847  */
1848 /* The Least Significant Bit (LSB) position of the ALT_QSPI_SRAMPART_ADDR register field. */
1849 #define ALT_QSPI_SRAMPART_ADDR_LSB 0
1850 /* The Most Significant Bit (MSB) position of the ALT_QSPI_SRAMPART_ADDR register field. */
1851 #define ALT_QSPI_SRAMPART_ADDR_MSB 6
1852 /* The width in bits of the ALT_QSPI_SRAMPART_ADDR register field. */
1853 #define ALT_QSPI_SRAMPART_ADDR_WIDTH 7
1854 /* The mask used to set the ALT_QSPI_SRAMPART_ADDR register field value. */
1855 #define ALT_QSPI_SRAMPART_ADDR_SET_MSK 0x0000007f
1856 /* The mask used to clear the ALT_QSPI_SRAMPART_ADDR register field value. */
1857 #define ALT_QSPI_SRAMPART_ADDR_CLR_MSK 0xffffff80
1858 /* The reset value of the ALT_QSPI_SRAMPART_ADDR register field. */
1859 #define ALT_QSPI_SRAMPART_ADDR_RESET 0x40
1860 /* Extracts the ALT_QSPI_SRAMPART_ADDR field value from a register. */
1861 #define ALT_QSPI_SRAMPART_ADDR_GET(value) (((value) & 0x0000007f) >> 0)
1862 /* Produces a ALT_QSPI_SRAMPART_ADDR register field value suitable for setting the register. */
1863 #define ALT_QSPI_SRAMPART_ADDR_SET(value) (((value) << 0) & 0x0000007f)
1864
1865 #ifndef __ASSEMBLY__
1866 /*
1867  * WARNING: The C register and register group struct declarations are provided for
1868  * convenience and illustrative purposes. They should, however, be used with
1869  * caution as the C language standard provides no guarantees about the alignment or
1870  * atomicity of device memory accesses. The recommended practice for writing
1871  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1872  * alt_write_word() functions.
1873  *
1874  * The struct declaration for register ALT_QSPI_SRAMPART.
1875  */
1877 {
1878  uint32_t addr : 7; /* Indirect Read Partition Size */
1879  uint32_t : 25; /* *UNDEFINED* */
1880 };
1881
1882 /* The typedef declaration for register ALT_QSPI_SRAMPART. */
1883 typedef volatile struct ALT_QSPI_SRAMPART_s ALT_QSPI_SRAMPART_t;
1884 #endif /* __ASSEMBLY__ */
1885
1886 /* The byte offset of the ALT_QSPI_SRAMPART register from the beginning of the component. */
1887 #define ALT_QSPI_SRAMPART_OFST 0x18
1888
1889 /*
1890  * Register : Indirect AHB Address Trigger Register - indaddrtrig
1891  *
1892  * Register Layout
1893  *
1894  * Bits | Access | Reset | Description
1895  * :-------|:-------|:------|:----------------
1896  * [31:0] | RW | 0x0 | Trigger Address
1897  *
1898  */
1899 /*
1900  * Field : Trigger Address - addr
1901  *
1902  * This is the base address that will be used by the AHB controller. When the
1903  * incoming AHB read access address matches a range of addresses from this trigger
1904  * address to the trigger address + 15, then the AHB request will be completed by
1905  * fetching data from the Indirect Controllers SRAM.
1906  *
1907  * Field Access Macros:
1908  *
1909  */
1910 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDADDRTRIG_ADDR register field. */
1911 #define ALT_QSPI_INDADDRTRIG_ADDR_LSB 0
1912 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDADDRTRIG_ADDR register field. */
1913 #define ALT_QSPI_INDADDRTRIG_ADDR_MSB 31
1914 /* The width in bits of the ALT_QSPI_INDADDRTRIG_ADDR register field. */
1915 #define ALT_QSPI_INDADDRTRIG_ADDR_WIDTH 32
1916 /* The mask used to set the ALT_QSPI_INDADDRTRIG_ADDR register field value. */
1917 #define ALT_QSPI_INDADDRTRIG_ADDR_SET_MSK 0xffffffff
1918 /* The mask used to clear the ALT_QSPI_INDADDRTRIG_ADDR register field value. */
1919 #define ALT_QSPI_INDADDRTRIG_ADDR_CLR_MSK 0x00000000
1920 /* The reset value of the ALT_QSPI_INDADDRTRIG_ADDR register field. */
1921 #define ALT_QSPI_INDADDRTRIG_ADDR_RESET 0x0
1922 /* Extracts the ALT_QSPI_INDADDRTRIG_ADDR field value from a register. */
1923 #define ALT_QSPI_INDADDRTRIG_ADDR_GET(value) (((value) & 0xffffffff) >> 0)
1924 /* Produces a ALT_QSPI_INDADDRTRIG_ADDR register field value suitable for setting the register. */
1925 #define ALT_QSPI_INDADDRTRIG_ADDR_SET(value) (((value) << 0) & 0xffffffff)
1926
1927 #ifndef __ASSEMBLY__
1928 /*
1929  * WARNING: The C register and register group struct declarations are provided for
1930  * convenience and illustrative purposes. They should, however, be used with
1931  * caution as the C language standard provides no guarantees about the alignment or
1932  * atomicity of device memory accesses. The recommended practice for writing
1933  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1934  * alt_write_word() functions.
1935  *
1936  * The struct declaration for register ALT_QSPI_INDADDRTRIG.
1937  */
1939 {
1940  uint32_t addr : 32; /* Trigger Address */
1941 };
1942
1943 /* The typedef declaration for register ALT_QSPI_INDADDRTRIG. */
1944 typedef volatile struct ALT_QSPI_INDADDRTRIG_s ALT_QSPI_INDADDRTRIG_t;
1945 #endif /* __ASSEMBLY__ */
1946
1947 /* The byte offset of the ALT_QSPI_INDADDRTRIG register from the beginning of the component. */
1948 #define ALT_QSPI_INDADDRTRIG_OFST 0x1c
1949
1950 /*
1951  * Register : DMA Peripheral Register - dmaper
1952  *
1953  * Register Layout
1954  *
1955  * Bits | Access | Reset | Description
1956  * :--------|:-------|:------|:-----------------------
1957  * [3:0] | RW | 0x0 | Number of Single Bytes
1958  * [7:4] | ??? | 0x0 | *UNDEFINED*
1959  * [11:8] | RW | 0x0 | Number of Burst Bytes
1960  * [31:12] | ??? | 0x0 | *UNDEFINED*
1961  *
1962  */
1963 /*
1964  * Field : Number of Single Bytes - numsglreqbytes
1965  *
1966  * Number of bytes in a single type request on the DMA peripheral request. A
1967  * programmed value of 0 represents a single byte. This should be setup before
1968  * starting the indirect read or write operation. The actual number of bytes used
1969  * is 2**(value in this register) which will simplify implementation.
1970  *
1971  * Field Access Macros:
1972  *
1973  */
1974 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DMAPER_NUMSGLREQBYTES register field. */
1975 #define ALT_QSPI_DMAPER_NUMSGLREQBYTES_LSB 0
1976 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DMAPER_NUMSGLREQBYTES register field. */
1977 #define ALT_QSPI_DMAPER_NUMSGLREQBYTES_MSB 3
1978 /* The width in bits of the ALT_QSPI_DMAPER_NUMSGLREQBYTES register field. */
1979 #define ALT_QSPI_DMAPER_NUMSGLREQBYTES_WIDTH 4
1980 /* The mask used to set the ALT_QSPI_DMAPER_NUMSGLREQBYTES register field value. */
1981 #define ALT_QSPI_DMAPER_NUMSGLREQBYTES_SET_MSK 0x0000000f
1982 /* The mask used to clear the ALT_QSPI_DMAPER_NUMSGLREQBYTES register field value. */
1983 #define ALT_QSPI_DMAPER_NUMSGLREQBYTES_CLR_MSK 0xfffffff0
1984 /* The reset value of the ALT_QSPI_DMAPER_NUMSGLREQBYTES register field. */
1985 #define ALT_QSPI_DMAPER_NUMSGLREQBYTES_RESET 0x0
1986 /* Extracts the ALT_QSPI_DMAPER_NUMSGLREQBYTES field value from a register. */
1987 #define ALT_QSPI_DMAPER_NUMSGLREQBYTES_GET(value) (((value) & 0x0000000f) >> 0)
1988 /* Produces a ALT_QSPI_DMAPER_NUMSGLREQBYTES register field value suitable for setting the register. */
1989 #define ALT_QSPI_DMAPER_NUMSGLREQBYTES_SET(value) (((value) << 0) & 0x0000000f)
1990
1991 /*
1992  * Field : Number of Burst Bytes - numburstreqbytes
1993  *
1994  * Number of bytes in a burst type request on the DMA peripheral request. A
1995  * programmed value of 0 represents a single byte. This should be setup before
1996  * starting the indirect read or write operation. The actual number of bytes used
1997  * is 2**(value in this register) which will simplify implementation.
1998  *
1999  * Field Access Macros:
2000  *
2001  */
2002 /* The Least Significant Bit (LSB) position of the ALT_QSPI_DMAPER_NUMBURSTREQBYTES register field. */
2003 #define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_LSB 8
2004 /* The Most Significant Bit (MSB) position of the ALT_QSPI_DMAPER_NUMBURSTREQBYTES register field. */
2005 #define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_MSB 11
2006 /* The width in bits of the ALT_QSPI_DMAPER_NUMBURSTREQBYTES register field. */
2007 #define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_WIDTH 4
2008 /* The mask used to set the ALT_QSPI_DMAPER_NUMBURSTREQBYTES register field value. */
2009 #define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_SET_MSK 0x00000f00
2010 /* The mask used to clear the ALT_QSPI_DMAPER_NUMBURSTREQBYTES register field value. */
2011 #define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_CLR_MSK 0xfffff0ff
2012 /* The reset value of the ALT_QSPI_DMAPER_NUMBURSTREQBYTES register field. */
2013 #define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_RESET 0x0
2014 /* Extracts the ALT_QSPI_DMAPER_NUMBURSTREQBYTES field value from a register. */
2015 #define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_GET(value) (((value) & 0x00000f00) >> 8)
2016 /* Produces a ALT_QSPI_DMAPER_NUMBURSTREQBYTES register field value suitable for setting the register. */
2017 #define ALT_QSPI_DMAPER_NUMBURSTREQBYTES_SET(value) (((value) << 8) & 0x00000f00)
2018
2019 #ifndef __ASSEMBLY__
2020 /*
2021  * WARNING: The C register and register group struct declarations are provided for
2022  * convenience and illustrative purposes. They should, however, be used with
2023  * caution as the C language standard provides no guarantees about the alignment or
2024  * atomicity of device memory accesses. The recommended practice for writing
2025  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2026  * alt_write_word() functions.
2027  *
2028  * The struct declaration for register ALT_QSPI_DMAPER.
2029  */
2031 {
2032  uint32_t numsglreqbytes : 4; /* Number of Single Bytes */
2033  uint32_t : 4; /* *UNDEFINED* */
2034  uint32_t numburstreqbytes : 4; /* Number of Burst Bytes */
2035  uint32_t : 20; /* *UNDEFINED* */
2036 };
2037
2038 /* The typedef declaration for register ALT_QSPI_DMAPER. */
2039 typedef volatile struct ALT_QSPI_DMAPER_s ALT_QSPI_DMAPER_t;
2040 #endif /* __ASSEMBLY__ */
2041
2042 /* The byte offset of the ALT_QSPI_DMAPER register from the beginning of the component. */
2043 #define ALT_QSPI_DMAPER_OFST 0x20
2044
2045 /*
2046  * Register : Remap Address Register - remapaddr
2047  *
2048  * This register is used to remap an incoming AHB address to a different address
2049  * used by the FLASH device.
2050  *
2051  * Register Layout
2052  *
2053  * Bits | Access | Reset | Description
2054  * :-------|:-------|:------|:---------------------
2055  * [31:0] | RW | 0x0 | Remap Address Offset
2056  *
2057  */
2058 /*
2059  * Field : Remap Address Offset - value
2060  *
2061  * This offset is added to the incoming AHB address to determine the address used
2062  * by the FLASH device.
2063  *
2064  * Field Access Macros:
2065  *
2066  */
2067 /* The Least Significant Bit (LSB) position of the ALT_QSPI_REMAPADDR_VALUE register field. */
2068 #define ALT_QSPI_REMAPADDR_VALUE_LSB 0
2069 /* The Most Significant Bit (MSB) position of the ALT_QSPI_REMAPADDR_VALUE register field. */
2070 #define ALT_QSPI_REMAPADDR_VALUE_MSB 31
2071 /* The width in bits of the ALT_QSPI_REMAPADDR_VALUE register field. */
2072 #define ALT_QSPI_REMAPADDR_VALUE_WIDTH 32
2073 /* The mask used to set the ALT_QSPI_REMAPADDR_VALUE register field value. */
2074 #define ALT_QSPI_REMAPADDR_VALUE_SET_MSK 0xffffffff
2075 /* The mask used to clear the ALT_QSPI_REMAPADDR_VALUE register field value. */
2076 #define ALT_QSPI_REMAPADDR_VALUE_CLR_MSK 0x00000000
2077 /* The reset value of the ALT_QSPI_REMAPADDR_VALUE register field. */
2078 #define ALT_QSPI_REMAPADDR_VALUE_RESET 0x0
2079 /* Extracts the ALT_QSPI_REMAPADDR_VALUE field value from a register. */
2080 #define ALT_QSPI_REMAPADDR_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
2081 /* Produces a ALT_QSPI_REMAPADDR_VALUE register field value suitable for setting the register. */
2082 #define ALT_QSPI_REMAPADDR_VALUE_SET(value) (((value) << 0) & 0xffffffff)
2083
2084 #ifndef __ASSEMBLY__
2085 /*
2086  * WARNING: The C register and register group struct declarations are provided for
2087  * convenience and illustrative purposes. They should, however, be used with
2088  * caution as the C language standard provides no guarantees about the alignment or
2089  * atomicity of device memory accesses. The recommended practice for writing
2090  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2091  * alt_write_word() functions.
2092  *
2093  * The struct declaration for register ALT_QSPI_REMAPADDR.
2094  */
2096 {
2097  uint32_t value : 32; /* Remap Address Offset */
2098 };
2099
2100 /* The typedef declaration for register ALT_QSPI_REMAPADDR. */
2101 typedef volatile struct ALT_QSPI_REMAPADDR_s ALT_QSPI_REMAPADDR_t;
2102 #endif /* __ASSEMBLY__ */
2103
2104 /* The byte offset of the ALT_QSPI_REMAPADDR register from the beginning of the component. */
2105 #define ALT_QSPI_REMAPADDR_OFST 0x24
2106
2107 /*
2108  * Register : Mode Bit Register - modebit
2109  *
2110  * Register Layout
2111  *
2112  * Bits | Access | Reset | Description
2113  * :-------|:-------|:------|:------------
2114  * [7:0] | RW | 0x0 | Mode
2115  * [31:8] | ??? | 0x0 | *UNDEFINED*
2116  *
2117  */
2118 /*
2119  * Field : Mode - mode
2120  *
2121  * These are the 8 mode bits that are sent to the device following the address
2122  * bytes if mode bit transmission has been enabled.
2123  *
2124  * Field Access Macros:
2125  *
2126  */
2127 /* The Least Significant Bit (LSB) position of the ALT_QSPI_MODBIT_MOD register field. */
2128 #define ALT_QSPI_MODBIT_MOD_LSB 0
2129 /* The Most Significant Bit (MSB) position of the ALT_QSPI_MODBIT_MOD register field. */
2130 #define ALT_QSPI_MODBIT_MOD_MSB 7
2131 /* The width in bits of the ALT_QSPI_MODBIT_MOD register field. */
2132 #define ALT_QSPI_MODBIT_MOD_WIDTH 8
2133 /* The mask used to set the ALT_QSPI_MODBIT_MOD register field value. */
2134 #define ALT_QSPI_MODBIT_MOD_SET_MSK 0x000000ff
2135 /* The mask used to clear the ALT_QSPI_MODBIT_MOD register field value. */
2136 #define ALT_QSPI_MODBIT_MOD_CLR_MSK 0xffffff00
2137 /* The reset value of the ALT_QSPI_MODBIT_MOD register field. */
2138 #define ALT_QSPI_MODBIT_MOD_RESET 0x0
2139 /* Extracts the ALT_QSPI_MODBIT_MOD field value from a register. */
2140 #define ALT_QSPI_MODBIT_MOD_GET(value) (((value) & 0x000000ff) >> 0)
2141 /* Produces a ALT_QSPI_MODBIT_MOD register field value suitable for setting the register. */
2142 #define ALT_QSPI_MODBIT_MOD_SET(value) (((value) << 0) & 0x000000ff)
2143
2144 #ifndef __ASSEMBLY__
2145 /*
2146  * WARNING: The C register and register group struct declarations are provided for
2147  * convenience and illustrative purposes. They should, however, be used with
2148  * caution as the C language standard provides no guarantees about the alignment or
2149  * atomicity of device memory accesses. The recommended practice for writing
2150  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2151  * alt_write_word() functions.
2152  *
2153  * The struct declaration for register ALT_QSPI_MODBIT.
2154  */
2156 {
2157  uint32_t mode : 8; /* Mode */
2158  uint32_t : 24; /* *UNDEFINED* */
2159 };
2160
2161 /* The typedef declaration for register ALT_QSPI_MODBIT. */
2162 typedef volatile struct ALT_QSPI_MODBIT_s ALT_QSPI_MODBIT_t;
2163 #endif /* __ASSEMBLY__ */
2164
2165 /* The byte offset of the ALT_QSPI_MODBIT register from the beginning of the component. */
2166 #define ALT_QSPI_MODBIT_OFST 0x28
2167
2168 /*
2169  * Register : SRAM Fill Register - sramfill
2170  *
2171  * Register Layout
2172  *
2173  * Bits | Access | Reset | Description
2174  * :--------|:-------|:------|:-------------------------------------------------------------------
2175  * [15:0] | R | 0x0 | SRAM Fill Level (Indirect Read Partition). In units of SRAM WORDS
2176  * [31:16] | R | 0x0 | SRAM Fill Level (Indirect Write Partition). In units of SRAM WORDS
2177  *
2178  */
2179 /*
2180  * Field : SRAM Fill Level (Indirect Read Partition). In units of SRAM WORDS - indrdpart
2181  *
2182  * Field Access Macros:
2183  *
2184  */
2185 /* The Least Significant Bit (LSB) position of the ALT_QSPI_SRAMFILL_INDRDPART register field. */
2186 #define ALT_QSPI_SRAMFILL_INDRDPART_LSB 0
2187 /* The Most Significant Bit (MSB) position of the ALT_QSPI_SRAMFILL_INDRDPART register field. */
2188 #define ALT_QSPI_SRAMFILL_INDRDPART_MSB 15
2189 /* The width in bits of the ALT_QSPI_SRAMFILL_INDRDPART register field. */
2190 #define ALT_QSPI_SRAMFILL_INDRDPART_WIDTH 16
2191 /* The mask used to set the ALT_QSPI_SRAMFILL_INDRDPART register field value. */
2192 #define ALT_QSPI_SRAMFILL_INDRDPART_SET_MSK 0x0000ffff
2193 /* The mask used to clear the ALT_QSPI_SRAMFILL_INDRDPART register field value. */
2194 #define ALT_QSPI_SRAMFILL_INDRDPART_CLR_MSK 0xffff0000
2195 /* The reset value of the ALT_QSPI_SRAMFILL_INDRDPART register field. */
2196 #define ALT_QSPI_SRAMFILL_INDRDPART_RESET 0x0
2197 /* Extracts the ALT_QSPI_SRAMFILL_INDRDPART field value from a register. */
2198 #define ALT_QSPI_SRAMFILL_INDRDPART_GET(value) (((value) & 0x0000ffff) >> 0)
2199 /* Produces a ALT_QSPI_SRAMFILL_INDRDPART register field value suitable for setting the register. */
2200 #define ALT_QSPI_SRAMFILL_INDRDPART_SET(value) (((value) << 0) & 0x0000ffff)
2201
2202 /*
2203  * Field : SRAM Fill Level (Indirect Write Partition). In units of SRAM WORDS - indwrpart
2204  *
2205  * Field Access Macros:
2206  *
2207  */
2208 /* The Least Significant Bit (LSB) position of the ALT_QSPI_SRAMFILL_INDWRPART register field. */
2209 #define ALT_QSPI_SRAMFILL_INDWRPART_LSB 16
2210 /* The Most Significant Bit (MSB) position of the ALT_QSPI_SRAMFILL_INDWRPART register field. */
2211 #define ALT_QSPI_SRAMFILL_INDWRPART_MSB 31
2212 /* The width in bits of the ALT_QSPI_SRAMFILL_INDWRPART register field. */
2213 #define ALT_QSPI_SRAMFILL_INDWRPART_WIDTH 16
2214 /* The mask used to set the ALT_QSPI_SRAMFILL_INDWRPART register field value. */
2215 #define ALT_QSPI_SRAMFILL_INDWRPART_SET_MSK 0xffff0000
2216 /* The mask used to clear the ALT_QSPI_SRAMFILL_INDWRPART register field value. */
2217 #define ALT_QSPI_SRAMFILL_INDWRPART_CLR_MSK 0x0000ffff
2218 /* The reset value of the ALT_QSPI_SRAMFILL_INDWRPART register field. */
2219 #define ALT_QSPI_SRAMFILL_INDWRPART_RESET 0x0
2220 /* Extracts the ALT_QSPI_SRAMFILL_INDWRPART field value from a register. */
2221 #define ALT_QSPI_SRAMFILL_INDWRPART_GET(value) (((value) & 0xffff0000) >> 16)
2222 /* Produces a ALT_QSPI_SRAMFILL_INDWRPART register field value suitable for setting the register. */
2223 #define ALT_QSPI_SRAMFILL_INDWRPART_SET(value) (((value) << 16) & 0xffff0000)
2224
2225 #ifndef __ASSEMBLY__
2226 /*
2227  * WARNING: The C register and register group struct declarations are provided for
2228  * convenience and illustrative purposes. They should, however, be used with
2229  * caution as the C language standard provides no guarantees about the alignment or
2230  * atomicity of device memory accesses. The recommended practice for writing
2231  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2232  * alt_write_word() functions.
2233  *
2234  * The struct declaration for register ALT_QSPI_SRAMFILL.
2235  */
2237 {
2238  const uint32_t indrdpart : 16; /* SRAM Fill Level (Indirect Read Partition). In units of SRAM WORDS */
2239  const uint32_t indwrpart : 16; /* SRAM Fill Level (Indirect Write Partition). In units of SRAM WORDS */
2240 };
2241
2242 /* The typedef declaration for register ALT_QSPI_SRAMFILL. */
2243 typedef volatile struct ALT_QSPI_SRAMFILL_s ALT_QSPI_SRAMFILL_t;
2244 #endif /* __ASSEMBLY__ */
2245
2246 /* The byte offset of the ALT_QSPI_SRAMFILL register from the beginning of the component. */
2247 #define ALT_QSPI_SRAMFILL_OFST 0x2c
2248
2249 /*
2250  * Register : TX Threshold Register - txthresh
2251  *
2252  * Register Layout
2253  *
2254  * Bits | Access | Reset | Description
2255  * :-------|:-------|:------|:------------
2256  * [3:0] | RW | 0x1 | Level
2257  * [31:4] | ??? | 0x0 | *UNDEFINED*
2258  *
2259  */
2260 /*
2261  * Field : Level - level
2262  *
2263  * Defines the level at which the transmit FIFO not full interrupt is generated
2264  *
2265  * Field Access Macros:
2266  *
2267  */
2268 /* The Least Significant Bit (LSB) position of the ALT_QSPI_TXTHRESH_LEVEL register field. */
2269 #define ALT_QSPI_TXTHRESH_LEVEL_LSB 0
2270 /* The Most Significant Bit (MSB) position of the ALT_QSPI_TXTHRESH_LEVEL register field. */
2271 #define ALT_QSPI_TXTHRESH_LEVEL_MSB 3
2272 /* The width in bits of the ALT_QSPI_TXTHRESH_LEVEL register field. */
2273 #define ALT_QSPI_TXTHRESH_LEVEL_WIDTH 4
2274 /* The mask used to set the ALT_QSPI_TXTHRESH_LEVEL register field value. */
2275 #define ALT_QSPI_TXTHRESH_LEVEL_SET_MSK 0x0000000f
2276 /* The mask used to clear the ALT_QSPI_TXTHRESH_LEVEL register field value. */
2277 #define ALT_QSPI_TXTHRESH_LEVEL_CLR_MSK 0xfffffff0
2278 /* The reset value of the ALT_QSPI_TXTHRESH_LEVEL register field. */
2279 #define ALT_QSPI_TXTHRESH_LEVEL_RESET 0x1
2280 /* Extracts the ALT_QSPI_TXTHRESH_LEVEL field value from a register. */
2281 #define ALT_QSPI_TXTHRESH_LEVEL_GET(value) (((value) & 0x0000000f) >> 0)
2282 /* Produces a ALT_QSPI_TXTHRESH_LEVEL register field value suitable for setting the register. */
2283 #define ALT_QSPI_TXTHRESH_LEVEL_SET(value) (((value) << 0) & 0x0000000f)
2284
2285 #ifndef __ASSEMBLY__
2286 /*
2287  * WARNING: The C register and register group struct declarations are provided for
2288  * convenience and illustrative purposes. They should, however, be used with
2289  * caution as the C language standard provides no guarantees about the alignment or
2290  * atomicity of device memory accesses. The recommended practice for writing
2291  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2292  * alt_write_word() functions.
2293  *
2294  * The struct declaration for register ALT_QSPI_TXTHRESH.
2295  */
2297 {
2298  uint32_t level : 4; /* Level */
2299  uint32_t : 28; /* *UNDEFINED* */
2300 };
2301
2302 /* The typedef declaration for register ALT_QSPI_TXTHRESH. */
2303 typedef volatile struct ALT_QSPI_TXTHRESH_s ALT_QSPI_TXTHRESH_t;
2304 #endif /* __ASSEMBLY__ */
2305
2306 /* The byte offset of the ALT_QSPI_TXTHRESH register from the beginning of the component. */
2307 #define ALT_QSPI_TXTHRESH_OFST 0x30
2308
2309 /*
2310  * Register : RX Threshold Register - rxthresh
2311  *
2312  * Device Instruction Register
2313  *
2314  * Register Layout
2315  *
2316  * Bits | Access | Reset | Description
2317  * :-------|:-------|:------|:------------
2318  * [3:0] | RW | 0x1 | Level
2319  * [31:4] | ??? | 0x0 | *UNDEFINED*
2320  *
2321  */
2322 /*
2323  * Field : Level - level
2324  *
2325  * Defines the level at which the receive FIFO not empty interrupt is generated
2326  *
2327  * Field Access Macros:
2328  *
2329  */
2330 /* The Least Significant Bit (LSB) position of the ALT_QSPI_RXTHRESH_LEVEL register field. */
2331 #define ALT_QSPI_RXTHRESH_LEVEL_LSB 0
2332 /* The Most Significant Bit (MSB) position of the ALT_QSPI_RXTHRESH_LEVEL register field. */
2333 #define ALT_QSPI_RXTHRESH_LEVEL_MSB 3
2334 /* The width in bits of the ALT_QSPI_RXTHRESH_LEVEL register field. */
2335 #define ALT_QSPI_RXTHRESH_LEVEL_WIDTH 4
2336 /* The mask used to set the ALT_QSPI_RXTHRESH_LEVEL register field value. */
2337 #define ALT_QSPI_RXTHRESH_LEVEL_SET_MSK 0x0000000f
2338 /* The mask used to clear the ALT_QSPI_RXTHRESH_LEVEL register field value. */
2339 #define ALT_QSPI_RXTHRESH_LEVEL_CLR_MSK 0xfffffff0
2340 /* The reset value of the ALT_QSPI_RXTHRESH_LEVEL register field. */
2341 #define ALT_QSPI_RXTHRESH_LEVEL_RESET 0x1
2342 /* Extracts the ALT_QSPI_RXTHRESH_LEVEL field value from a register. */
2343 #define ALT_QSPI_RXTHRESH_LEVEL_GET(value) (((value) & 0x0000000f) >> 0)
2344 /* Produces a ALT_QSPI_RXTHRESH_LEVEL register field value suitable for setting the register. */
2345 #define ALT_QSPI_RXTHRESH_LEVEL_SET(value) (((value) << 0) & 0x0000000f)
2346
2347 #ifndef __ASSEMBLY__
2348 /*
2349  * WARNING: The C register and register group struct declarations are provided for
2350  * convenience and illustrative purposes. They should, however, be used with
2351  * caution as the C language standard provides no guarantees about the alignment or
2352  * atomicity of device memory accesses. The recommended practice for writing
2353  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2354  * alt_write_word() functions.
2355  *
2356  * The struct declaration for register ALT_QSPI_RXTHRESH.
2357  */
2359 {
2360  uint32_t level : 4; /* Level */
2361  uint32_t : 28; /* *UNDEFINED* */
2362 };
2363
2364 /* The typedef declaration for register ALT_QSPI_RXTHRESH. */
2365 typedef volatile struct ALT_QSPI_RXTHRESH_s ALT_QSPI_RXTHRESH_t;
2366 #endif /* __ASSEMBLY__ */
2367
2368 /* The byte offset of the ALT_QSPI_RXTHRESH register from the beginning of the component. */
2369 #define ALT_QSPI_RXTHRESH_OFST 0x34
2370
2371 /*
2372  * Register : Interrupt Status Register - irqstat
2373  *
2374  * The status fields in this register are set when the described event occurs and
2375  * the interrupt is enabled in the mask register. When any of these bit fields are
2376  * set, the interrupt output is asserted high. The fields are each cleared by
2377  * writing a 1 to the field. Note that bit fields 7 thru 11 are only valid when
2378  * legacy SPI mode is active.
2379  *
2380  * Register Layout
2381  *
2382  * Bits | Access | Reset | Description
2383  * :--------|:-------|:------|:------------------------------------
2384  * [0] | ??? | 0x0 | *UNDEFINED*
2385  * [1] | RW | 0x0 | Underflow Detected
2386  * [2] | RW | 0x0 | Indirect Operation Complete
2387  * [3] | RW | 0x0 | Indirect Read Reject
2388  * [4] | RW | 0x0 | Protected Area Write Attempt
2389  * [5] | RW | 0x0 | Illegal AHB Access Detected
2390  * [6] | RW | 0x0 | Transfer Watermark Reached
2391  * [7] | RW | 0x0 | Receive Overflow
2392  * [8] | RW | 0x1 | Transmit FIFO Compared to Threshold
2393  * [9] | RW | 0x0 | Transmit FIFO Full
2394  * [10] | RW | 0x0 | Receive FIFO Compared to Threshold
2395  * [11] | RW | 0x0 | Receive FIFO Full
2396  * [12] | RW | 0x0 | Indirect Read Partition overflow
2397  * [31:13] | ??? | 0x0 | *UNDEFINED*
2398  *
2399  */
2400 /*
2401  * Field : Underflow Detected - underflowdet
2402  *
2403  * An underflow is detected when an attempt to transfer data is made when the
2404  * transmit FIFO is empty. This may occur when the AHB write data is being supplied
2405  * too slowly to keep up with the requested write operation. This bit is reset only
2406  * by a system reset and cleared only when the register is read.
2407  *
2408  * Field Enumeration Values:
2409  *
2410  * Enum | Value | Description
2411  * :--------------------------------------------|:------|:-------------
2412  * ALT_QSPI_IRQSTAT_UNDERFLOWDET_E_UNDERFLOW | 0x1 | Underflow
2413  * ALT_QSPI_IRQSTAT_UNDERFLOWDET_E_NOUNDERFLOW | 0x0 | No Underflow
2414  *
2415  * Field Access Macros:
2416  *
2417  */
2418 /*
2419  * Enumerated value for register field ALT_QSPI_IRQSTAT_UNDERFLOWDET
2420  *
2421  * Underflow
2422  */
2423 #define ALT_QSPI_IRQSTAT_UNDERFLOWDET_E_UNDERFLOW 0x1
2424 /*
2425  * Enumerated value for register field ALT_QSPI_IRQSTAT_UNDERFLOWDET
2426  *
2427  * No Underflow
2428  */
2429 #define ALT_QSPI_IRQSTAT_UNDERFLOWDET_E_NOUNDERFLOW 0x0
2430
2431 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_UNDERFLOWDET register field. */
2432 #define ALT_QSPI_IRQSTAT_UNDERFLOWDET_LSB 1
2433 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_UNDERFLOWDET register field. */
2434 #define ALT_QSPI_IRQSTAT_UNDERFLOWDET_MSB 1
2435 /* The width in bits of the ALT_QSPI_IRQSTAT_UNDERFLOWDET register field. */
2436 #define ALT_QSPI_IRQSTAT_UNDERFLOWDET_WIDTH 1
2437 /* The mask used to set the ALT_QSPI_IRQSTAT_UNDERFLOWDET register field value. */
2438 #define ALT_QSPI_IRQSTAT_UNDERFLOWDET_SET_MSK 0x00000002
2439 /* The mask used to clear the ALT_QSPI_IRQSTAT_UNDERFLOWDET register field value. */
2440 #define ALT_QSPI_IRQSTAT_UNDERFLOWDET_CLR_MSK 0xfffffffd
2441 /* The reset value of the ALT_QSPI_IRQSTAT_UNDERFLOWDET register field. */
2442 #define ALT_QSPI_IRQSTAT_UNDERFLOWDET_RESET 0x0
2443 /* Extracts the ALT_QSPI_IRQSTAT_UNDERFLOWDET field value from a register. */
2444 #define ALT_QSPI_IRQSTAT_UNDERFLOWDET_GET(value) (((value) & 0x00000002) >> 1)
2445 /* Produces a ALT_QSPI_IRQSTAT_UNDERFLOWDET register field value suitable for setting the register. */
2446 #define ALT_QSPI_IRQSTAT_UNDERFLOWDET_SET(value) (((value) << 1) & 0x00000002)
2447
2448 /*
2449  * Field : Indirect Operation Complete - indopdone
2450  *
2451  * Controller has completed last triggered indirect operation
2452  *
2453  * Field Enumeration Values:
2454  *
2455  * Enum | Value | Description
2456  * :------------------------------------------|:------|:-----------------------------
2457  * ALT_QSPI_IRQSTAT_INDOPDONE_E_INDIRECTOP | 0x1 | Completed Indirect Operation
2458  * ALT_QSPI_IRQSTAT_INDOPDONE_E_NOINDIRECTOP | 0x0 | No Indirect Operation
2459  *
2460  * Field Access Macros:
2461  *
2462  */
2463 /*
2464  * Enumerated value for register field ALT_QSPI_IRQSTAT_INDOPDONE
2465  *
2466  * Completed Indirect Operation
2467  */
2468 #define ALT_QSPI_IRQSTAT_INDOPDONE_E_INDIRECTOP 0x1
2469 /*
2470  * Enumerated value for register field ALT_QSPI_IRQSTAT_INDOPDONE
2471  *
2472  * No Indirect Operation
2473  */
2474 #define ALT_QSPI_IRQSTAT_INDOPDONE_E_NOINDIRECTOP 0x0
2475
2476 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_INDOPDONE register field. */
2477 #define ALT_QSPI_IRQSTAT_INDOPDONE_LSB 2
2478 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_INDOPDONE register field. */
2479 #define ALT_QSPI_IRQSTAT_INDOPDONE_MSB 2
2480 /* The width in bits of the ALT_QSPI_IRQSTAT_INDOPDONE register field. */
2481 #define ALT_QSPI_IRQSTAT_INDOPDONE_WIDTH 1
2482 /* The mask used to set the ALT_QSPI_IRQSTAT_INDOPDONE register field value. */
2483 #define ALT_QSPI_IRQSTAT_INDOPDONE_SET_MSK 0x00000004
2484 /* The mask used to clear the ALT_QSPI_IRQSTAT_INDOPDONE register field value. */
2485 #define ALT_QSPI_IRQSTAT_INDOPDONE_CLR_MSK 0xfffffffb
2486 /* The reset value of the ALT_QSPI_IRQSTAT_INDOPDONE register field. */
2487 #define ALT_QSPI_IRQSTAT_INDOPDONE_RESET 0x0
2488 /* Extracts the ALT_QSPI_IRQSTAT_INDOPDONE field value from a register. */
2489 #define ALT_QSPI_IRQSTAT_INDOPDONE_GET(value) (((value) & 0x00000004) >> 2)
2490 /* Produces a ALT_QSPI_IRQSTAT_INDOPDONE register field value suitable for setting the register. */
2491 #define ALT_QSPI_IRQSTAT_INDOPDONE_SET(value) (((value) << 2) & 0x00000004)
2492
2493 /*
2494  * Field : Indirect Read Reject - indrdreject
2495  *
2496  * Indirect operation was requested but could not be accepted. Two indirect
2497  * operations already in storage.
2498  *
2499  * Field Enumeration Values:
2500  *
2501  * Enum | Value | Description
2502  * :---------------------------------------------|:------|:-----------------------------
2503  * ALT_QSPI_IRQSTAT_INDRDREJECT_E_INDIRECTREQ | 0x1 | Indirect Operation Requested
2504  * ALT_QSPI_IRQSTAT_INDRDREJECT_E_NOINDIRECTREQ | 0x0 | No Indirect Operation
2505  *
2506  * Field Access Macros:
2507  *
2508  */
2509 /*
2510  * Enumerated value for register field ALT_QSPI_IRQSTAT_INDRDREJECT
2511  *
2512  * Indirect Operation Requested
2513  */
2514 #define ALT_QSPI_IRQSTAT_INDRDREJECT_E_INDIRECTREQ 0x1
2515 /*
2516  * Enumerated value for register field ALT_QSPI_IRQSTAT_INDRDREJECT
2517  *
2518  * No Indirect Operation
2519  */
2520 #define ALT_QSPI_IRQSTAT_INDRDREJECT_E_NOINDIRECTREQ 0x0
2521
2522 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_INDRDREJECT register field. */
2523 #define ALT_QSPI_IRQSTAT_INDRDREJECT_LSB 3
2524 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_INDRDREJECT register field. */
2525 #define ALT_QSPI_IRQSTAT_INDRDREJECT_MSB 3
2526 /* The width in bits of the ALT_QSPI_IRQSTAT_INDRDREJECT register field. */
2527 #define ALT_QSPI_IRQSTAT_INDRDREJECT_WIDTH 1
2528 /* The mask used to set the ALT_QSPI_IRQSTAT_INDRDREJECT register field value. */
2529 #define ALT_QSPI_IRQSTAT_INDRDREJECT_SET_MSK 0x00000008
2530 /* The mask used to clear the ALT_QSPI_IRQSTAT_INDRDREJECT register field value. */
2531 #define ALT_QSPI_IRQSTAT_INDRDREJECT_CLR_MSK 0xfffffff7
2532 /* The reset value of the ALT_QSPI_IRQSTAT_INDRDREJECT register field. */
2533 #define ALT_QSPI_IRQSTAT_INDRDREJECT_RESET 0x0
2534 /* Extracts the ALT_QSPI_IRQSTAT_INDRDREJECT field value from a register. */
2535 #define ALT_QSPI_IRQSTAT_INDRDREJECT_GET(value) (((value) & 0x00000008) >> 3)
2536 /* Produces a ALT_QSPI_IRQSTAT_INDRDREJECT register field value suitable for setting the register. */
2537 #define ALT_QSPI_IRQSTAT_INDRDREJECT_SET(value) (((value) << 3) & 0x00000008)
2538
2539 /*
2540  * Field : Protected Area Write Attempt - protwrattempt
2541  *
2542  * Write to protected area was attempted and rejected.
2543  *
2544  * Field Enumeration Values:
2545  *
2546  * Enum | Value | Description
2547  * :------------------------------------------|:------|:--------------------------------
2548  * ALT_QSPI_IRQSTAT_PROTWRATTEMPT_E_WRPROT | 0x1 | Write Attempt to protected area
2549  * ALT_QSPI_IRQSTAT_PROTWRATTEMPT_E_NOWRPROT | 0x0 | No Write Attempt
2550  *
2551  * Field Access Macros:
2552  *
2553  */
2554 /*
2555  * Enumerated value for register field ALT_QSPI_IRQSTAT_PROTWRATTEMPT
2556  *
2557  * Write Attempt to protected area
2558  */
2559 #define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_E_WRPROT 0x1
2560 /*
2561  * Enumerated value for register field ALT_QSPI_IRQSTAT_PROTWRATTEMPT
2562  *
2563  * No Write Attempt
2564  */
2565 #define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_E_NOWRPROT 0x0
2566
2567 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_PROTWRATTEMPT register field. */
2568 #define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_LSB 4
2569 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_PROTWRATTEMPT register field. */
2570 #define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_MSB 4
2571 /* The width in bits of the ALT_QSPI_IRQSTAT_PROTWRATTEMPT register field. */
2572 #define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_WIDTH 1
2573 /* The mask used to set the ALT_QSPI_IRQSTAT_PROTWRATTEMPT register field value. */
2574 #define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_SET_MSK 0x00000010
2575 /* The mask used to clear the ALT_QSPI_IRQSTAT_PROTWRATTEMPT register field value. */
2576 #define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_CLR_MSK 0xffffffef
2577 /* The reset value of the ALT_QSPI_IRQSTAT_PROTWRATTEMPT register field. */
2578 #define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_RESET 0x0
2579 /* Extracts the ALT_QSPI_IRQSTAT_PROTWRATTEMPT field value from a register. */
2580 #define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_GET(value) (((value) & 0x00000010) >> 4)
2581 /* Produces a ALT_QSPI_IRQSTAT_PROTWRATTEMPT register field value suitable for setting the register. */
2582 #define ALT_QSPI_IRQSTAT_PROTWRATTEMPT_SET(value) (((value) << 4) & 0x00000010)
2583
2584 /*
2585  * Field : Illegal AHB Access Detected - illegalacc
2586  *
2587  * Illegal AHB access has been detected. AHB wrapping bursts and the use of
2588  * SPLIT/RETRY accesses will cause this error interrupt to trigger.
2589  *
2590  * Field Enumeration Values:
2591  *
2592  * Enum | Value | Description
2593  * :-------------------------------------------|:------|:-----------------------
2594  * ALT_QSPI_IRQSTAT_ILLEGALACC_E_ILLEGALAHB | 0x1 | Illegal AHB attempt
2595  * ALT_QSPI_IRQSTAT_ILLEGALACC_E_NOILLEGALAHB | 0x0 | No Illegal AHB attempt
2596  *
2597  * Field Access Macros:
2598  *
2599  */
2600 /*
2601  * Enumerated value for register field ALT_QSPI_IRQSTAT_ILLEGALACC
2602  *
2603  * Illegal AHB attempt
2604  */
2605 #define ALT_QSPI_IRQSTAT_ILLEGALACC_E_ILLEGALAHB 0x1
2606 /*
2607  * Enumerated value for register field ALT_QSPI_IRQSTAT_ILLEGALACC
2608  *
2609  * No Illegal AHB attempt
2610  */
2611 #define ALT_QSPI_IRQSTAT_ILLEGALACC_E_NOILLEGALAHB 0x0
2612
2613 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_ILLEGALACC register field. */
2614 #define ALT_QSPI_IRQSTAT_ILLEGALACC_LSB 5
2615 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_ILLEGALACC register field. */
2616 #define ALT_QSPI_IRQSTAT_ILLEGALACC_MSB 5
2617 /* The width in bits of the ALT_QSPI_IRQSTAT_ILLEGALACC register field. */
2618 #define ALT_QSPI_IRQSTAT_ILLEGALACC_WIDTH 1
2619 /* The mask used to set the ALT_QSPI_IRQSTAT_ILLEGALACC register field value. */
2620 #define ALT_QSPI_IRQSTAT_ILLEGALACC_SET_MSK 0x00000020
2621 /* The mask used to clear the ALT_QSPI_IRQSTAT_ILLEGALACC register field value. */
2622 #define ALT_QSPI_IRQSTAT_ILLEGALACC_CLR_MSK 0xffffffdf
2623 /* The reset value of the ALT_QSPI_IRQSTAT_ILLEGALACC register field. */
2624 #define ALT_QSPI_IRQSTAT_ILLEGALACC_RESET 0x0
2625 /* Extracts the ALT_QSPI_IRQSTAT_ILLEGALACC field value from a register. */
2626 #define ALT_QSPI_IRQSTAT_ILLEGALACC_GET(value) (((value) & 0x00000020) >> 5)
2627 /* Produces a ALT_QSPI_IRQSTAT_ILLEGALACC register field value suitable for setting the register. */
2628 #define ALT_QSPI_IRQSTAT_ILLEGALACC_SET(value) (((value) << 5) & 0x00000020)
2629
2630 /*
2631  * Field : Transfer Watermark Reached - indxfrlvl
2632  *
2633  * Indirect Transfer Watermark Level Reached
2634  *
2635  * Field Enumeration Values:
2636  *
2637  * Enum | Value | Description
2638  * :----------------------------------------|:------|:-----------------------
2639  * ALT_QSPI_IRQSTAT_INDXFRLVL_E_WATERLEVL | 0x1 | Water level reached
2640  * ALT_QSPI_IRQSTAT_INDXFRLVL_E_NOWATERLVL | 0x0 | No water level reached
2641  *
2642  * Field Access Macros:
2643  *
2644  */
2645 /*
2646  * Enumerated value for register field ALT_QSPI_IRQSTAT_INDXFRLVL
2647  *
2648  * Water level reached
2649  */
2650 #define ALT_QSPI_IRQSTAT_INDXFRLVL_E_WATERLEVL 0x1
2651 /*
2652  * Enumerated value for register field ALT_QSPI_IRQSTAT_INDXFRLVL
2653  *
2654  * No water level reached
2655  */
2656 #define ALT_QSPI_IRQSTAT_INDXFRLVL_E_NOWATERLVL 0x0
2657
2658 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_INDXFRLVL register field. */
2659 #define ALT_QSPI_IRQSTAT_INDXFRLVL_LSB 6
2660 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_INDXFRLVL register field. */
2661 #define ALT_QSPI_IRQSTAT_INDXFRLVL_MSB 6
2662 /* The width in bits of the ALT_QSPI_IRQSTAT_INDXFRLVL register field. */
2663 #define ALT_QSPI_IRQSTAT_INDXFRLVL_WIDTH 1
2664 /* The mask used to set the ALT_QSPI_IRQSTAT_INDXFRLVL register field value. */
2665 #define ALT_QSPI_IRQSTAT_INDXFRLVL_SET_MSK 0x00000040
2666 /* The mask used to clear the ALT_QSPI_IRQSTAT_INDXFRLVL register field value. */
2667 #define ALT_QSPI_IRQSTAT_INDXFRLVL_CLR_MSK 0xffffffbf
2668 /* The reset value of the ALT_QSPI_IRQSTAT_INDXFRLVL register field. */
2669 #define ALT_QSPI_IRQSTAT_INDXFRLVL_RESET 0x0
2670 /* Extracts the ALT_QSPI_IRQSTAT_INDXFRLVL field value from a register. */
2671 #define ALT_QSPI_IRQSTAT_INDXFRLVL_GET(value) (((value) & 0x00000040) >> 6)
2672 /* Produces a ALT_QSPI_IRQSTAT_INDXFRLVL register field value suitable for setting the register. */
2673 #define ALT_QSPI_IRQSTAT_INDXFRLVL_SET(value) (((value) << 6) & 0x00000040)
2674
2675 /*
2676  * Field : Receive Overflow - rxover
2677  *
2678  * This should only occur in Legacy SPI mode. Set if an attempt is made to push the
2679  * RX FIFO when it is full. This bit is reset only by a system reset and cleared
2680  * only when this register is read. If a new push to the RX FIFO occurs coincident
2681  * with a register read this flag will remain set. 0 : no overflow has been
2682  * detected. 1 : an overflow has occurred.
2683  *
2684  * Field Enumeration Values:
2685  *
2686  * Enum | Value | Description
2687  * :------------------------------------|:------|:--------------------
2688  * ALT_QSPI_IRQSTAT_RXOVER_E_RCVOVER | 0x1 | Receive Overflow
2689  * ALT_QSPI_IRQSTAT_RXOVER_E_NORCVOVER | 0x0 | No Receive Overflow
2690  *
2691  * Field Access Macros:
2692  *
2693  */
2694 /*
2695  * Enumerated value for register field ALT_QSPI_IRQSTAT_RXOVER
2696  *
2697  * Receive Overflow
2698  */
2699 #define ALT_QSPI_IRQSTAT_RXOVER_E_RCVOVER 0x1
2700 /*
2701  * Enumerated value for register field ALT_QSPI_IRQSTAT_RXOVER
2702  *
2703  * No Receive Overflow
2704  */
2705 #define ALT_QSPI_IRQSTAT_RXOVER_E_NORCVOVER 0x0
2706
2707 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_RXOVER register field. */
2708 #define ALT_QSPI_IRQSTAT_RXOVER_LSB 7
2709 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_RXOVER register field. */
2710 #define ALT_QSPI_IRQSTAT_RXOVER_MSB 7
2711 /* The width in bits of the ALT_QSPI_IRQSTAT_RXOVER register field. */
2712 #define ALT_QSPI_IRQSTAT_RXOVER_WIDTH 1
2713 /* The mask used to set the ALT_QSPI_IRQSTAT_RXOVER register field value. */
2714 #define ALT_QSPI_IRQSTAT_RXOVER_SET_MSK 0x00000080
2715 /* The mask used to clear the ALT_QSPI_IRQSTAT_RXOVER register field value. */
2716 #define ALT_QSPI_IRQSTAT_RXOVER_CLR_MSK 0xffffff7f
2717 /* The reset value of the ALT_QSPI_IRQSTAT_RXOVER register field. */
2718 #define ALT_QSPI_IRQSTAT_RXOVER_RESET 0x0
2719 /* Extracts the ALT_QSPI_IRQSTAT_RXOVER field value from a register. */
2720 #define ALT_QSPI_IRQSTAT_RXOVER_GET(value) (((value) & 0x00000080) >> 7)
2721 /* Produces a ALT_QSPI_IRQSTAT_RXOVER register field value suitable for setting the register. */
2722 #define ALT_QSPI_IRQSTAT_RXOVER_SET(value) (((value) << 7) & 0x00000080)
2723
2724 /*
2725  * Field : Transmit FIFO Compared to Threshold - txthreshcmp
2726  *
2727  * Indicates the number of entries in the transmit FIFO with respect to the
2728  * threshold specified in the TXTHRESH register. Only relevant in SPI legacy mode.
2729  *
2730  * Field Enumeration Values:
2731  *
2732  * Enum | Value | Description
2733  * :----------------------------------|:------|:-----------------------------
2734  * ALT_QSPI_IRQSTAT_TXTHRESHCMP_E_GT | 0x0 | FIFO has > TXTHRESH entries
2735  * ALT_QSPI_IRQSTAT_TXTHRESHCMP_E_LE | 0x1 | FIFO has <= TXTHRESH entries
2736  *
2737  * Field Access Macros:
2738  *
2739  */
2740 /*
2741  * Enumerated value for register field ALT_QSPI_IRQSTAT_TXTHRESHCMP
2742  *
2743  * FIFO has > TXTHRESH entries
2744  */
2745 #define ALT_QSPI_IRQSTAT_TXTHRESHCMP_E_GT 0x0
2746 /*
2747  * Enumerated value for register field ALT_QSPI_IRQSTAT_TXTHRESHCMP
2748  *
2749  * FIFO has <= TXTHRESH entries
2750  */
2751 #define ALT_QSPI_IRQSTAT_TXTHRESHCMP_E_LE 0x1
2752
2753 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_TXTHRESHCMP register field. */
2754 #define ALT_QSPI_IRQSTAT_TXTHRESHCMP_LSB 8
2755 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_TXTHRESHCMP register field. */
2756 #define ALT_QSPI_IRQSTAT_TXTHRESHCMP_MSB 8
2757 /* The width in bits of the ALT_QSPI_IRQSTAT_TXTHRESHCMP register field. */
2758 #define ALT_QSPI_IRQSTAT_TXTHRESHCMP_WIDTH 1
2759 /* The mask used to set the ALT_QSPI_IRQSTAT_TXTHRESHCMP register field value. */
2760 #define ALT_QSPI_IRQSTAT_TXTHRESHCMP_SET_MSK 0x00000100
2761 /* The mask used to clear the ALT_QSPI_IRQSTAT_TXTHRESHCMP register field value. */
2762 #define ALT_QSPI_IRQSTAT_TXTHRESHCMP_CLR_MSK 0xfffffeff
2763 /* The reset value of the ALT_QSPI_IRQSTAT_TXTHRESHCMP register field. */
2764 #define ALT_QSPI_IRQSTAT_TXTHRESHCMP_RESET 0x1
2765 /* Extracts the ALT_QSPI_IRQSTAT_TXTHRESHCMP field value from a register. */
2766 #define ALT_QSPI_IRQSTAT_TXTHRESHCMP_GET(value) (((value) & 0x00000100) >> 8)
2767 /* Produces a ALT_QSPI_IRQSTAT_TXTHRESHCMP register field value suitable for setting the register. */
2768 #define ALT_QSPI_IRQSTAT_TXTHRESHCMP_SET(value) (((value) << 8) & 0x00000100)
2769
2770 /*
2771  * Field : Transmit FIFO Full - txfull
2772  *
2773  * Indicates that the transmit FIFO is full or not. Only relevant in SPI legacy
2774  * mode.
2775  *
2776  * Field Enumeration Values:
2777  *
2778  * Enum | Value | Description
2779  * :----------------------------------|:------|:-----------------------
2780  * ALT_QSPI_IRQSTAT_TXFULL_E_NOTFULL | 0x0 | Transmit FIFO Not Full
2781  * ALT_QSPI_IRQSTAT_TXFULL_E_FULL | 0x1 | Transmit FIFO Full
2782  *
2783  * Field Access Macros:
2784  *
2785  */
2786 /*
2787  * Enumerated value for register field ALT_QSPI_IRQSTAT_TXFULL
2788  *
2789  * Transmit FIFO Not Full
2790  */
2791 #define ALT_QSPI_IRQSTAT_TXFULL_E_NOTFULL 0x0
2792 /*
2793  * Enumerated value for register field ALT_QSPI_IRQSTAT_TXFULL
2794  *
2795  * Transmit FIFO Full
2796  */
2797 #define ALT_QSPI_IRQSTAT_TXFULL_E_FULL 0x1
2798
2799 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_TXFULL register field. */
2800 #define ALT_QSPI_IRQSTAT_TXFULL_LSB 9
2801 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_TXFULL register field. */
2802 #define ALT_QSPI_IRQSTAT_TXFULL_MSB 9
2803 /* The width in bits of the ALT_QSPI_IRQSTAT_TXFULL register field. */
2804 #define ALT_QSPI_IRQSTAT_TXFULL_WIDTH 1
2805 /* The mask used to set the ALT_QSPI_IRQSTAT_TXFULL register field value. */
2806 #define ALT_QSPI_IRQSTAT_TXFULL_SET_MSK 0x00000200
2807 /* The mask used to clear the ALT_QSPI_IRQSTAT_TXFULL register field value. */
2808 #define ALT_QSPI_IRQSTAT_TXFULL_CLR_MSK 0xfffffdff
2809 /* The reset value of the ALT_QSPI_IRQSTAT_TXFULL register field. */
2810 #define ALT_QSPI_IRQSTAT_TXFULL_RESET 0x0
2811 /* Extracts the ALT_QSPI_IRQSTAT_TXFULL field value from a register. */
2812 #define ALT_QSPI_IRQSTAT_TXFULL_GET(value) (((value) & 0x00000200) >> 9)
2813 /* Produces a ALT_QSPI_IRQSTAT_TXFULL register field value suitable for setting the register. */
2814 #define ALT_QSPI_IRQSTAT_TXFULL_SET(value) (((value) << 9) & 0x00000200)
2815
2816 /*
2817  * Field : Receive FIFO Compared to Threshold - rxthreshcmp
2818  *
2819  * Indicates the number of entries in the receive FIFO with respect to the
2820  * threshold specified in the RXTHRESH register. Only relevant in SPI legacy mode.
2821  *
2822  * Field Enumeration Values:
2823  *
2824  * Enum | Value | Description
2825  * :----------------------------------|:------|:-----------------------------
2826  * ALT_QSPI_IRQSTAT_RXTHRESHCMP_E_LE | 0x0 | FIFO has <= RXTHRESH entries
2827  * ALT_QSPI_IRQSTAT_RXTHRESHCMP_E_GT | 0x1 | FIFO has > RXTHRESH entries
2828  *
2829  * Field Access Macros:
2830  *
2831  */
2832 /*
2833  * Enumerated value for register field ALT_QSPI_IRQSTAT_RXTHRESHCMP
2834  *
2835  * FIFO has <= RXTHRESH entries
2836  */
2837 #define ALT_QSPI_IRQSTAT_RXTHRESHCMP_E_LE 0x0
2838 /*
2839  * Enumerated value for register field ALT_QSPI_IRQSTAT_RXTHRESHCMP
2840  *
2841  * FIFO has > RXTHRESH entries
2842  */
2843 #define ALT_QSPI_IRQSTAT_RXTHRESHCMP_E_GT 0x1
2844
2845 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_RXTHRESHCMP register field. */
2846 #define ALT_QSPI_IRQSTAT_RXTHRESHCMP_LSB 10
2847 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_RXTHRESHCMP register field. */
2848 #define ALT_QSPI_IRQSTAT_RXTHRESHCMP_MSB 10
2849 /* The width in bits of the ALT_QSPI_IRQSTAT_RXTHRESHCMP register field. */
2850 #define ALT_QSPI_IRQSTAT_RXTHRESHCMP_WIDTH 1
2851 /* The mask used to set the ALT_QSPI_IRQSTAT_RXTHRESHCMP register field value. */
2852 #define ALT_QSPI_IRQSTAT_RXTHRESHCMP_SET_MSK 0x00000400
2853 /* The mask used to clear the ALT_QSPI_IRQSTAT_RXTHRESHCMP register field value. */
2854 #define ALT_QSPI_IRQSTAT_RXTHRESHCMP_CLR_MSK 0xfffffbff
2855 /* The reset value of the ALT_QSPI_IRQSTAT_RXTHRESHCMP register field. */
2856 #define ALT_QSPI_IRQSTAT_RXTHRESHCMP_RESET 0x0
2857 /* Extracts the ALT_QSPI_IRQSTAT_RXTHRESHCMP field value from a register. */
2858 #define ALT_QSPI_IRQSTAT_RXTHRESHCMP_GET(value) (((value) & 0x00000400) >> 10)
2859 /* Produces a ALT_QSPI_IRQSTAT_RXTHRESHCMP register field value suitable for setting the register. */
2860 #define ALT_QSPI_IRQSTAT_RXTHRESHCMP_SET(value) (((value) << 10) & 0x00000400)
2861
2862 /*
2863  * Field : Receive FIFO Full - rxfull
2864  *
2865  * Indicates that the receive FIFO is full or not. Only relevant in SPI legacy
2866  * mode.
2867  *
2868  * Field Enumeration Values:
2869  *
2870  * Enum | Value | Description
2871  * :----------------------------------|:------|:----------------------
2872  * ALT_QSPI_IRQSTAT_RXFULL_E_NOTFULL | 0x0 | Receive FIFO Not Full
2873  * ALT_QSPI_IRQSTAT_RXFULL_E_FULL | 0x1 | Receive FIFO Full
2874  *
2875  * Field Access Macros:
2876  *
2877  */
2878 /*
2879  * Enumerated value for register field ALT_QSPI_IRQSTAT_RXFULL
2880  *
2881  * Receive FIFO Not Full
2882  */
2883 #define ALT_QSPI_IRQSTAT_RXFULL_E_NOTFULL 0x0
2884 /*
2885  * Enumerated value for register field ALT_QSPI_IRQSTAT_RXFULL
2886  *
2887  * Receive FIFO Full
2888  */
2889 #define ALT_QSPI_IRQSTAT_RXFULL_E_FULL 0x1
2890
2891 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_RXFULL register field. */
2892 #define ALT_QSPI_IRQSTAT_RXFULL_LSB 11
2893 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_RXFULL register field. */
2894 #define ALT_QSPI_IRQSTAT_RXFULL_MSB 11
2895 /* The width in bits of the ALT_QSPI_IRQSTAT_RXFULL register field. */
2896 #define ALT_QSPI_IRQSTAT_RXFULL_WIDTH 1
2897 /* The mask used to set the ALT_QSPI_IRQSTAT_RXFULL register field value. */
2898 #define ALT_QSPI_IRQSTAT_RXFULL_SET_MSK 0x00000800
2899 /* The mask used to clear the ALT_QSPI_IRQSTAT_RXFULL register field value. */
2900 #define ALT_QSPI_IRQSTAT_RXFULL_CLR_MSK 0xfffff7ff
2901 /* The reset value of the ALT_QSPI_IRQSTAT_RXFULL register field. */
2902 #define ALT_QSPI_IRQSTAT_RXFULL_RESET 0x0
2903 /* Extracts the ALT_QSPI_IRQSTAT_RXFULL field value from a register. */
2904 #define ALT_QSPI_IRQSTAT_RXFULL_GET(value) (((value) & 0x00000800) >> 11)
2905 /* Produces a ALT_QSPI_IRQSTAT_RXFULL register field value suitable for setting the register. */
2906 #define ALT_QSPI_IRQSTAT_RXFULL_SET(value) (((value) << 11) & 0x00000800)
2907
2908 /*
2909  * Field : Indirect Read Partition overflow - indsramfull
2910  *
2911  * Indirect Read Partition of SRAM is full and unable to immediately complete
2912  * indirect operation
2913  *
2914  * Field Enumeration Values:
2915  *
2916  * Enum | Value | Description
2917  * :---------------------------------------------|:------|:-----------------
2918  * ALT_QSPI_IRQSTAT_INDSRAMFULL_E_RDPARTFULL | 0x1 | SRAM is full
2919  * ALT_QSPI_IRQSTAT_INDSRAMFULL_E_RDPARTNOTFULL | 0x0 | SRAM is not full
2920  *
2921  * Field Access Macros:
2922  *
2923  */
2924 /*
2925  * Enumerated value for register field ALT_QSPI_IRQSTAT_INDSRAMFULL
2926  *
2927  * SRAM is full
2928  */
2929 #define ALT_QSPI_IRQSTAT_INDSRAMFULL_E_RDPARTFULL 0x1
2930 /*
2931  * Enumerated value for register field ALT_QSPI_IRQSTAT_INDSRAMFULL
2932  *
2933  * SRAM is not full
2934  */
2935 #define ALT_QSPI_IRQSTAT_INDSRAMFULL_E_RDPARTNOTFULL 0x0
2936
2937 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQSTAT_INDSRAMFULL register field. */
2938 #define ALT_QSPI_IRQSTAT_INDSRAMFULL_LSB 12
2939 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQSTAT_INDSRAMFULL register field. */
2940 #define ALT_QSPI_IRQSTAT_INDSRAMFULL_MSB 12
2941 /* The width in bits of the ALT_QSPI_IRQSTAT_INDSRAMFULL register field. */
2942 #define ALT_QSPI_IRQSTAT_INDSRAMFULL_WIDTH 1
2943 /* The mask used to set the ALT_QSPI_IRQSTAT_INDSRAMFULL register field value. */
2944 #define ALT_QSPI_IRQSTAT_INDSRAMFULL_SET_MSK 0x00001000
2945 /* The mask used to clear the ALT_QSPI_IRQSTAT_INDSRAMFULL register field value. */
2946 #define ALT_QSPI_IRQSTAT_INDSRAMFULL_CLR_MSK 0xffffefff
2947 /* The reset value of the ALT_QSPI_IRQSTAT_INDSRAMFULL register field. */
2948 #define ALT_QSPI_IRQSTAT_INDSRAMFULL_RESET 0x0
2949 /* Extracts the ALT_QSPI_IRQSTAT_INDSRAMFULL field value from a register. */
2950 #define ALT_QSPI_IRQSTAT_INDSRAMFULL_GET(value) (((value) & 0x00001000) >> 12)
2951 /* Produces a ALT_QSPI_IRQSTAT_INDSRAMFULL register field value suitable for setting the register. */
2952 #define ALT_QSPI_IRQSTAT_INDSRAMFULL_SET(value) (((value) << 12) & 0x00001000)
2953
2954 #ifndef __ASSEMBLY__
2955 /*
2956  * WARNING: The C register and register group struct declarations are provided for
2957  * convenience and illustrative purposes. They should, however, be used with
2958  * caution as the C language standard provides no guarantees about the alignment or
2959  * atomicity of device memory accesses. The recommended practice for writing
2960  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2961  * alt_write_word() functions.
2962  *
2963  * The struct declaration for register ALT_QSPI_IRQSTAT.
2964  */
2966 {
2967  uint32_t : 1; /* *UNDEFINED* */
2968  uint32_t underflowdet : 1; /* Underflow Detected */
2969  uint32_t indopdone : 1; /* Indirect Operation Complete */
2970  uint32_t indrdreject : 1; /* Indirect Read Reject */
2971  uint32_t protwrattempt : 1; /* Protected Area Write Attempt */
2972  uint32_t illegalacc : 1; /* Illegal AHB Access Detected */
2973  uint32_t indxfrlvl : 1; /* Transfer Watermark Reached */
2974  uint32_t rxover : 1; /* Receive Overflow */
2975  uint32_t txthreshcmp : 1; /* Transmit FIFO Compared to Threshold */
2976  uint32_t txfull : 1; /* Transmit FIFO Full */
2977  uint32_t rxthreshcmp : 1; /* Receive FIFO Compared to Threshold */
2978  uint32_t rxfull : 1; /* Receive FIFO Full */
2979  uint32_t indsramfull : 1; /* Indirect Read Partition overflow */
2980  uint32_t : 19; /* *UNDEFINED* */
2981 };
2982
2983 /* The typedef declaration for register ALT_QSPI_IRQSTAT. */
2984 typedef volatile struct ALT_QSPI_IRQSTAT_s ALT_QSPI_IRQSTAT_t;
2985 #endif /* __ASSEMBLY__ */
2986
2987 /* The byte offset of the ALT_QSPI_IRQSTAT register from the beginning of the component. */
2988 #define ALT_QSPI_IRQSTAT_OFST 0x40
2989
2990 /*
2991  * Register : Interrupt Mask - irqmask
2992  *
2993  * If disabled, the interrupt for the corresponding interrupt status register bit
2994  * is disabled. If enabled, the interrupt for the corresponding interrupt status
2995  * register bit is enabled.
2996  *
2997  * Register Layout
2998  *
2999  * Bits | Access | Reset | Description
3000  * :--------|:-------|:------|:--------------------------------------
3001  * [0] | ??? | 0x0 | *UNDEFINED*
3002  * [1] | RW | 0x0 | Underflow Detected Mask
3003  * [2] | RW | 0x0 | Mask
3004  * [3] | RW | 0x0 | Indirect Read Reject Mask
3005  * [4] | RW | 0x0 | Protected Area Write Attempt Mask
3006  * [5] | RW | 0x0 | Illegal Access Detected Mask
3007  * [6] | RW | 0x0 | Transfer Watermark Breach Mask
3008  * [7] | RW | 0x0 | Receive Overflow Mask
3009  * [8] | RW | 0x0 | Transmit FIFO Threshold Compare Mask
3010  * [9] | RW | 0x0 | Transmit FIFO Full Mask
3011  * [10] | RW | 0x0 | Receive FIFO Threshold Compare Mask
3012  * [11] | RW | 0x0 | Receive FIFO full Mask
3013  * [12] | RW | 0x0 | Indirect Read Partition overflow mask
3014  * [31:13] | ??? | 0x0 | *UNDEFINED*
3015  *
3016  */
3017 /*
3018  * Field : Underflow Detected Mask - underflowdet
3019  *
3020  * Field Enumeration Values:
3021  *
3022  * Enum | Value | Description
3023  * :------------------------------------|:------|:-----------------------------
3024  * ALT_QSPI_IRQMSK_UNDERFLOWDET_E_DISD | 0x0 | Disable Interrupt by Masking
3025  * ALT_QSPI_IRQMSK_UNDERFLOWDET_E_END | 0x1 | Enable Interrupt
3026  *
3027  * Field Access Macros:
3028  *
3029  */
3030 /*
3031  * Enumerated value for register field ALT_QSPI_IRQMSK_UNDERFLOWDET
3032  *
3033  * Disable Interrupt by Masking
3034  */
3035 #define ALT_QSPI_IRQMSK_UNDERFLOWDET_E_DISD 0x0
3036 /*
3037  * Enumerated value for register field ALT_QSPI_IRQMSK_UNDERFLOWDET
3038  *
3039  * Enable Interrupt
3040  */
3041 #define ALT_QSPI_IRQMSK_UNDERFLOWDET_E_END 0x1
3042
3043 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_UNDERFLOWDET register field. */
3044 #define ALT_QSPI_IRQMSK_UNDERFLOWDET_LSB 1
3045 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_UNDERFLOWDET register field. */
3046 #define ALT_QSPI_IRQMSK_UNDERFLOWDET_MSB 1
3047 /* The width in bits of the ALT_QSPI_IRQMSK_UNDERFLOWDET register field. */
3048 #define ALT_QSPI_IRQMSK_UNDERFLOWDET_WIDTH 1
3049 /* The mask used to set the ALT_QSPI_IRQMSK_UNDERFLOWDET register field value. */
3050 #define ALT_QSPI_IRQMSK_UNDERFLOWDET_SET_MSK 0x00000002
3051 /* The mask used to clear the ALT_QSPI_IRQMSK_UNDERFLOWDET register field value. */
3052 #define ALT_QSPI_IRQMSK_UNDERFLOWDET_CLR_MSK 0xfffffffd
3053 /* The reset value of the ALT_QSPI_IRQMSK_UNDERFLOWDET register field. */
3054 #define ALT_QSPI_IRQMSK_UNDERFLOWDET_RESET 0x0
3055 /* Extracts the ALT_QSPI_IRQMSK_UNDERFLOWDET field value from a register. */
3056 #define ALT_QSPI_IRQMSK_UNDERFLOWDET_GET(value) (((value) & 0x00000002) >> 1)
3057 /* Produces a ALT_QSPI_IRQMSK_UNDERFLOWDET register field value suitable for setting the register. */
3058 #define ALT_QSPI_IRQMSK_UNDERFLOWDET_SET(value) (((value) << 1) & 0x00000002)
3059
3060 /*
3061  * Field : Mask - indopdone
3062  *
3063  * Field Enumeration Values:
3064  *
3065  * Enum | Value | Description
3066  * :---------------------------------|:------|:-----------------------------
3067  * ALT_QSPI_IRQMSK_INDOPDONE_E_DISD | 0x0 | Disable Interrupt by Masking
3068  * ALT_QSPI_IRQMSK_INDOPDONE_E_END | 0x1 | Enable Interrupt
3069  *
3070  * Field Access Macros:
3071  *
3072  */
3073 /*
3074  * Enumerated value for register field ALT_QSPI_IRQMSK_INDOPDONE
3075  *
3076  * Disable Interrupt by Masking
3077  */
3078 #define ALT_QSPI_IRQMSK_INDOPDONE_E_DISD 0x0
3079 /*
3080  * Enumerated value for register field ALT_QSPI_IRQMSK_INDOPDONE
3081  *
3082  * Enable Interrupt
3083  */
3084 #define ALT_QSPI_IRQMSK_INDOPDONE_E_END 0x1
3085
3086 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_INDOPDONE register field. */
3087 #define ALT_QSPI_IRQMSK_INDOPDONE_LSB 2
3088 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_INDOPDONE register field. */
3089 #define ALT_QSPI_IRQMSK_INDOPDONE_MSB 2
3090 /* The width in bits of the ALT_QSPI_IRQMSK_INDOPDONE register field. */
3091 #define ALT_QSPI_IRQMSK_INDOPDONE_WIDTH 1
3092 /* The mask used to set the ALT_QSPI_IRQMSK_INDOPDONE register field value. */
3093 #define ALT_QSPI_IRQMSK_INDOPDONE_SET_MSK 0x00000004
3094 /* The mask used to clear the ALT_QSPI_IRQMSK_INDOPDONE register field value. */
3095 #define ALT_QSPI_IRQMSK_INDOPDONE_CLR_MSK 0xfffffffb
3096 /* The reset value of the ALT_QSPI_IRQMSK_INDOPDONE register field. */
3097 #define ALT_QSPI_IRQMSK_INDOPDONE_RESET 0x0
3098 /* Extracts the ALT_QSPI_IRQMSK_INDOPDONE field value from a register. */
3099 #define ALT_QSPI_IRQMSK_INDOPDONE_GET(value) (((value) & 0x00000004) >> 2)
3100 /* Produces a ALT_QSPI_IRQMSK_INDOPDONE register field value suitable for setting the register. */
3101 #define ALT_QSPI_IRQMSK_INDOPDONE_SET(value) (((value) << 2) & 0x00000004)
3102
3103 /*
3104  * Field : Indirect Read Reject Mask - indrdreject
3105  *
3106  * Field Enumeration Values:
3107  *
3108  * Enum | Value | Description
3109  * :-----------------------------------|:------|:-----------------------------
3110  * ALT_QSPI_IRQMSK_INDRDREJECT_E_DISD | 0x0 | Disable Interrupt by Masking
3111  * ALT_QSPI_IRQMSK_INDRDREJECT_E_END | 0x1 | Enable Interrupt
3112  *
3113  * Field Access Macros:
3114  *
3115  */
3116 /*
3117  * Enumerated value for register field ALT_QSPI_IRQMSK_INDRDREJECT
3118  *
3119  * Disable Interrupt by Masking
3120  */
3121 #define ALT_QSPI_IRQMSK_INDRDREJECT_E_DISD 0x0
3122 /*
3123  * Enumerated value for register field ALT_QSPI_IRQMSK_INDRDREJECT
3124  *
3125  * Enable Interrupt
3126  */
3127 #define ALT_QSPI_IRQMSK_INDRDREJECT_E_END 0x1
3128
3129 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_INDRDREJECT register field. */
3130 #define ALT_QSPI_IRQMSK_INDRDREJECT_LSB 3
3131 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_INDRDREJECT register field. */
3132 #define ALT_QSPI_IRQMSK_INDRDREJECT_MSB 3
3133 /* The width in bits of the ALT_QSPI_IRQMSK_INDRDREJECT register field. */
3134 #define ALT_QSPI_IRQMSK_INDRDREJECT_WIDTH 1
3135 /* The mask used to set the ALT_QSPI_IRQMSK_INDRDREJECT register field value. */
3136 #define ALT_QSPI_IRQMSK_INDRDREJECT_SET_MSK 0x00000008
3137 /* The mask used to clear the ALT_QSPI_IRQMSK_INDRDREJECT register field value. */
3138 #define ALT_QSPI_IRQMSK_INDRDREJECT_CLR_MSK 0xfffffff7
3139 /* The reset value of the ALT_QSPI_IRQMSK_INDRDREJECT register field. */
3140 #define ALT_QSPI_IRQMSK_INDRDREJECT_RESET 0x0
3141 /* Extracts the ALT_QSPI_IRQMSK_INDRDREJECT field value from a register. */
3142 #define ALT_QSPI_IRQMSK_INDRDREJECT_GET(value) (((value) & 0x00000008) >> 3)
3143 /* Produces a ALT_QSPI_IRQMSK_INDRDREJECT register field value suitable for setting the register. */
3144 #define ALT_QSPI_IRQMSK_INDRDREJECT_SET(value) (((value) << 3) & 0x00000008)
3145
3146 /*
3147  * Field : Protected Area Write Attempt Mask - protwrattempt
3148  *
3149  * Field Enumeration Values:
3150  *
3151  * Enum | Value | Description
3152  * :-------------------------------------|:------|:-----------------------------
3153  * ALT_QSPI_IRQMSK_PROTWRATTEMPT_E_DISD | 0x0 | Disable Interrupt by Masking
3154  * ALT_QSPI_IRQMSK_PROTWRATTEMPT_E_END | 0x1 | Enable Interrupt
3155  *
3156  * Field Access Macros:
3157  *
3158  */
3159 /*
3160  * Enumerated value for register field ALT_QSPI_IRQMSK_PROTWRATTEMPT
3161  *
3162  * Disable Interrupt by Masking
3163  */
3164 #define ALT_QSPI_IRQMSK_PROTWRATTEMPT_E_DISD 0x0
3165 /*
3166  * Enumerated value for register field ALT_QSPI_IRQMSK_PROTWRATTEMPT
3167  *
3168  * Enable Interrupt
3169  */
3170 #define ALT_QSPI_IRQMSK_PROTWRATTEMPT_E_END 0x1
3171
3172 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_PROTWRATTEMPT register field. */
3173 #define ALT_QSPI_IRQMSK_PROTWRATTEMPT_LSB 4
3174 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_PROTWRATTEMPT register field. */
3175 #define ALT_QSPI_IRQMSK_PROTWRATTEMPT_MSB 4
3176 /* The width in bits of the ALT_QSPI_IRQMSK_PROTWRATTEMPT register field. */
3177 #define ALT_QSPI_IRQMSK_PROTWRATTEMPT_WIDTH 1
3178 /* The mask used to set the ALT_QSPI_IRQMSK_PROTWRATTEMPT register field value. */
3179 #define ALT_QSPI_IRQMSK_PROTWRATTEMPT_SET_MSK 0x00000010
3180 /* The mask used to clear the ALT_QSPI_IRQMSK_PROTWRATTEMPT register field value. */
3181 #define ALT_QSPI_IRQMSK_PROTWRATTEMPT_CLR_MSK 0xffffffef
3182 /* The reset value of the ALT_QSPI_IRQMSK_PROTWRATTEMPT register field. */
3183 #define ALT_QSPI_IRQMSK_PROTWRATTEMPT_RESET 0x0
3184 /* Extracts the ALT_QSPI_IRQMSK_PROTWRATTEMPT field value from a register. */
3185 #define ALT_QSPI_IRQMSK_PROTWRATTEMPT_GET(value) (((value) & 0x00000010) >> 4)
3186 /* Produces a ALT_QSPI_IRQMSK_PROTWRATTEMPT register field value suitable for setting the register. */
3187 #define ALT_QSPI_IRQMSK_PROTWRATTEMPT_SET(value) (((value) << 4) & 0x00000010)
3188
3189 /*
3190  * Field : Illegal Access Detected Mask - illegalacc
3191  *
3192  * Field Enumeration Values:
3193  *
3194  * Enum | Value | Description
3195  * :----------------------------------|:------|:-----------------------------
3196  * ALT_QSPI_IRQMSK_ILLEGALACC_E_DISD | 0x0 | Disable Interrupt by Masking
3197  * ALT_QSPI_IRQMSK_ILLEGALACC_E_END | 0x1 | Enable Interrupt
3198  *
3199  * Field Access Macros:
3200  *
3201  */
3202 /*
3203  * Enumerated value for register field ALT_QSPI_IRQMSK_ILLEGALACC
3204  *
3205  * Disable Interrupt by Masking
3206  */
3207 #define ALT_QSPI_IRQMSK_ILLEGALACC_E_DISD 0x0
3208 /*
3209  * Enumerated value for register field ALT_QSPI_IRQMSK_ILLEGALACC
3210  *
3211  * Enable Interrupt
3212  */
3213 #define ALT_QSPI_IRQMSK_ILLEGALACC_E_END 0x1
3214
3215 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_ILLEGALACC register field. */
3216 #define ALT_QSPI_IRQMSK_ILLEGALACC_LSB 5
3217 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_ILLEGALACC register field. */
3218 #define ALT_QSPI_IRQMSK_ILLEGALACC_MSB 5
3219 /* The width in bits of the ALT_QSPI_IRQMSK_ILLEGALACC register field. */
3220 #define ALT_QSPI_IRQMSK_ILLEGALACC_WIDTH 1
3221 /* The mask used to set the ALT_QSPI_IRQMSK_ILLEGALACC register field value. */
3222 #define ALT_QSPI_IRQMSK_ILLEGALACC_SET_MSK 0x00000020
3223 /* The mask used to clear the ALT_QSPI_IRQMSK_ILLEGALACC register field value. */
3224 #define ALT_QSPI_IRQMSK_ILLEGALACC_CLR_MSK 0xffffffdf
3225 /* The reset value of the ALT_QSPI_IRQMSK_ILLEGALACC register field. */
3226 #define ALT_QSPI_IRQMSK_ILLEGALACC_RESET 0x0
3227 /* Extracts the ALT_QSPI_IRQMSK_ILLEGALACC field value from a register. */
3228 #define ALT_QSPI_IRQMSK_ILLEGALACC_GET(value) (((value) & 0x00000020) >> 5)
3229 /* Produces a ALT_QSPI_IRQMSK_ILLEGALACC register field value suitable for setting the register. */
3230 #define ALT_QSPI_IRQMSK_ILLEGALACC_SET(value) (((value) << 5) & 0x00000020)
3231
3232 /*
3233  * Field : Transfer Watermark Breach Mask - indxfrlvl
3234  *
3235  * Field Enumeration Values:
3236  *
3237  * Enum | Value | Description
3238  * :---------------------------------|:------|:-----------------------------
3239  * ALT_QSPI_IRQMSK_INDXFRLVL_E_DISD | 0x0 | Disable Interrupt by Masking
3240  * ALT_QSPI_IRQMSK_INDXFRLVL_E_END | 0x1 | Enable Interrupt
3241  *
3242  * Field Access Macros:
3243  *
3244  */
3245 /*
3246  * Enumerated value for register field ALT_QSPI_IRQMSK_INDXFRLVL
3247  *
3248  * Disable Interrupt by Masking
3249  */
3250 #define ALT_QSPI_IRQMSK_INDXFRLVL_E_DISD 0x0
3251 /*
3252  * Enumerated value for register field ALT_QSPI_IRQMSK_INDXFRLVL
3253  *
3254  * Enable Interrupt
3255  */
3256 #define ALT_QSPI_IRQMSK_INDXFRLVL_E_END 0x1
3257
3258 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_INDXFRLVL register field. */
3259 #define ALT_QSPI_IRQMSK_INDXFRLVL_LSB 6
3260 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_INDXFRLVL register field. */
3261 #define ALT_QSPI_IRQMSK_INDXFRLVL_MSB 6
3262 /* The width in bits of the ALT_QSPI_IRQMSK_INDXFRLVL register field. */
3263 #define ALT_QSPI_IRQMSK_INDXFRLVL_WIDTH 1
3264 /* The mask used to set the ALT_QSPI_IRQMSK_INDXFRLVL register field value. */
3265 #define ALT_QSPI_IRQMSK_INDXFRLVL_SET_MSK 0x00000040
3266 /* The mask used to clear the ALT_QSPI_IRQMSK_INDXFRLVL register field value. */
3267 #define ALT_QSPI_IRQMSK_INDXFRLVL_CLR_MSK 0xffffffbf
3268 /* The reset value of the ALT_QSPI_IRQMSK_INDXFRLVL register field. */
3269 #define ALT_QSPI_IRQMSK_INDXFRLVL_RESET 0x0
3270 /* Extracts the ALT_QSPI_IRQMSK_INDXFRLVL field value from a register. */
3271 #define ALT_QSPI_IRQMSK_INDXFRLVL_GET(value) (((value) & 0x00000040) >> 6)
3272 /* Produces a ALT_QSPI_IRQMSK_INDXFRLVL register field value suitable for setting the register. */
3273 #define ALT_QSPI_IRQMSK_INDXFRLVL_SET(value) (((value) << 6) & 0x00000040)
3274
3275 /*
3276  * Field : Receive Overflow Mask - rxover
3277  *
3278  * Field Enumeration Values:
3279  *
3280  * Enum | Value | Description
3281  * :------------------------------|:------|:-----------------------------
3282  * ALT_QSPI_IRQMSK_RXOVER_E_DISD | 0x0 | Disable Interrupt by Masking
3283  * ALT_QSPI_IRQMSK_RXOVER_E_END | 0x1 | Enable Interrupt
3284  *
3285  * Field Access Macros:
3286  *
3287  */
3288 /*
3289  * Enumerated value for register field ALT_QSPI_IRQMSK_RXOVER
3290  *
3291  * Disable Interrupt by Masking
3292  */
3293 #define ALT_QSPI_IRQMSK_RXOVER_E_DISD 0x0
3294 /*
3295  * Enumerated value for register field ALT_QSPI_IRQMSK_RXOVER
3296  *
3297  * Enable Interrupt
3298  */
3299 #define ALT_QSPI_IRQMSK_RXOVER_E_END 0x1
3300
3301 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_RXOVER register field. */
3302 #define ALT_QSPI_IRQMSK_RXOVER_LSB 7
3303 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_RXOVER register field. */
3304 #define ALT_QSPI_IRQMSK_RXOVER_MSB 7
3305 /* The width in bits of the ALT_QSPI_IRQMSK_RXOVER register field. */
3306 #define ALT_QSPI_IRQMSK_RXOVER_WIDTH 1
3307 /* The mask used to set the ALT_QSPI_IRQMSK_RXOVER register field value. */
3308 #define ALT_QSPI_IRQMSK_RXOVER_SET_MSK 0x00000080
3309 /* The mask used to clear the ALT_QSPI_IRQMSK_RXOVER register field value. */
3310 #define ALT_QSPI_IRQMSK_RXOVER_CLR_MSK 0xffffff7f
3311 /* The reset value of the ALT_QSPI_IRQMSK_RXOVER register field. */
3312 #define ALT_QSPI_IRQMSK_RXOVER_RESET 0x0
3313 /* Extracts the ALT_QSPI_IRQMSK_RXOVER field value from a register. */
3314 #define ALT_QSPI_IRQMSK_RXOVER_GET(value) (((value) & 0x00000080) >> 7)
3315 /* Produces a ALT_QSPI_IRQMSK_RXOVER register field value suitable for setting the register. */
3316 #define ALT_QSPI_IRQMSK_RXOVER_SET(value) (((value) << 7) & 0x00000080)
3317
3318 /*
3319  * Field : Transmit FIFO Threshold Compare Mask - txthreshcmp
3320  *
3321  * Field Enumeration Values:
3322  *
3323  * Enum | Value | Description
3324  * :-----------------------------------|:------|:-----------------------------
3325  * ALT_QSPI_IRQMSK_TXTHRESHCMP_E_DISD | 0x0 | Disable Interrupt by Masking
3326  * ALT_QSPI_IRQMSK_TXTHRESHCMP_E_END | 0x1 | Enable Interrupt
3327  *
3328  * Field Access Macros:
3329  *
3330  */
3331 /*
3332  * Enumerated value for register field ALT_QSPI_IRQMSK_TXTHRESHCMP
3333  *
3334  * Disable Interrupt by Masking
3335  */
3336 #define ALT_QSPI_IRQMSK_TXTHRESHCMP_E_DISD 0x0
3337 /*
3338  * Enumerated value for register field ALT_QSPI_IRQMSK_TXTHRESHCMP
3339  *
3340  * Enable Interrupt
3341  */
3342 #define ALT_QSPI_IRQMSK_TXTHRESHCMP_E_END 0x1
3343
3344 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_TXTHRESHCMP register field. */
3345 #define ALT_QSPI_IRQMSK_TXTHRESHCMP_LSB 8
3346 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_TXTHRESHCMP register field. */
3347 #define ALT_QSPI_IRQMSK_TXTHRESHCMP_MSB 8
3348 /* The width in bits of the ALT_QSPI_IRQMSK_TXTHRESHCMP register field. */
3349 #define ALT_QSPI_IRQMSK_TXTHRESHCMP_WIDTH 1
3350 /* The mask used to set the ALT_QSPI_IRQMSK_TXTHRESHCMP register field value. */
3351 #define ALT_QSPI_IRQMSK_TXTHRESHCMP_SET_MSK 0x00000100
3352 /* The mask used to clear the ALT_QSPI_IRQMSK_TXTHRESHCMP register field value. */
3353 #define ALT_QSPI_IRQMSK_TXTHRESHCMP_CLR_MSK 0xfffffeff
3354 /* The reset value of the ALT_QSPI_IRQMSK_TXTHRESHCMP register field. */
3355 #define ALT_QSPI_IRQMSK_TXTHRESHCMP_RESET 0x0
3356 /* Extracts the ALT_QSPI_IRQMSK_TXTHRESHCMP field value from a register. */
3357 #define ALT_QSPI_IRQMSK_TXTHRESHCMP_GET(value) (((value) & 0x00000100) >> 8)
3358 /* Produces a ALT_QSPI_IRQMSK_TXTHRESHCMP register field value suitable for setting the register. */
3359 #define ALT_QSPI_IRQMSK_TXTHRESHCMP_SET(value) (((value) << 8) & 0x00000100)
3360
3361 /*
3362  * Field : Transmit FIFO Full Mask - txfull
3363  *
3364  * Field Enumeration Values:
3365  *
3366  * Enum | Value | Description
3367  * :------------------------------|:------|:-----------------------------
3368  * ALT_QSPI_IRQMSK_TXFULL_E_DISD | 0x0 | Disable Interrupt by Masking
3369  * ALT_QSPI_IRQMSK_TXFULL_E_END | 0x1 | Enable Interrupt
3370  *
3371  * Field Access Macros:
3372  *
3373  */
3374 /*
3375  * Enumerated value for register field ALT_QSPI_IRQMSK_TXFULL
3376  *
3377  * Disable Interrupt by Masking
3378  */
3379 #define ALT_QSPI_IRQMSK_TXFULL_E_DISD 0x0
3380 /*
3381  * Enumerated value for register field ALT_QSPI_IRQMSK_TXFULL
3382  *
3383  * Enable Interrupt
3384  */
3385 #define ALT_QSPI_IRQMSK_TXFULL_E_END 0x1
3386
3387 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_TXFULL register field. */
3388 #define ALT_QSPI_IRQMSK_TXFULL_LSB 9
3389 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_TXFULL register field. */
3390 #define ALT_QSPI_IRQMSK_TXFULL_MSB 9
3391 /* The width in bits of the ALT_QSPI_IRQMSK_TXFULL register field. */
3392 #define ALT_QSPI_IRQMSK_TXFULL_WIDTH 1
3393 /* The mask used to set the ALT_QSPI_IRQMSK_TXFULL register field value. */
3394 #define ALT_QSPI_IRQMSK_TXFULL_SET_MSK 0x00000200
3395 /* The mask used to clear the ALT_QSPI_IRQMSK_TXFULL register field value. */
3396 #define ALT_QSPI_IRQMSK_TXFULL_CLR_MSK 0xfffffdff
3397 /* The reset value of the ALT_QSPI_IRQMSK_TXFULL register field. */
3398 #define ALT_QSPI_IRQMSK_TXFULL_RESET 0x0
3399 /* Extracts the ALT_QSPI_IRQMSK_TXFULL field value from a register. */
3400 #define ALT_QSPI_IRQMSK_TXFULL_GET(value) (((value) & 0x00000200) >> 9)
3401 /* Produces a ALT_QSPI_IRQMSK_TXFULL register field value suitable for setting the register. */
3402 #define ALT_QSPI_IRQMSK_TXFULL_SET(value) (((value) << 9) & 0x00000200)
3403
3404 /*
3405  * Field : Receive FIFO Threshold Compare Mask - rxthreshcmp
3406  *
3407  * Field Enumeration Values:
3408  *
3409  * Enum | Value | Description
3410  * :-----------------------------------|:------|:-----------------------------
3411  * ALT_QSPI_IRQMSK_RXTHRESHCMP_E_DISD | 0x0 | Disable Interrupt by Masking
3412  * ALT_QSPI_IRQMSK_RXTHRESHCMP_E_END | 0x1 | Enable Interrupt
3413  *
3414  * Field Access Macros:
3415  *
3416  */
3417 /*
3418  * Enumerated value for register field ALT_QSPI_IRQMSK_RXTHRESHCMP
3419  *
3420  * Disable Interrupt by Masking
3421  */
3422 #define ALT_QSPI_IRQMSK_RXTHRESHCMP_E_DISD 0x0
3423 /*
3424  * Enumerated value for register field ALT_QSPI_IRQMSK_RXTHRESHCMP
3425  *
3426  * Enable Interrupt
3427  */
3428 #define ALT_QSPI_IRQMSK_RXTHRESHCMP_E_END 0x1
3429
3430 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_RXTHRESHCMP register field. */
3431 #define ALT_QSPI_IRQMSK_RXTHRESHCMP_LSB 10
3432 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_RXTHRESHCMP register field. */
3433 #define ALT_QSPI_IRQMSK_RXTHRESHCMP_MSB 10
3434 /* The width in bits of the ALT_QSPI_IRQMSK_RXTHRESHCMP register field. */
3435 #define ALT_QSPI_IRQMSK_RXTHRESHCMP_WIDTH 1
3436 /* The mask used to set the ALT_QSPI_IRQMSK_RXTHRESHCMP register field value. */
3437 #define ALT_QSPI_IRQMSK_RXTHRESHCMP_SET_MSK 0x00000400
3438 /* The mask used to clear the ALT_QSPI_IRQMSK_RXTHRESHCMP register field value. */
3439 #define ALT_QSPI_IRQMSK_RXTHRESHCMP_CLR_MSK 0xfffffbff
3440 /* The reset value of the ALT_QSPI_IRQMSK_RXTHRESHCMP register field. */
3441 #define ALT_QSPI_IRQMSK_RXTHRESHCMP_RESET 0x0
3442 /* Extracts the ALT_QSPI_IRQMSK_RXTHRESHCMP field value from a register. */
3443 #define ALT_QSPI_IRQMSK_RXTHRESHCMP_GET(value) (((value) & 0x00000400) >> 10)
3444 /* Produces a ALT_QSPI_IRQMSK_RXTHRESHCMP register field value suitable for setting the register. */
3445 #define ALT_QSPI_IRQMSK_RXTHRESHCMP_SET(value) (((value) << 10) & 0x00000400)
3446
3447 /*
3448  * Field : Receive FIFO full Mask - rxfull
3449  *
3450  * Field Enumeration Values:
3451  *
3452  * Enum | Value | Description
3453  * :------------------------------|:------|:-----------------------------
3454  * ALT_QSPI_IRQMSK_RXFULL_E_DISD | 0x0 | Disable Interrupt by Masking
3455  * ALT_QSPI_IRQMSK_RXFULL_E_END | 0x1 | Enable Interrupt
3456  *
3457  * Field Access Macros:
3458  *
3459  */
3460 /*
3461  * Enumerated value for register field ALT_QSPI_IRQMSK_RXFULL
3462  *
3463  * Disable Interrupt by Masking
3464  */
3465 #define ALT_QSPI_IRQMSK_RXFULL_E_DISD 0x0
3466 /*
3467  * Enumerated value for register field ALT_QSPI_IRQMSK_RXFULL
3468  *
3469  * Enable Interrupt
3470  */
3471 #define ALT_QSPI_IRQMSK_RXFULL_E_END 0x1
3472
3473 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_RXFULL register field. */
3474 #define ALT_QSPI_IRQMSK_RXFULL_LSB 11
3475 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_RXFULL register field. */
3476 #define ALT_QSPI_IRQMSK_RXFULL_MSB 11
3477 /* The width in bits of the ALT_QSPI_IRQMSK_RXFULL register field. */
3478 #define ALT_QSPI_IRQMSK_RXFULL_WIDTH 1
3479 /* The mask used to set the ALT_QSPI_IRQMSK_RXFULL register field value. */
3480 #define ALT_QSPI_IRQMSK_RXFULL_SET_MSK 0x00000800
3481 /* The mask used to clear the ALT_QSPI_IRQMSK_RXFULL register field value. */
3482 #define ALT_QSPI_IRQMSK_RXFULL_CLR_MSK 0xfffff7ff
3483 /* The reset value of the ALT_QSPI_IRQMSK_RXFULL register field. */
3484 #define ALT_QSPI_IRQMSK_RXFULL_RESET 0x0
3485 /* Extracts the ALT_QSPI_IRQMSK_RXFULL field value from a register. */
3486 #define ALT_QSPI_IRQMSK_RXFULL_GET(value) (((value) & 0x00000800) >> 11)
3487 /* Produces a ALT_QSPI_IRQMSK_RXFULL register field value suitable for setting the register. */
3488 #define ALT_QSPI_IRQMSK_RXFULL_SET(value) (((value) << 11) & 0x00000800)
3489
3490 /*
3491  * Field : Indirect Read Partition overflow mask - indsramfull
3492  *
3493  * Field Enumeration Values:
3494  *
3495  * Enum | Value | Description
3496  * :-----------------------------------|:------|:-----------------------------
3497  * ALT_QSPI_IRQMSK_INDSRAMFULL_E_DISD | 0x0 | Disable Interrupt by Masking
3498  * ALT_QSPI_IRQMSK_INDSRAMFULL_E_END | 0x1 | Enable Interrupt
3499  *
3500  * Field Access Macros:
3501  *
3502  */
3503 /*
3504  * Enumerated value for register field ALT_QSPI_IRQMSK_INDSRAMFULL
3505  *
3506  * Disable Interrupt by Masking
3507  */
3508 #define ALT_QSPI_IRQMSK_INDSRAMFULL_E_DISD 0x0
3509 /*
3510  * Enumerated value for register field ALT_QSPI_IRQMSK_INDSRAMFULL
3511  *
3512  * Enable Interrupt
3513  */
3514 #define ALT_QSPI_IRQMSK_INDSRAMFULL_E_END 0x1
3515
3516 /* The Least Significant Bit (LSB) position of the ALT_QSPI_IRQMSK_INDSRAMFULL register field. */
3517 #define ALT_QSPI_IRQMSK_INDSRAMFULL_LSB 12
3518 /* The Most Significant Bit (MSB) position of the ALT_QSPI_IRQMSK_INDSRAMFULL register field. */
3519 #define ALT_QSPI_IRQMSK_INDSRAMFULL_MSB 12
3520 /* The width in bits of the ALT_QSPI_IRQMSK_INDSRAMFULL register field. */
3521 #define ALT_QSPI_IRQMSK_INDSRAMFULL_WIDTH 1
3522 /* The mask used to set the ALT_QSPI_IRQMSK_INDSRAMFULL register field value. */
3523 #define ALT_QSPI_IRQMSK_INDSRAMFULL_SET_MSK 0x00001000
3524 /* The mask used to clear the ALT_QSPI_IRQMSK_INDSRAMFULL register field value. */
3525 #define ALT_QSPI_IRQMSK_INDSRAMFULL_CLR_MSK 0xffffefff
3526 /* The reset value of the ALT_QSPI_IRQMSK_INDSRAMFULL register field. */
3527 #define ALT_QSPI_IRQMSK_INDSRAMFULL_RESET 0x0
3528 /* Extracts the ALT_QSPI_IRQMSK_INDSRAMFULL field value from a register. */
3529 #define ALT_QSPI_IRQMSK_INDSRAMFULL_GET(value) (((value) & 0x00001000) >> 12)
3530 /* Produces a ALT_QSPI_IRQMSK_INDSRAMFULL register field value suitable for setting the register. */
3531 #define ALT_QSPI_IRQMSK_INDSRAMFULL_SET(value) (((value) << 12) & 0x00001000)
3532
3533 #ifndef __ASSEMBLY__
3534 /*
3535  * WARNING: The C register and register group struct declarations are provided for
3536  * convenience and illustrative purposes. They should, however, be used with
3537  * caution as the C language standard provides no guarantees about the alignment or
3538  * atomicity of device memory accesses. The recommended practice for writing
3539  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3540  * alt_write_word() functions.
3541  *
3542  * The struct declaration for register ALT_QSPI_IRQMSK.
3543  */
3545 {
3546  uint32_t : 1; /* *UNDEFINED* */
3547  uint32_t underflowdet : 1; /* Underflow Detected Mask */
3548  uint32_t indopdone : 1; /* Mask */
3549  uint32_t indrdreject : 1; /* Indirect Read Reject Mask */
3550  uint32_t protwrattempt : 1; /* Protected Area Write Attempt Mask */
3551  uint32_t illegalacc : 1; /* Illegal Access Detected Mask */
3552  uint32_t indxfrlvl : 1; /* Transfer Watermark Breach Mask */
3553  uint32_t rxover : 1; /* Receive Overflow Mask */
3554  uint32_t txthreshcmp : 1; /* Transmit FIFO Threshold Compare Mask */
3555  uint32_t txfull : 1; /* Transmit FIFO Full Mask */
3556  uint32_t rxthreshcmp : 1; /* Receive FIFO Threshold Compare Mask */
3557  uint32_t rxfull : 1; /* Receive FIFO full Mask */
3558  uint32_t indsramfull : 1; /* Indirect Read Partition overflow mask */
3559  uint32_t : 19; /* *UNDEFINED* */
3560 };
3561
3562 /* The typedef declaration for register ALT_QSPI_IRQMSK. */
3563 typedef volatile struct ALT_QSPI_IRQMSK_s ALT_QSPI_IRQMSK_t;
3564 #endif /* __ASSEMBLY__ */
3565
3566 /* The byte offset of the ALT_QSPI_IRQMSK register from the beginning of the component. */
3567 #define ALT_QSPI_IRQMSK_OFST 0x44
3568
3569 /*
3570  * Register : Lower Write Protection Register - lowwrprot
3571  *
3572  * Register Layout
3573  *
3574  * Bits | Access | Reset | Description
3575  * :-------|:-------|:------|:-------------
3576  * [31:0] | RW | 0x0 | Block Number
3577  *
3578  */
3579 /*
3580  * Field : Block Number - subsector
3581  *
3582  * The block number that defines the lower block in the range of blocks that is to
3583  * be locked from writing. The definition of a block in terms of number of bytes is
3584  * programmable via the Device Size Configuration register.
3585  *
3586  * Field Access Macros:
3587  *
3588  */
3589 /* The Least Significant Bit (LSB) position of the ALT_QSPI_LOWWRPROT_SUBSECTOR register field. */
3590 #define ALT_QSPI_LOWWRPROT_SUBSECTOR_LSB 0
3591 /* The Most Significant Bit (MSB) position of the ALT_QSPI_LOWWRPROT_SUBSECTOR register field. */
3592 #define ALT_QSPI_LOWWRPROT_SUBSECTOR_MSB 31
3593 /* The width in bits of the ALT_QSPI_LOWWRPROT_SUBSECTOR register field. */
3594 #define ALT_QSPI_LOWWRPROT_SUBSECTOR_WIDTH 32
3595 /* The mask used to set the ALT_QSPI_LOWWRPROT_SUBSECTOR register field value. */
3596 #define ALT_QSPI_LOWWRPROT_SUBSECTOR_SET_MSK 0xffffffff
3597 /* The mask used to clear the ALT_QSPI_LOWWRPROT_SUBSECTOR register field value. */
3598 #define ALT_QSPI_LOWWRPROT_SUBSECTOR_CLR_MSK 0x00000000
3599 /* The reset value of the ALT_QSPI_LOWWRPROT_SUBSECTOR register field. */
3600 #define ALT_QSPI_LOWWRPROT_SUBSECTOR_RESET 0x0
3601 /* Extracts the ALT_QSPI_LOWWRPROT_SUBSECTOR field value from a register. */
3602 #define ALT_QSPI_LOWWRPROT_SUBSECTOR_GET(value) (((value) & 0xffffffff) >> 0)
3603 /* Produces a ALT_QSPI_LOWWRPROT_SUBSECTOR register field value suitable for setting the register. */
3604 #define ALT_QSPI_LOWWRPROT_SUBSECTOR_SET(value) (((value) << 0) & 0xffffffff)
3605
3606 #ifndef __ASSEMBLY__
3607 /*
3608  * WARNING: The C register and register group struct declarations are provided for
3609  * convenience and illustrative purposes. They should, however, be used with
3610  * caution as the C language standard provides no guarantees about the alignment or
3611  * atomicity of device memory accesses. The recommended practice for writing
3612  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3613  * alt_write_word() functions.
3614  *
3615  * The struct declaration for register ALT_QSPI_LOWWRPROT.
3616  */
3618 {
3619  uint32_t subsector : 32; /* Block Number */
3620 };
3621
3622 /* The typedef declaration for register ALT_QSPI_LOWWRPROT. */
3623 typedef volatile struct ALT_QSPI_LOWWRPROT_s ALT_QSPI_LOWWRPROT_t;
3624 #endif /* __ASSEMBLY__ */
3625
3626 /* The byte offset of the ALT_QSPI_LOWWRPROT register from the beginning of the component. */
3627 #define ALT_QSPI_LOWWRPROT_OFST 0x50
3628
3629 /*
3630  * Register : Upper Write Protection Register - uppwrprot
3631  *
3632  * Register Layout
3633  *
3634  * Bits | Access | Reset | Description
3635  * :-------|:-------|:------|:-------------
3636  * [31:0] | RW | 0x0 | Block Number
3637  *
3638  */
3639 /*
3640  * Field : Block Number - subsector
3641  *
3642  * The block number that defines the upper block in the range of blocks that is to
3643  * be locked from writing. The definition of a block in terms of number of bytes is
3644  * programmable via the Device Size Configuration register.
3645  *
3646  * Field Access Macros:
3647  *
3648  */
3649 /* The Least Significant Bit (LSB) position of the ALT_QSPI_UPPWRPROT_SUBSECTOR register field. */
3650 #define ALT_QSPI_UPPWRPROT_SUBSECTOR_LSB 0
3651 /* The Most Significant Bit (MSB) position of the ALT_QSPI_UPPWRPROT_SUBSECTOR register field. */
3652 #define ALT_QSPI_UPPWRPROT_SUBSECTOR_MSB 31
3653 /* The width in bits of the ALT_QSPI_UPPWRPROT_SUBSECTOR register field. */
3654 #define ALT_QSPI_UPPWRPROT_SUBSECTOR_WIDTH 32
3655 /* The mask used to set the ALT_QSPI_UPPWRPROT_SUBSECTOR register field value. */
3656 #define ALT_QSPI_UPPWRPROT_SUBSECTOR_SET_MSK 0xffffffff
3657 /* The mask used to clear the ALT_QSPI_UPPWRPROT_SUBSECTOR register field value. */
3658 #define ALT_QSPI_UPPWRPROT_SUBSECTOR_CLR_MSK 0x00000000
3659 /* The reset value of the ALT_QSPI_UPPWRPROT_SUBSECTOR register field. */
3660 #define ALT_QSPI_UPPWRPROT_SUBSECTOR_RESET 0x0
3661 /* Extracts the ALT_QSPI_UPPWRPROT_SUBSECTOR field value from a register. */
3662 #define ALT_QSPI_UPPWRPROT_SUBSECTOR_GET(value) (((value) & 0xffffffff) >> 0)
3663 /* Produces a ALT_QSPI_UPPWRPROT_SUBSECTOR register field value suitable for setting the register. */
3664 #define ALT_QSPI_UPPWRPROT_SUBSECTOR_SET(value) (((value) << 0) & 0xffffffff)
3665
3666 #ifndef __ASSEMBLY__
3667 /*
3668  * WARNING: The C register and register group struct declarations are provided for
3669  * convenience and illustrative purposes. They should, however, be used with
3670  * caution as the C language standard provides no guarantees about the alignment or
3671  * atomicity of device memory accesses. The recommended practice for writing
3672  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3673  * alt_write_word() functions.
3674  *
3675  * The struct declaration for register ALT_QSPI_UPPWRPROT.
3676  */
3678 {
3679  uint32_t subsector : 32; /* Block Number */
3680 };
3681
3682 /* The typedef declaration for register ALT_QSPI_UPPWRPROT. */
3683 typedef volatile struct ALT_QSPI_UPPWRPROT_s ALT_QSPI_UPPWRPROT_t;
3684 #endif /* __ASSEMBLY__ */
3685
3686 /* The byte offset of the ALT_QSPI_UPPWRPROT register from the beginning of the component. */
3687 #define ALT_QSPI_UPPWRPROT_OFST 0x54
3688
3689 /*
3690  * Register : Write Protection Register - wrprot
3691  *
3692  * Register Layout
3693  *
3694  * Bits | Access | Reset | Description
3695  * :-------|:-------|:------|:-------------------------------
3696  * [0] | RW | 0x0 | Write Protection Inversion Bit
3697  * [1] | RW | 0x0 | Write Protection Enable Bit
3698  * [31:2] | ??? | 0x0 | *UNDEFINED*
3699  *
3700  */
3701 /*
3702  * Field : Write Protection Inversion Bit - inv
3703  *
3704  * When enabled, the protection region defined in the lower and upper write
3705  * protection registers is inverted meaning it is the region that the system is
3706  * permitted to write to. When disabled, the protection region defined in the lower
3707  * and upper write protection registers is the region that the system is not
3708  * permitted to write to.
3709  *
3710  * Field Enumeration Values:
3711  *
3712  * Enum | Value | Description
3713  * :--------------------------|:------|:-------------------------
3714  * ALT_QSPI_WRPROT_INV_E_EN | 0x1 | Write Region allowed
3715  * ALT_QSPI_WRPROT_INV_E_DIS | 0x0 | Write Region not allowed
3716  *
3717  * Field Access Macros:
3718  *
3719  */
3720 /*
3721  * Enumerated value for register field ALT_QSPI_WRPROT_INV
3722  *
3723  * Write Region allowed
3724  */
3725 #define ALT_QSPI_WRPROT_INV_E_EN 0x1
3726 /*
3727  * Enumerated value for register field ALT_QSPI_WRPROT_INV
3728  *
3729  * Write Region not allowed
3730  */
3731 #define ALT_QSPI_WRPROT_INV_E_DIS 0x0
3732
3733 /* The Least Significant Bit (LSB) position of the ALT_QSPI_WRPROT_INV register field. */
3734 #define ALT_QSPI_WRPROT_INV_LSB 0
3735 /* The Most Significant Bit (MSB) position of the ALT_QSPI_WRPROT_INV register field. */
3736 #define ALT_QSPI_WRPROT_INV_MSB 0
3737 /* The width in bits of the ALT_QSPI_WRPROT_INV register field. */
3738 #define ALT_QSPI_WRPROT_INV_WIDTH 1
3739 /* The mask used to set the ALT_QSPI_WRPROT_INV register field value. */
3740 #define ALT_QSPI_WRPROT_INV_SET_MSK 0x00000001
3741 /* The mask used to clear the ALT_QSPI_WRPROT_INV register field value. */
3742 #define ALT_QSPI_WRPROT_INV_CLR_MSK 0xfffffffe
3743 /* The reset value of the ALT_QSPI_WRPROT_INV register field. */
3744 #define ALT_QSPI_WRPROT_INV_RESET 0x0
3745 /* Extracts the ALT_QSPI_WRPROT_INV field value from a register. */
3746 #define ALT_QSPI_WRPROT_INV_GET(value) (((value) & 0x00000001) >> 0)
3747 /* Produces a ALT_QSPI_WRPROT_INV register field value suitable for setting the register. */
3748 #define ALT_QSPI_WRPROT_INV_SET(value) (((value) << 0) & 0x00000001)
3749
3750 /*
3751  * Field : Write Protection Enable Bit - en
3752  *
3753  * When enabled, any AHB write access with an address within the protection region
3754  * defined in the lower and upper write protection registers is rejected. An AHB
3755  * error response is generated and an interrupt source triggered. When disabled,
3756  * the protection region is disabled.
3757  *
3758  * Field Enumeration Values:
3759  *
3760  * Enum | Value | Description
3761  * :-------------------------|:------|:---------------------------
3762  * ALT_QSPI_WRPROT_EN_E_EN | 0x1 | AHB Write Access rejected
3763  * ALT_QSPI_WRPROT_EN_E_DIS | 0x0 | Protection Region Disabled
3764  *
3765  * Field Access Macros:
3766  *
3767  */
3768 /*
3769  * Enumerated value for register field ALT_QSPI_WRPROT_EN
3770  *
3771  * AHB Write Access rejected
3772  */
3773 #define ALT_QSPI_WRPROT_EN_E_EN 0x1
3774 /*
3775  * Enumerated value for register field ALT_QSPI_WRPROT_EN
3776  *
3777  * Protection Region Disabled
3778  */
3779 #define ALT_QSPI_WRPROT_EN_E_DIS 0x0
3780
3781 /* The Least Significant Bit (LSB) position of the ALT_QSPI_WRPROT_EN register field. */
3782 #define ALT_QSPI_WRPROT_EN_LSB 1
3783 /* The Most Significant Bit (MSB) position of the ALT_QSPI_WRPROT_EN register field. */
3784 #define ALT_QSPI_WRPROT_EN_MSB 1
3785 /* The width in bits of the ALT_QSPI_WRPROT_EN register field. */
3786 #define ALT_QSPI_WRPROT_EN_WIDTH 1
3787 /* The mask used to set the ALT_QSPI_WRPROT_EN register field value. */
3788 #define ALT_QSPI_WRPROT_EN_SET_MSK 0x00000002
3789 /* The mask used to clear the ALT_QSPI_WRPROT_EN register field value. */
3790 #define ALT_QSPI_WRPROT_EN_CLR_MSK 0xfffffffd
3791 /* The reset value of the ALT_QSPI_WRPROT_EN register field. */
3792 #define ALT_QSPI_WRPROT_EN_RESET 0x0
3793 /* Extracts the ALT_QSPI_WRPROT_EN field value from a register. */
3794 #define ALT_QSPI_WRPROT_EN_GET(value) (((value) & 0x00000002) >> 1)
3795 /* Produces a ALT_QSPI_WRPROT_EN register field value suitable for setting the register. */
3796 #define ALT_QSPI_WRPROT_EN_SET(value) (((value) << 1) & 0x00000002)
3797
3798 #ifndef __ASSEMBLY__
3799 /*
3800  * WARNING: The C register and register group struct declarations are provided for
3801  * convenience and illustrative purposes. They should, however, be used with
3802  * caution as the C language standard provides no guarantees about the alignment or
3803  * atomicity of device memory accesses. The recommended practice for writing
3804  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3805  * alt_write_word() functions.
3806  *
3807  * The struct declaration for register ALT_QSPI_WRPROT.
3808  */
3810 {
3811  uint32_t inv : 1; /* Write Protection Inversion Bit */
3812  uint32_t en : 1; /* Write Protection Enable Bit */
3813  uint32_t : 30; /* *UNDEFINED* */
3814 };
3815
3816 /* The typedef declaration for register ALT_QSPI_WRPROT. */
3817 typedef volatile struct ALT_QSPI_WRPROT_s ALT_QSPI_WRPROT_t;
3818 #endif /* __ASSEMBLY__ */
3819
3820 /* The byte offset of the ALT_QSPI_WRPROT register from the beginning of the component. */
3821 #define ALT_QSPI_WRPROT_OFST 0x58
3822
3823 /*
3824  * Register : Indirect Read Transfer Register - indrd
3825  *
3826  * Register Layout
3827  *
3828  * Bits | Access | Reset | Description
3829  * :-------|:-------|:--------|:--------------------------------
3830  * [0] | RW | 0x0 | Start Indirect Read
3831  * [1] | RW | 0x0 | Cancel Indirect Read
3832  * [2] | R | Unknown | Indirect Read Status
3833  * [3] | RW | Unknown | SRAM Full
3834  * [4] | R | Unknown | Queued Indirect Read Operations
3835  * [5] | RW | Unknown | Indirect Completion Status
3836  * [7:6] | R | Unknown | Completed Indirect Operations
3837  * [31:8] | ??? | 0x0 | *UNDEFINED*
3838  *
3839  */
3840 /*
3841  * Field : Start Indirect Read - start
3842  *
3843  * When this bit is enabled, it will trigger an indirect read operation. The
3844  * assumption is that the indirect start address and the indirect number of bytes
3845  * register is setup before triggering the indirect read operation.
3846  *
3847  * Field Enumeration Values:
3848  *
3849  * Enum | Value | Description
3850  * :----------------------------|:------|:----------------------
3851  * ALT_QSPI_INDRD_START_E_END | 0x1 | Trigger Indirect Read
3852  * ALT_QSPI_INDRD_START_E_DISD | 0x0 | No Indirect Read
3853  *
3854  * Field Access Macros:
3855  *
3856  */
3857 /*
3858  * Enumerated value for register field ALT_QSPI_INDRD_START
3859  *
3860  * Trigger Indirect Read
3861  */
3862 #define ALT_QSPI_INDRD_START_E_END 0x1
3863 /*
3864  * Enumerated value for register field ALT_QSPI_INDRD_START
3865  *
3866  * No Indirect Read
3867  */
3868 #define ALT_QSPI_INDRD_START_E_DISD 0x0
3869
3870 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDRD_START register field. */
3871 #define ALT_QSPI_INDRD_START_LSB 0
3872 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDRD_START register field. */
3873 #define ALT_QSPI_INDRD_START_MSB 0
3874 /* The width in bits of the ALT_QSPI_INDRD_START register field. */
3875 #define ALT_QSPI_INDRD_START_WIDTH 1
3876 /* The mask used to set the ALT_QSPI_INDRD_START register field value. */
3877 #define ALT_QSPI_INDRD_START_SET_MSK 0x00000001
3878 /* The mask used to clear the ALT_QSPI_INDRD_START register field value. */
3879 #define ALT_QSPI_INDRD_START_CLR_MSK 0xfffffffe
3880 /* The reset value of the ALT_QSPI_INDRD_START register field. */
3881 #define ALT_QSPI_INDRD_START_RESET 0x0
3882 /* Extracts the ALT_QSPI_INDRD_START field value from a register. */
3883 #define ALT_QSPI_INDRD_START_GET(value) (((value) & 0x00000001) >> 0)
3884 /* Produces a ALT_QSPI_INDRD_START register field value suitable for setting the register. */
3885 #define ALT_QSPI_INDRD_START_SET(value) (((value) << 0) & 0x00000001)
3886
3887 /*
3888  * Field : Cancel Indirect Read - cancel
3889  *
3890  * This bit will cancel all ongoing indirect read operations.
3891  *
3892  * Field Enumeration Values:
3893  *
3894  * Enum | Value | Description
3895  * :---------------------------------|:------|:----------------------------
3896  * ALT_QSPI_INDRD_CANCEL_E_CANCEL | 0x1 | Cancel Indirect Read
3897  * ALT_QSPI_INDRD_CANCEL_E_NOACTION | 0x0 | Do Not Cancel Indirect Read
3898  *
3899  * Field Access Macros:
3900  *
3901  */
3902 /*
3903  * Enumerated value for register field ALT_QSPI_INDRD_CANCEL
3904  *
3905  * Cancel Indirect Read
3906  */
3907 #define ALT_QSPI_INDRD_CANCEL_E_CANCEL 0x1
3908 /*
3909  * Enumerated value for register field ALT_QSPI_INDRD_CANCEL
3910  *
3911  * Do Not Cancel Indirect Read
3912  */
3913 #define ALT_QSPI_INDRD_CANCEL_E_NOACTION 0x0
3914
3915 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDRD_CANCEL register field. */
3916 #define ALT_QSPI_INDRD_CANCEL_LSB 1
3917 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDRD_CANCEL register field. */
3918 #define ALT_QSPI_INDRD_CANCEL_MSB 1
3919 /* The width in bits of the ALT_QSPI_INDRD_CANCEL register field. */
3920 #define ALT_QSPI_INDRD_CANCEL_WIDTH 1
3921 /* The mask used to set the ALT_QSPI_INDRD_CANCEL register field value. */
3922 #define ALT_QSPI_INDRD_CANCEL_SET_MSK 0x00000002
3923 /* The mask used to clear the ALT_QSPI_INDRD_CANCEL register field value. */
3924 #define ALT_QSPI_INDRD_CANCEL_CLR_MSK 0xfffffffd
3925 /* The reset value of the ALT_QSPI_INDRD_CANCEL register field. */
3926 #define ALT_QSPI_INDRD_CANCEL_RESET 0x0
3927 /* Extracts the ALT_QSPI_INDRD_CANCEL field value from a register. */
3928 #define ALT_QSPI_INDRD_CANCEL_GET(value) (((value) & 0x00000002) >> 1)
3929 /* Produces a ALT_QSPI_INDRD_CANCEL register field value suitable for setting the register. */
3930 #define ALT_QSPI_INDRD_CANCEL_SET(value) (((value) << 1) & 0x00000002)
3931
3932 /*
3933  * Field : Indirect Read Status - rd_status
3934  *
3935  * Indirect read operation in progress (status)
3936  *
3937  * Field Enumeration Values:
3938  *
3939  * Enum | Value | Description
3940  * :----------------------------------|:------|:------------------------------
3941  * ALT_QSPI_INDRD_RD_STAT_E_RDOP | 0x1 | Read Operation in progress
3942  * ALT_QSPI_INDRD_RD_STAT_E_NOACTION | 0x0 | No read operation in progress
3943  *
3944  * Field Access Macros:
3945  *
3946  */
3947 /*
3948  * Enumerated value for register field ALT_QSPI_INDRD_RD_STAT
3949  *
3950  * Read Operation in progress
3951  */
3952 #define ALT_QSPI_INDRD_RD_STAT_E_RDOP 0x1
3953 /*
3954  * Enumerated value for register field ALT_QSPI_INDRD_RD_STAT
3955  *
3956  * No read operation in progress
3957  */
3958 #define ALT_QSPI_INDRD_RD_STAT_E_NOACTION 0x0
3959
3960 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDRD_RD_STAT register field. */
3961 #define ALT_QSPI_INDRD_RD_STAT_LSB 2
3962 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDRD_RD_STAT register field. */
3963 #define ALT_QSPI_INDRD_RD_STAT_MSB 2
3964 /* The width in bits of the ALT_QSPI_INDRD_RD_STAT register field. */
3965 #define ALT_QSPI_INDRD_RD_STAT_WIDTH 1
3966 /* The mask used to set the ALT_QSPI_INDRD_RD_STAT register field value. */
3967 #define ALT_QSPI_INDRD_RD_STAT_SET_MSK 0x00000004
3968 /* The mask used to clear the ALT_QSPI_INDRD_RD_STAT register field value. */
3969 #define ALT_QSPI_INDRD_RD_STAT_CLR_MSK 0xfffffffb
3970 /* The reset value of the ALT_QSPI_INDRD_RD_STAT register field is UNKNOWN. */
3971 #define ALT_QSPI_INDRD_RD_STAT_RESET 0x0
3972 /* Extracts the ALT_QSPI_INDRD_RD_STAT field value from a register. */
3973 #define ALT_QSPI_INDRD_RD_STAT_GET(value) (((value) & 0x00000004) >> 2)
3974 /* Produces a ALT_QSPI_INDRD_RD_STAT register field value suitable for setting the register. */
3975 #define ALT_QSPI_INDRD_RD_STAT_SET(value) (((value) << 2) & 0x00000004)
3976
3977 /*
3978  * Field : SRAM Full - sram_full
3979  *
3980  * SRAM full and unable to immediately complete an indirect operation. Write a 1 to
3981  * this field to clear it. ; indirect operation (status)
3982  *
3983  * Field Enumeration Values:
3984  *
3985  * Enum | Value | Description
3986  * :------------------------------------|:------|:-----------------------------------
3987  * ALT_QSPI_INDRD_SRAM_FULL_E_SRAMFULL | 0x1 | Sram Full- Cant complete operation
3988  * ALT_QSPI_INDRD_SRAM_FULL_E_NOACTION | 0x0 | SRram Not Full
3989  *
3990  * Field Access Macros:
3991  *
3992  */
3993 /*
3994  * Enumerated value for register field ALT_QSPI_INDRD_SRAM_FULL
3995  *
3996  * Sram Full- Cant complete operation
3997  */
3998 #define ALT_QSPI_INDRD_SRAM_FULL_E_SRAMFULL 0x1
3999 /*
4000  * Enumerated value for register field ALT_QSPI_INDRD_SRAM_FULL
4001  *
4002  * SRram Not Full
4003  */
4004 #define ALT_QSPI_INDRD_SRAM_FULL_E_NOACTION 0x0
4005
4006 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDRD_SRAM_FULL register field. */
4007 #define ALT_QSPI_INDRD_SRAM_FULL_LSB 3
4008 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDRD_SRAM_FULL register field. */
4009 #define ALT_QSPI_INDRD_SRAM_FULL_MSB 3
4010 /* The width in bits of the ALT_QSPI_INDRD_SRAM_FULL register field. */
4011 #define ALT_QSPI_INDRD_SRAM_FULL_WIDTH 1
4012 /* The mask used to set the ALT_QSPI_INDRD_SRAM_FULL register field value. */
4013 #define ALT_QSPI_INDRD_SRAM_FULL_SET_MSK 0x00000008
4014 /* The mask used to clear the ALT_QSPI_INDRD_SRAM_FULL register field value. */
4015 #define ALT_QSPI_INDRD_SRAM_FULL_CLR_MSK 0xfffffff7
4016 /* The reset value of the ALT_QSPI_INDRD_SRAM_FULL register field is UNKNOWN. */
4017 #define ALT_QSPI_INDRD_SRAM_FULL_RESET 0x0
4018 /* Extracts the ALT_QSPI_INDRD_SRAM_FULL field value from a register. */
4019 #define ALT_QSPI_INDRD_SRAM_FULL_GET(value) (((value) & 0x00000008) >> 3)
4020 /* Produces a ALT_QSPI_INDRD_SRAM_FULL register field value suitable for setting the register. */
4021 #define ALT_QSPI_INDRD_SRAM_FULL_SET(value) (((value) << 3) & 0x00000008)
4022
4023 /*
4024  * Field : Queued Indirect Read Operations - rd_queued
4025  *
4026  * Two indirect read operations have been queued
4027  *
4028  * Field Enumeration Values:
4029  *
4030  * Enum | Value | Description
4031  * :----------------------------------------|:------|:---------------------
4032  * ALT_QSPI_INDRD_RD_QUEUED_E_QUINDIRECTRD | 0x1 | Queued Indirect Read
4033  * ALT_QSPI_INDRD_RD_QUEUED_E_NOACTION | 0x0 | No Queued Read
4034  *
4035  * Field Access Macros:
4036  *
4037  */
4038 /*
4039  * Enumerated value for register field ALT_QSPI_INDRD_RD_QUEUED
4040  *
4041  * Queued Indirect Read
4042  */
4043 #define ALT_QSPI_INDRD_RD_QUEUED_E_QUINDIRECTRD 0x1
4044 /*
4045  * Enumerated value for register field ALT_QSPI_INDRD_RD_QUEUED
4046  *
4047  * No Queued Read
4048  */
4049 #define ALT_QSPI_INDRD_RD_QUEUED_E_NOACTION 0x0
4050
4051 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDRD_RD_QUEUED register field. */
4052 #define ALT_QSPI_INDRD_RD_QUEUED_LSB 4
4053 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDRD_RD_QUEUED register field. */
4054 #define ALT_QSPI_INDRD_RD_QUEUED_MSB 4
4055 /* The width in bits of the ALT_QSPI_INDRD_RD_QUEUED register field. */
4056 #define ALT_QSPI_INDRD_RD_QUEUED_WIDTH 1
4057 /* The mask used to set the ALT_QSPI_INDRD_RD_QUEUED register field value. */
4058 #define ALT_QSPI_INDRD_RD_QUEUED_SET_MSK 0x00000010
4059 /* The mask used to clear the ALT_QSPI_INDRD_RD_QUEUED register field value. */
4060 #define ALT_QSPI_INDRD_RD_QUEUED_CLR_MSK 0xffffffef
4061 /* The reset value of the ALT_QSPI_INDRD_RD_QUEUED register field is UNKNOWN. */
4062 #define ALT_QSPI_INDRD_RD_QUEUED_RESET 0x0
4063 /* Extracts the ALT_QSPI_INDRD_RD_QUEUED field value from a register. */
4064 #define ALT_QSPI_INDRD_RD_QUEUED_GET(value) (((value) & 0x00000010) >> 4)
4065 /* Produces a ALT_QSPI_INDRD_RD_QUEUED register field value suitable for setting the register. */
4066 #define ALT_QSPI_INDRD_RD_QUEUED_SET(value) (((value) << 4) & 0x00000010)
4067
4068 /*
4069  * Field : Indirect Completion Status - ind_ops_done_status
4070  *
4071  * This field is set to 1 when an indirect operation has completed. Write a 1 to
4072  * this field to clear it.
4073  *
4074  * Field Enumeration Values:
4075  *
4076  * Enum | Value | Description
4077  * :--------------------------------------------|:------|:-------------------------------
4078  * ALT_QSPI_INDRD_IND_OPS_DONE_STAT_E_INDCOMP | 0x1 | Indirect Op Complete operation
4079  * ALT_QSPI_INDRD_IND_OPS_DONE_STAT_E_NOACTION | 0x0 | Indirect Op Not Complete
4080  *
4081  * Field Access Macros:
4082  *
4083  */
4084 /*
4085  * Enumerated value for register field ALT_QSPI_INDRD_IND_OPS_DONE_STAT
4086  *
4087  * Indirect Op Complete operation
4088  */
4089 #define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_E_INDCOMP 0x1
4090 /*
4091  * Enumerated value for register field ALT_QSPI_INDRD_IND_OPS_DONE_STAT
4092  *
4093  * Indirect Op Not Complete
4094  */
4095 #define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_E_NOACTION 0x0
4096
4097 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDRD_IND_OPS_DONE_STAT register field. */
4098 #define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_LSB 5
4099 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDRD_IND_OPS_DONE_STAT register field. */
4100 #define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_MSB 5
4101 /* The width in bits of the ALT_QSPI_INDRD_IND_OPS_DONE_STAT register field. */
4102 #define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_WIDTH 1
4103 /* The mask used to set the ALT_QSPI_INDRD_IND_OPS_DONE_STAT register field value. */
4104 #define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_SET_MSK 0x00000020
4105 /* The mask used to clear the ALT_QSPI_INDRD_IND_OPS_DONE_STAT register field value. */
4106 #define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_CLR_MSK 0xffffffdf
4107 /* The reset value of the ALT_QSPI_INDRD_IND_OPS_DONE_STAT register field is UNKNOWN. */
4108 #define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_RESET 0x0
4109 /* Extracts the ALT_QSPI_INDRD_IND_OPS_DONE_STAT field value from a register. */
4110 #define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_GET(value) (((value) & 0x00000020) >> 5)
4111 /* Produces a ALT_QSPI_INDRD_IND_OPS_DONE_STAT register field value suitable for setting the register. */
4112 #define ALT_QSPI_INDRD_IND_OPS_DONE_STAT_SET(value) (((value) << 5) & 0x00000020)
4113
4114 /*
4115  * Field : Completed Indirect Operations - num_ind_ops_done
4116  *
4117  * This field contains the number of indirect operations which have been completed.
4118  * This is used in conjunction with the indirect completion status field (bit 5).
4119  *
4120  * Field Access Macros:
4121  *
4122  */
4123 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDRD_NUM_IND_OPS_DONE register field. */
4124 #define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_LSB 6
4125 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDRD_NUM_IND_OPS_DONE register field. */
4126 #define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_MSB 7
4127 /* The width in bits of the ALT_QSPI_INDRD_NUM_IND_OPS_DONE register field. */
4128 #define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_WIDTH 2
4129 /* The mask used to set the ALT_QSPI_INDRD_NUM_IND_OPS_DONE register field value. */
4130 #define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_SET_MSK 0x000000c0
4131 /* The mask used to clear the ALT_QSPI_INDRD_NUM_IND_OPS_DONE register field value. */
4132 #define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_CLR_MSK 0xffffff3f
4133 /* The reset value of the ALT_QSPI_INDRD_NUM_IND_OPS_DONE register field is UNKNOWN. */
4134 #define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_RESET 0x0
4135 /* Extracts the ALT_QSPI_INDRD_NUM_IND_OPS_DONE field value from a register. */
4136 #define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_GET(value) (((value) & 0x000000c0) >> 6)
4137 /* Produces a ALT_QSPI_INDRD_NUM_IND_OPS_DONE register field value suitable for setting the register. */
4138 #define ALT_QSPI_INDRD_NUM_IND_OPS_DONE_SET(value) (((value) << 6) & 0x000000c0)
4139
4140 #ifndef __ASSEMBLY__
4141 /*
4142  * WARNING: The C register and register group struct declarations are provided for
4143  * convenience and illustrative purposes. They should, however, be used with
4144  * caution as the C language standard provides no guarantees about the alignment or
4145  * atomicity of device memory accesses. The recommended practice for writing
4146  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4147  * alt_write_word() functions.
4148  *
4149  * The struct declaration for register ALT_QSPI_INDRD.
4150  */
4152 {
4153  uint32_t start : 1; /* Start Indirect Read */
4154  uint32_t cancel : 1; /* Cancel Indirect Read */
4155  const uint32_t rd_status : 1; /* Indirect Read Status */
4156  uint32_t sram_full : 1; /* SRAM Full */
4157  const uint32_t rd_queued : 1; /* Queued Indirect Read Operations */
4158  uint32_t ind_ops_done_status : 1; /* Indirect Completion Status */
4159  const uint32_t num_ind_ops_done : 2; /* Completed Indirect Operations */
4160  uint32_t : 24; /* *UNDEFINED* */
4161 };
4162
4163 /* The typedef declaration for register ALT_QSPI_INDRD. */
4164 typedef volatile struct ALT_QSPI_INDRD_s ALT_QSPI_INDRD_t;
4165 #endif /* __ASSEMBLY__ */
4166
4167 /* The byte offset of the ALT_QSPI_INDRD register from the beginning of the component. */
4168 #define ALT_QSPI_INDRD_OFST 0x60
4169
4170 /*
4171  * Register : Indirect Read Transfer Watermark Register - indrdwater
4172  *
4173  * Register Layout
4174  *
4175  * Bits | Access | Reset | Description
4176  * :-------|:-------|:------|:----------------
4177  * [31:0] | RW | 0x0 | Watermark Value
4178  *
4179  */
4180 /*
4181  * Field : Watermark Value - level
4182  *
4183  * This represents the minimum fill level of the SRAM before a DMA peripheral
4184  * access is permitted. When the SRAM fill level passes the watermark, an interrupt
4185  * is also generated. This field can be disabled by writing a value of all zeroes.
4186  * The units of this register are BYTES
4187  *
4188  * Field Access Macros:
4189  *
4190  */
4191 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDRDWATER_LEVEL register field. */
4192 #define ALT_QSPI_INDRDWATER_LEVEL_LSB 0
4193 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDRDWATER_LEVEL register field. */
4194 #define ALT_QSPI_INDRDWATER_LEVEL_MSB 31
4195 /* The width in bits of the ALT_QSPI_INDRDWATER_LEVEL register field. */
4196 #define ALT_QSPI_INDRDWATER_LEVEL_WIDTH 32
4197 /* The mask used to set the ALT_QSPI_INDRDWATER_LEVEL register field value. */
4198 #define ALT_QSPI_INDRDWATER_LEVEL_SET_MSK 0xffffffff
4199 /* The mask used to clear the ALT_QSPI_INDRDWATER_LEVEL register field value. */
4200 #define ALT_QSPI_INDRDWATER_LEVEL_CLR_MSK 0x00000000
4201 /* The reset value of the ALT_QSPI_INDRDWATER_LEVEL register field. */
4202 #define ALT_QSPI_INDRDWATER_LEVEL_RESET 0x0
4203 /* Extracts the ALT_QSPI_INDRDWATER_LEVEL field value from a register. */
4204 #define ALT_QSPI_INDRDWATER_LEVEL_GET(value) (((value) & 0xffffffff) >> 0)
4205 /* Produces a ALT_QSPI_INDRDWATER_LEVEL register field value suitable for setting the register. */
4206 #define ALT_QSPI_INDRDWATER_LEVEL_SET(value) (((value) << 0) & 0xffffffff)
4207
4208 #ifndef __ASSEMBLY__
4209 /*
4210  * WARNING: The C register and register group struct declarations are provided for
4211  * convenience and illustrative purposes. They should, however, be used with
4212  * caution as the C language standard provides no guarantees about the alignment or
4213  * atomicity of device memory accesses. The recommended practice for writing
4214  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4215  * alt_write_word() functions.
4216  *
4217  * The struct declaration for register ALT_QSPI_INDRDWATER.
4218  */
4220 {
4221  uint32_t level : 32; /* Watermark Value */
4222 };
4223
4224 /* The typedef declaration for register ALT_QSPI_INDRDWATER. */
4225 typedef volatile struct ALT_QSPI_INDRDWATER_s ALT_QSPI_INDRDWATER_t;
4226 #endif /* __ASSEMBLY__ */
4227
4228 /* The byte offset of the ALT_QSPI_INDRDWATER register from the beginning of the component. */
4229 #define ALT_QSPI_INDRDWATER_OFST 0x64
4230
4231 /*
4232  * Register : Indirect Read Transfer Start Address Register - indrdstaddr
4233  *
4234  * Register Layout
4235  *
4236  * Bits | Access | Reset | Description
4237  * :-------|:-------|:------|:---------------------------------
4238  * [31:0] | RW | 0x0 | Start Address of Indirect Access
4239  *
4240  */
4241 /*
4242  * Field : Start Address of Indirect Access - addr
4243  *
4244  * This is the start address from which the indirect access will commence its READ
4245  * operation.
4246  *
4247  * Field Access Macros:
4248  *
4249  */
4250 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDRDSTADDR_ADDR register field. */
4251 #define ALT_QSPI_INDRDSTADDR_ADDR_LSB 0
4252 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDRDSTADDR_ADDR register field. */
4253 #define ALT_QSPI_INDRDSTADDR_ADDR_MSB 31
4254 /* The width in bits of the ALT_QSPI_INDRDSTADDR_ADDR register field. */
4255 #define ALT_QSPI_INDRDSTADDR_ADDR_WIDTH 32
4256 /* The mask used to set the ALT_QSPI_INDRDSTADDR_ADDR register field value. */
4257 #define ALT_QSPI_INDRDSTADDR_ADDR_SET_MSK 0xffffffff
4258 /* The mask used to clear the ALT_QSPI_INDRDSTADDR_ADDR register field value. */
4259 #define ALT_QSPI_INDRDSTADDR_ADDR_CLR_MSK 0x00000000
4260 /* The reset value of the ALT_QSPI_INDRDSTADDR_ADDR register field. */
4261 #define ALT_QSPI_INDRDSTADDR_ADDR_RESET 0x0
4262 /* Extracts the ALT_QSPI_INDRDSTADDR_ADDR field value from a register. */
4263 #define ALT_QSPI_INDRDSTADDR_ADDR_GET(value) (((value) & 0xffffffff) >> 0)
4264 /* Produces a ALT_QSPI_INDRDSTADDR_ADDR register field value suitable for setting the register. */
4265 #define ALT_QSPI_INDRDSTADDR_ADDR_SET(value) (((value) << 0) & 0xffffffff)
4266
4267 #ifndef __ASSEMBLY__
4268 /*
4269  * WARNING: The C register and register group struct declarations are provided for
4270  * convenience and illustrative purposes. They should, however, be used with
4271  * caution as the C language standard provides no guarantees about the alignment or
4272  * atomicity of device memory accesses. The recommended practice for writing
4273  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4274  * alt_write_word() functions.
4275  *
4276  * The struct declaration for register ALT_QSPI_INDRDSTADDR.
4277  */
4279 {
4280  uint32_t addr : 32; /* Start Address of Indirect Access */
4281 };
4282
4283 /* The typedef declaration for register ALT_QSPI_INDRDSTADDR. */
4284 typedef volatile struct ALT_QSPI_INDRDSTADDR_s ALT_QSPI_INDRDSTADDR_t;
4285 #endif /* __ASSEMBLY__ */
4286
4287 /* The byte offset of the ALT_QSPI_INDRDSTADDR register from the beginning of the component. */
4288 #define ALT_QSPI_INDRDSTADDR_OFST 0x68
4289
4290 /*
4291  * Register : Indirect Read Transfer Number Bytes Register - indrdcnt
4292  *
4293  * Register Layout
4294  *
4295  * Bits | Access | Reset | Description
4296  * :-------|:-------|:------|:---------------
4297  * [31:0] | RW | 0x0 | Indirect Count
4298  *
4299  */
4300 /*
4301  * Field : Indirect Count - value
4302  *
4303  * This is the number of bytes that the indirect access will consume. This can be
4304  * bigger than the configured size of SRAM.
4305  *
4306  * Field Access Macros:
4307  *
4308  */
4309 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDRDCNT_VALUE register field. */
4310 #define ALT_QSPI_INDRDCNT_VALUE_LSB 0
4311 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDRDCNT_VALUE register field. */
4312 #define ALT_QSPI_INDRDCNT_VALUE_MSB 31
4313 /* The width in bits of the ALT_QSPI_INDRDCNT_VALUE register field. */
4314 #define ALT_QSPI_INDRDCNT_VALUE_WIDTH 32
4315 /* The mask used to set the ALT_QSPI_INDRDCNT_VALUE register field value. */
4316 #define ALT_QSPI_INDRDCNT_VALUE_SET_MSK 0xffffffff
4317 /* The mask used to clear the ALT_QSPI_INDRDCNT_VALUE register field value. */
4318 #define ALT_QSPI_INDRDCNT_VALUE_CLR_MSK 0x00000000
4319 /* The reset value of the ALT_QSPI_INDRDCNT_VALUE register field. */
4320 #define ALT_QSPI_INDRDCNT_VALUE_RESET 0x0
4321 /* Extracts the ALT_QSPI_INDRDCNT_VALUE field value from a register. */
4322 #define ALT_QSPI_INDRDCNT_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
4323 /* Produces a ALT_QSPI_INDRDCNT_VALUE register field value suitable for setting the register. */
4324 #define ALT_QSPI_INDRDCNT_VALUE_SET(value) (((value) << 0) & 0xffffffff)
4325
4326 #ifndef __ASSEMBLY__
4327 /*
4328  * WARNING: The C register and register group struct declarations are provided for
4329  * convenience and illustrative purposes. They should, however, be used with
4330  * caution as the C language standard provides no guarantees about the alignment or
4331  * atomicity of device memory accesses. The recommended practice for writing
4332  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4333  * alt_write_word() functions.
4334  *
4335  * The struct declaration for register ALT_QSPI_INDRDCNT.
4336  */
4338 {
4339  uint32_t value : 32; /* Indirect Count */
4340 };
4341
4342 /* The typedef declaration for register ALT_QSPI_INDRDCNT. */
4343 typedef volatile struct ALT_QSPI_INDRDCNT_s ALT_QSPI_INDRDCNT_t;
4344 #endif /* __ASSEMBLY__ */
4345
4346 /* The byte offset of the ALT_QSPI_INDRDCNT register from the beginning of the component. */
4347 #define ALT_QSPI_INDRDCNT_OFST 0x6c
4348
4349 /*
4350  * Register : Indirect Write Transfer Register - indwr
4351  *
4352  * Register Layout
4353  *
4354  * Bits | Access | Reset | Description
4355  * :-------|:-------|:--------|:---------------------------------
4356  * [0] | RW | 0x0 | Start Indirect Write
4357  * [1] | RW | 0x0 | Cancel Indirect Write
4358  * [2] | R | Unknown | Indirect Write Status
4359  * [3] | R | 0x0 | Reserved
4360  * [4] | R | Unknown | Queued Indirect Write Operations
4361  * [5] | RW | Unknown | Indirect Completion Status
4362  * [7:6] | R | Unknown | Completed Indirect Operations
4363  * [31:8] | ??? | 0x0 | *UNDEFINED*
4364  *
4365  */
4366 /*
4367  * Field : Start Indirect Write - start
4368  *
4369  * Writing a 1 to this bit will trigger an indirect write operation. The assumption
4370  * is that the indirect start address and the indirect number of bytes register is
4371  * setup before triggering the indirect write operation.
4372  *
4373  * Field Enumeration Values:
4374  *
4375  * Enum | Value | Description
4376  * :----------------------------|:------|:---------------------------------
4377  * ALT_QSPI_INDWR_START_E_END | 0x1 | Trigger indirect write operation
4378  * ALT_QSPI_INDWR_START_E_DISD | 0x0 | No Action
4379  *
4380  * Field Access Macros:
4381  *
4382  */
4383 /*
4384  * Enumerated value for register field ALT_QSPI_INDWR_START
4385  *
4386  * Trigger indirect write operation
4387  */
4388 #define ALT_QSPI_INDWR_START_E_END 0x1
4389 /*
4390  * Enumerated value for register field ALT_QSPI_INDWR_START
4391  *
4392  * No Action
4393  */
4394 #define ALT_QSPI_INDWR_START_E_DISD 0x0
4395
4396 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDWR_START register field. */
4397 #define ALT_QSPI_INDWR_START_LSB 0
4398 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDWR_START register field. */
4399 #define ALT_QSPI_INDWR_START_MSB 0
4400 /* The width in bits of the ALT_QSPI_INDWR_START register field. */
4401 #define ALT_QSPI_INDWR_START_WIDTH 1
4402 /* The mask used to set the ALT_QSPI_INDWR_START register field value. */
4403 #define ALT_QSPI_INDWR_START_SET_MSK 0x00000001
4404 /* The mask used to clear the ALT_QSPI_INDWR_START register field value. */
4405 #define ALT_QSPI_INDWR_START_CLR_MSK 0xfffffffe
4406 /* The reset value of the ALT_QSPI_INDWR_START register field. */
4407 #define ALT_QSPI_INDWR_START_RESET 0x0
4408 /* Extracts the ALT_QSPI_INDWR_START field value from a register. */
4409 #define ALT_QSPI_INDWR_START_GET(value) (((value) & 0x00000001) >> 0)
4410 /* Produces a ALT_QSPI_INDWR_START register field value suitable for setting the register. */
4411 #define ALT_QSPI_INDWR_START_SET(value) (((value) << 0) & 0x00000001)
4412
4413 /*
4414  * Field : Cancel Indirect Write - cancel
4415  *
4416  * Writing a 1 to this bit will cancel all ongoing indirect write operations.
4417  *
4418  * Field Enumeration Values:
4419  *
4420  * Enum | Value | Description
4421  * :-----------------------------------|:------|:--------------------------------
4422  * ALT_QSPI_INDWR_CANCEL_E_CANCEINDWR | 0x1 | Cancel Indirect write operation
4423  * ALT_QSPI_INDWR_CANCEL_E_NOACTION | 0x0 | No Action
4424  *
4425  * Field Access Macros:
4426  *
4427  */
4428 /*
4429  * Enumerated value for register field ALT_QSPI_INDWR_CANCEL
4430  *
4431  * Cancel Indirect write operation
4432  */
4433 #define ALT_QSPI_INDWR_CANCEL_E_CANCEINDWR 0x1
4434 /*
4435  * Enumerated value for register field ALT_QSPI_INDWR_CANCEL
4436  *
4437  * No Action
4438  */
4439 #define ALT_QSPI_INDWR_CANCEL_E_NOACTION 0x0
4440
4441 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDWR_CANCEL register field. */
4442 #define ALT_QSPI_INDWR_CANCEL_LSB 1
4443 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDWR_CANCEL register field. */
4444 #define ALT_QSPI_INDWR_CANCEL_MSB 1
4445 /* The width in bits of the ALT_QSPI_INDWR_CANCEL register field. */
4446 #define ALT_QSPI_INDWR_CANCEL_WIDTH 1
4447 /* The mask used to set the ALT_QSPI_INDWR_CANCEL register field value. */
4448 #define ALT_QSPI_INDWR_CANCEL_SET_MSK 0x00000002
4449 /* The mask used to clear the ALT_QSPI_INDWR_CANCEL register field value. */
4450 #define ALT_QSPI_INDWR_CANCEL_CLR_MSK 0xfffffffd
4451 /* The reset value of the ALT_QSPI_INDWR_CANCEL register field. */
4452 #define ALT_QSPI_INDWR_CANCEL_RESET 0x0
4453 /* Extracts the ALT_QSPI_INDWR_CANCEL field value from a register. */
4454 #define ALT_QSPI_INDWR_CANCEL_GET(value) (((value) & 0x00000002) >> 1)
4455 /* Produces a ALT_QSPI_INDWR_CANCEL register field value suitable for setting the register. */
4456 #define ALT_QSPI_INDWR_CANCEL_SET(value) (((value) << 1) & 0x00000002)
4457
4458 /*
4459  * Field : Indirect Write Status - rdstat
4460  *
4461  * Indirect write operation in progress (status)
4462  *
4463  * Field Enumeration Values:
4464  *
4465  * Enum | Value | Description
4466  * :----------------------------------|:------|:-------------------------
4467  * ALT_QSPI_INDWR_RDSTAT_E_INDWRSTAT | 0x1 | Indirect write operation
4468  * ALT_QSPI_INDWR_RDSTAT_E_NOACTION | 0x0 | No Action
4469  *
4470  * Field Access Macros:
4471  *
4472  */
4473 /*
4474  * Enumerated value for register field ALT_QSPI_INDWR_RDSTAT
4475  *
4476  * Indirect write operation
4477  */
4478 #define ALT_QSPI_INDWR_RDSTAT_E_INDWRSTAT 0x1
4479 /*
4480  * Enumerated value for register field ALT_QSPI_INDWR_RDSTAT
4481  *
4482  * No Action
4483  */
4484 #define ALT_QSPI_INDWR_RDSTAT_E_NOACTION 0x0
4485
4486 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDWR_RDSTAT register field. */
4487 #define ALT_QSPI_INDWR_RDSTAT_LSB 2
4488 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDWR_RDSTAT register field. */
4489 #define ALT_QSPI_INDWR_RDSTAT_MSB 2
4490 /* The width in bits of the ALT_QSPI_INDWR_RDSTAT register field. */
4491 #define ALT_QSPI_INDWR_RDSTAT_WIDTH 1
4492 /* The mask used to set the ALT_QSPI_INDWR_RDSTAT register field value. */
4493 #define ALT_QSPI_INDWR_RDSTAT_SET_MSK 0x00000004
4494 /* The mask used to clear the ALT_QSPI_INDWR_RDSTAT register field value. */
4495 #define ALT_QSPI_INDWR_RDSTAT_CLR_MSK 0xfffffffb
4496 /* The reset value of the ALT_QSPI_INDWR_RDSTAT register field is UNKNOWN. */
4497 #define ALT_QSPI_INDWR_RDSTAT_RESET 0x0
4498 /* Extracts the ALT_QSPI_INDWR_RDSTAT field value from a register. */
4499 #define ALT_QSPI_INDWR_RDSTAT_GET(value) (((value) & 0x00000004) >> 2)
4500 /* Produces a ALT_QSPI_INDWR_RDSTAT register field value suitable for setting the register. */
4501 #define ALT_QSPI_INDWR_RDSTAT_SET(value) (((value) << 2) & 0x00000004)
4502
4503 /*
4504  * Field : Reserved - sramfull
4505  *
4506  * Field Access Macros:
4507  *
4508  */
4509 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDWR_SRAMFULL register field. */
4510 #define ALT_QSPI_INDWR_SRAMFULL_LSB 3
4511 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDWR_SRAMFULL register field. */
4512 #define ALT_QSPI_INDWR_SRAMFULL_MSB 3
4513 /* The width in bits of the ALT_QSPI_INDWR_SRAMFULL register field. */
4514 #define ALT_QSPI_INDWR_SRAMFULL_WIDTH 1
4515 /* The mask used to set the ALT_QSPI_INDWR_SRAMFULL register field value. */
4516 #define ALT_QSPI_INDWR_SRAMFULL_SET_MSK 0x00000008
4517 /* The mask used to clear the ALT_QSPI_INDWR_SRAMFULL register field value. */
4518 #define ALT_QSPI_INDWR_SRAMFULL_CLR_MSK 0xfffffff7
4519 /* The reset value of the ALT_QSPI_INDWR_SRAMFULL register field. */
4520 #define ALT_QSPI_INDWR_SRAMFULL_RESET 0x0
4521 /* Extracts the ALT_QSPI_INDWR_SRAMFULL field value from a register. */
4522 #define ALT_QSPI_INDWR_SRAMFULL_GET(value) (((value) & 0x00000008) >> 3)
4523 /* Produces a ALT_QSPI_INDWR_SRAMFULL register field value suitable for setting the register. */
4524 #define ALT_QSPI_INDWR_SRAMFULL_SET(value) (((value) << 3) & 0x00000008)
4525
4526 /*
4527  * Field : Queued Indirect Write Operations - rdqueued
4528  *
4529  * Two indirect write operations have been queued
4530  *
4531  * Field Enumeration Values:
4532  *
4533  * Enum | Value | Description
4534  * :-----------------------------------|:------|:-----------------------------
4535  * ALT_QSPI_INDWR_RDQUEUED_E_INDWROP | 0x1 | Two Indirect write operation
4536  * ALT_QSPI_INDWR_RDQUEUED_E_NOACTION | 0x0 | No Action
4537  *
4538  * Field Access Macros:
4539  *
4540  */
4541 /*
4542  * Enumerated value for register field ALT_QSPI_INDWR_RDQUEUED
4543  *
4544  * Two Indirect write operation
4545  */
4546 #define ALT_QSPI_INDWR_RDQUEUED_E_INDWROP 0x1
4547 /*
4548  * Enumerated value for register field ALT_QSPI_INDWR_RDQUEUED
4549  *
4550  * No Action
4551  */
4552 #define ALT_QSPI_INDWR_RDQUEUED_E_NOACTION 0x0
4553
4554 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDWR_RDQUEUED register field. */
4555 #define ALT_QSPI_INDWR_RDQUEUED_LSB 4
4556 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDWR_RDQUEUED register field. */
4557 #define ALT_QSPI_INDWR_RDQUEUED_MSB 4
4558 /* The width in bits of the ALT_QSPI_INDWR_RDQUEUED register field. */
4559 #define ALT_QSPI_INDWR_RDQUEUED_WIDTH 1
4560 /* The mask used to set the ALT_QSPI_INDWR_RDQUEUED register field value. */
4561 #define ALT_QSPI_INDWR_RDQUEUED_SET_MSK 0x00000010
4562 /* The mask used to clear the ALT_QSPI_INDWR_RDQUEUED register field value. */
4563 #define ALT_QSPI_INDWR_RDQUEUED_CLR_MSK 0xffffffef
4564 /* The reset value of the ALT_QSPI_INDWR_RDQUEUED register field is UNKNOWN. */
4565 #define ALT_QSPI_INDWR_RDQUEUED_RESET 0x0
4566 /* Extracts the ALT_QSPI_INDWR_RDQUEUED field value from a register. */
4567 #define ALT_QSPI_INDWR_RDQUEUED_GET(value) (((value) & 0x00000010) >> 4)
4568 /* Produces a ALT_QSPI_INDWR_RDQUEUED register field value suitable for setting the register. */
4569 #define ALT_QSPI_INDWR_RDQUEUED_SET(value) (((value) << 4) & 0x00000010)
4570
4571 /*
4572  * Field : Indirect Completion Status - inddone
4573  *
4574  * This field is set to 1 when an indirect operation has completed. Write a 1 to
4575  * this field to clear it.
4576  *
4577  * Field Enumeration Values:
4578  *
4579  * Enum | Value | Description
4580  * :-----------------------------------|:------|:-----------------------------
4581  * ALT_QSPI_INDWR_INDDONE_E_INDCOMPST | 0x1 | Indirect operation completed
4582  * ALT_QSPI_INDWR_INDDONE_E_NOACTION | 0x0 | No Action
4583  *
4584  * Field Access Macros:
4585  *
4586  */
4587 /*
4588  * Enumerated value for register field ALT_QSPI_INDWR_INDDONE
4589  *
4590  * Indirect operation completed
4591  */
4592 #define ALT_QSPI_INDWR_INDDONE_E_INDCOMPST 0x1
4593 /*
4594  * Enumerated value for register field ALT_QSPI_INDWR_INDDONE
4595  *
4596  * No Action
4597  */
4598 #define ALT_QSPI_INDWR_INDDONE_E_NOACTION 0x0
4599
4600 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDWR_INDDONE register field. */
4601 #define ALT_QSPI_INDWR_INDDONE_LSB 5
4602 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDWR_INDDONE register field. */
4603 #define ALT_QSPI_INDWR_INDDONE_MSB 5
4604 /* The width in bits of the ALT_QSPI_INDWR_INDDONE register field. */
4605 #define ALT_QSPI_INDWR_INDDONE_WIDTH 1
4606 /* The mask used to set the ALT_QSPI_INDWR_INDDONE register field value. */
4607 #define ALT_QSPI_INDWR_INDDONE_SET_MSK 0x00000020
4608 /* The mask used to clear the ALT_QSPI_INDWR_INDDONE register field value. */
4609 #define ALT_QSPI_INDWR_INDDONE_CLR_MSK 0xffffffdf
4610 /* The reset value of the ALT_QSPI_INDWR_INDDONE register field is UNKNOWN. */
4611 #define ALT_QSPI_INDWR_INDDONE_RESET 0x0
4612 /* Extracts the ALT_QSPI_INDWR_INDDONE field value from a register. */
4613 #define ALT_QSPI_INDWR_INDDONE_GET(value) (((value) & 0x00000020) >> 5)
4614 /* Produces a ALT_QSPI_INDWR_INDDONE register field value suitable for setting the register. */
4615 #define ALT_QSPI_INDWR_INDDONE_SET(value) (((value) << 5) & 0x00000020)
4616
4617 /*
4618  * Field : Completed Indirect Operations - indcnt
4619  *
4620  * This field contains the count of indirect operations which have been completed.
4621  * This is used in conjunction with the indirect completion status field (bit 5).
4622  *
4623  * Field Access Macros:
4624  *
4625  */
4626 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDWR_INDCNT register field. */
4627 #define ALT_QSPI_INDWR_INDCNT_LSB 6
4628 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDWR_INDCNT register field. */
4629 #define ALT_QSPI_INDWR_INDCNT_MSB 7
4630 /* The width in bits of the ALT_QSPI_INDWR_INDCNT register field. */
4631 #define ALT_QSPI_INDWR_INDCNT_WIDTH 2
4632 /* The mask used to set the ALT_QSPI_INDWR_INDCNT register field value. */
4633 #define ALT_QSPI_INDWR_INDCNT_SET_MSK 0x000000c0
4634 /* The mask used to clear the ALT_QSPI_INDWR_INDCNT register field value. */
4635 #define ALT_QSPI_INDWR_INDCNT_CLR_MSK 0xffffff3f
4636 /* The reset value of the ALT_QSPI_INDWR_INDCNT register field is UNKNOWN. */
4637 #define ALT_QSPI_INDWR_INDCNT_RESET 0x0
4638 /* Extracts the ALT_QSPI_INDWR_INDCNT field value from a register. */
4639 #define ALT_QSPI_INDWR_INDCNT_GET(value) (((value) & 0x000000c0) >> 6)
4640 /* Produces a ALT_QSPI_INDWR_INDCNT register field value suitable for setting the register. */
4641 #define ALT_QSPI_INDWR_INDCNT_SET(value) (((value) << 6) & 0x000000c0)
4642
4643 #ifndef __ASSEMBLY__
4644 /*
4645  * WARNING: The C register and register group struct declarations are provided for
4646  * convenience and illustrative purposes. They should, however, be used with
4647  * caution as the C language standard provides no guarantees about the alignment or
4648  * atomicity of device memory accesses. The recommended practice for writing
4649  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4650  * alt_write_word() functions.
4651  *
4652  * The struct declaration for register ALT_QSPI_INDWR.
4653  */
4655 {
4656  uint32_t start : 1; /* Start Indirect Write */
4657  uint32_t cancel : 1; /* Cancel Indirect Write */
4658  const uint32_t rdstat : 1; /* Indirect Write Status */
4659  const uint32_t sramfull : 1; /* Reserved */
4660  const uint32_t rdqueued : 1; /* Queued Indirect Write Operations */
4661  uint32_t inddone : 1; /* Indirect Completion Status */
4662  const uint32_t indcnt : 2; /* Completed Indirect Operations */
4663  uint32_t : 24; /* *UNDEFINED* */
4664 };
4665
4666 /* The typedef declaration for register ALT_QSPI_INDWR. */
4667 typedef volatile struct ALT_QSPI_INDWR_s ALT_QSPI_INDWR_t;
4668 #endif /* __ASSEMBLY__ */
4669
4670 /* The byte offset of the ALT_QSPI_INDWR register from the beginning of the component. */
4671 #define ALT_QSPI_INDWR_OFST 0x70
4672
4673 /*
4674  * Register : Indirect Write Transfer Watermark Register - indwrwater
4675  *
4676  * Register Layout
4677  *
4678  * Bits | Access | Reset | Description
4679  * :-------|:-------|:-----------|:----------------
4680  * [31:0] | RW | 0xffffffff | Watermark Value
4681  *
4682  */
4683 /*
4684  * Field : Watermark Value - level
4685  *
4686  * This represents the maximum fill level of the SRAM before a DMA peripheral
4687  * access is permitted. When the SRAM fill level falls below the watermark, an
4688  * interrupt is also generated. This field can be disabled by writing a value of
4689  * all ones. The units of this register are bytes.
4690  *
4691  * Field Access Macros:
4692  *
4693  */
4694 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDWRWATER_LEVEL register field. */
4695 #define ALT_QSPI_INDWRWATER_LEVEL_LSB 0
4696 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDWRWATER_LEVEL register field. */
4697 #define ALT_QSPI_INDWRWATER_LEVEL_MSB 31
4698 /* The width in bits of the ALT_QSPI_INDWRWATER_LEVEL register field. */
4699 #define ALT_QSPI_INDWRWATER_LEVEL_WIDTH 32
4700 /* The mask used to set the ALT_QSPI_INDWRWATER_LEVEL register field value. */
4701 #define ALT_QSPI_INDWRWATER_LEVEL_SET_MSK 0xffffffff
4702 /* The mask used to clear the ALT_QSPI_INDWRWATER_LEVEL register field value. */
4703 #define ALT_QSPI_INDWRWATER_LEVEL_CLR_MSK 0x00000000
4704 /* The reset value of the ALT_QSPI_INDWRWATER_LEVEL register field. */
4705 #define ALT_QSPI_INDWRWATER_LEVEL_RESET 0xffffffff
4706 /* Extracts the ALT_QSPI_INDWRWATER_LEVEL field value from a register. */
4707 #define ALT_QSPI_INDWRWATER_LEVEL_GET(value) (((value) & 0xffffffff) >> 0)
4708 /* Produces a ALT_QSPI_INDWRWATER_LEVEL register field value suitable for setting the register. */
4709 #define ALT_QSPI_INDWRWATER_LEVEL_SET(value) (((value) << 0) & 0xffffffff)
4710
4711 #ifndef __ASSEMBLY__
4712 /*
4713  * WARNING: The C register and register group struct declarations are provided for
4714  * convenience and illustrative purposes. They should, however, be used with
4715  * caution as the C language standard provides no guarantees about the alignment or
4716  * atomicity of device memory accesses. The recommended practice for writing
4717  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4718  * alt_write_word() functions.
4719  *
4720  * The struct declaration for register ALT_QSPI_INDWRWATER.
4721  */
4723 {
4724  uint32_t level : 32; /* Watermark Value */
4725 };
4726
4727 /* The typedef declaration for register ALT_QSPI_INDWRWATER. */
4728 typedef volatile struct ALT_QSPI_INDWRWATER_s ALT_QSPI_INDWRWATER_t;
4729 #endif /* __ASSEMBLY__ */
4730
4731 /* The byte offset of the ALT_QSPI_INDWRWATER register from the beginning of the component. */
4732 #define ALT_QSPI_INDWRWATER_OFST 0x74
4733
4734 /*
4735  * Register : Indirect Write Transfer Start Address Register - indwrstaddr
4736  *
4737  * Register Layout
4738  *
4739  * Bits | Access | Reset | Description
4740  * :-------|:-------|:------|:-------------------------
4741  * [31:0] | RW | 0x0 | Start of Indirect Access
4742  *
4743  */
4744 /*
4745  * Field : Start of Indirect Access - addr
4746  *
4747  * This is the start address from which the indirect access will commence its write
4748  * operation.
4749  *
4750  * Field Access Macros:
4751  *
4752  */
4753 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDWRSTADDR_ADDR register field. */
4754 #define ALT_QSPI_INDWRSTADDR_ADDR_LSB 0
4755 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDWRSTADDR_ADDR register field. */
4756 #define ALT_QSPI_INDWRSTADDR_ADDR_MSB 31
4757 /* The width in bits of the ALT_QSPI_INDWRSTADDR_ADDR register field. */
4758 #define ALT_QSPI_INDWRSTADDR_ADDR_WIDTH 32
4759 /* The mask used to set the ALT_QSPI_INDWRSTADDR_ADDR register field value. */
4760 #define ALT_QSPI_INDWRSTADDR_ADDR_SET_MSK 0xffffffff
4761 /* The mask used to clear the ALT_QSPI_INDWRSTADDR_ADDR register field value. */
4762 #define ALT_QSPI_INDWRSTADDR_ADDR_CLR_MSK 0x00000000
4763 /* The reset value of the ALT_QSPI_INDWRSTADDR_ADDR register field. */
4764 #define ALT_QSPI_INDWRSTADDR_ADDR_RESET 0x0
4765 /* Extracts the ALT_QSPI_INDWRSTADDR_ADDR field value from a register. */
4766 #define ALT_QSPI_INDWRSTADDR_ADDR_GET(value) (((value) & 0xffffffff) >> 0)
4767 /* Produces a ALT_QSPI_INDWRSTADDR_ADDR register field value suitable for setting the register. */
4768 #define ALT_QSPI_INDWRSTADDR_ADDR_SET(value) (((value) << 0) & 0xffffffff)
4769
4770 #ifndef __ASSEMBLY__
4771 /*
4772  * WARNING: The C register and register group struct declarations are provided for
4773  * convenience and illustrative purposes. They should, however, be used with
4774  * caution as the C language standard provides no guarantees about the alignment or
4775  * atomicity of device memory accesses. The recommended practice for writing
4776  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4777  * alt_write_word() functions.
4778  *
4779  * The struct declaration for register ALT_QSPI_INDWRSTADDR.
4780  */
4782 {
4783  uint32_t addr : 32; /* Start of Indirect Access */
4784 };
4785
4786 /* The typedef declaration for register ALT_QSPI_INDWRSTADDR. */
4787 typedef volatile struct ALT_QSPI_INDWRSTADDR_s ALT_QSPI_INDWRSTADDR_t;
4788 #endif /* __ASSEMBLY__ */
4789
4790 /* The byte offset of the ALT_QSPI_INDWRSTADDR register from the beginning of the component. */
4791 #define ALT_QSPI_INDWRSTADDR_OFST 0x78
4792
4793 /*
4794  * Register : Indirect Write Transfer Count Register - indwrcnt
4795  *
4796  * Register Layout
4797  *
4798  * Bits | Access | Reset | Description
4799  * :-------|:-------|:------|:-------------------------
4800  * [31:0] | RW | 0x0 | Indirect Number of Bytes
4801  *
4802  */
4803 /*
4804  * Field : Indirect Number of Bytes - value
4805  *
4806  * This is the number of bytes that the indirect access will consume. This can be
4807  * bigger than the configured size of SRAM.
4808  *
4809  * Field Access Macros:
4810  *
4811  */
4812 /* The Least Significant Bit (LSB) position of the ALT_QSPI_INDWRCNT_VALUE register field. */
4813 #define ALT_QSPI_INDWRCNT_VALUE_LSB 0
4814 /* The Most Significant Bit (MSB) position of the ALT_QSPI_INDWRCNT_VALUE register field. */
4815 #define ALT_QSPI_INDWRCNT_VALUE_MSB 31
4816 /* The width in bits of the ALT_QSPI_INDWRCNT_VALUE register field. */
4817 #define ALT_QSPI_INDWRCNT_VALUE_WIDTH 32
4818 /* The mask used to set the ALT_QSPI_INDWRCNT_VALUE register field value. */
4819 #define ALT_QSPI_INDWRCNT_VALUE_SET_MSK 0xffffffff
4820 /* The mask used to clear the ALT_QSPI_INDWRCNT_VALUE register field value. */
4821 #define ALT_QSPI_INDWRCNT_VALUE_CLR_MSK 0x00000000
4822 /* The reset value of the ALT_QSPI_INDWRCNT_VALUE register field. */
4823 #define ALT_QSPI_INDWRCNT_VALUE_RESET 0x0
4824 /* Extracts the ALT_QSPI_INDWRCNT_VALUE field value from a register. */
4825 #define ALT_QSPI_INDWRCNT_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
4826 /* Produces a ALT_QSPI_INDWRCNT_VALUE register field value suitable for setting the register. */
4827 #define ALT_QSPI_INDWRCNT_VALUE_SET(value) (((value) << 0) & 0xffffffff)
4828
4829 #ifndef __ASSEMBLY__
4830 /*
4831  * WARNING: The C register and register group struct declarations are provided for
4832  * convenience and illustrative purposes. They should, however, be used with
4833  * caution as the C language standard provides no guarantees about the alignment or
4834  * atomicity of device memory accesses. The recommended practice for writing
4835  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4836  * alt_write_word() functions.
4837  *
4838  * The struct declaration for register ALT_QSPI_INDWRCNT.
4839  */
4841 {
4842  uint32_t value : 32; /* Indirect Number of Bytes */
4843 };
4844
4845 /* The typedef declaration for register ALT_QSPI_INDWRCNT. */
4846 typedef volatile struct ALT_QSPI_INDWRCNT_s ALT_QSPI_INDWRCNT_t;
4847 #endif /* __ASSEMBLY__ */
4848
4849 /* The byte offset of the ALT_QSPI_INDWRCNT register from the beginning of the component. */
4850 #define ALT_QSPI_INDWRCNT_OFST 0x7c
4851
4852 /*
4853  * Register : Flash Command Register - flashcmd
4854  *
4855  * Register Layout
4856  *
4857  * Bits | Access | Reset | Description
4858  * :--------|:-------|:------|:---------------------------
4859  * [0] | RW | 0x0 | Execute Command
4860  * [1] | R | 0x0 | Command Execution Status
4861  * [6:2] | ??? | 0x0 | *UNDEFINED*
4862  * [11:7] | RW | 0x0 | Number of Dummy Bytes
4863  * [14:12] | RW | 0x0 | Number of Write Data Bytes
4864  * [15] | RW | 0x0 | Write Data Enable
4865  * [17:16] | RW | 0x0 | Number of Address Bytes
4866  * [18] | RW | 0x0 | Mode Bit Enable
4867  * [19] | RW | 0x0 | Command Address Enable
4868  * [22:20] | RW | 0x0 | Number of Read Data Bytes
4869  * [23] | RW | 0x0 | Read Data Enable
4870  * [31:24] | RW | 0x0 | Command Opcode
4871  *
4872  */
4873 /*
4874  * Field : Execute Command - execcmd
4875  *
4876  * Execute the command.
4877  *
4878  * Field Enumeration Values:
4879  *
4880  * Enum | Value | Description
4881  * :------------------------------------|:------|:----------------
4882  * ALT_QSPI_FLSHCMD_EXECCMD_E_EXECUTE | 0x1 | Execute Command
4883  * ALT_QSPI_FLSHCMD_EXECCMD_E_NOACTION | 0x0 | No Action
4884  *
4885  * Field Access Macros:
4886  *
4887  */
4888 /*
4889  * Enumerated value for register field ALT_QSPI_FLSHCMD_EXECCMD
4890  *
4891  * Execute Command
4892  */
4893 #define ALT_QSPI_FLSHCMD_EXECCMD_E_EXECUTE 0x1
4894 /*
4895  * Enumerated value for register field ALT_QSPI_FLSHCMD_EXECCMD
4896  *
4897  * No Action
4898  */
4899 #define ALT_QSPI_FLSHCMD_EXECCMD_E_NOACTION 0x0
4900
4901 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_EXECCMD register field. */
4902 #define ALT_QSPI_FLSHCMD_EXECCMD_LSB 0
4903 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_EXECCMD register field. */
4904 #define ALT_QSPI_FLSHCMD_EXECCMD_MSB 0
4905 /* The width in bits of the ALT_QSPI_FLSHCMD_EXECCMD register field. */
4906 #define ALT_QSPI_FLSHCMD_EXECCMD_WIDTH 1
4907 /* The mask used to set the ALT_QSPI_FLSHCMD_EXECCMD register field value. */
4908 #define ALT_QSPI_FLSHCMD_EXECCMD_SET_MSK 0x00000001
4909 /* The mask used to clear the ALT_QSPI_FLSHCMD_EXECCMD register field value. */
4910 #define ALT_QSPI_FLSHCMD_EXECCMD_CLR_MSK 0xfffffffe
4911 /* The reset value of the ALT_QSPI_FLSHCMD_EXECCMD register field. */
4912 #define ALT_QSPI_FLSHCMD_EXECCMD_RESET 0x0
4913 /* Extracts the ALT_QSPI_FLSHCMD_EXECCMD field value from a register. */
4914 #define ALT_QSPI_FLSHCMD_EXECCMD_GET(value) (((value) & 0x00000001) >> 0)
4915 /* Produces a ALT_QSPI_FLSHCMD_EXECCMD register field value suitable for setting the register. */
4916 #define ALT_QSPI_FLSHCMD_EXECCMD_SET(value) (((value) << 0) & 0x00000001)
4917
4918 /*
4919  * Field : Command Execution Status - cmdexecstat
4920  *
4921  * Command execution in progress.
4922  *
4923  * Field Enumeration Values:
4924  *
4925  * Enum | Value | Description
4926  * :-------------------------------------------|:------|:-------------------------
4927  * ALT_QSPI_FLSHCMD_CMDEXECSTAT_E_EXECUTESTAT | 0x1 | Command Execution Status
4928  * ALT_QSPI_FLSHCMD_CMDEXECSTAT_E_NOACTION | 0x0 | No Action
4929  *
4930  * Field Access Macros:
4931  *
4932  */
4933 /*
4934  * Enumerated value for register field ALT_QSPI_FLSHCMD_CMDEXECSTAT
4935  *
4936  * Command Execution Status
4937  */
4938 #define ALT_QSPI_FLSHCMD_CMDEXECSTAT_E_EXECUTESTAT 0x1
4939 /*
4940  * Enumerated value for register field ALT_QSPI_FLSHCMD_CMDEXECSTAT
4941  *
4942  * No Action
4943  */
4944 #define ALT_QSPI_FLSHCMD_CMDEXECSTAT_E_NOACTION 0x0
4945
4946 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_CMDEXECSTAT register field. */
4947 #define ALT_QSPI_FLSHCMD_CMDEXECSTAT_LSB 1
4948 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_CMDEXECSTAT register field. */
4949 #define ALT_QSPI_FLSHCMD_CMDEXECSTAT_MSB 1
4950 /* The width in bits of the ALT_QSPI_FLSHCMD_CMDEXECSTAT register field. */
4951 #define ALT_QSPI_FLSHCMD_CMDEXECSTAT_WIDTH 1
4952 /* The mask used to set the ALT_QSPI_FLSHCMD_CMDEXECSTAT register field value. */
4953 #define ALT_QSPI_FLSHCMD_CMDEXECSTAT_SET_MSK 0x00000002
4954 /* The mask used to clear the ALT_QSPI_FLSHCMD_CMDEXECSTAT register field value. */
4955 #define ALT_QSPI_FLSHCMD_CMDEXECSTAT_CLR_MSK 0xfffffffd
4956 /* The reset value of the ALT_QSPI_FLSHCMD_CMDEXECSTAT register field. */
4957 #define ALT_QSPI_FLSHCMD_CMDEXECSTAT_RESET 0x0
4958 /* Extracts the ALT_QSPI_FLSHCMD_CMDEXECSTAT field value from a register. */
4959 #define ALT_QSPI_FLSHCMD_CMDEXECSTAT_GET(value) (((value) & 0x00000002) >> 1)
4960 /* Produces a ALT_QSPI_FLSHCMD_CMDEXECSTAT register field value suitable for setting the register. */
4961 #define ALT_QSPI_FLSHCMD_CMDEXECSTAT_SET(value) (((value) << 1) & 0x00000002)
4962
4963 /*
4964  * Field : Number of Dummy Bytes - numdummybytes
4965  *
4966  * Set to the number of dummy bytes required This should be setup before triggering
4967  * the command via the execute field of this register.
4968  *
4969  * Field Access Macros:
4970  *
4971  */
4972 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_NUMDUMMYBYTES register field. */
4973 #define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_LSB 7
4974 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_NUMDUMMYBYTES register field. */
4975 #define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_MSB 11
4976 /* The width in bits of the ALT_QSPI_FLSHCMD_NUMDUMMYBYTES register field. */
4977 #define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_WIDTH 5
4978 /* The mask used to set the ALT_QSPI_FLSHCMD_NUMDUMMYBYTES register field value. */
4979 #define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_SET_MSK 0x00000f80
4980 /* The mask used to clear the ALT_QSPI_FLSHCMD_NUMDUMMYBYTES register field value. */
4981 #define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_CLR_MSK 0xfffff07f
4982 /* The reset value of the ALT_QSPI_FLSHCMD_NUMDUMMYBYTES register field. */
4983 #define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_RESET 0x0
4984 /* Extracts the ALT_QSPI_FLSHCMD_NUMDUMMYBYTES field value from a register. */
4985 #define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_GET(value) (((value) & 0x00000f80) >> 7)
4986 /* Produces a ALT_QSPI_FLSHCMD_NUMDUMMYBYTES register field value suitable for setting the register. */
4987 #define ALT_QSPI_FLSHCMD_NUMDUMMYBYTES_SET(value) (((value) << 7) & 0x00000f80)
4988
4989 /*
4990  * Field : Number of Write Data Bytes - numwrdatabytes
4991  *
4992  * Up to 8 Data bytes may be written using this command.
4993  *
4994  * Field Enumeration Values:
4995  *
4996  * Enum | Value | Description
4997  * :------------------------------------------|:------|:-------------
4998  * ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE1 | 0x0 | Write 1 Byte
4999  * ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE2 | 0x1 | Write 2 Byte
5000  * ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE3 | 0x2 | Write 3 Byte
5001  * ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE4 | 0x3 | Write 4 Byte
5002  * ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE5 | 0x4 | Write 5 Byte
5003  * ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE6 | 0x5 | Write 6 Byte
5004  * ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE7 | 0x6 | Write 7 Byte
5005  * ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE8 | 0x7 | Write 8 Byte
5006  *
5007  * Field Access Macros:
5008  *
5009  */
5010 /*
5011  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMWRDATABYTES
5012  *
5013  * Write 1 Byte
5014  */
5015 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE1 0x0
5016 /*
5017  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMWRDATABYTES
5018  *
5019  * Write 2 Byte
5020  */
5021 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE2 0x1
5022 /*
5023  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMWRDATABYTES
5024  *
5025  * Write 3 Byte
5026  */
5027 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE3 0x2
5028 /*
5029  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMWRDATABYTES
5030  *
5031  * Write 4 Byte
5032  */
5033 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE4 0x3
5034 /*
5035  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMWRDATABYTES
5036  *
5037  * Write 5 Byte
5038  */
5039 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE5 0x4
5040 /*
5041  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMWRDATABYTES
5042  *
5043  * Write 6 Byte
5044  */
5045 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE6 0x5
5046 /*
5047  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMWRDATABYTES
5048  *
5049  * Write 7 Byte
5050  */
5051 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE7 0x6
5052 /*
5053  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMWRDATABYTES
5054  *
5055  * Write 8 Byte
5056  */
5057 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_E_WRBYTE8 0x7
5058
5059 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_NUMWRDATABYTES register field. */
5060 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_LSB 12
5061 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_NUMWRDATABYTES register field. */
5062 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_MSB 14
5063 /* The width in bits of the ALT_QSPI_FLSHCMD_NUMWRDATABYTES register field. */
5064 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_WIDTH 3
5065 /* The mask used to set the ALT_QSPI_FLSHCMD_NUMWRDATABYTES register field value. */
5066 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_SET_MSK 0x00007000
5067 /* The mask used to clear the ALT_QSPI_FLSHCMD_NUMWRDATABYTES register field value. */
5068 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_CLR_MSK 0xffff8fff
5069 /* The reset value of the ALT_QSPI_FLSHCMD_NUMWRDATABYTES register field. */
5070 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_RESET 0x0
5071 /* Extracts the ALT_QSPI_FLSHCMD_NUMWRDATABYTES field value from a register. */
5072 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_GET(value) (((value) & 0x00007000) >> 12)
5073 /* Produces a ALT_QSPI_FLSHCMD_NUMWRDATABYTES register field value suitable for setting the register. */
5074 #define ALT_QSPI_FLSHCMD_NUMWRDATABYTES_SET(value) (((value) << 12) & 0x00007000)
5075
5076 /*
5077  * Field : Write Data Enable - enwrdata
5078  *
5079  * Set to 1 if the command specified in the command opcode field requires write
5080  * data bytes to be sent to the device.
5081  *
5082  * Field Enumeration Values:
5083  *
5084  * Enum | Value | Description
5085  * :----------------------------------------|:------|:----------------------------------
5086  * ALT_QSPI_FLSHCMD_ENWRDATA_E_WRDATABYTES | 0x1 | Command requires write data bytes
5087  * ALT_QSPI_FLSHCMD_ENWRDATA_E_NOACTION | 0x0 | No Action
5088  *
5089  * Field Access Macros:
5090  *
5091  */
5092 /*
5093  * Enumerated value for register field ALT_QSPI_FLSHCMD_ENWRDATA
5094  *
5095  * Command requires write data bytes
5096  */
5097 #define ALT_QSPI_FLSHCMD_ENWRDATA_E_WRDATABYTES 0x1
5098 /*
5099  * Enumerated value for register field ALT_QSPI_FLSHCMD_ENWRDATA
5100  *
5101  * No Action
5102  */
5103 #define ALT_QSPI_FLSHCMD_ENWRDATA_E_NOACTION 0x0
5104
5105 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_ENWRDATA register field. */
5106 #define ALT_QSPI_FLSHCMD_ENWRDATA_LSB 15
5107 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_ENWRDATA register field. */
5108 #define ALT_QSPI_FLSHCMD_ENWRDATA_MSB 15
5109 /* The width in bits of the ALT_QSPI_FLSHCMD_ENWRDATA register field. */
5110 #define ALT_QSPI_FLSHCMD_ENWRDATA_WIDTH 1
5111 /* The mask used to set the ALT_QSPI_FLSHCMD_ENWRDATA register field value. */
5112 #define ALT_QSPI_FLSHCMD_ENWRDATA_SET_MSK 0x00008000
5113 /* The mask used to clear the ALT_QSPI_FLSHCMD_ENWRDATA register field value. */
5114 #define ALT_QSPI_FLSHCMD_ENWRDATA_CLR_MSK 0xffff7fff
5115 /* The reset value of the ALT_QSPI_FLSHCMD_ENWRDATA register field. */
5116 #define ALT_QSPI_FLSHCMD_ENWRDATA_RESET 0x0
5117 /* Extracts the ALT_QSPI_FLSHCMD_ENWRDATA field value from a register. */
5118 #define ALT_QSPI_FLSHCMD_ENWRDATA_GET(value) (((value) & 0x00008000) >> 15)
5119 /* Produces a ALT_QSPI_FLSHCMD_ENWRDATA register field value suitable for setting the register. */
5120 #define ALT_QSPI_FLSHCMD_ENWRDATA_SET(value) (((value) << 15) & 0x00008000)
5121
5122 /*
5123  * Field : Number of Address Bytes - numaddrbytes
5124  *
5125  * Set to the number of address bytes required (the address itself is programmed in
5126  * the FLASH COMMAND ADDRESS REGISTERS). This should be setup before triggering the
5127  * command via bit 0 of this register. 2'b00 : 1 address byte 2'b01 : 2 address
5128  * bytes 2'b10 : 3 address bytes 2'b11 : 4 address bytes
5129  *
5130  * Field Enumeration Values:
5131  *
5132  * Enum | Value | Description
5133  * :------------------------------------------|:------|:----------------------
5134  * ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE1 | 0x0 | Write 1 Address Byte
5135  * ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE2 | 0x1 | Write 2 Address Bytes
5136  * ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE3 | 0x2 | Write 3 Address Bytes
5137  * ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE4 | 0x3 | Write 4 Address Bytes
5138  *
5139  * Field Access Macros:
5140  *
5141  */
5142 /*
5143  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMADDRBYTES
5144  *
5145  * Write 1 Address Byte
5146  */
5147 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE1 0x0
5148 /*
5149  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMADDRBYTES
5150  *
5151  * Write 2 Address Bytes
5152  */
5153 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE2 0x1
5154 /*
5155  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMADDRBYTES
5156  *
5157  * Write 3 Address Bytes
5158  */
5159 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE3 0x2
5160 /*
5161  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMADDRBYTES
5162  *
5163  * Write 4 Address Bytes
5164  */
5165 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_E_ADDRBYTE4 0x3
5166
5167 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_NUMADDRBYTES register field. */
5168 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_LSB 16
5169 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_NUMADDRBYTES register field. */
5170 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_MSB 17
5171 /* The width in bits of the ALT_QSPI_FLSHCMD_NUMADDRBYTES register field. */
5172 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_WIDTH 2
5173 /* The mask used to set the ALT_QSPI_FLSHCMD_NUMADDRBYTES register field value. */
5174 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_SET_MSK 0x00030000
5175 /* The mask used to clear the ALT_QSPI_FLSHCMD_NUMADDRBYTES register field value. */
5176 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_CLR_MSK 0xfffcffff
5177 /* The reset value of the ALT_QSPI_FLSHCMD_NUMADDRBYTES register field. */
5178 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_RESET 0x0
5179 /* Extracts the ALT_QSPI_FLSHCMD_NUMADDRBYTES field value from a register. */
5180 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_GET(value) (((value) & 0x00030000) >> 16)
5181 /* Produces a ALT_QSPI_FLSHCMD_NUMADDRBYTES register field value suitable for setting the register. */
5182 #define ALT_QSPI_FLSHCMD_NUMADDRBYTES_SET(value) (((value) << 16) & 0x00030000)
5183
5184 /*
5185  * Field : Mode Bit Enable - enmodebit
5186  *
5187  * Set to 1 to ensure the mode bits as defined in the Mode Bit Configuration
5188  * register are sent following the address bytes.
5189  *
5190  * Field Enumeration Values:
5191  *
5192  * Enum | Value | Description
5193  * :---------------------------------|:------|:-------------------------------
5194  * ALT_QSPI_FLSHCMD_ENMODBIT_E_END | 0x1 | Mode Bit follows address bytes
5195  * ALT_QSPI_FLSHCMD_ENMODBIT_E_DISD | 0x0 | No Action
5196  *
5197  * Field Access Macros:
5198  *
5199  */
5200 /*
5201  * Enumerated value for register field ALT_QSPI_FLSHCMD_ENMODBIT
5202  *
5203  * Mode Bit follows address bytes
5204  */
5205 #define ALT_QSPI_FLSHCMD_ENMODBIT_E_END 0x1
5206 /*
5207  * Enumerated value for register field ALT_QSPI_FLSHCMD_ENMODBIT
5208  *
5209  * No Action
5210  */
5211 #define ALT_QSPI_FLSHCMD_ENMODBIT_E_DISD 0x0
5212
5213 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_ENMODBIT register field. */
5214 #define ALT_QSPI_FLSHCMD_ENMODBIT_LSB 18
5215 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_ENMODBIT register field. */
5216 #define ALT_QSPI_FLSHCMD_ENMODBIT_MSB 18
5217 /* The width in bits of the ALT_QSPI_FLSHCMD_ENMODBIT register field. */
5218 #define ALT_QSPI_FLSHCMD_ENMODBIT_WIDTH 1
5219 /* The mask used to set the ALT_QSPI_FLSHCMD_ENMODBIT register field value. */
5220 #define ALT_QSPI_FLSHCMD_ENMODBIT_SET_MSK 0x00040000
5221 /* The mask used to clear the ALT_QSPI_FLSHCMD_ENMODBIT register field value. */
5222 #define ALT_QSPI_FLSHCMD_ENMODBIT_CLR_MSK 0xfffbffff
5223 /* The reset value of the ALT_QSPI_FLSHCMD_ENMODBIT register field. */
5224 #define ALT_QSPI_FLSHCMD_ENMODBIT_RESET 0x0
5225 /* Extracts the ALT_QSPI_FLSHCMD_ENMODBIT field value from a register. */
5226 #define ALT_QSPI_FLSHCMD_ENMODBIT_GET(value) (((value) & 0x00040000) >> 18)
5227 /* Produces a ALT_QSPI_FLSHCMD_ENMODBIT register field value suitable for setting the register. */
5228 #define ALT_QSPI_FLSHCMD_ENMODBIT_SET(value) (((value) << 18) & 0x00040000)
5229
5230 /*
5231  * Field : Command Address Enable - encmdaddr
5232  *
5233  * If enabled, the command specified in bits 31:24 requires an address. This should
5234  * be setup before triggering the command via writing a 1 to the execute field.
5235  *
5236  * Field Enumeration Values:
5237  *
5238  * Enum | Value | Description
5239  * :----------------------------------|:------|:---------------------------------------
5240  * ALT_QSPI_FLSHCMD_ENCMDADDR_E_END | 0x1 | Command in bits 31:24 requires address
5241  * ALT_QSPI_FLSHCMD_ENCMDADDR_E_DISD | 0x0 | No Action
5242  *
5243  * Field Access Macros:
5244  *
5245  */
5246 /*
5247  * Enumerated value for register field ALT_QSPI_FLSHCMD_ENCMDADDR
5248  *
5249  * Command in bits 31:24 requires address
5250  */
5251 #define ALT_QSPI_FLSHCMD_ENCMDADDR_E_END 0x1
5252 /*
5253  * Enumerated value for register field ALT_QSPI_FLSHCMD_ENCMDADDR
5254  *
5255  * No Action
5256  */
5257 #define ALT_QSPI_FLSHCMD_ENCMDADDR_E_DISD 0x0
5258
5259 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_ENCMDADDR register field. */
5260 #define ALT_QSPI_FLSHCMD_ENCMDADDR_LSB 19
5261 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_ENCMDADDR register field. */
5262 #define ALT_QSPI_FLSHCMD_ENCMDADDR_MSB 19
5263 /* The width in bits of the ALT_QSPI_FLSHCMD_ENCMDADDR register field. */
5264 #define ALT_QSPI_FLSHCMD_ENCMDADDR_WIDTH 1
5265 /* The mask used to set the ALT_QSPI_FLSHCMD_ENCMDADDR register field value. */
5266 #define ALT_QSPI_FLSHCMD_ENCMDADDR_SET_MSK 0x00080000
5267 /* The mask used to clear the ALT_QSPI_FLSHCMD_ENCMDADDR register field value. */
5268 #define ALT_QSPI_FLSHCMD_ENCMDADDR_CLR_MSK 0xfff7ffff
5269 /* The reset value of the ALT_QSPI_FLSHCMD_ENCMDADDR register field. */
5270 #define ALT_QSPI_FLSHCMD_ENCMDADDR_RESET 0x0
5271 /* Extracts the ALT_QSPI_FLSHCMD_ENCMDADDR field value from a register. */
5272 #define ALT_QSPI_FLSHCMD_ENCMDADDR_GET(value) (((value) & 0x00080000) >> 19)
5273 /* Produces a ALT_QSPI_FLSHCMD_ENCMDADDR register field value suitable for setting the register. */
5274 #define ALT_QSPI_FLSHCMD_ENCMDADDR_SET(value) (((value) << 19) & 0x00080000)
5275
5276 /*
5277  * Field : Number of Read Data Bytes - numrddatabytes
5278  *
5279  * Up to 8 data bytes may be read using this command. Set to 0 for 1 byte and 7 for
5280  * 8 bytes.
5281  *
5282  * Field Enumeration Values:
5283  *
5284  * Enum | Value | Description
5285  * :------------------------------------------|:------|:------------
5286  * ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE1 | 0x0 | Read 1 Byte
5287  * ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE2 | 0x1 | Read 2 Byte
5288  * ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE3 | 0x2 | Read 3 Byte
5289  * ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE4 | 0x3 | Read 4 Byte
5290  * ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE5 | 0x4 | Read 5 Byte
5291  * ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE6 | 0x5 | Read 6 Byte
5292  * ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE7 | 0x6 | Read 7 Byte
5293  * ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE8 | 0x7 | Read 8 Byte
5294  *
5295  * Field Access Macros:
5296  *
5297  */
5298 /*
5299  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMRDDATABYTES
5300  *
5301  * Read 1 Byte
5302  */
5303 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE1 0x0
5304 /*
5305  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMRDDATABYTES
5306  *
5307  * Read 2 Byte
5308  */
5309 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE2 0x1
5310 /*
5311  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMRDDATABYTES
5312  *
5313  * Read 3 Byte
5314  */
5315 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE3 0x2
5316 /*
5317  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMRDDATABYTES
5318  *
5319  * Read 4 Byte
5320  */
5321 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE4 0x3
5322 /*
5323  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMRDDATABYTES
5324  *
5325  * Read 5 Byte
5326  */
5327 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE5 0x4
5328 /*
5329  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMRDDATABYTES
5330  *
5331  * Read 6 Byte
5332  */
5333 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE6 0x5
5334 /*
5335  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMRDDATABYTES
5336  *
5337  * Read 7 Byte
5338  */
5339 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE7 0x6
5340 /*
5341  * Enumerated value for register field ALT_QSPI_FLSHCMD_NUMRDDATABYTES
5342  *
5343  * Read 8 Byte
5344  */
5345 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_E_RDBYTE8 0x7
5346
5347 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_NUMRDDATABYTES register field. */
5348 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_LSB 20
5349 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_NUMRDDATABYTES register field. */
5350 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_MSB 22
5351 /* The width in bits of the ALT_QSPI_FLSHCMD_NUMRDDATABYTES register field. */
5352 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_WIDTH 3
5353 /* The mask used to set the ALT_QSPI_FLSHCMD_NUMRDDATABYTES register field value. */
5354 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_SET_MSK 0x00700000
5355 /* The mask used to clear the ALT_QSPI_FLSHCMD_NUMRDDATABYTES register field value. */
5356 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_CLR_MSK 0xff8fffff
5357 /* The reset value of the ALT_QSPI_FLSHCMD_NUMRDDATABYTES register field. */
5358 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_RESET 0x0
5359 /* Extracts the ALT_QSPI_FLSHCMD_NUMRDDATABYTES field value from a register. */
5360 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_GET(value) (((value) & 0x00700000) >> 20)
5361 /* Produces a ALT_QSPI_FLSHCMD_NUMRDDATABYTES register field value suitable for setting the register. */
5362 #define ALT_QSPI_FLSHCMD_NUMRDDATABYTES_SET(value) (((value) << 20) & 0x00700000)
5363
5364 /*
5365  * Field : Read Data Enable - enrddata
5366  *
5367  * If enabled, the command specified in the command opcode field (bits 31:24)
5368  * requires read data bytes to be received from the device.
5369  *
5370  * Field Enumeration Values:
5371  *
5372  * Enum | Value | Description
5373  * :-------------------------------------|:------|:---------------------------
5374  * ALT_QSPI_FLSHCMD_ENRDDATA_E_EN | 0x1 | Command Requires read data
5375  * ALT_QSPI_FLSHCMD_ENRDDATA_E_NOACTION | 0x0 | No Action
5376  *
5377  * Field Access Macros:
5378  *
5379  */
5380 /*
5381  * Enumerated value for register field ALT_QSPI_FLSHCMD_ENRDDATA
5382  *
5383  * Command Requires read data
5384  */
5385 #define ALT_QSPI_FLSHCMD_ENRDDATA_E_EN 0x1
5386 /*
5387  * Enumerated value for register field ALT_QSPI_FLSHCMD_ENRDDATA
5388  *
5389  * No Action
5390  */
5391 #define ALT_QSPI_FLSHCMD_ENRDDATA_E_NOACTION 0x0
5392
5393 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_ENRDDATA register field. */
5394 #define ALT_QSPI_FLSHCMD_ENRDDATA_LSB 23
5395 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_ENRDDATA register field. */
5396 #define ALT_QSPI_FLSHCMD_ENRDDATA_MSB 23
5397 /* The width in bits of the ALT_QSPI_FLSHCMD_ENRDDATA register field. */
5398 #define ALT_QSPI_FLSHCMD_ENRDDATA_WIDTH 1
5399 /* The mask used to set the ALT_QSPI_FLSHCMD_ENRDDATA register field value. */
5400 #define ALT_QSPI_FLSHCMD_ENRDDATA_SET_MSK 0x00800000
5401 /* The mask used to clear the ALT_QSPI_FLSHCMD_ENRDDATA register field value. */
5402 #define ALT_QSPI_FLSHCMD_ENRDDATA_CLR_MSK 0xff7fffff
5403 /* The reset value of the ALT_QSPI_FLSHCMD_ENRDDATA register field. */
5404 #define ALT_QSPI_FLSHCMD_ENRDDATA_RESET 0x0
5405 /* Extracts the ALT_QSPI_FLSHCMD_ENRDDATA field value from a register. */
5406 #define ALT_QSPI_FLSHCMD_ENRDDATA_GET(value) (((value) & 0x00800000) >> 23)
5407 /* Produces a ALT_QSPI_FLSHCMD_ENRDDATA register field value suitable for setting the register. */
5408 #define ALT_QSPI_FLSHCMD_ENRDDATA_SET(value) (((value) << 23) & 0x00800000)
5409
5410 /*
5411  * Field : Command Opcode - cmdopcode
5412  *
5413  * The command opcode field should be setup before triggering the command. For
5414  * example, 0x20 maps to SubSector Erase. Writeing to the execute field (bit 0) of
5415  * this register launches the command. NOTE : Using this approach to issue commands
5416  * to the device will make use of the instruction type of the device instruction
5417  * configuration register. If this field is set to 2'b00, then the command opcode,
5418  * command address, command dummy bytes and command data will all be transferred in
5419  * a serial fashion. If this field is set to 2'b01, then the command opcode,
5420  * command address, command dummy bytes and command data will all be transferred in
5421  * parallel using DQ0 and DQ1 pins. If this field is set to 2'b10, then the command
5422  * opcode, command address, command dummy bytes and command data will all be
5423  * transferred in parallel using DQ0, DQ1, DQ2 and DQ3 pins.
5424  *
5425  * Field Access Macros:
5426  *
5427  */
5428 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMD_CMDOPCODE register field. */
5429 #define ALT_QSPI_FLSHCMD_CMDOPCODE_LSB 24
5430 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMD_CMDOPCODE register field. */
5431 #define ALT_QSPI_FLSHCMD_CMDOPCODE_MSB 31
5432 /* The width in bits of the ALT_QSPI_FLSHCMD_CMDOPCODE register field. */
5433 #define ALT_QSPI_FLSHCMD_CMDOPCODE_WIDTH 8
5434 /* The mask used to set the ALT_QSPI_FLSHCMD_CMDOPCODE register field value. */
5435 #define ALT_QSPI_FLSHCMD_CMDOPCODE_SET_MSK 0xff000000
5436 /* The mask used to clear the ALT_QSPI_FLSHCMD_CMDOPCODE register field value. */
5437 #define ALT_QSPI_FLSHCMD_CMDOPCODE_CLR_MSK 0x00ffffff
5438 /* The reset value of the ALT_QSPI_FLSHCMD_CMDOPCODE register field. */
5439 #define ALT_QSPI_FLSHCMD_CMDOPCODE_RESET 0x0
5440 /* Extracts the ALT_QSPI_FLSHCMD_CMDOPCODE field value from a register. */
5441 #define ALT_QSPI_FLSHCMD_CMDOPCODE_GET(value) (((value) & 0xff000000) >> 24)
5442 /* Produces a ALT_QSPI_FLSHCMD_CMDOPCODE register field value suitable for setting the register. */
5443 #define ALT_QSPI_FLSHCMD_CMDOPCODE_SET(value) (((value) << 24) & 0xff000000)
5444
5445 #ifndef __ASSEMBLY__
5446 /*
5447  * WARNING: The C register and register group struct declarations are provided for
5448  * convenience and illustrative purposes. They should, however, be used with
5449  * caution as the C language standard provides no guarantees about the alignment or
5450  * atomicity of device memory accesses. The recommended practice for writing
5451  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5452  * alt_write_word() functions.
5453  *
5454  * The struct declaration for register ALT_QSPI_FLSHCMD.
5455  */
5457 {
5458  uint32_t execcmd : 1; /* Execute Command */
5459  const uint32_t cmdexecstat : 1; /* Command Execution Status */
5460  uint32_t : 5; /* *UNDEFINED* */
5461  uint32_t numdummybytes : 5; /* Number of Dummy Bytes */
5462  uint32_t numwrdatabytes : 3; /* Number of Write Data Bytes */
5463  uint32_t enwrdata : 1; /* Write Data Enable */
5464  uint32_t numaddrbytes : 2; /* Number of Address Bytes */
5465  uint32_t enmodebit : 1; /* Mode Bit Enable */
5466  uint32_t encmdaddr : 1; /* Command Address Enable */
5467  uint32_t numrddatabytes : 3; /* Number of Read Data Bytes */
5468  uint32_t enrddata : 1; /* Read Data Enable */
5469  uint32_t cmdopcode : 8; /* Command Opcode */
5470 };
5471
5472 /* The typedef declaration for register ALT_QSPI_FLSHCMD. */
5473 typedef volatile struct ALT_QSPI_FLSHCMD_s ALT_QSPI_FLSHCMD_t;
5474 #endif /* __ASSEMBLY__ */
5475
5476 /* The byte offset of the ALT_QSPI_FLSHCMD register from the beginning of the component. */
5477 #define ALT_QSPI_FLSHCMD_OFST 0x90
5478
5479 /*
5480  * Register : Flash Command Address Registers - flashcmdaddr
5481  *
5482  * Register Layout
5483  *
5484  * Bits | Access | Reset | Description
5485  * :-------|:-------|:------|:----------------
5486  * [31:0] | RW | 0x0 | Command Address
5487  *
5488  */
5489 /*
5490  * Field : Command Address - addr
5491  *
5492  * This should be setup before triggering the command with execute field (bit 0) of
5493  * the Flash Command Control register. It is the address used by the command
5494  * specified in the opcode field (bits 31:24) of the Flash Command Control
5495  * register.
5496  *
5497  * Field Access Macros:
5498  *
5499  */
5500 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMDADDR_ADDR register field. */
5501 #define ALT_QSPI_FLSHCMDADDR_ADDR_LSB 0
5502 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMDADDR_ADDR register field. */
5503 #define ALT_QSPI_FLSHCMDADDR_ADDR_MSB 31
5504 /* The width in bits of the ALT_QSPI_FLSHCMDADDR_ADDR register field. */
5505 #define ALT_QSPI_FLSHCMDADDR_ADDR_WIDTH 32
5506 /* The mask used to set the ALT_QSPI_FLSHCMDADDR_ADDR register field value. */
5507 #define ALT_QSPI_FLSHCMDADDR_ADDR_SET_MSK 0xffffffff
5508 /* The mask used to clear the ALT_QSPI_FLSHCMDADDR_ADDR register field value. */
5509 #define ALT_QSPI_FLSHCMDADDR_ADDR_CLR_MSK 0x00000000
5510 /* The reset value of the ALT_QSPI_FLSHCMDADDR_ADDR register field. */
5511 #define ALT_QSPI_FLSHCMDADDR_ADDR_RESET 0x0
5512 /* Extracts the ALT_QSPI_FLSHCMDADDR_ADDR field value from a register. */
5513 #define ALT_QSPI_FLSHCMDADDR_ADDR_GET(value) (((value) & 0xffffffff) >> 0)
5514 /* Produces a ALT_QSPI_FLSHCMDADDR_ADDR register field value suitable for setting the register. */
5515 #define ALT_QSPI_FLSHCMDADDR_ADDR_SET(value) (((value) << 0) & 0xffffffff)
5516
5517 #ifndef __ASSEMBLY__
5518 /*
5519  * WARNING: The C register and register group struct declarations are provided for
5520  * convenience and illustrative purposes. They should, however, be used with
5521  * caution as the C language standard provides no guarantees about the alignment or
5522  * atomicity of device memory accesses. The recommended practice for writing
5523  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5524  * alt_write_word() functions.
5525  *
5526  * The struct declaration for register ALT_QSPI_FLSHCMDADDR.
5527  */
5529 {
5530  uint32_t addr : 32; /* Command Address */
5531 };
5532
5533 /* The typedef declaration for register ALT_QSPI_FLSHCMDADDR. */
5534 typedef volatile struct ALT_QSPI_FLSHCMDADDR_s ALT_QSPI_FLSHCMDADDR_t;
5535 #endif /* __ASSEMBLY__ */
5536
5537 /* The byte offset of the ALT_QSPI_FLSHCMDADDR register from the beginning of the component. */
5538 #define ALT_QSPI_FLSHCMDADDR_OFST 0x94
5539
5540 /*
5541  * Register : Flash Command Read Data Register (Lower) - flashcmdrddatalo
5542  *
5543  * Register Layout
5544  *
5545  * Bits | Access | Reset | Description
5546  * :-------|:-------|:------|:-------------------------------
5547  * [31:0] | RW | 0x0 | Command Read Data (Lower byte)
5548  *
5549  */
5550 /*
5551  * Field : Command Read Data (Lower byte) - data
5552  *
5553  * This is the data that is returned by the flash device for any status or
5554  * configuration read operation carried out by triggering the event in the control
5555  * register. The register will be valid when the polling bit in the control
5556  * register is low.
5557  *
5558  * Field Access Macros:
5559  *
5560  */
5561 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMDRDDATALO_DATA register field. */
5562 #define ALT_QSPI_FLSHCMDRDDATALO_DATA_LSB 0
5563 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMDRDDATALO_DATA register field. */
5564 #define ALT_QSPI_FLSHCMDRDDATALO_DATA_MSB 31
5565 /* The width in bits of the ALT_QSPI_FLSHCMDRDDATALO_DATA register field. */
5566 #define ALT_QSPI_FLSHCMDRDDATALO_DATA_WIDTH 32
5567 /* The mask used to set the ALT_QSPI_FLSHCMDRDDATALO_DATA register field value. */
5568 #define ALT_QSPI_FLSHCMDRDDATALO_DATA_SET_MSK 0xffffffff
5569 /* The mask used to clear the ALT_QSPI_FLSHCMDRDDATALO_DATA register field value. */
5570 #define ALT_QSPI_FLSHCMDRDDATALO_DATA_CLR_MSK 0x00000000
5571 /* The reset value of the ALT_QSPI_FLSHCMDRDDATALO_DATA register field. */
5572 #define ALT_QSPI_FLSHCMDRDDATALO_DATA_RESET 0x0
5573 /* Extracts the ALT_QSPI_FLSHCMDRDDATALO_DATA field value from a register. */
5574 #define ALT_QSPI_FLSHCMDRDDATALO_DATA_GET(value) (((value) & 0xffffffff) >> 0)
5575 /* Produces a ALT_QSPI_FLSHCMDRDDATALO_DATA register field value suitable for setting the register. */
5576 #define ALT_QSPI_FLSHCMDRDDATALO_DATA_SET(value) (((value) << 0) & 0xffffffff)
5577
5578 #ifndef __ASSEMBLY__
5579 /*
5580  * WARNING: The C register and register group struct declarations are provided for
5581  * convenience and illustrative purposes. They should, however, be used with
5582  * caution as the C language standard provides no guarantees about the alignment or
5583  * atomicity of device memory accesses. The recommended practice for writing
5584  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5585  * alt_write_word() functions.
5586  *
5587  * The struct declaration for register ALT_QSPI_FLSHCMDRDDATALO.
5588  */
5590 {
5591  uint32_t data : 32; /* Command Read Data (Lower byte) */
5592 };
5593
5594 /* The typedef declaration for register ALT_QSPI_FLSHCMDRDDATALO. */
5595 typedef volatile struct ALT_QSPI_FLSHCMDRDDATALO_s ALT_QSPI_FLSHCMDRDDATALO_t;
5596 #endif /* __ASSEMBLY__ */
5597
5598 /* The byte offset of the ALT_QSPI_FLSHCMDRDDATALO register from the beginning of the component. */
5599 #define ALT_QSPI_FLSHCMDRDDATALO_OFST 0xa0
5600
5601 /*
5602  * Register : Flash Command Read Data Register (Upper) - flashcmdrddataup
5603  *
5604  * Device Instruction Register
5605  *
5606  * Register Layout
5607  *
5608  * Bits | Access | Reset | Description
5609  * :-------|:-------|:------|:-------------------------------
5610  * [31:0] | RW | 0x0 | Command Read Data (Upper byte)
5611  *
5612  */
5613 /*
5614  * Field : Command Read Data (Upper byte) - data
5615  *
5616  * This is the data that is returned by the FLASH device for any status or
5617  * configuration read operation carried out by triggering the event in the control
5618  * register. The register will be valid when the polling bit in the control
5619  * register is low.
5620  *
5621  * Field Access Macros:
5622  *
5623  */
5624 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMDRDDATAUP_DATA register field. */
5625 #define ALT_QSPI_FLSHCMDRDDATAUP_DATA_LSB 0
5626 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMDRDDATAUP_DATA register field. */
5627 #define ALT_QSPI_FLSHCMDRDDATAUP_DATA_MSB 31
5628 /* The width in bits of the ALT_QSPI_FLSHCMDRDDATAUP_DATA register field. */
5629 #define ALT_QSPI_FLSHCMDRDDATAUP_DATA_WIDTH 32
5630 /* The mask used to set the ALT_QSPI_FLSHCMDRDDATAUP_DATA register field value. */
5631 #define ALT_QSPI_FLSHCMDRDDATAUP_DATA_SET_MSK 0xffffffff
5632 /* The mask used to clear the ALT_QSPI_FLSHCMDRDDATAUP_DATA register field value. */
5633 #define ALT_QSPI_FLSHCMDRDDATAUP_DATA_CLR_MSK 0x00000000
5634 /* The reset value of the ALT_QSPI_FLSHCMDRDDATAUP_DATA register field. */
5635 #define ALT_QSPI_FLSHCMDRDDATAUP_DATA_RESET 0x0
5636 /* Extracts the ALT_QSPI_FLSHCMDRDDATAUP_DATA field value from a register. */
5637 #define ALT_QSPI_FLSHCMDRDDATAUP_DATA_GET(value) (((value) & 0xffffffff) >> 0)
5638 /* Produces a ALT_QSPI_FLSHCMDRDDATAUP_DATA register field value suitable for setting the register. */
5639 #define ALT_QSPI_FLSHCMDRDDATAUP_DATA_SET(value) (((value) << 0) & 0xffffffff)
5640
5641 #ifndef __ASSEMBLY__
5642 /*
5643  * WARNING: The C register and register group struct declarations are provided for
5644  * convenience and illustrative purposes. They should, however, be used with
5645  * caution as the C language standard provides no guarantees about the alignment or
5646  * atomicity of device memory accesses. The recommended practice for writing
5647  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5648  * alt_write_word() functions.
5649  *
5650  * The struct declaration for register ALT_QSPI_FLSHCMDRDDATAUP.
5651  */
5653 {
5654  uint32_t data : 32; /* Command Read Data (Upper byte) */
5655 };
5656
5657 /* The typedef declaration for register ALT_QSPI_FLSHCMDRDDATAUP. */
5658 typedef volatile struct ALT_QSPI_FLSHCMDRDDATAUP_s ALT_QSPI_FLSHCMDRDDATAUP_t;
5659 #endif /* __ASSEMBLY__ */
5660
5661 /* The byte offset of the ALT_QSPI_FLSHCMDRDDATAUP register from the beginning of the component. */
5662 #define ALT_QSPI_FLSHCMDRDDATAUP_OFST 0xa4
5663
5664 /*
5665  * Register : Flash Command Write Data Register (Lower) - flashcmdwrdatalo
5666  *
5667  * Register Layout
5668  *
5669  * Bits | Access | Reset | Description
5670  * :-------|:-------|:------|:------------------------------
5671  * [31:0] | RW | 0x0 | Command Write Data Lower Byte
5672  *
5673  */
5674 /*
5675  * Field : Command Write Data Lower Byte - data
5676  *
5677  * This is the command write data lower byte. This should be setup before
5678  * triggering the command with execute field (bit 0) of the Flash Command Control
5679  * register. It is the data that is to be written to the flash for any status or
5680  * configuration write operation carried out by triggering the event in the Flash
5681  * Command Control register.
5682  *
5683  * Field Access Macros:
5684  *
5685  */
5686 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMDWRDATALO_DATA register field. */
5687 #define ALT_QSPI_FLSHCMDWRDATALO_DATA_LSB 0
5688 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMDWRDATALO_DATA register field. */
5689 #define ALT_QSPI_FLSHCMDWRDATALO_DATA_MSB 31
5690 /* The width in bits of the ALT_QSPI_FLSHCMDWRDATALO_DATA register field. */
5691 #define ALT_QSPI_FLSHCMDWRDATALO_DATA_WIDTH 32
5692 /* The mask used to set the ALT_QSPI_FLSHCMDWRDATALO_DATA register field value. */
5693 #define ALT_QSPI_FLSHCMDWRDATALO_DATA_SET_MSK 0xffffffff
5694 /* The mask used to clear the ALT_QSPI_FLSHCMDWRDATALO_DATA register field value. */
5695 #define ALT_QSPI_FLSHCMDWRDATALO_DATA_CLR_MSK 0x00000000
5696 /* The reset value of the ALT_QSPI_FLSHCMDWRDATALO_DATA register field. */
5697 #define ALT_QSPI_FLSHCMDWRDATALO_DATA_RESET 0x0
5698 /* Extracts the ALT_QSPI_FLSHCMDWRDATALO_DATA field value from a register. */
5699 #define ALT_QSPI_FLSHCMDWRDATALO_DATA_GET(value) (((value) & 0xffffffff) >> 0)
5700 /* Produces a ALT_QSPI_FLSHCMDWRDATALO_DATA register field value suitable for setting the register. */
5701 #define ALT_QSPI_FLSHCMDWRDATALO_DATA_SET(value) (((value) << 0) & 0xffffffff)
5702
5703 #ifndef __ASSEMBLY__
5704 /*
5705  * WARNING: The C register and register group struct declarations are provided for
5706  * convenience and illustrative purposes. They should, however, be used with
5707  * caution as the C language standard provides no guarantees about the alignment or
5708  * atomicity of device memory accesses. The recommended practice for writing
5709  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5710  * alt_write_word() functions.
5711  *
5712  * The struct declaration for register ALT_QSPI_FLSHCMDWRDATALO.
5713  */
5715 {
5716  uint32_t data : 32; /* Command Write Data Lower Byte */
5717 };
5718
5719 /* The typedef declaration for register ALT_QSPI_FLSHCMDWRDATALO. */
5720 typedef volatile struct ALT_QSPI_FLSHCMDWRDATALO_s ALT_QSPI_FLSHCMDWRDATALO_t;
5721 #endif /* __ASSEMBLY__ */
5722
5723 /* The byte offset of the ALT_QSPI_FLSHCMDWRDATALO register from the beginning of the component. */
5724 #define ALT_QSPI_FLSHCMDWRDATALO_OFST 0xa8
5725
5726 /*
5727  * Register : Flash Command Write Data Register (Upper) - flashcmdwrdataup
5728  *
5729  * Register Layout
5730  *
5731  * Bits | Access | Reset | Description
5732  * :-------|:-------|:------|:------------------------------
5733  * [31:0] | RW | 0x0 | ALT_QSPI_FLSHCMDWRDATAUP_DATA
5734  *
5735  */
5736 /*
5737  * Field : data
5738  *
5739  * This is the command write data upper byte. This should be setup before
5740  * triggering the command with execute field (bit 0) of the Flash Command Control
5741  * register. It is the data that is to be written to the flash for any status or
5742  * configuration write operation carried out by triggering the event in the Flash
5743  * Command Control register.
5744  *
5745  * Field Access Macros:
5746  *
5747  */
5748 /* The Least Significant Bit (LSB) position of the ALT_QSPI_FLSHCMDWRDATAUP_DATA register field. */
5749 #define ALT_QSPI_FLSHCMDWRDATAUP_DATA_LSB 0
5750 /* The Most Significant Bit (MSB) position of the ALT_QSPI_FLSHCMDWRDATAUP_DATA register field. */
5751 #define ALT_QSPI_FLSHCMDWRDATAUP_DATA_MSB 31
5752 /* The width in bits of the ALT_QSPI_FLSHCMDWRDATAUP_DATA register field. */
5753 #define ALT_QSPI_FLSHCMDWRDATAUP_DATA_WIDTH 32
5754 /* The mask used to set the ALT_QSPI_FLSHCMDWRDATAUP_DATA register field value. */
5755 #define ALT_QSPI_FLSHCMDWRDATAUP_DATA_SET_MSK 0xffffffff
5756 /* The mask used to clear the ALT_QSPI_FLSHCMDWRDATAUP_DATA register field value. */
5757 #define ALT_QSPI_FLSHCMDWRDATAUP_DATA_CLR_MSK 0x00000000
5758 /* The reset value of the ALT_QSPI_FLSHCMDWRDATAUP_DATA register field. */
5759 #define ALT_QSPI_FLSHCMDWRDATAUP_DATA_RESET 0x0
5760 /* Extracts the ALT_QSPI_FLSHCMDWRDATAUP_DATA field value from a register. */
5761 #define ALT_QSPI_FLSHCMDWRDATAUP_DATA_GET(value) (((value) & 0xffffffff) >> 0)
5762 /* Produces a ALT_QSPI_FLSHCMDWRDATAUP_DATA register field value suitable for setting the register. */
5763 #define ALT_QSPI_FLSHCMDWRDATAUP_DATA_SET(value) (((value) << 0) & 0xffffffff)
5764
5765 #ifndef __ASSEMBLY__
5766 /*
5767  * WARNING: The C register and register group struct declarations are provided for
5768  * convenience and illustrative purposes. They should, however, be used with
5769  * caution as the C language standard provides no guarantees about the alignment or
5770  * atomicity of device memory accesses. The recommended practice for writing
5771  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5772  * alt_write_word() functions.
5773  *
5774  * The struct declaration for register ALT_QSPI_FLSHCMDWRDATAUP.
5775  */
5777 {
5778  uint32_t data : 32; /* ALT_QSPI_FLSHCMDWRDATAUP_DATA */
5779 };
5780
5781 /* The typedef declaration for register ALT_QSPI_FLSHCMDWRDATAUP. */
5782 typedef volatile struct ALT_QSPI_FLSHCMDWRDATAUP_s ALT_QSPI_FLSHCMDWRDATAUP_t;
5783 #endif /* __ASSEMBLY__ */
5784
5785 /* The byte offset of the ALT_QSPI_FLSHCMDWRDATAUP register from the beginning of the component. */
5786 #define ALT_QSPI_FLSHCMDWRDATAUP_OFST 0xac
5787
5788 /*
5789  * Register : Module ID Register - moduleid
5790  *
5791  * Register Layout
5792  *
5793  * Bits | Access | Reset | Description
5794  * :--------|:-------|:-------|:-----------------
5795  * [24:0] | R | 0x1001 | Module ID number
5796  * [31:25] | ??? | 0x0 | *UNDEFINED*
5797  *
5798  */
5799 /*
5800  * Field : Module ID number - value
5801  *
5802  * Field Access Macros:
5803  *
5804  */
5805 /* The Least Significant Bit (LSB) position of the ALT_QSPI_MODULEID_VALUE register field. */
5806 #define ALT_QSPI_MODULEID_VALUE_LSB 0
5807 /* The Most Significant Bit (MSB) position of the ALT_QSPI_MODULEID_VALUE register field. */
5808 #define ALT_QSPI_MODULEID_VALUE_MSB 24
5809 /* The width in bits of the ALT_QSPI_MODULEID_VALUE register field. */
5810 #define ALT_QSPI_MODULEID_VALUE_WIDTH 25
5811 /* The mask used to set the ALT_QSPI_MODULEID_VALUE register field value. */
5812 #define ALT_QSPI_MODULEID_VALUE_SET_MSK 0x01ffffff
5813 /* The mask used to clear the ALT_QSPI_MODULEID_VALUE register field value. */
5814 #define ALT_QSPI_MODULEID_VALUE_CLR_MSK 0xfe000000
5815 /* The reset value of the ALT_QSPI_MODULEID_VALUE register field. */
5816 #define ALT_QSPI_MODULEID_VALUE_RESET 0x1001
5817 /* Extracts the ALT_QSPI_MODULEID_VALUE field value from a register. */
5818 #define ALT_QSPI_MODULEID_VALUE_GET(value) (((value) & 0x01ffffff) >> 0)
5819 /* Produces a ALT_QSPI_MODULEID_VALUE register field value suitable for setting the register. */
5820 #define ALT_QSPI_MODULEID_VALUE_SET(value) (((value) << 0) & 0x01ffffff)
5821
5822 #ifndef __ASSEMBLY__
5823 /*
5824  * WARNING: The C register and register group struct declarations are provided for
5825  * convenience and illustrative purposes. They should, however, be used with
5826  * caution as the C language standard provides no guarantees about the alignment or
5827  * atomicity of device memory accesses. The recommended practice for writing
5828  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5829  * alt_write_word() functions.
5830  *
5831  * The struct declaration for register ALT_QSPI_MODULEID.
5832  */
5834 {
5835  const uint32_t value : 25; /* Module ID number */
5836  uint32_t : 7; /* *UNDEFINED* */
5837 };
5838
5839 /* The typedef declaration for register ALT_QSPI_MODULEID. */
5840 typedef volatile struct ALT_QSPI_MODULEID_s ALT_QSPI_MODULEID_t;
5841 #endif /* __ASSEMBLY__ */
5842
5843 /* The byte offset of the ALT_QSPI_MODULEID register from the beginning of the component. */
5844 #define ALT_QSPI_MODULEID_OFST 0xfc
5845
5846 #ifndef __ASSEMBLY__
5847 /*
5848  * WARNING: The C register and register group struct declarations are provided for
5849  * convenience and illustrative purposes. They should, however, be used with
5850  * caution as the C language standard provides no guarantees about the alignment or
5851  * atomicity of device memory accesses. The recommended practice for writing
5852  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5853  * alt_write_word() functions.
5854  *
5855  * The struct declaration for register group ALT_QSPI.
5856  */
5858 {
5859  volatile ALT_QSPI_CFG_t cfg; /* ALT_QSPI_CFG */
5860  volatile ALT_QSPI_DEVRD_t devrd; /* ALT_QSPI_DEVRD */
5861  volatile ALT_QSPI_DEVWR_t devwr; /* ALT_QSPI_DEVWR */
5862  volatile ALT_QSPI_DELAY_t delay; /* ALT_QSPI_DELAY */
5863  volatile ALT_QSPI_RDDATACAP_t rddatacap; /* ALT_QSPI_RDDATACAP */
5864  volatile ALT_QSPI_DEVSZ_t devsz; /* ALT_QSPI_DEVSZ */
5865  volatile ALT_QSPI_SRAMPART_t srampart; /* ALT_QSPI_SRAMPART */
5866  volatile ALT_QSPI_INDADDRTRIG_t indaddrtrig; /* ALT_QSPI_INDADDRTRIG */
5867  volatile ALT_QSPI_DMAPER_t dmaper; /* ALT_QSPI_DMAPER */
5868  volatile ALT_QSPI_REMAPADDR_t remapaddr; /* ALT_QSPI_REMAPADDR */
5869  volatile ALT_QSPI_MODBIT_t modebit; /* ALT_QSPI_MODBIT */
5870  volatile ALT_QSPI_SRAMFILL_t sramfill; /* ALT_QSPI_SRAMFILL */
5871  volatile ALT_QSPI_TXTHRESH_t txthresh; /* ALT_QSPI_TXTHRESH */
5872  volatile ALT_QSPI_RXTHRESH_t rxthresh; /* ALT_QSPI_RXTHRESH */
5873  volatile uint32_t _pad_0x38_0x3f[2]; /* *UNDEFINED* */
5874  volatile ALT_QSPI_IRQSTAT_t irqstat; /* ALT_QSPI_IRQSTAT */
5875  volatile ALT_QSPI_IRQMSK_t irqmask; /* ALT_QSPI_IRQMSK */
5876  volatile uint32_t _pad_0x48_0x4f[2]; /* *UNDEFINED* */
5877  volatile ALT_QSPI_LOWWRPROT_t lowwrprot; /* ALT_QSPI_LOWWRPROT */
5878  volatile ALT_QSPI_UPPWRPROT_t uppwrprot; /* ALT_QSPI_UPPWRPROT */
5879  volatile ALT_QSPI_WRPROT_t wrprot; /* ALT_QSPI_WRPROT */
5880  volatile uint32_t _pad_0x5c_0x5f; /* *UNDEFINED* */
5881  volatile ALT_QSPI_INDRD_t indrd; /* ALT_QSPI_INDRD */
5882  volatile ALT_QSPI_INDRDWATER_t indrdwater; /* ALT_QSPI_INDRDWATER */
5883  volatile ALT_QSPI_INDRDSTADDR_t indrdstaddr; /* ALT_QSPI_INDRDSTADDR */
5884  volatile ALT_QSPI_INDRDCNT_t indrdcnt; /* ALT_QSPI_INDRDCNT */
5885  volatile ALT_QSPI_INDWR_t indwr; /* ALT_QSPI_INDWR */
5886  volatile ALT_QSPI_INDWRWATER_t indwrwater; /* ALT_QSPI_INDWRWATER */
5887  volatile ALT_QSPI_INDWRSTADDR_t indwrstaddr; /* ALT_QSPI_INDWRSTADDR */
5888  volatile ALT_QSPI_INDWRCNT_t indwrcnt; /* ALT_QSPI_INDWRCNT */
5889  volatile uint32_t _pad_0x80_0x8f[4]; /* *UNDEFINED* */
5890  volatile ALT_QSPI_FLSHCMD_t flashcmd; /* ALT_QSPI_FLSHCMD */
5891  volatile ALT_QSPI_FLSHCMDADDR_t flashcmdaddr; /* ALT_QSPI_FLSHCMDADDR */
5892  volatile uint32_t _pad_0x98_0x9f[2]; /* *UNDEFINED* */
5893  volatile ALT_QSPI_FLSHCMDRDDATALO_t flashcmdrddatalo; /* ALT_QSPI_FLSHCMDRDDATALO */
5894  volatile ALT_QSPI_FLSHCMDRDDATAUP_t flashcmdrddataup; /* ALT_QSPI_FLSHCMDRDDATAUP */
5895  volatile ALT_QSPI_FLSHCMDWRDATALO_t flashcmdwrdatalo; /* ALT_QSPI_FLSHCMDWRDATALO */
5896  volatile ALT_QSPI_FLSHCMDWRDATAUP_t flashcmdwrdataup; /* ALT_QSPI_FLSHCMDWRDATAUP */
5897  volatile uint32_t _pad_0xb0_0xfb[19]; /* *UNDEFINED* */
5898  volatile ALT_QSPI_MODULEID_t moduleid; /* ALT_QSPI_MODULEID */
5899 };
5900
5901 /* The typedef declaration for register group ALT_QSPI. */
5902 typedef volatile struct ALT_QSPI_s ALT_QSPI_t;
5903 /* The struct declaration for the raw register contents of register group ALT_QSPI. */
5905 {
5906  volatile uint32_t cfg; /* ALT_QSPI_CFG */
5907  volatile uint32_t devrd; /* ALT_QSPI_DEVRD */
5908  volatile uint32_t devwr; /* ALT_QSPI_DEVWR */
5909  volatile uint32_t delay; /* ALT_QSPI_DELAY */
5910  volatile uint32_t rddatacap; /* ALT_QSPI_RDDATACAP */
5911  volatile uint32_t devsz; /* ALT_QSPI_DEVSZ */
5912  volatile uint32_t srampart; /* ALT_QSPI_SRAMPART */
5913  volatile uint32_t indaddrtrig; /* ALT_QSPI_INDADDRTRIG */
5914  volatile uint32_t dmaper; /* ALT_QSPI_DMAPER */
5915  volatile uint32_t remapaddr; /* ALT_QSPI_REMAPADDR */
5916  volatile uint32_t modebit; /* ALT_QSPI_MODBIT */
5917  volatile uint32_t sramfill; /* ALT_QSPI_SRAMFILL */
5918  volatile uint32_t txthresh; /* ALT_QSPI_TXTHRESH */
5919  volatile uint32_t rxthresh; /* ALT_QSPI_RXTHRESH */
5920  volatile uint32_t _pad_0x38_0x3f[2]; /* *UNDEFINED* */
5921  volatile uint32_t irqstat; /* ALT_QSPI_IRQSTAT */
5922  volatile uint32_t irqmask; /* ALT_QSPI_IRQMSK */
5923  volatile uint32_t _pad_0x48_0x4f[2]; /* *UNDEFINED* */
5924  volatile uint32_t lowwrprot; /* ALT_QSPI_LOWWRPROT */
5925  volatile uint32_t uppwrprot; /* ALT_QSPI_UPPWRPROT */
5926  volatile uint32_t wrprot; /* ALT_QSPI_WRPROT */
5927  volatile uint32_t _pad_0x5c_0x5f; /* *UNDEFINED* */
5928  volatile uint32_t indrd; /* ALT_QSPI_INDRD */
5929  volatile uint32_t indrdwater; /* ALT_QSPI_INDRDWATER */
5930  volatile uint32_t indrdstaddr; /* ALT_QSPI_INDRDSTADDR */
5931  volatile uint32_t indrdcnt; /* ALT_QSPI_INDRDCNT */
5932  volatile uint32_t indwr; /* ALT_QSPI_INDWR */
5933  volatile uint32_t indwrwater; /* ALT_QSPI_INDWRWATER */
5934  volatile uint32_t indwrstaddr; /* ALT_QSPI_INDWRSTADDR */
5935  volatile uint32_t indwrcnt; /* ALT_QSPI_INDWRCNT */
5936  volatile uint32_t _pad_0x80_0x8f[4]; /* *UNDEFINED* */
5937  volatile uint32_t flashcmd; /* ALT_QSPI_FLSHCMD */
5938  volatile uint32_t flashcmdaddr; /* ALT_QSPI_FLSHCMDADDR */
5939  volatile uint32_t _pad_0x98_0x9f[2]; /* *UNDEFINED* */
5940  volatile uint32_t flashcmdrddatalo; /* ALT_QSPI_FLSHCMDRDDATALO */
5941  volatile uint32_t flashcmdrddataup; /* ALT_QSPI_FLSHCMDRDDATAUP */
5942  volatile uint32_t flashcmdwrdatalo; /* ALT_QSPI_FLSHCMDWRDATALO */
5943  volatile uint32_t flashcmdwrdataup; /* ALT_QSPI_FLSHCMDWRDATAUP */
5944  volatile uint32_t _pad_0xb0_0xfb[19]; /* *UNDEFINED* */
5945  volatile uint32_t moduleid; /* ALT_QSPI_MODULEID */
5946 };
5947
5948 /* The typedef declaration for the raw register contents of register group ALT_QSPI. */
5949 typedef volatile struct ALT_QSPI_raw_s ALT_QSPI_raw_t;
5950 #endif /* __ASSEMBLY__ */
5951
5952
5953 #ifdef __cplusplus
5954 }
5955 #endif /* __cplusplus */
5956 #endif /* __ALTERA_ALT_QSPI_H__ */
5957
Definition: alt_qspi.h:1433
Definition: alt_qspi.h:3809
Definition: alt_qspi.h:5528
Definition: alt_qspi.h:4781
Definition: alt_qspi.h:3677
Definition: alt_qspi.h:2095
Definition: alt_qspi.h:4337
Definition: alt_qspi.h:1812
Definition: alt_qspi.h:2236
Definition: alt_qspi.h:2965
Definition: alt_qspi.h:5714
Definition: alt_qspi.h:839
Definition: alt_qspi.h:4278
Definition: alt_qspi.h:5589
Definition: alt_qspi.h:5857
Definition: alt_qspi.h:3544
Definition: alt_qspi.h:5833
Definition: alt_qspi.h:5776
Definition: alt_qspi.h:4840
Definition: alt_qspi.h:1938
Definition: alt_qspi.h:5456
Definition: alt_qspi.h:2155
Definition: alt_qspi.h:5904
Definition: alt_qspi.h:2358
Definition: alt_qspi.h:1696
Definition: alt_qspi.h:1876
Definition: alt_qspi.h:4219
Definition: alt_qspi.h:4151
Definition: alt_qspi.h:2030
Definition: alt_qspi.h:2296
Definition: alt_qspi.h:1203
Definition: alt_qspi.h:3617
Definition: alt_qspi.h:1588
Definition: alt_qspi.h:4722
Definition: alt_qspi.h:4654
Definition: alt_qspi.h:5652
